Also, FYI, my 2003 3.0l gets about 16 MPG in the city. Which is quite different from the 20+ you can get with a 2.3l, but my engine only has 2,500 miles on it. Still gotta break her in. I have heard the 4.0l getting equal or better milage, but I am sure it will suck it down worse if you have the lead foot. A manual transmission usually increases your MPG too.
Thanks, David
I have an 01 with the 6 CD radio. I always felt warm to me, then one day it went stone dead. Dealer replaced it with a brand new one. The new one does not even feel warm at all. If it's under warranty, take it back, they should replace it with out a problem. The Ford audio warranty for all SE US is here in Jax, FL. They were suspossed to open the radio (Ford dealer won't do it) and return my 6 CDs. Took a letter to the GM of the dealer to get them to move on that. I seem to remember reading an earlier msg on one of these boards of this radio getting hot and melting CDs causing them to stick. Get a new radio.
Good Luck
Goldranger
You have 2 temp sensors, one for the temp gauge, and another for the 'computer', telling it when the engine is cold/hot. The 'computer' one is probably bad. Both are on or around the thermostat housing. I think the one you need to replace has 2 wires to it......
Thanks for the info. I actually was able to eject the stuck CD (with the help of a small knife). The problem CD was a copy and had a sticker label on it. I guess with the heat, the sticker began to bubble which caused the problem.
Be careful with sticker labels in the 6CD changer (& probably all CD players).
slickhead, your airbag light is stuck? Is this the passenger button disable light, or the dash light by the guages? Since you bought the vehicle used, it's a possibility it has been in a wreck and was deployed. Perhaps it was fixed by a shadetree mechanic who only replaced the airbag, and not the sensor that tripped it. Just an idea. I don't know 98's, so maybe it's supposed to be on all the time? I know blinking is definitely a problem... Maybe on is good? I don't know...
dunny6, I hate CD Labels... They eat up toner, and jam up many cd-players (not just fords) I much prefer a sharpie marker, but it doesn't look as good...
pennyi, I own a 2003 Edge and I love it. My truck is an Edge model too, so it has a 4x4 suspension, just not the drivetrain. That does make it a rougher ride than cars, but it is still very smooth and civil on the payment. I paid a little over 14,000 on after TTL & Rebates, payments are $301. Not too shabby. Only complaints, 4.0l v6 not a regular option on the regular cabs any more, the 4 speakers are fairly weak, but the 6 disc cd-changer is great. I love the ride height, the 60/40 bench seats with high backs, and my 3.0l with a manual transmission is pretty quick. It's a tough and fun little truck to own!
jtc, that doesn't sound normal. It sounds like a tired motor. It's been about 5 years, Have you tried a tune up, new filters, flushing the motor oil and coolant, cleaning your throttle body, changing out the fuel filters, and maybe adjusting your throttle cable? I would start with the throttle body, and try the cheaper fixes first.
I called Ford Consumer Affairs and got the standard line how they sorry they are but I exceed the 36 month warranty!
I have 3 other Ford products and this call was a test to see how Ford would handle and they failed!
I was going to trade my '98 Mustang for a '03 but not now!
Ranger owners check your tailgates for paint problems!
From Edmunds, the only significant change I can see is a different trany implemented in '97. Does that mean the trany prior to '97 was prone to problems?
Appreciate any advice.
1) New plug wires. At 56,000 miles, I think you are due for these. Also new plugs. If you can work on it yourself, these are cheap, less than $40 or so.
2) The Idle Control Solnoid (ICS) I think is the name. This is a silver and black cylinder on the side of the intake. It controls the idle. Has 2 wires into it. It basically is a solnoid and an air valve into the intake. It can clog up with gas vapors. Unbolt it, carefully, and clean the valve part (not the solnoid!) with carb cleaner. If done carefully you should not mess up the gasket under it. This can also be replace, but it is rather expensive, $50 or more.
3)Has the fuel filter been changed? At 56,000 this also is due. If plugged up some, this usually causes high speed problems, but might also cause idle problems.
Justin
I decided on Monroe Reflex shocks as the replacements. I wanted improved ride control, but not the stiffness of high-pressure units such as KYB’s. Now, with about 300 miles of experience with the Monroes, I can say that I am pleased with my decision. The ride is a more tightly-snubbed at low speeds (the gas pressure is surprisingly high for a low-pressure design, and the valving is less “soft” than The Shock Warehouse’s description indicated)), control of body motions is much better, and there is so much more absorbing of impacts going on!
Only peeve is that the Ranger sits up higher than the other P/Us (higher center of gravity) which causes the truck to want to tip when rounding a curve. Besides adding suspension parts or changing to 16 inch rims and lower/wider profile tires which cost some $$$, is there any other practical or cheaper fixes to alleviate this tendency.
I took my new '03 B2300 (Ranger Clone) into the dealer for a clunking that can be heard and felt through the steering wheel yesterday. They called late in the afternoon saying they could feel it too but were having problems tracking the source down. Got a call from them today saying it was normal on the trucks with the tilt wheel per the manufacturer. Has anyone else with the tilt wheel experienced this problem? If so I'd really appreciate your input.
Ron
I have a 2003 Ranger with tilt. Never have felt any kind of clunk, except for a bit of adjustment when I first tilt the wheel down, but that is common to all tilt wheels I have used. When does it occur?
Thanks for your reply,
Ron
Some people say WD40 or electrical cleaner sprayed into the latch can free it up. Most people say you need to pull the door panel off to actually get to the switch and give it a good spray, or replace it.
Dash light going out, one by one? Whoa, this is kind of scary. I've never seen all of them go out. This looks like there might be some bad grounds or bad leads somewhere to cause this, a problem with the circuit board of the instrument panel. You probably need a manual to tell you how to remove the dash trim and instrument panel to get to these. You have to get the panel out to get to the lights which plug into it.
quickest and easiest is to add a rear sway bar. you can get aftermarket for around $130 I think or check out a junkyard for a late model Explorer Sport. They have a rear sway bar and should fit. Be sure you get all the connecting parts. I'd like to do that for my 01 4.0 extra cab,m just haven't found the time
not sure of part #s, but I believe the the explorer sport's frame a& rear axle are pretty much the same. You would want to stay with a 99 or later. Check internet for a company called ADDCO. They make after market suspension parts. I've used them a number of years ago and quality and performance were excellent.
I have a 1995 Ranger XLT 4x4, 4.0L, auto, 130,000 miles, that experiences the same description in TSB 01-11-11 --- Driveline-Thump/clunk Noise on initial acceleration or coming to a stop.
The TSB mentions that it is for Ranger years, 1998-2001. Is there a separate TSB for the '95 or would it possibly be the same?
-HTD
I have a 96 xlt 4x4 Ranger and when the weather seems to get really hot and i'm running the AC my engine at idle makes a loud humming noise.....augh...when I start driving the sound goes away also it used to stop if i would turn off the ac
And now it seems that it is doing it more so , even if i turn off the ac and even the fan it still humms...i do have an airfilter on there, took the stock one out and put in a K&N Air Filter
my mechanic buddy told me THIS was the problem....does any else out there experience this weird humming sound......kinda sounds like ALiens are landing or as one guy asked me "hey man....you got a blower on under the hood?!"
pls email any response to me at
vince@falconecoins.com
Vince
San Jose CA
