Not only have I never encountered a problem, from everything I have read about synthetics, I am pretty sure it is a good thing to do, the sooner the better..
Especially so if you have already decided to use syn oil.
Todd
How do you change the oil without taking the cap off?
This is the reason for a PCV valve, or whatever these things have in place of it.
This allows the engine to burn off fuel/fuel residue, etc.
Short trips don't allow the burn-off to occur, which is the likely case here.
That was not a very nice comment to a person that has gone to the lenght of checking things out that this person has. Lighten up! SNOKING
Elevatorguy- I do change my own oil and I have never smelled gas odor from the oil in the crankcase. I have heard stories of transmission fluid getting mixed with the crankcase on some older GM models with higher mileage, but never gas or gas odor from the crankcase. Let us know if you find the cause as this would be very educational for all the forum. I agree with Scott that short trips might cause a small odor (regarding the vehicle with 14 miles on it, the dealers sometimes crank the vehicles for a short time period while they are sitting ont he lot). Maybe you smelled the odor shortly after the vehicle was cranked for a short time period. Perhaps the varaible valve timing is off on your model. I guess I have one of the better TB's, though I have noticed the transmission forum has started up some activity.
-gmfan
I thought your question was in reference to elevatorguy's '03 TB. In any case, carry on!
Anyone running these snow tires. Thinking about them for the winter on the Rainier. Seems to be about the only 255/60R17 I can find that is studable. SNOKING
It has a new fan clutch (had a check engine light) and has also had the TSB reprogram of the PCM to increase fan utilization. (Now it runs in the 220--225 range instead of the 230-235 range.) I am told "they all run like that". Well, maybe so, but my other vehicles don't and I don't like seeing the temp fluctuate like that. AC would be nice too. Otherwise truck is great.
Any experiences appreciated, or am I just being too picky?
Wxman
After 7 months and 7,000 miles of use, I like the tires. They hold the road better (no squeal around corners) and go smoothly down the highway. The Michelins were better in the snow, but the Pirellis did fine this past winter (a heavy New Hampshire winter). The tread, as of yet, is not showing any signs of wear.
It did take alot of balance weights to balance the Pirelli tires, but so far so good.
My Envoy has had the Stabilizer Link bushings replaced twice -- at 25,840 under warranty and recently at 47,100 miles, not under warranty. My dealership was charging 188.00 to replace the bushings. A call to GMC customer care resulted in the bill being cut in half. Next time the bushings need to be replaced, I will look for other sources than GM service/parts.
Might try some Royal Purple "Purple Ice" to see if that will lower your operating temp. Quote: "It is formulated to reduce the surface tension of the coolant, which improves heat transfer through the cooling system". You have excellent conditions to test it!
But for what it's worth, I have the 4.2L I-6 and I live in San Diego. Even in 90 degree heat (which isn't very often here) it stays pretty consistantly at 210 deg.
As for the A/C issue, I did notice that when it was around 90 outside, the A/C didn't quite work as well at low speeds. I've never seen that happen in my last 5 GM vehicles. In fact, I really think GM makes one of the best A/C systems out there. Is there a clutch on the compressor pulley that is slipping too much? Seems like that would cause it.
No Purple Ice, but it does already have "Redline Water Wetter" added, another surface tension breaker.
Wxman
Wxman
This link show what I done to fill the gap:
Filled gap between radiator and condensor
Close up
I also added some aluminized bubble wrap insulation to the top of the accumulator
Insulated accumulator top
and insulated the long suction line on the I6. I haven't looked at the 5.3 setup so don't know if a signicant amount of line is exposed.
Insulated long suction line
I don't have an A-B comparison to tell you if the above helped. Plus I don't drive much city traffic BUT I do live in Arizona. The gap, in particular, would affect low speed airflow which is predominently from the engine fan.
Wxman
Just got back, checked it out with a digital thermometer in the center vent. Outside ambient air was about 90° with fairly high humidity 63° dew point, interior was about 113° at start-up, within 2 min down to 60°, by the time I got home (about 15 min) blowing 43-45° air out of the center vent. That's with it in Recirculate mode, fan speed on 3.
I am experiencing an issue with my 02 Trailblazer where the blower fan for the A/C does not work in fan speeds 1, 2 and 3, speeds 4 and 5 work fine. When I switch it to positions 1- 3 the compressor kicks in but the blower does not work. I experienced this in my 99 Malibu and it was sort of resistor that needed replacement. Has anyone experienced this and if so how did you fix it. I noticed this started happening today after the dealership changed my oil, any chance something got reprogrammed or unplugged? Where do I start ?
:sick:
The resistor is a printed circuit type and if it overheats, will burn out one of the legs.
I repaired mine with some copper wire, bridging the burned out area and all was well.
I doubt it was oil-change related, just luck of the draw.
Paul P
Thank you for your reply...since you repaired yours, could you guide me through it? If I remove the glove box door, how do I recognize the part and how do I repir it? Can I just buy it new and replace it? Any help would be greatly appreciated, and any guidence would be eternally appreciated
Joe
Also if you are so unhappy with what you are getting than why are you buying it? Feel free to buy one of those 12,000 dollar toys. If you are this unhappy before you buy than I'm sure you will end up being more unhappy later, and then every little problem you have (if any) you will blow way out of wack because you are an unhappy buyer.
When you pull the resistor out, if you are familiar with printed circuits and it is burnt out, you can figure out how to fix it by jumpering the burned spot with a piece of wire and some solder.
Be aware, there is also an auxilary resistor in the circuit. You'll need to troubleshoot to see which one is truly bad.
This one is the most logical and easiest to access.
Paul P">
I got an email from tblazed yesterday and I ended up replacing the circuit, easy job took 10 minutes and cost me $23.00 for the part, saved me a few hundred probably. The whole printed circuit was black, it burn out somewhere and it wasnt gonna be easy to figure out, a new one did the trick Thanks again for all your help and to anyone who helped.
Joe
Happy car again
GAM
