Has anyone spoken to the dealer about this? I plan to contact mine tomorrow (today is Thanksgiving).
Happy Turkey Day!
I bought a set of seat heaters intended for a subaru from someone on Ebay that included wiring, switches, relay and the carbotex heating elements for 3 seats in the low $100 range. When my LE comes in I intend to install the units as stock as possible.
There is some info about this at a Odyssey forum I visit and also on a Miata forum using a product from a vendor that isn't too expensive (127 per seat).
Most movies have a majority of it at a low volume and then a huge crescendo with action. One tends to expect the crescendo due to the apparent action.
CDs and FM both tend to keep a relatively narrow range (unless you listen to classical) so you will likely have the volume set quite a bit lower due to the higher average signal.
This is the way it is, and its just something you need to keep in mind when changing sources. Quite a few others have commented on this issue at another Sienna forum I frequent, none of them have a better solution to this issue.
I have yet to find a recordable DVD media that will work with the factory DVD player. I don't think it's a good idea to leave original copies in the car during summer months.
Stephen
That's the only home disc I've tried so far.
As for getting home-burned DVDs to work, it may be more of a trick. I had instant success with the combination described in my last post, but as with much home-burned media, it's ability to play properly can be influenced by the brand of media you use, the speed it's burned, the software used, etc. My suggestion is to start with RW media so you can use it for something else if it doesn't work. If you try both formats with no success, try reducing the burning speed to the slowest possible. If still no luck, try different burning software. Keep in mind burning DVDs is more complicated than CD's: DVDs have a specific file structure, it's not just a bunch of .wav files like on a cd. To burn a real DVD, you have to have software that "Authors" DVDs, not just writes to it. Most software will do this now, you just have to make sure you're telling it to burn a DVD movie. If you're using InstantCopy, XCopy, etc you shouldn't have problems with the software itself.
I've found that like the manual says, if you put a printed paper label on the DVD, it may play but will eventually cause the player to hang/not recognize the disc. When the same movie is burned to an identical disc without a paper label added (mark it with a Sharpie instead), everything works out just fine. I've made backups of several of our kiddie movies/programs on DVD-R media (Princo & Ritek brands, I believe). I also had luck with a DVD +RW (Verbatim) in testing other movie files as well. Using the backup copies in the van will allow for the originals to hopefully last much longer.
Thanks you.
This DVD player also plays VCD burned on CDR without problems.
2): do any one have experience to install the fog light? I believe there have the wire connection to the fog light already, because at each side closed to the position of fog light, there has one plug there.
3): My van has tow pre package. I have found the hole at the frame, but I does not find the tow wire connection. Any one can provide info here?
www.toyotaparts.com
www.toyotaparts4u.com
www.toyotapartsstore.com
www.toyotaterritory.com/
color coded mudguards. Price is $37.95 for 2 pieces
No one I know of has installed factory fogs. The wiring may well be there, but you need a different control stalk for the headlight switch to use the factory system. I suspect the total cost would be prohibitive relative to the value of the factroy fogs.
The wiring is not in place for the tow system. You need to get the wiring harness from the dealer or get one of the better ones from an aftermarket source. There is a harness connector in the interior of the left pillar area behind behind the rear wheel. You will have to disassemble the interior panels to access it. You will also likely have to run a power wire (for a control box) to the fuse box as the lighting circuits are not fused for the added load of a trailer's lights. You may also be able to get the kit from one of the sites above.
2): For fog light, Today I go to Auto show at San Jose, and carefully check the fog light wire on XLE trim, the unused wire plug at my LE IS the wire connection to fog light. But at XLE, the headlight lamp and fog light on the same lever have two switches, while on my LE, the lever only have one switch for head light. I'm NOT sure I can use head light switch to control both head light and fog light. (I have found some other SUV/sedan use one switch to control both head light and fog light).
3): For Tow receive, since I only try to tow the bike carrier, not to tow trail, the tow wire staff may be not necessary. It looks difficult for me to DIY the tow wire. Does any one has experiment?
Not all things are illustrated on websites, calling or filling out a form will allow you to find other things that may be in the product catalog but not on the site.
You can get a hitch at most any hitch place and requires only 6 bolts to install. If you only intend to get it for a bike rack then the wiring seems to be optional. Get a 2" reciever type as it can take the most weight and gives you the most options for different racks. The best racks need a 2" receiver.
Alloy Wheels $699
Running Boards $599
Rear Spoiler $485
Hood Protector $105
Cargo Net $49
Does anyone know of aftermarket alternatives or if dealers are willing to deal on these items?
Paul
Tsunami, I try to buy color keyed mud guard, but can not find it. Even I have make calls to the some sites given by Kmead.
If you are successful to get it, please let me know where you get.
Paul
http://www.mrtoyotaparts.com/prodlist.asp?NodeID=71616&TopID=- 71446
The fronts took less than 5 minutes and so far I have not installed the rears. A simple tutorial can be found at the following user site:
http://community.webshots.com/album/87574174lcUNZc
Hope that helps.
The same user's site has a very good tutorial on how to install the backup sensor system as well:
http://community.webshots.com/album/84943179xUYHhK
How high can the headrest be raised?
Has anyone seen a headrest screen in the second row?
Vizualogic.com lists it for the 2004 Sienna but it's hard to believe with the removable seats.
The Toyota bug guard went on without a hitch and took 5 minutes. No wind noise noticed. I am certain it will reduce rock chips on the hood. I am pleased with the appearance and would recommend it without reserve.
Paul
2004 XLE, Artic Frost Pearl, Package #12
XLE Salsa Red Pearl Pkg.#1
We're very happy with the hood protector. While there are no bugs in NY in Jan, the road salt and slop that collect on the sides and running boards is nonexistent on the hood. The windshield seemed to collect less road spray when travelling at speed.
Thanks for any input!
Dooper
I saw at Weathertech site that they sell a separate piece that matches nicely (at least according to the picture) the size and shape of the area. Thanks.
I got the Toyota mats from trdparts4u.com Email me and I will send you the links to the photos of both sets of mats. (on another forum...I don't believe I can post the link here...?) I tried to email you but could not, I think problem is with MY pc.
CPS Tech
I first looked at the WeatherTech rubber mats for Sienna. But they are a bit expensive. I have a set (WeatherTech) for my SUV. The front set is custom fitted. And the rear set is better than the unviseral fitted but they are not the same shape as the stock mats. Both Toyota and WeatherTech mats hold good amount of water, but WeatherTech seems better.
I guess a good setup might be what cpstech suggested for the cargo area behind the 3rd row. I will check out trdparts4u.com. I also know of the other site and I will do a search over there about pictures of the various mats.
