JEEPS like a good battery nice stedy volts etc.
Also, on a different web site (I can't remember it) there was an airline mechanic who figured out the the screws holding in the top part of box holding the computer was actually wearing through some barrier over time. This caused the "shorting" or stalling. He backed out the screws a couple of times (or pput shorter screws in) and many many people on that thread were singing his brilliance because he solved the problem they were having.
:shades: Hopefully this will help.
I too have recently had this problem with my JGC 2001. I took it into my garage who were baffled and decided to put it up on the ramps, the switch underneath the engine was covered in muck and gunk and the mechanic gave it a good clean and sprayed it with damp start and low and behold it hasnt done it again. they said the cover under neath the engine covers most of the engine but this particular switch is open to the elements. Hope it works for you
Am I the only one having these problems?? The only reason they actually took it more seriously this time was b/c I did a Google search and found that Chrysler has done a massive recall on other Jeeps and Nitros for the same problem. I took the articles with me to my dealership and they decided that it was possible that there was in fact something wrong with my Jeep.
Sidenote- oil was changed and all the fluids are good.
Any advice will be appreciated. :confuse:
Thank You,
Brittany
Any ideas?
Turns out the computer is in a bad location just below hoses that leak on top of it. Took it to someone other then Jeep and had the computer rebuilt. They found six errors showing up! Problem was when you checked the actual error it turned out to be fine. After rebuilding the computer at a cost of 395.00 it has been running excellent. Not cutting off after a 20 minute drive. Have placed over 200 miles on it without a problem. Take it to a Triple A guaranteed for 12,000 miles. That way you have backup when a engine light comes on again. Mine did come on once it was under the battery a reset button. Two years of sheer hell because Jeep placed the computer under the hoses to where liquids could fall. Hope this helps all that are suffering from break downs on the side of the road!
My 98 JGC...not so good. I find that I usually have to crank the ignition and at the same time give it gas, perhaps halfway down on the pedal. Usually it starts first time although after a couple of seconds of cranking. If it doesn't start first time then it start immediately on the second try; but you can usually smell a little gas. Once it starts first time or second it runs fine.
I thought most late model cars were supposed to start like the Nissan with the foot on the brake, no gas applied.
Am I the only one with this issue? Could there something wrong with a sensor or something? The car isn't throwing any kind of code that would trip the engine light.
I thought it might be the Idle Air Controller valve, so I replaced it but it is still happening.
Could it be a dirty fuel injector? What else should I check?
Dave
Any other ideas?
Occasionally, the car will start stuttering when coming to a stop, or accelerating out of a stop and eventually stalling out. It happened today for the first time while driving at low speeds. If I drop the car into neutral while it is stuttering, it will recover and I can continue to drive, but if I just leave it in gear the car will stall out for sure.
I've replaced the idle-air control valve and the throttle position sensor but no luck so far. Interestingly, i've been having intermittent problems(not at all since the stalling started 2 weeks ago) with the electric door locks all the sudden going crazy (repeatedly locking/unlocking for 10-20 cycles and then stopping) while driving. Also, and I'm not sure if it's related, but the low beam lights don't work while I have no problems with the high-beams. I've already replaced the head light switch.
All of this makes me think there must be some faulty wiring somewhere causing all of these problems.
There is one other thing that could be the heart of my stalling problems.
The engine diagnostic code gives me code 43, indicating cylinder misfires.
Could all of these symptoms point to one thing that may be the main culprit?
A trick we used to use to make big bucks off Dodge/Jeep/Chrysler customers. I work for Ford now but still love my Jeep!
I have a Jeep grand cherokee, V8 4.7L I think it is year 2000 one of the first new look ones. Anyway when I take it on a short journey or it gets parked in the sun, the majority of the time the car wont start again. If it is cold or hot then starting is fine if occassionally a little hesitant. I have had the fuel pump replaced as my garage reckons the sensors were showing a fuel problem, but it still does it, I have had the crank sensor replaced but it still does it. I want to take it to an engine diagnostic place but want to give them clue as where it might be. If the sensors are scanned afterwards when the car is running again no error shows up. Please any suggestions would be fantastic
Thanks Claire
