Traction control runs off the ABS monitors and watches for wheel speed variances ... it only intrudes when a wheel starts to spin ... I notice it in the winter in slippery conditions, and occassionaly in the summer in wet or sandy/gravel conditions. There is no penalty for having it on.
I really learned to appreciate it last fall at the Bragg-Smith Advanced Driving School. http://www.bragg-smith.com/home.html
Bottom line is they are giving you something that you pretty much already had. Pretty sporty of them, don't you think?
Limited slip differentials have the planetary gears that don't spin freely, thereby limiting the maximum spin ratio between the two sides to some ratio less than 1:0 (say .75:.25). (A spin ratio of 1:0 would be one side spining 1 rotation to the other side spining 0 rotations.) This way you are guaranteed that the most the slipping side will spin is .75 rotations to every .25 rotations of the side with traction (or 3 spins to every one spin of the other side). Such a system is passive.
Locking differentials cause the planetary gears to lock up with some "centrifugal" mechanism when the slip ratio exceeds a certain amount (let's say .75:.25), at which point the transfer ratio then locks into .5:.5 (equal spin on both sides). Because one side has traction and the other side does not, even though the wheels start spinning at the same speed when locking kicks in, the locking mechanism is kept active because of torque difference between the side with traction and the side without. The side with traction would be experiencing a lot of torque whereas the side without traction would be experiencing a very small amount of torque. When traction is fully restored to both sides, the torque difference becomes zero, and the locking mechanism is released. This is how the system shifts from .75:.25 slip to .5:.5 (locked) to .5:.5 (unlocked) automatically. Such a system is a mechanically controlled active system, and doesn't rely on a computer and electronic sensors.
This is how the locking differential works on the TB/Envoy/Bravada.
The number you posted is Chevy, do you know the number for Olds?
thanks,
bob
jim f
No one is leasing and that has always been a significant part of every dealer's business.
Interesting how just a few weeks ago, everyone was paying close to MSRP.
I recently picked up my TB after having a witring harness replaced and some wiring taped with nickel plated taping. Soon after leaving I discovered my right turn signal didn't work. When I got home I found the fuse was blown. I replaced it but the new ones kept blowing out. Another trip to the dealer (that's 3 now but who's counting) and the mechanic fixed it by moving the wiring behind the compartment on the right side cargo area. Just wanted to let everyone know in case they run into a similar problem.
The first thing you do is set a purchase price. On these vehicles I talked them down to $100.00 over factory invoice in no time flat (Try even getting close to invoice on a BMW or a Lexus).
Next you work on the lease itself. You can get pre-approved with GMAC online before you even go. If you have good credit don't even think about letting them charge you the security deposit. From my dealings the residual value and money factor are the hardest things to negotiate. If you know what rates are and normal residual ratings are you can quickly see if they are trying to play games. www.alg.com has a great program you can download that gives you pretty accurate depreciation rates on ALL new cars (including the 2002s)
By the way, has anyone had a problem with the interior door handle escutcheon? I noticed this morning that the one on the front passenger door was coming off. It snapped back into place but not very securely. Another item for my punch list.
Has anyone noticed how people stare out you in this vehicle, especially Tahoe and Yukon owners. I love that the vehicle is much taller than the old ones.
zeen : Perception is reality and for many people, they think it's better coming from Mercedes or Lexus even though they aren't even real trucks.
Saw a 2002 Explorer up close today. Not attractive at all. I like the old one better even though it is smaller. I think Ford blew it. Trailblazer and Pathfinder are both far more attractive to me.
So when he drove home in a 2002 Explorer it gave me a chance to look at it very closely.
You are absolutely right it's not attractive, and it's not "evolutionary" as Ford puts it. In fact when it comes to looks it has regressed. Ford did a better job with the new Escape.
As much as Motor Trend boasted about the new Explorer having a third seat. I got into the third seat and needed help getting out. The third seat is for kids - adults should avoid it. It also is not padded very well. Which means shorts trips only. I think GM was smart in waiting to add the all so popular third seat until next year when the extended versions are coming out. I still think third seats belong in Vans. Easier to get in and out of.
Also remember that the lease example is based on the MSRP of $35,127 which makes the figures seem high until you start negotiating the price, and try to deal up from the invoice instead of down from the sticker. If you were planning to give them $3000 that would help even more.
Here's what I did today. I priced an Envoy SLE at $29500 (invoice plus $300). I would put down $4000 and the lease price the dealer came up with was $404 before tax. I ran the numbers with an estimated $17000 residual and 7% lease factor and came up with a payment of $365 before tax. That seems awfully low. Using your numbers with the less expensive Envoy, if I reduced your price by almost $4000, that would be about $120 off your monthly payment bringing it down to $330? Does that make sense? What would you expect to pay monthly with your $3500 down and a price of $29500?
Thanks again for your help
Gm seems to be havings problems with their panel fit. In fact, with every new vehicle that GM produces the gaps appear to get larger.
The gap between the lower front fender and the lower leading edge of the passenger side front door was so large that i could stick my index finger in a few inches. No exxageration!
The gap on the driver's side was not as large. The gaps between the doors are way too big also.
This is absurd.
By the way I have to comment on your "check out your states laws...". Why are people so eager for government to take control of their lives? GM does not sell these vehicles, they are sold by their respective companies. Why would a government care what different car companies give on their vehicles? Does that mean that since power windows are standard they should be standard in every car a company sells. Lets get away from having an all powerful government and take responsibility for ourselves. If you don't like a vehicle because another has a better warranty, buy the other vehicle!
Unfortunately, I'm not quite sure how to figure out a lease by myself even though I know the lease rate and the residual value of the Bravada after 3 years. The way I figure how much a lease would cost is if I have a printed example of one and apply the formula that my salesman told me. I
think the difference between a 12,000 mile and a 15,000 mile lease is $12-15 a month. $365 a month
plus tax with $4000 down seems to be about right to me personally even though the difference in price between yours and mine is way off if you use that dealers' lease formula. Actually, I priced an Envoy that was about $300 less than the Bravada and my saleman used the same terms that I gave him. His company owns a GMC dealership across town so he had their finance lady plug in the numbers in their computer with the current lease rate. What she came up with was $580 a month including tax, which is obviously way too much. I did that before I found the Bravada leases on the Olds website, and when I showed it to my salesman he ran the numbers and came up with far better terms than the GMC based on the example I gave him. He doesn't sell Oldsmobiles but his company also owns an Olds dealer in another city so he had the sales manager there run the lease through his computer and he got the same terms. The only thing my salesman could think of was that maybe the Bravada had a better residual than the Envoy and that Olds was putting some money into the lease because it was so expensive at first. Whatever the case maybe you should try to price a Bravada next and compare it to the Envoy monthly payment that your salesman gave you. If there's not much difference then perhaps you should get the Bravada because for whatever reasons the Bravada lease turned out to be much more affordable for me. It amazes me why the Envoy is so much more costly per month, but then again GM does work in mysterious ways.
1. The body fit on the panels is the worst of any American SUV manufacturer. I could easily stick my index finger in the gaps around the right front door. Quality control appears to be nonexistent. Ford and Jeep build their vehicles to a much stricter tolerance and it shows. I also looked at a Toyota Highlander on his lot, what a difference.
2. The 1SH package has a 4.10 axle ratio which cannot be substituted with the 3.42 or 3.73 gears which are more fuel efficient. It would make sense to offer options with the price of gas moving higher daily.
3. The 1SH package also contains the load leveling suspension which seemed to sway and lean when I did any type of hard cornering activity at 35 mph or better.
4. The sales person indicated that his Dealership is experiencing difficulty selling new or rebuild new Envoys because of the bad press involved with the recall.
I think prospective buyers should wait a while to see if the fix is effective and what General Motors will do to stimulate sales. The recall problem and the high price of gasoline may require new $ incentatives.
Thank you and God bless you for your comments about government involvement.
If only more people felt the way you do we would be a lot better off.
Re: Gas mileage. The 4.10 gear will probably only hurt hwy. mileage by about a gallon. Remember, the tires are very tall on these SUV's.
If it were a camaro with 4.10's the gas mileage would be horrible, but the tires on the triplets are much taller than those on a passenger car.
I checked the Bravada lease numbers at the Bravada web site. My only questions is what price are those figures based on? It is not clear that they are using the MSRP as the purchase price. They may be using something in between invoice and MSRP. Did your experience indicate that the MSRP was the price used on the Bravada site?
You guys have been very helpful. Thanks.
I went to Leaseguide and used my purchase price and down payment, the .0028 money factor and the only unknown is residual. Fulmer: Where did you come out on residual?
There was considerable discussion on this board earlier about gaps, and now this latest round finally got me curious. I did a thorough check of my Trailblazer this morning, and certainly didn't find the size of the gaps offensive. I guess I would have to see some other makes to decide how much better they might have been. I can assure you I could't fit even my little finger in any of the gaps. In fact, I wouldn't be able to fit my index finger in the total gaps (both front and rear combined) surrounding the front doors. And I don't have fat fingers.
I then went one step further, and measured the differences in size between corresponding left side & right side gaps, including the hood. The biggest difference I could find was .031 (center door gaps), which is about 7 sheets of copy paper or 10 sheets of newsprint. Not exactly a staggering difference. I would venture to say I could probably find that kind of difference even on everyone's favorite benchmark Toyota.
The only thing I can figure is that the big gaps must be one of the extras that come with the more expensive Envoys & Bravadas.
As for gas mileage with the 4:10 gears, I am getting 18-21 average interstate at 65 -75 mph.
In my case the extra performance and torque offset the mpg.
Another thing,I changed oil,and filter yesterday. The owners manual calls for a PF 59 filter. I removed a PF 58. There is a difference inside the filter. No charts available, dealer was closed,so went with the PF59. Oil pressure is the same as before. Overall, I am less than satisfied with the Envoy,but like I stated before I am a real critic.
There is body cladding on the doors and what looks like body cladding on the front fender, which is in fact sheetmetal. The gap on the driver side was acceptable, but the gap on the passenger side was large enough to put my finger in.
I wonder how much snow and mud will pile up in there?
Also the gaps on the hood/fender are uneven.
I finally test drove the Trailblazer yesterday. One word: S_W_E_E_T
I can't believe how much more power it has than my 96 blazer. I drove a black Onyx LTZ. What a difference. I want one!
What I need is some convincing from the people on this board that it is a great car and worth the 34,000! A big step up!
Any feedback would be greatly appreciated.
Plus, any info on what you paid for an LTZ. with no options would be very helpful. When talking with the salesman, he said they would be in the '500 over invoice' range (didn't even ask, didn't even want to talk about money at this point).
