I just want your opinion though on a couple of issues that has been bothering me. First, is it normal in all 5spd CRVs to have their clutch pedals sit quite high from the floor, higher in fact compared to the brake and accelarator pedals?
Second, being high, I have noticed (experimented) that I can shift normally by stepping on the clutch a third to half of the way rather than push it all the way down. Is this normal? Will this break things?
Third, if I release the clutch without pausing halfway back I'd more often than not induce jerking. My feeling is that you have to give the gears a bit more time to catch before releasing it. Is this a Honda thing? That's why it's kind of hard to take off quickly from stop; one because of the clutch travel and second because the car doesn't take too kindly to quick shifting.
I know I'm not technical enough to explain it but I know that something's different with my car considering that I've read very good reviews about the 5 speed here.
I do hope somebody can help me in this regard. Could this be an adjustment issue with the clutch. If so I'd be more than willing to pay for the labor fees to sort of "tune" my shifting.
Any help will be greatly appreciated.
Isda65
As to the quick release resulting in jerking, mine does that too. You do know that the clutch pedal activates a hydraulic system that engages and disengages the clutch, right? There isn't a cable that runs between the pedal and clutch. I was surprised to learn that, as all my previous manual transmission vehicles had cables. I've gotten used to it, and just assume it's a function of the hydraulics.
Yes, I've been told by Honda mechanics about this. I guess I just needed to hear this from other CRV 5spd owners. I have also made the necessary adjustments but I have yet to feel the experience of enjoying it. I'll see if I can have the clutch pedal height adjusted. I feel it would make a big difference.
Thanks theracoon for your reply. Any more comments from other CRV 5-spd owners?
Most domestics that I have driven engage the clutch when the clutch pedal is very close to the floor. I think this is harder. Hondas typically get all their clutch action in the last half of clutch travel. Meaning, a quick stab at the clutch about half-way down is enough to shift gears. Also, if you have the clutch pedal depressed all the way, it doesn't seem to start to engage until you release it about half-way.
I'm surprised that after 6000 miles, you haven't become used to it. But, it should in no way be related to the fact that the clutch is hydraulic.
regards,
kyfdx
My experience is with Toyota's, Nissan's and Mitsubishi's and I can't remember having any complaints about the driving experience especially shifting.
"I'm surprised that after 6000 miles, you haven't become used to it".
Actually it's about 4700 miles but even then I guess one of the reason's is the level of resistance that I have shown thinking that there's something wrong with the car.
Do you agree with theracoon though about the fact that the clutch pedal height can be adjusted?
Thank you for your input and time, kyfdx.
That said, I'm almost positive they can adjust the clutch pedal down. That may solve most of your problem. Without being there, I can't say for sure that there is nothing wrong with your car, but a properly working hydraulic clutch should work just as well as the mechanical kind.
regards,
kyfdx
I let the car cool off, then after a short drive,(I believe after brakes heated up, the whine returned). Touching pedal again stops noise, but it returns.
I only have 9000 miles on the EX. Am taking it to dealer for service next week. It is still under warranty.
Has anyone had a similar problem, or have an idea what causes the noise?
It's not enjoyable at all.
As for wanted to trade in the car early, I must admit that I felt the same way, and am still not happy with mine but it does grow on you, or you just begin to ignore the picular driving positions, constant rattles etc. I guess with the warm weather and windows open I dont hear them as much. My plan was to get rid of it after a year but considering gas prices, 23 mpg seems alot better than the 15 to 18 other SUV's are getting.
Bike Racks - does anyone have any recommendations for a good bike rack /setup, for this car. I didnt get the roof rack as I wasnt sure yet if I needed it to get a roof mounter bike rack.
Any help is appreciated.
regards,
kyfdx
regards,
kyfdx
Just curious,
kyfdx
It's not unreasnoble for an A/C compressor to fail after than many miles. They usually last longer but stuff happens.
You might have had a cheaper rebuilt compressor installed instead of a factory new one or remanufactured one. Labor would probably be about the same. 1200.00 sounds awful high!
You mentioned cost of ownership?
Hondas are usually far more reliable than the domestisc you mentioned and the resale values down the road will be MUCH better.
regards,
kyfdx
I placed my hands.The left spoke had a groove in it from my left index finger.Mechanically it was fine except I had to have the front rotors turned because of warpage.I guess I will learn if Toyota
quality is as good as it is claimed.I got my Highlander for $100 over
invoice because my son is an employee of the owner at another dealer
and negotitated it.He works for Ford owned by the same owner of the Toyota dealer and I could have any Ford under invoice but cheap quality turns me off.I had a 98 Explorer and at 40k miles the leather seat seams were splitting,besides terrible gas mileage.
I am the proud owner of a 2000 CRV. About one week ago, an odor started coming out of the vents. It smells like stale flowers. At first I thought perhaps a cat had gone to the bathroom under my car but I have opened the hood and everything else smells normal. As soon as I start the car and start rolling, the odor starts coming out of the vents only. I will be servicing my car in 2 weeks and can ask Honda, however I thought maybe some of you might have an idea. Thanx!
Thank you for your advice. Not being an auto buff, is changing the cabin microfilter difficult??
How much is an airline ticket to Chicago? You can buy Hondas here for invoice or below. I can't imagine this is the only area this happens.
CR-V EX w/AT for $20795 is a very doable price here. I think that even beats a similarly equipped Ford, or if not it is awful close. And the Honda's higher residual value will more than make up for the small difference.
