Crankshaft Position (CKP) Sensor
TESTING
http://www.autozone.com/images/cds/gif/large/0900823d80170ba4.gif
1. Disconnect the CKP sensor harness. Connect an LED test light between battery ground and CKP harness terminal A.
2. With the ignition ON and the engine off, verify that the test light illuminates.
3. If not as specified, repair or replace the fuse and/or wiring.
4. Carefully connect the test light between CKP harness terminal A and B. Verify that the test light illuminates.
5. If not as specified, repair the CKP harness ground circuit (terminal .
6. Turn the ignition OFF and disconnect the test light.
7. Next, connect suitable jumper wires between the CKP sensor and CKP sensor harness. Connect a duty cycle meter to the jumper wire corresponding to CKP terminal C and battery ground.
8. Crank the engine and verify that the duty cycle signal is between 40-60%.
9. If it is not as specified, the CKP sensor may be faulty.
10. Next, connect a AC volt meter to the jumper wire corresponding to CKP terminal C and battery ground.
11. Crank the engine and verify that the AC voltage signal is at least 10.0 volts.
12. If not as specified the CKP sensor may be faulty.
It is. The coolant temp sensor is usually a 3 wire sensor which inputs data to the engine control module. The temp sending unit is usually a single wire sender used for temp gauge/temp light operation.
Would the airbag light come on when the airbag monitor fuse is pulled? Would an experienced tech replace a crash detector without first checking the monitor? Am I getting taken for a ride?
Yes.
"Would an experienced tech replace a crash detector without first checking the monitor?"
Probably not.
"Am I getting taken for a ride?"
Probably not. I sometimes get customers in who "just did a bit of checking" and inadvertantly caused major damage. The invoice is usually significantly more than if they'd just brought it to me to repair it in the first place instead of screwing around with systems they have no knowledge of and no troubleshooting flowcharts to repair it properly.
Yeah, you probably do need to take the door panel off and you'd probably find a broken or loose metal rod that comes from the door handle and works the door lock open. Sometimes there are clips that connect the rod to the lock and these fall off....
P0171 = Fuel Trim System Lean (Bank 1)
The O2 sensor has indicated a lean air/fuel mixture and the engine control computer has tried to compensate by adding fuel (richened the mixture) to it's limit. Start by looking for whatever's causing the lean mixture; vacuum leak, restricted fuel filter, weak fuel pump, the usual suspects.
P "1" codes are manufacturer specific. Can't help you on that one.
Of course I can't hear the noise you are describing, but the way you describe it sounds about right...the ABS pulses your brakes on and off many times in a short period of time. It is reading wheel lock and backs off every so slightly as soon as it senses that the wheel is no longer rotating.
http://www.cdxetextbook.com
It contains heaps of information, pictures and videos.
make sure the top and bottom tracks are clear of any items.
go to the Honda Odyssey Problems and Solutions forum, and do a search for door relearn. there is a procedure for resetting the door opening / closing system which may ultimately help you.
good luck.
High
My wife has an '02 Elantra with 70K miles on it. Oil has been changed every 3,500 miles, timing belt, and drive belts were replaced at 60K, and the auto tranny gets flushed every 30K. Car runs like a top, and delivers upwards of 39mpg on the hwy.
Saturday afternoon about 3:30, I started the car up to run an errand. It was a cold start (outside temperature was @50, but it had gotten down into the 20s the night before. When I first started it in the driveway, I heard a tapping noise coming from under the hood (on the passenger's side). I then backed the car out of the driveway, put it in drive, and accelerated slowly. The tapping noise continued for the first 15 yards, and then went way completely. I drove the car about 20 miles after that, and everything was normal. I then let it sit overnight on Saturday, and did a cold start on it yesterday morning and drove it, and there were no strange noises at all. The side I heard the noise coming from under the hood is the side of the engine that the belts are on. I had just washed the car before I heard the noise on Saturday...so I don't know if water had gotten under the hood and played any role in this???? Any ideas as to what this might be?
It might have been ice on a belt but that would have been flaked off or beaten off in a couple of revolutions of the belt.
If it happens again I'd start looking for the source and if it might be lifters maybe it's time for an oil additive to clean out lifters just before an oil change. I have used Rislone by adding it about 300 miles before an oil change at half strength and repeating each oil change for a couple more.
I will try the Rislone in the meantime.
However, having said that, excessive red-lining would not be wise...this is not the same at full throttle operation in midrange.
I don't think 5,000 rpm is redline on your truck anyway.
i was thinking of red lining it a couple of times after i hit about 1000-1200 miles but unsure of how much of it i should do. Im at the point where my pre break-in period is almost up=about 400 miles to go, and now feel like doing the upper rpms(5000-6000rpms) to get the most of it later on.
This may sound a bit confusing but, if i wanted to get a quicker more efficient blast up to 6000 rpm or near redline(redline on my truck is from 7k-8k rpm) for example, is it better to floor it when the stop light goes green or take off gently when its green light and let the needle come down once and then floor it? Thanks.
High
I would just like to know how much red lining do you consider to be excessive?
High
One last question Mr_Shiftright since you've been much of a help, i've been usually doing quick bursts of throttle and just letting go of the pedal to drop off about 10mph or so, and then accelerate gently again. I've also done some high rpm and braking but mostly just letting the foot off the pedal to decel. I believe the braking after the hard accel is more efficient in terms of breaking in an engine but can only letting the foot off the gas to drop off several mph's after several wide open throttles be okay as well?
High
And I don't think you should be racing with a brand new engine, unless I misunderstood you. When at the track, mistakes are made, shifts are missed, etc. and then you could be in trouble.
thanks!
