There are two totally separate circuits: 1.) the low intensity running lights and 2.) the high intensity brake/turn signals which has the signal flasher as part of that circuit. The only place the circuits get close together is at the bulb itself. The fact that your turn signal flasher works normal except when the running lights are on, tells me that one of the bulbs must be causing the problem. This is actually a fairly common failure where one filament burns out and breaks, and then lays across the other filament and causes a short between the two circuits. Unfortunately, you looking at the bulbs has not validated that a bulb is bad, and/or which bulb it is.
So if I therefore assume that the bulbs are the correct bulbs, and that they are working correctly, then the only thing left it could be is the flasher itself. That flasher is behind the left kick panel. Sitting in the drivers seat, put your left foot on the floor and slide it to the left until it hits the kick panel on the left. Take that panel off, and there is a relay block behind that. The flasher is the top corner of that relay block. If you take the panel off, and then turn your flasher on, you should be able to feel it clicking when it's working. Replace that flasher.
I guess it's possible that your flasher is just soo borderline that sometimes it works and other times it doesn't. The only way to prove for certain, is to just replace it.
If you do replace it and it doesn't fix the problem, you have to go back and look closer at those bulbs. You may have to take the bulbs out of the sockets to physically look at the filaments while they are on. A dual filament bulb only fits in the socket one way. You will notice that the prongs which hold the bulb in the socket are offset and at a different height. That offset cooresponds to an offset in the socket. Also when you look at a bulb, one filament stands up higher in the bulb than the other. This is important to look at to verify the high intensity brightness compared to the low intensity. I still feel that there is something not right with one of those bulbs.
I ohmed out all of the leads from the ignition coils associated with cylinders 1 and 4. They appeared identical. The only resistance reading I was able to obtain was approximately 390 ohms between pins 3 and 4.
When I reinstall the ignition coils I intend to switch the ignition coils between cylinders 1 and 4 and see if the error code then follows the coil.
Any more thoughts?
The error code was "P0304 Cylinder 4 misfire". I have replaced all of the spark plugs with the proper irridium type as they were due anyway. The engine is still running rough. I have pulled the #4 and # 1 ignition coil and ohmed them out on the work bench. I can find no difference between them but only got a reading between pins 3 and 4 (390 ohms). I intend to switch the ignition coils when I reinstall them to see if the error moves with the coil.
I would love to hear any ideas you might have. I apologize for the initial confusion.
Check
- Camshaft sensor resistance is 1400 ohms cold, 1645 hot
- Crankshaft sensor is 1600 ohms cold, 1890 hot
- Swap position of coil, to see if the problem moves with the coil.
Hope ECM is not fried with the jumping / battery replacement.
If you totally run out of options, you might consider disconnecting the battery again, and then when you reconnect and restart.....do not floor the accelerator, just let it idle for a while.
flasher location
someone told me it might be the relay?
i bought a flasher at autozone for 10 bucks. but i cant find the place where to put it at. i checked the lower left of the drivers side.
A suggestion is to turn the blinker on, and follow your ears to where it's clicking. You may be able to feel the flasher clicking as well.
I don't have the ability to reach thru the internet to your vehicle and do this for you. You may have to take to a mechanic if you can't recognize the flasher on the relay block and swap it out. They may also be required to look closer at the bulb filaments if the new flasher doesn't fix the problem.....I still think you may have a bulb problem somewhere, given the symptoms you describe and when/how it allegedly fails only with the running lights on.
Lay down on your back, feet hanging out the door opening, with your head under the dash on the drivers side. Buy a replacement fuse at autoparts store, make sure you have the old one with you so you get the right physical size, and amperage.
Does your flasher freeze ONLY when the audio system is on?
Is this a standard typical audio system, or some big amperage drawing mega monster?
Doe your flasher only have problems when the engine is at low speed idling? If you put in neutral and rev up the engine so the alternator is putting out more power, does the flasher freezing go away?
im just pushing a total of 620 rms. one amp is a 60 amp and the other amp is a 50 amp.
"Doe your flasher only have problems when the engine is at low speed idling?"
- they still freeze at high speeds, even on the freeway.
"If you put in neutral and rev up the engine so the alternator is putting out more power, does the flasher freezing go away?"
- havnt tried this yet. i will today. it usually freezes when im on the road driving normally.
If it IS, then we're done. If it ISN'T, then we'll check some other things.
I don't want to get you diverted.
Are you in the U.S.?
FYI .It started as an intermittant problem, that got progressively worse, but now it no longer works at all.
From a door lock perspective, all 4 of the door lock motors are wired together, so when one of them is turned on they should all turn on. The fact that only 3 out of 4 work, tells us that either that door lock motor is bad in the drivers door, or the wiring to it is bad. So I would start there first in trying to figure out this problem.
The door lock motors are DC, so if voltage is applied one way it will lock, when applied the other way they will unlock. The two wires that go to the door lock motors, are controlled by the transistorized door lock control relay. That door lock control will put either:
a.) +13 on one line, Grnd on the other line, which will lock the doors, or
b.) Grnd on one line, +13v on the other line, which will unlock the doors, or
c.) Grnd on both lines, which will do nothing.
Start first by unplugging the drivers side door lock, and apply battery voltage directly to the locking motor to lock and unlock it. I suspect the door lock motor will be fine, but you need to verify that the motor works fine and it's not the problem. Then with a voltmeter, check the drivers side plug to see if the socket is getting voltage from the door lock control..... when you turn the passenger lock switch up and down. If the connector isn't getting voltage, then you'll need to trace the wiring back thru the door jamb. You should try it by probing across the connector, but then also probe it from one leg of the connector to ground, and then the other leg of the connector to ground.
Also observe what voltage the door lock control is putting out when it is telling the motors to lock or unlock. Want to make sure you don't have a bad control relay.
Please also verify that the 10A Gauge fuse is good.
Tell me what you find/conclude.
i was in drive through and i put the gear into "park" and the engine just died (E brake was down). i started the car right back up and it was running good. but when i put it into park again it did the same thing; it did this 2 or 3 times that night. this morning i tried putting it into drive then park it didnt die.
this mechanic told me he can clean out the "idle", something like that. its by the starter. any clues? thanks.
does it have anything to do with the idle being dirty? also i have a small tear on this big black hose, its on the right side of the engine. i should cover that up wit electric tape right?
Are you talking about the IAC, Idle Air Control valve?
Idle Air Control valave, what does this look like? what is it for?
and their is a black hose connected to it right? well their is a slice/hole on the hose. i covered it with electric tape. good idea or what?
With the underhood engine temperatures and moisture, it should harden better than the hose was brand new.
If you find that this doesn't hold and you have problems with your vehicle, or you get 'stuck' somewhere, then you can always take the gum off and re-chew it. After the tow home or to the repair garage, then have them replace the hose like you should have done in the first place.
can this be the reason why my car died when putting my gear to drive to park?
I don't know which hose you are talking about, but you can be assured, that if there was any way that the hose "wasn't needed", Toyota would have found a way to get rid of it long ago. This is from kiawah's post #717.
I'd say kiawah is on your page. You've asked for advice and the advice you've gotten is to replace the hose. I'd take that advice if I were you.
