lexusguy- the photos of the seats that arent full leather:
http://gallery.dealerrater.com/gallery/xl/100_1389.jpg
http://gallery.dealerrater.com/gallery/xl/100_1388.jpg
The base of the front seat also seem somewhat shorter than the current GS.
'01 was a significant freshening, with revised headlamps, grill, and tail lamps, the 4.3L VVTi ULEV V8 (The 3.0L 6 was a carry over), and the Xenon lights became standard. Also, front\rear side curtain airbags were added, there's more wood in the interior, it got the updated NAV system, and the Nakamachi package was dropped for Mark Levinson. The steering wheel changed with the rest of Lexus 3-spoke wheeled cars for '01-03 (ES, GS, IS, RX, SC) and secondary audio controls, and the standard 16" alloy design was changed. The 3-tunnel gagues also appear to be slightly restyled (same black on white with a light green illumination though), and the '01 cars got some chrome trim around the gauges.
The seats of the '06 look to have a perforated leather insert in the center, unless Im mistaken.
http://autoz.org/w/lexus/Lexus_GS430_2006_020.jpg
The '06 GS looks a lot more muscular and more modern. I think I'll just go for the '06 GS300 next year, and add the options.
I heard that 18" wheels are standard with the GS430, so thats good to hear. Prices will probably increase quite a lot though. A site predicted it to be $62,000 - $80,000 canadian dollars. Which model thats for, i dont know.
Actually, the 2nd generation GS had a GPS system right from the beginning for the 1998 model year.
Just a correction...from 1998-2000 only the GS 400 had the E-shift controls, the GS 300 did not (my family has a 1999 GS 300). When the V8 went from the GS 400 to the GS 430 in 2001, the E-shift controls were gone but appeared on the GS 300. I remember something about E-shift not being compatible with the 4.3 engine. I haven't kept up with the current GS 300 so I don't know whether or not it still has E-shift.
Boomsama, I really have no idea. Details on the new GS are extremely scare. No one is even sure exactly what six cylinder is going to be in the engine bay.
1) inline-6 is generally smoother running.
2) more efficient internally equals more power with a straight 6.
more efficient because less parts, such as in DOHC design, only 2 cams vs. 4.
From Automobile Magazine; March, 2004; page 29:
"The new 3.0-liter V-6 is unrelated to the current Lexus/toyota v-6s."
Fbear, that would be only logical, after all, the only 3.0L V that Toyota has is the one that was just replaced. It would seem more than a little odd for them to use the old RX300 engine in a new for '05 car.
I'm still hearing quite a lot of talk about the GS having a tweaked version of the 3MZ-FE. It wouldnt't make much sense for them to use the mainstream toyota V6 since this is supposedly Lexus' first lexus-only designed car. On the other hand, with the new A6 having at least 188kw (252hp) in their V6 3.2 FSI engine, would it be possible that they may possibly tweak it up higher to beat the A6's? As it is the newest "sports-sedan" 6 cyclinder engine, it may seem to be the new benchmark. It doesn't make sense for Lexus to release an engine after the A6, only with lower power.
~alpha
Just my opinion.
The one reason I will be glad to see the straight 6 go is due to inefficiency(by modern standards) and weight. That inline-6 is heavy due to the iron block. Today basically all engines are using aluminum blocks for weight savings.
I also think Lexus is throwing us a curveball with the talk of a 3.0L V6. I think closer to actual introduction they will reveal a bigger production engine.
How is that so? Do you own one? Can you point me to any references that state that the 3.3L in the ES/RX/Sienna/Solara is less than excellent?
I can offer a reference from Car and Driver that likened the 3.3L's sound quality and thrust to that of a BMW inline 6, if you'd like...
~alpha
Why would I buy something that I don't like?
However, I have driven the ES, RX, and Camry SE and while the engines are refined, they truly don't live up to their numbers. For example the Camry is lighter that the accord, however not as quick even though engine is 10% larger.
Camry SE 3.3 (curb weight) 3350 lbs (0-60) 7.6s (edmunds)
Honda Accord EX V6 (3385 lbs) 7.5s (edmunds)
If it matches up like that to the accord, how is is it going to match up to the VQ, one of the best engines in the market. Not very well. In fact I think the engine I had in my 1996 Maxima (3L VQV6) is faster, more inspiring than than Toyota's 3.3.
I have nothing against Toyota/Lexus (in fact I am buying a GX470 tomorrow), however the 3L in the GS300 needs to be much better than the 3.3L because Lexus doesn't need another ES. That being said I am going to get an M35/45 or GS430 come next spring (I would only consider the GS300 if it is leaps and bounds better than the 3.3).
Is it better to have more torque, or more power in a car like the GS?
dogface- Toyota lists the Camry SE V6's curb weight as 3494. In other words, your assertion that the Camry is lighter than the Accord is wrong.
I hardly find Edmunds.com a good source of performance info, but given that the Camry SE V6 is about 100 lbs. heavier than the Accord, being shy of the Accord's time by a tenth of a second doesnt really seem like much.
(It should be noted that Car and Driver tested an Accord V6 4 door to 60 at 7 flat, and the Camry Solara SE V6 Sport at 6.9.)
FWIW, the VQ is a powerful engine, a great one. It is NOT as refined as the 3.3L or Honda's 3.0L, at least not in the Altima I drove.
~alpha
I think most companies that make both FWD and RWD cars are abandoning the straight 6 and going with v6 b/c a v6 will fit in both FWD and RWD cars.
Not knocking the v6, m personal preference is the straight 6 b/c the engine just feels so good.
Take a ride in the Chevy Trailblazer which has an awesome 4.2L straight 6 to see what I mean. It's a shame that an engine that good has to be stuck in a car so mediocre.
