Chevy Tahoe Maintenance and Repair
Have 2004 1500 z71 w/off road packg.over even slight bumps it sounds like a broken shock nocking/thumping noise. I found when I push against the cross member that connects the torsion bars to the frame with my foot I get the noise . The dealer 2x says nothing wrong. It is obviously loud. rubber mounts don't look broken any others have the same problem out there ? thank you
Whe I first looked at a Tahoe early last week, the salesman is the one who directly told me that the the remotes were labeled #1 and #2. And that when Driver #1 used Remote #1 that the Tahoe would use Driver Memory #1. And the same for the #2 drive/remote/memory. But I'll be damned if I can make it work or find any reference to it in the manual.
If you find any informaiton on this, please let me know.
M. Wold
Elburn, IL
mark.wold - at - gmail.com
(buttons located on driver's door, round, marked 1 and 2)
These buttons are used to program and recall memory settings for the driver's seat, throttle and brake pedals and both the driver's and passenger's outside mirrors. The settings for these features can be saved for up to two drivers.
To store the settings, do the following:
While the vehicle is in PARK (P), adjust the driver's seat, including the seatback recliner, lumbar, and side wing area, throttle and brake pedals and both of the outside mirrors to your preference.
Press and hold the 1 or 2 button of the memory control for three seconds. A double chime will sound to let you know that the position has been stored.
To repeat the procedure for a second driver, follow the preceding steps, but press the other numbered memory control button.
Each time button 1 or 2 is pressed and released while the vehicle is in PARK (P), a single chime will sound and the memory position will be recalled.
To stop recall movement of the memory seat feature at any time, press one of the memory buttons or power seat controls.
Easy Exit Seat
The controls for this memory function are located on the driver's door.
(Easy Exit Seat):
(oval button with picture of car and arrow)
This button is used to program and recall the desired driver's seat position when exiting/entering the vehicle. The seat position can be saved for up to two drivers.
To store the seat exit position, do the following:
Press and release the 1 or 2 button. The seat will move to the stored memory position.
Adjust the seat to the desired exit position.
Press and hold the exit button of the memory control for three seconds. A double chime will sound to let you know that the position has been stored for the selected button (1 or 2).
To use the seat exit position, press the exit button on the memory control.
I bugged the salesmen up front about the remotes. Newer Tahoes/Suburbans/Trailblazers do not have a connection between the remotes and seat memory. Now you have to push the button on the door to get the seat to move to your favorite position. They tell me it's been that way for a couple of years.
Dealer also told me that enough people complained about this new "feature" on the escalade, and GM rewrote the software to include the recall from remote function. I have been complaining to GM for weeks now, hopefully they will fix it for my Envoy.
C
"Changes to personalization features"
It just explains that they are trying to simplify the personalization and memory features starting in 2005. It goes on to say that this is an engineering change and no repairs should be attempted.
All they have to do is update the software. I have called GMC and complained a few times. Hopefully enough people will complain and they will do something.
The dealers response was that it was gone.... And also they told me that enough people already complained about the Escalade and they rewrote the software for it. Hopefully they do the same for us too.
Engine - Knocking on Cold Start Explanation
File In Section: 06 - Engine/Propulsion System
Bulletin No.: 01-06-01-028A
Date: March, 2003
INFORMATION
Subject:
Engine Knock on Cold Start
Models:
1999-2002 Chevrolet and GMC C/K Pickup and Utility Models
2002 Cadillac Escalade (2WD)
with 4.8L, 5.3L or 6.0L Engine (VINS V, T, Z, U - RPOs LR4, LM7, L59, LQ4)
This bulletin is being revised to add an additional engine to the models section. Please discard Corporate Bulletin Number 01-06-01-028 (Section 06-Engine).
Some of the above vehicles may exhibit an engine knock noise that begins in the first 19,000-24,000 km (12,000-15,000 mi) of use. The knock noise is most often noticed during initial start-up and typically disappears within the first 5-30 seconds (may last longer in extreme cold temperatures). The noise is usually more noticeable on the initial start-up when the temperature is below 10°C (50°F) and may be more pronounced on the first cold start following a long trip.
This noise may be caused by an interaction between carbon that has formed on the piston, the piston motion and the cylinder wall. GM Powertrain Engineering, and an analysis of engines with this condition, has confirmed that the noise is not detrimental to the performance, reliability or durability of the engine.
THIS NOISE DOES NOT HAVE ANY EFFECT ON THE LONGEVITY OF ANY OF THE ENGINE COMPONENTS.
Important: At this time, attempts to repair this condition by replacing the engine assembly or pistons are not recommended.
Please share the information found in this bulletin with customers who inquire about this condition. In the event they have additional questions or concerns, please advise your Area Service Manager.
I took it in and they said that a value was clogged and the noise is just the fuel injectors pulsating. Well, three days later, the A/C goes out and the noise is still there.
Come to find it, the compressor it going out. Had to get it replaced today. $1300 later, ($500 a week ago and $800 today)
I am also having a squeak or rattle under the dash area of my 2003 Tahoe. Looked everywhere, can't find it. Exactly where did you lubricate the emergency brake cable? Is it under the carpet area? Thanks
Thanks Jeff
When I start for the first time in the morning it will start and them cough and die. Time seems to fix it till the next morning
Best regards
Tahoe_Sweden
I just bought an XM commander for my Tahoe Z 71. For about 85.00, it was install at circuit city. I bought it off e-bay for 70.00 (total). If you by the whole unit, new it will cost you 170.00 plus installation. My suggestion, is to get the XM commander unt, it looks factory when installed right, and the sound is awesome. Let me know how it goes!
We had it with our 03....
--jay
Also, anyone had the torsion bars adjusted? I complained three times that the front end was too low, they finally put it on the machine and said "did you know the front end was 2 inches too low?"
Thanks for the input
-KAG
Any help appreciated much.
There is a fix for this problem now. It is a software update, which I had done to my truck 2 weeks ago. I have not seen any problem yet and I'm using the easy access function now. It used to malfunction about 25% of time. Not once yet in two weeks.
Below link takes to GM-tech page where this is explained amongst other issues
http://www.gmtechlink.com/images/issues/jul05/TLjul05e.html#story17
They should fix is for free even if your truck would be outside warranty I would think. In the GM-tech page it clearly says that they found it to be a software issue. This means that whoever has the memory seat with this problem never had it correctly working, which should mean they'll fix it for free.
--Arrie--
My dealer service printed a document that showed the locations. Reason for two grounding points is that there are two big connectors to computer and I guess they both have a ground.
--Arrie--
Had it Road Force Balance and it made it worse?
Dealer is looking at a problem called "beaming".
Something to do with the frame and idler arm installations at the factory.
Anyone have any information on Beaming or other cause for this symptom?
Is this normal? Is the oil gauge supposed to be up that high and floating or is my truck all jacked up? Is the volts gauge supposed to be reading at 3/4 as well?
