andy
i had the exact same problem, just remember to put the big round rubber caps back on when you are finished
It could also be that the socket is burnt out. Make a visual inspection and replace it if necessary. It seems to be a common occurrence.
HTH
hope that works for you.
while we are on the topic of warranty and repairs, i have a 2001 GL with 65,000 km with extended warranty going to expire next september. Is there any way i can have them fix/replace any potential problem before it happen
on my 98 olds i had some old tires and it was LOUD, 2 years ago i installed michelin hydroedge and the noiz cut down by half.
or you can close the window next time
Ohh.. i also sell auto parts for a living and i can tell you stick with GM
stay away from hyunday dewoo kia any import that has a timing belt that you need to change every 40k to 60k if not say bye bye you your heads. and i sold a lot of those. and also how they say that American cars suck and asian cars rule. from selling parts i know that when people buy a car to go to church they buy a honda and etc.. but when they want to go to work they buy american, well guess what car is going to last longer. yea so BUY GM
Good idea!
Anyone have any thoughts on why a part like this needs to be replaced so early in a car's life?
I recommend new headlight. and all your troublr Bgone.
I don't think auto parts stores carry this part. Try gmpartsdirect.com or a dealer. It's cheaper to buy it online.
Confirm it is the socket first. Take a look and if you notice a "burned" residue on the connectors, you need to replace the socket. It will take you about 5 minutes to replace the part.
It's not just intigue with this, the intermediate shaft applies to most mid size GM's
Typical poorly designed GM "Aftermarket OE parts" :
>Intermediate shafts
>Alternaters
>ABS sensors
>Wheel bearings
>Blower motor ballast resistors
>Door/dome light switches
>Rotors
>Ignition key switchs
>Fuel pumps
>Power window regulators/motors
Small sample of parts that GM commissions for their cars. The bean counters only care if they make it through the warranty period.
So many people wonder why Delphi has declared bankruptcy and why Gm is not looking so smooth either. People are fed up.
Sorry, rant over.
sockets were faulty. I went through 6-8 bulbs in several weeks. Since we replaced
the sockets.....no problems at all. Cut the wires near the old socket(s) and tie into new ones.
Here are the facts:
Engine shut down (Olds 98 GL, 150k km, 3800 engine), all dashboard lights are on. There were no bumps on the road. Happened a couple of times.
Sometime when taken from park to drive and release the brake, I hear calipers release (click), and ABS comes on. If I shut down and restart (no problems to restart), ABS resets.
Engine shut down happens during full speed or just slow crawl in the traffic.
3 years ago the same happened, ignition switch was replaced, never had problems till now. No fault code was stored back then. I was told then that heavy keys would do that slowly to the switch, as these switches are not designed for heavy loads, opposed to column switches that are more robust. But I was careful and only had remote on my key chain, could it be a switch again?
Some more puzzled things: few days ago my rear window all of the sudden started working. I traced the problem few months ago to the seized motor, but never did anything to it. Now it works. The same day it started working, for the first time engine shut down. I presume this was coincidence. It has been raining for three days, wet weather could also be a factor I presume.
So again, could it be ignition switch? Any other possibilities?
Thanks in advance.
I guess I should get a Chiltons at this point.
Do a search on this forum. It even shows what bulb size you need.
>Intermediate shafts
>Alternators
>ABS sensors
>Wheel bearings
>Rotors
>Ignition key switches
>Fuel pumps
Good Grief!! Well from this list I have replaced the intermediate shaft, ABS Sensor, rotors, ignition key switch. Friday I will have the dealer look into why the engine shuts down during operation. Someone here said it maybe a crankshaft sensor, someone else suggested it might be a fuel pump.
I also need to have them replace the blower motor ballast, the HVAC only works on the highest setting.
I hate the fact that 99% of the time I am posting I seem to be ranting about my car. When things are running fine, I do love the car, and I would really like to keep it as long as I can. I just hope the car does not put me in the poorhouse with repairs before I pay it off.
does it look like?
If it's the 3.8 you have - I can post instructions. It takes all of 5 minutes to change. I don't know about the shorstar.
