We don't have it yet. I was hoping it would be ready with the redesign but, unfortunately, that is not the case.
tidester
SUVs; Aftermarket & Accessories
jonahb "Town Hall Redesign 2002: Tell Us Your Thoughts" Jun 7, 2002 12:12pm
Steve
tidester
Hey, that was fun, no wonder you guys do it so much.
Has anyone seen a urethane replacement bushing kit for the front stabilizer bar?
Hopefully in a year or two there will be more aftermarket choices for the triplets.
GAM2
That is one nice attribute of the triplets front coil springs mean you can get some stiffer ones and replace them cheap and easily. As for shocks, even though the ones in there are Bilstien, I'll bet if you put in some REAL Bilstiens it would make a difference.
As for sway bar bushings, you should be able to measure the bar and buy a set from JC Whitney for about $10.
-mike
I like a product called the Absorber, which is smoother and picks up more water than a natural chamois. It costs about $8.99 at Walmart/AutoZone/Pepboys, etc. You just lightly pull it along or blot the water, and it sure does absorb without streaking or waterspots. I don't have a black vehicle (mine is pewter) so I'm not sure about swirling, but I've heard other people like it, too. You could also consider microfiber towels. These are very smooth and very absorptive, and also are good for dusting, cleaning glass, etc. Not all microfiber towels are alike; the ones with less polyester are better (a 70/30 mix is generally better than the 80/20 towels). The number of microfibers per square inch also makes a difference. The ones in stores are generally of lower quality (perhaps with the exception of Viper which have gotten some good remarks). Here are some sources of the good ones, and you can read about how microfibers work at these pages:
http://www.neatitems.com/micro.htm
http://www.yosteveshop.homestead.com/mt.html
Proper Auto Care Microfiber
I have 6,300 miles on my Envoy SLE and have averaged 14-17 mpg to date. I hope I can improve on that since the PCM reprogram. That is about the only issue that I have with this motor -- this thing kicks butt!
To GAM2:
The body roll is more than what I prefer also -- but help is on the way from various aftermarket groups. Eibach (http://www.eibach.com/index1.htm) is offering a set of progressive Pro Kit springs (p/n is 3826.540) that lowers the front by 1.5" and rear by 2.0" too. Hotchkis Performance (https://www.hotchkis.net/secure_index.html) will have a set of sway bars available in a few months. I haven't found a shock replacement yet.
-Ed
Armed with all of the advice and TSPS, we are now happy Envoy campers!
If anyone can figure out a way to get the gas mileage up to where it is supposed to me, let us all know!!
Happened to us twice now and it helped both times.
I am seriously considering an Envoy but I am a bit concerned about all the recalls. If I bought one, I would want to be able to check and see that all of the fixes have been done BEFORE delivery.
Travina
Steve
One way to make absolutely sure that you choose a vehicle that is "up to date" is to look at the manufacurer date stamp on the inside of the driver's door. If you are test driving a vehicle that you are interested in, you can open the driver's side door and there should be a white sticker listing the recommended tire pressue and the build date/year. Personally, I would attempt to locate an Envoy that has a build date after April 2002!
Good Luck!
IExplore2000@aol.com
http://www.eatonposi.com/prod2.htm
mtrammell, the 4wd triplets DO have CV joints on the front axles as do most IFS 4x4s.
Tim
-mike
-mike
I want to upgrade the factory speakers with top notch components in front and coax's in rear.
Scott
As for the truck, YOU GUYS WERE RIGHT!!! This truck moves, even though I can't go over 55, the power from start w/o pressing it is amazing. It's quiet (no baffle or moulding noises), it's comfortable (I'm 5'8 so the seats and legroom are more than ample), and my neighbors give nothing but compliments. By the way, my roof rack was already corrected.
I've still got a few new posts to read, but it's definately going to take more time to get to them now.
I don't personally use it, but I have other weathertech accessories and I believe Macneil to be one of the best quality aftermarket accessory providers!
I pull a 21 ft travel trailer also had no problem on a 5000 mi trip.
Another new little item is after heavy rains I get drops out of my overhead eyeglass holder, (only when I open it). I checked my sunroof, but everything looks dry. Can it be the rain sensor which I heard is located on the top part of the windshield?
Make sure you close it completely. When closing it from the open/back position, it should come all the way forward then go up a little. It's very easy to get it wrong. One time I found myself feeling drops of rain coming through when I had the sunroof closed and the moonroof open.
Anyone seen any pricing on the new Buick Rainier? Have not seen much on this truck so far aside from a couple of magazine pics.
Mirror memory/dimming problems: Dealer tells me there is NO part number to order at the present as they are going through a redesign because of the problems. I have to call back in a month or so!
Seal around rear hatch: The seal is split is several areas. The new seals are being redesigned and won't be available until August!
Transmission takes a while (30 seconds or so) to downshift after coming to a stop when cold. It also takes a second or so to "engage" from a complete stop. So far, dealer says cannot duplicate.
IRV Mirror makes a load squeal when cold. They tried replacing the stereo (?) but that didn't work. Now they can't duplicate the problem.
Front windshield moulding came loose - Fixed.
Engine knocks loudly. They say it's normal.
The right steering wheel radio control paint started chipping off. Dealer has ordered the part.
And get this - they won't even provide me with transportation!!!! They said they would drop me off somewhere within 5 miles except they are the closes Olds dealer to me and they are 12 miles away!!!!
I've been a loyal GM driver for years. I HATE this vehicle and have it two more years. I wish it would blow up. On the other hand, I love this vehicle. Everyone loves how it looks and the interior.
CURSES to all of GM!!!!
Steve
Still owed 4 years on the loan, but were so fed up by this past March, out it went. Took a week, found what we wanted got a great price, and haven't looked back since. Now we get to cruise around in a perfectly flawless (knock on wood) 2002 Chevy Avalanche Z66.
Didn't you have the Bravada with an air suspension that failed and then totalled the rest of the rear end? Kind of nice to have two identical POS new cars, one after the other, isn't it! It seems as though leasing it was a good and bad move. Good, for you don't own it and can just turn it in at the end of the lease. But bad, because you most likely have to keep it until the end unless it becomes a true lemon.
We were almost going to buy a new Envoy last winter, but I am really glad we didn't. I haven't met one triplet owner yet who hasn't had problems, some minor and some horrendous.
Good luck with the Bravda!
The mirrors do have a fix and it has been around for a while now. Check out Tim Lauro's site (timlauro.com), he has TSB's there that address the mirror actuators. There may be other useful information there as well.
Also, if there are not any other Olds dealers near you, or any that provide better service than the one you are currently going to, try going to a GMC or Chevy dealer. You will eventually have to do this anyway with Olds being phased out. They can perform the same service as the Olds dealer, it may just take some time to get the parts since they may not have them in stock.
Worse case, call GM customer support and see if going over their heads makes a difference. Be the squeaky wheel.
I hope this helps.
JAW
Thanks...
I also noticed on the GMC order form, that the 2003 Envoy came with a 4 speed transmission with overdrive. Thats not what is in the 2002, right?
Thanks for all your help in advance.
ADJGUY
