Chevy Silverado Problems
I had my '99 Silverado Lt Extended Cab 4WD in for Service today. With 20 Miles left on the Warranty.
I asked them to check everything out and especially anything they would have done to it if it were their truck based on past problems they have seen and TSB's. Maybe that's nieve of me but, the service Guy has been straight up with me in the past and not recommended any crapola, so dare I say I trust him?
Based on some postings on this board when I took it in I did note:
#1 Rough Running at Start up when cold ( so I left overnight and they put a monitor on it and fired her up next day and said no problems noted)
#2 Wind noise in rear passenger windows - to which
they indicated they "Tightened" some molding behind driver side
#3 A finicky heater control (difficult to get comfortable either too hot or nearly cool) - they tested temp on full half and another position and said they had variable temperature readings thus OK
#4 Noted the "clunking" though this has only occured once since the "Fluid Flush refill" and asked for the new Yolk - On Order to replace when it arrives.
Well I picked it up today and the darn thing stalled out on me at a light 8 miles form the dealer (first time anything like this has ever happened) - Called the Service guy on the phone and he said may be due to injection cleaning (not dry?) and he told me to let him know if not Ok tomorrow. Does anyone know if that could have been the cause? (And was I a sucker for spending $90 on this??)
But my primary question is this,with my warranty near expiration, what do I want to be sure gets corrected?
I am going back through the posting now but a slow process, some of you experienced guys/gals can probably rattle the main ones off.
Any guidance is appreciated!! Thank you
Other background on me and the truck..
My first glimpse of a Silverado was about (May/June?) of '98 on the Chevy web site when they sneak previewed the new body style, sort of masked with a bunch of add ons so you couldn't really tell what it looked like (if my recollection is right it looked more like the avalanche in those previews), I kept checking and reading until they finally released the "real" pictures and colors, knew I had to have one and special orderd it in Feb '99 got It in May '99.
It's been great so far, with just the inconvenience of the few recalls, seat belts, brake pipe, etc. But really Love it it and have babied it. The only "service" I have had has been the standard recommended stuff. I hope this is a truck that will last as long as my '91 S-10, which now has 192K but is about pooped, fouling plugs, and burning oil etc. but hey I've got my money's worth out of it!!
File In Section: 08 - Body and Accessories
Bulletin No.: 99-08-48-001A
Date: September, 2000
Subject:
Wind Noise from Body Side Quarter Window (Replace Body Side Quarter Window Assembly)
Models:
1999-2000 Chevrolet and GMC C/K Extended Cab Pickup Models (Silverado and Sierra) Built Prior to February 1, 2000
This bulletin is being revised to add the 2000 model year, remove service procedures, and change the part numbers. Please discard Corporate Bulletin Number 99-08-48-01 (Section 08 - Body and Accessories).
Condition
Some customers may comment on wind noise coming from either of the body side quarter windows while driving with the quarter windows closed. The wind noise may be more noticeable at speeds over 56 km/h (35 mph).
Cause
An insufficient seal of the window frame to the body or an improper window latch length may cause this condition.
Correction
A new body side quarter window kit is available to correct this condition. This window kit includes the window frame and glass, three frame centering screws that reinforce the sealing of the window frame to the body, and an instruction sheet. The window frame also features a reinforcement latch tab to improve latch efforts and function.
Replace the applicable body side quarter window on affected vehicles. Use the appropriate part number listed below.
Refer to the applicable Service Manual for quarter window removal and additional installation procedures. Also refer to the instruction sheet provided with the window kit for installation information.
Parts number:
88935198
88935199
88935200
88935201
Parts Information
Parts are expected to be available from GMSPO on 9-18-00.
You can check here for a list and see what matches.....
http://www.alldata.com/TSB/11/991136FY.html
1.) During the first 5-6 miles of driving the truck doesn't want to shift into over drive and when it does, it gradually shifts( not like my dad's 92 that when it shifts it will jar your teeth. Dealer tells me that this is normal because the tranny needs to warm up.
Is this true??
2.) When it is cold (below 28 degrees F) when the truck reaches a speed of 25 miles mph the tranny seems to whine, kinda of like the sound oversize tires make on a rough road, after you accelerate through it it goes away, after the vehicle is driven a few miles and is warm the problem won't repeat. Also if you acelerate quickly you don't hear the whine either, but since I don't lay rubber in my driving habits the whine rather annoys me and summer is a ways off.Has anybody else experienced this? Since I haven't bought American since my Chevy Vega fell apart 28 years ago, I thought I would re-vist the domestic scene.
PS: to the Tundra guys, I think the Tundra is a bit crampy and the "Rado is much more comfortable, but hey, what do I know, I've been in a compact for so long I didn't know how nice it felt to stretch out.
2. True
Has been happening on my truck for 2 yrs with no problems just gotta let it warm up
Still wondering if that Fuel injection cleaning was worth the $90? But I guess that's sunk now anyhow.
Thanks again,
cowboyjohn
TSB #00-07-30-006 for Stall/Surge at Stop or When Shifting to Drive or Reverse (Install Updated Calibration)
The geocities site does not seem to work anymore for some reason.
Ray T.
A/T - Stalls and/or Surges at Stop
File In Section: 07 Transmission/Transaxle
Bulletin No.: 00-07-30-006
Date: May, 2000
TECHNICAL
Subject:
Stalls/Surges at Stop or When Shifted to Drive or Reverse (Install Updated Calibration)
Models:
1998-2000 Chevrolet and GMC C/K Models and G Van with Hydra-Matic 4L80-E Transmission (RPO MT1)
This bulletin is being revised to include additional model years and new Correction information. Please discard Corporate Bulletin Number 87-71-63 (Section 7 - Transmission/Transaxle).
Condition
Some owners may comment on an engine stall or a slight surge at a stop or when the transmission is shifted into drive or reverse.
Cause
The transmission calibration may not be optimal for the best engine/transmission performance.
Correction
Install the latest new calibration.
Parts Information
The calibrations listed are electronic calibrations and are NOT available from GMSPO. Calibrations will be available from Techline starting January 2000, on the TIS 2000 Disk 2 CD ROM.
Warranty Information
For vehicles repaired under warranty, use:
LaborOperation Description Labor Time
J6355 On-Car Reprogramming. Use published
Transmission labor operation time
I have scanned the nickel plated slip yoke tsb and the one for new 4 door latchs (ext cab doors hard closing when cold)
Send me an email to remind me ok
Last I heard was that GM is advising not to install it and that they were working on a third fix.
The nickel plated yoke works for about 3000 miles and then the noise comes back. Similar to greasing the splines.
Here is the original TSB
Info - Discontinue Flushing and Replacing Transfer Case Fluid Due to Bump/Clunk Concern #99-04-21-004A
1998-2000 Chevrolet and GMC K1-2 Pickup and Full-Size Utility Models
1999-2000 Cadillac Escalade
with NP246 Automatic Transfer Case (RPO NP8)
This bulletin is being issued to cancel Corporate Bulletin Number 99-04-21-004. Please discard Corporate Bulletin Number 99-04-21-004 (Section 04 - Driveline/Axle).
This bulletin is being issued to advise dealerships to no longer flush and replace the transfer case fluid when a customer comments about a "bump" feeling when the vehicle accelerates from a stop.
When Corporate Bulletin Number 99-04-21-004 was issued, a new transfer case fluid had just been developed to correct this condition. Currently, a nickel-plated slip yoke is being developed that will correct this condition. A new bulletin will be issued as soon as parts are available.
Please share the information in this bulletin with customers who may inquire about this condition.
© Copyright General Motors Corporation. All Rights Reserved.
I originally posted #1738 on these problems and went to the dealer in January. The hydraulic lifters and the limited slip are "live with it" sort of things. The limited slip is a design thing. The hyraulic lifters have been a complaint with other customers, but the dealership has not been able to fix, even after taking one engine apart. So, if the lifter does not make the noise all the time....live with it.
The muffler is a different story. They believed me about the "oil can" problem and ordered a new one, indicating that others had the problem too. The "oil can" noise is what you hear once when the muffler is heating up, and again once when it is cooling down. It probably helped that I told them what I thought was wrong inside the muffler, based on having worked for a muffler co. for many years. Well the new one has "loose insides." Parts inside the muffler rattle a lot when cold. You can hear the parts rattle when you tap the tail pipe or muffler with your fist. We are waiting for another replacement muffler.
Mannwi
A lot of us use Mobil 1 or other synthetics in our engines - but I don't worry about the engine -it is most likely going to last much much longer than the GM tranny. Anybody have a auto trans fail after using synthetic trans fluid? Should we all start "GM tranny savings accounts"?
Ray T.
The fan has a built in thermostat. It free-wheels when cold, but engages when more cooling air is needed through the radiator, at which time it will make more noise.
cowboyjohn
"You may also hear a fan noise when you start your engine. It will go away as the fan clutch partially disengages"
Stef
