According to the local Hawaii Honda Service Center, maintenance and service records are not recorded on a general Honda system that they have access to. Each service center and dealer keeps their own records that is NOT shared by VIN. Sounds like you mention this in your last sentence.
If you have some type of other information or a link that says otherwise I would be very interested in trying or seeing that information.
folks, always alwaya always insert the plug to the device you want to power via the ACC socket BEFORE you start the car, after pushing the plug all the way in. that way, there is little to no chance of blowing the fuse because of mis-insertion.
now, if the fuse still blows, this suggests to me either a circuit wiring / short issue in the wiring to the ACC socket or the ACC socket itself, or more likely a poorly designed power supply cord to the device you are powering.
in conclusion, DON'T insert a plug into the ACC socket when the vehicle is running.
Try writing to Granger in GA, providing the VIN and explaining that you want only the maintenance history, without any owner information. See what they do; it really depends on the dealer...
You are of course assuming that the plug is not hot wired to some kind of direct circuit, but rather goes through the electrical system that is powered up by the vehicle key.
I did write a step by step instructional with pictures, but it is on hondaSUV.com and I am not allowed to link it on here.
Can't you just re-post it here, or does that cause problems with the "other site"?
Hmmm, hot wire to the battery (with in-line fuse, of course), anyone?
i really believe though people are blowing fuses to the ACC ckt because of either poorly designed male plugs, or insertion of those plugs at a gross angle causing a momentary short.
Aloha
It won't cause problems, I am the owner of the copyright, if it comes to that. But it is double work for me.
Cut and paste, the modern wonder... :surprise:
Not as easy to do as said. Edmunds uses true HTML tags while HondaSUV uses modified HTML "[" and "]" which I guess I could change...
I don't think that is HTML, I believe that is a special scripting language used by the blogging program.
That sounds like an aftermarket alarm installed by the dealer. Take it in.
you know another possibility, is perhaps the alarm system isn't sensing all the switches that it is monitoring are closed.
assuming you don't have a door or trunk light on the dash illuminated, i'd check out the sensor for the hood.
i'm sorry, i'm just guessing now.
Reading this thread, it seems like this part has failed in many people's CR-V's (or, at least, is a commonly replaced part when the "check engine" light comes on).
https://techinfo.honda.com/rjanisis/pubs/AU/AAM32039.pdf
- Do other CR-V owners notice excessive wind noise at highway speeds?
- Has anyone found a dealer that actually corrected this?
- Has anyone fixed this themselves?
I appreciate any feedback.
Steve
2007 Honda CR-V EX-L AWD
K&N allows more particulates in than stock Honda filter = shorter engine life.
If Slick50 uses Teflon as main ingridient, then it is all settling down in some oil passage, and will eventually lead to oil starvation.
The solution: I traded my CR-V for a Subaru Outback (LL Bean edition). I LOVE IT. I miss the shape and interior design of the CR-V, but not the rough idle or having to change the differential fluid at 22k. I will never buy another 4 cylinder Honda again. From what I hear, the V6 Hondas don't seem to have the rough idle problem.
Something was wrong with that individual CR-V. Not sure what it was, my 2003 CR-V went to 45K before I traded it, and the idle was fine.
My father in law has a Gen 1 at 70K with fine idle.
Reason I ask is, I'm thinking of adding the controls, and I'd like to know what it will do when CD is on. My 2004 LX doesn't even have this in the manual, since it wasn't an option then.
(I'd post this in the 2006 forum, but it doesn't look like that forum is very active nowadays... )
There is a buzzer that will not stop unluss I turn on my headlights on my 2002 CRV. This is a big pain since sometimes I forget to turn off my headlights when I turn off the vehicle. Is there anyway to turn off this buzzer or perhaps get it to do something useful like sound when I have left my headlights on?
It sounds like the relay that turns on the buzzer for the "lights on, engine off" buzzer is broken. Have the dealer fix the problem...
The main reason I wouldn't get a Subaru is the engine vibrations transmitted through the shifter and the steering wheel. I think LL Bean uses H6, but it is still the boxer engine design, if I am correct, which is inherently shakier.
By the way, V6 Honda engine and automatic transmission should not be put in the same sentnce.
Do you have any dyno charts to substantiate that "it perform better"
How many miles have you been driving with this combination?
How many miles are you expecting to drive this car?
Honda race teams also rebuild their engines after each race, do you?
I had a CR-V diesel one year ago and was told that Honda had no service books but one would be sent to me, which i never recieved, when i asked when does it need a service the delivery driver told me 20k miles. it's no done 19.5k miles and developed an engine rattle, i took it to my local Honda dealer and have been told it needs a new engine because it's run out of oil, no oil warning light was displayed in the car but Honda say there is enough oil in the sump to stop that happening but not enough to stop the engine being broken. I've been told by Honda that i must now pay £8500 for a new engine.
Any advice would be gratful. Dave
MNF
Did you drive it for 19,500 miles without changing oil?
How often did you check the oil level with the dipstick?
Did you perform any other maintenance on the CR-V in the last 19,500 miles?
