I'm ordering the PIAA Xtreme White Plus bulbs for both high and low beams today and will be looking into the other bulbs too.
tim
-mike
I'm not sure of the travel on an explorer, but I wouldn't go showing that pic around saying "look at my wheel travel" those are tiny little ramps! Try stacking 2 or 3 of those ramps up
-mike
I hear you....and would agree, except, I've seen them installed on a vehicle and when next to my TB, they are much whiter and much brighter.
The Xtreme White Plus are stock Watts so they won't run hot and look just like the HID's on the new Acura TL that I also compared them too.
I'll have pics and comments in a few weeks
GE Bulb # 880 a real common bulb in case anyone is looking to replace them.
tim
-mike
A good example why we SHOULD have complete access to the TSBs- One of the bulletins I did get printed "On-Board Diagnostic Improvements ... #01-06-04-052" Reading JUST the 1st line one may easily conclude that this would apply to all of the triplets. However in the actual text of the bulletin specific VIN breakpoints are noted. I quickly determined that this DOES NOT APPLY to my TB. No time wasted by either me or the dealer checking to see if it applies.
-mike
Tim, keep up the good work and website.
Give me some time on this one, like I said, I got an idea.
Mark
The car was towed to a nearby Chevy dealership where the mechanic that fixed it told me that he had never seen one come loose and that he did not think it was possible for the screw to loosen and come off by itself.
-mike
-mike
That depends on what part of NY you live in! :-)
tidester
SUVs
-mike
I tried a set of 80/100w in my GTP but had to replace them after the first set of wires melted due to the higher voltage.
As far as the beam...the reflectors on the TB are just like my GTP. Didn't loose any width there so I'm assuming the TB will be the same. We'll see though.
I'll have pics shortly.
tim
"they couldn't hold a candle to the 80/100w bulbs from Phillips and Hella "
Anyone with info, please email me or post.
tim
Medowlark, I don't know what to tell you. If you're past the cutoff it must be something else. FWIW I don't think my problem has anything to do with the fans either.
I haven't taken my concern to the dealer yet because it is so random. However, the other day the baffles randomly transferred air flow to the windshield vents when I had the controls set for the dash vents.
My fan has never actuated as far as I know, yet I have this delay before acceleration (when the vehicle is cold - only). I think that is exactly what Iexplorer2000 has as well.
Black gasket around license plate panel is good looking and should stop popping noise when panel heats up and expands and chips paint.. This is good.
Software was upgraded to address hesitation on cold startup. We'll see.
Brakes were mushy. they still are, service manager said other TB's were the same. Either I'll adjust to new feel or something (TSB) will come later.
By the way, dealer appreciated the TSB's I presented him with.
GM drone: Thanks for the follow up and future plan. I just hope you don't turn out to be a 13 year old with too much time and not enough cable tv channels.
Frank
Mike
This is already the most troublesome vehicle I have ever owned (new or used)since I bought my first car in 1979. I have talked to 4 other triplet owners and every one has had problems (beyond the chipping tailgate gasket). Those of you with no problems should consider yourself lucky. Those thinking of buying a new one should probably think twice.
GAM2
less than 5k and you're in great shape for a buyback.
if anything....argue that you want the regional rep from GM (Olds) to put in writing that any related damages resulting from this issue are not to be seen as your fault.
not sure exactly what to state, but make sure that you get something noted officially about the part on back order. at least I'd want something.
or as I'd see it, put down that there is a serious concern for saftey as something bad happening with the drive train could happen resulting in an ugly suite.
just my pistols firing. tim
Thanks for any help you can give me. I would rather not screw up the Envoy by taking off panels I don't need to mess with
There's a 4-wire harness attached to a large harness under the dash to the left side of the steering column. Remove the lower fascia, 2 vertical facing screws on a Trailblazer, the wires have a white tag wrapped around them and is taped to the the larger harness. Tim
If that doesn't work, use the following resources:
Better Business Bureau
Regional consumer affairs
Bureau of automotive repair and saftey (Washington)
I've had to go down this path before, everyone of these agencies require the dealer to provide (in writing) a response to your complaint and goes on a formal record (which dealers don't like). The Org. in Washington can revoke their license or initiate a recall if they feel it's warrented. If your dealer doesn't seem interested in finding a solution for you, make sure he knows what your next steps will be.
If you have a valid case and the B. of automotive repair and saftey get involved, believe me the dealer will be more than happy to satisfy you
I live in Wisconsin. The lemon law here says 4 fixes for the same problem or 30 days out of service in the first year. That's one reason I don't want to turn in the rental. They would say I have my vehicle even though it hasn't been fixed. Another is I don't want to further damage the drivetrain, even if it is unlikely I would do so. Plus having my vehcle gives them little incentive to get the parts quickly. If GM is paying the tab for a rental, maybe it will speed up the process. Don't get me wrong, I like the vehicle (obvious or I wouldn't have bought it).
It's just that I expected some level of quality for a $35,000 vehicle. The rental car I'm driving (a 15,000 mile Prism) is pretty much flawless. And GM wonders why Honda is selling many new Pilots sight and price unseen......
GAM2
That TSB http://www.timlauro.com/cars/trailblazer/pdfs/fan-tranny-power-tsb-831229.pdf isn't just about fan noise (although that's one of the things it's supposed to fix). There are a couple of things in the old programming that could hinder acceleration:
First is the delayed transmission downshift. I've noticed this mainly at slow speeds. Say you're stuck in a lane going 10 MPH (probably in 3rd gear) and the lane next to you has cars cruising by at 50. If you want to pull out into that lane you need to get up to speed fast. When you put your foot to the floor, it takes longer than it should to kick down into the appropriate gear slowing your acceleration....
The second is the mention that a symtom might be a "Cam Phaser Performance" code set in the PCM. That has to do with the variable valve timing. If the variable valve timing is calibrated incorrectly or simply not working right, power will suffer somewhere in the RPM range. In my case, I'm HOPING this is my problem. My engine feels plenty strong at high RPM but it feels weak at low RPM compared with the dealer demo I drove for a few days before I bought mine (it had the same axle ratio, etc).
That's a lot of conjecture on my part but it seems to make sense. Either way I'll find out tomorrow if the TSB works the way I'm hoping it will.
Since yours is past the VIN cutoff, it should have the new programming and this TSB shouldn't apply. But that doesn't mean that everything is working perfectly on your vehicle.... Have they scanned the PCM for codes? When they do, they might as well notice if the PCM was programmed after August 2001 or not.
If your transfer case is locking in the front driveshaft, the wear and tear on your entire drivetrain will increase probably 10-fold, maybe more. My dealer even warned me not to use A4WD on dry pavement (although it should be OK) right after we drove around and felt it binding (he didn't realize it was binding because of the wheelspeed sensor). You might not break anything this week, but when a CV joint goes out 1 day after the warrantee expires, you'll know what caused the premature wear. Tell them that is unacceptable. Tell them you're worried about the wear this has caused already.... I don't know what else to say....
Both medolark and myself are suffering from the delayed acceleration problem. According the TSB issued, I really don't think that it applies to our vehicles. I am not experiencing any issues related to transmission shifting patterns. Actually, she's getting better and better everyday in simulating my driving habits. Surprisingly, it seems as if my tranny has a direct link to my brain. It will usually downshift without much effort on my part at all and usually when I want it to downshift as well.
My vehicle was manufactured on 10/02 (I don't know medolark's build date) and I think that it has all of the revamped tranny updates applied.
I am in Columbus, OH for the next several days (getting my father's Denali rustproofed) and today I had the pleasure of driving my good friend's new Envoy for several hours. I quickly noticed that he does not have the delayed acceleration problem that a few of us are experiencing, I will try it again in the morning just to be sure? His unit has a build date of 12/02 and he has roughly 2,000K on the odometer? Oddly enough, he showed me where the expansion/contraction of the license plate housing started to chip a large portion of his paint! During the viewing, we were quickly greeted by a loud "CRRAACK," the housing was expanding right before my very eyes! I was amazed at the damage that it caused. Fortunately, I often check the back of my Envoy and I must be one of the lucky few that does not have the housing on too tight because I have no paint damage and no cracking or popping?
Unfortunately, I do not have an answer yet as to what the dealer was able to find concerning my delayed acceleration problem. Can you believe that they have had my vehicle for a total of 4 days and it's not ready yet?? I didn't give them anything too complex to repair, just a few of the TSB's, door panel rattle, squeaky drivers seat and the cold acceleration problem? I guess that just goes to show that not every service department is the same. I think that this new dealership where I had taken my Envoy focuses on "customer service" (even with a GM paid loaner car in use) and prefer to get everything corrected the first time. Actually, I contacted the dealership today in order to get an update and he had mentioned that they were awaiting several parts to arrive.
I will keep you all posted.. Also, I am having my dad take the gasket that I purchased over to the dealership for installation in the morning. After looking at my friends Envoy, I decided that I had better not risk any damage. Better safe than sorry I guess!
IExplore2000@aol.com
The difference is pretty noticable when driving. Nice to see white as white now. Don't get me wrong, the stock bulbs were great and the new ones aren't any more powerfull as I didn't want to risk the heat issues higher watt bulbs bring or have people flashing me, but the light is whiter.
They look great, and of course....absolutely NO BLUE Tint (these are not the punk kid blue lights you may see around imitating HID Lights) Thanks to Dennis D aka iexplore2000 for the help.
Now if I can find some nicer fog lights....883 37watts are what I'm after.
Check it all out here:
http://www.timlauro.com/cars/trailblazer/piaa-headlight-stuff/piaa-mod.htm
The TB's on the lots here had a $3000 dealer markup (or "Northwest Market Adjustment" as they called it) on the stickers over and above MSRP--bringing the total for a fully loaded one right to $40K.... I went through GMbuypower.com and thought I did well to get around $2500 under MSRP. There weren't any rebates at the time but they had the 0% financing, etc.
Are you trading something in? If so, you've only won half the battle....
Mike
The dealer on the otherhand is terrible. I called about the rear gasket TSB. Mine does not have the gasket, however the paint isn't chipping either. They seemed really annoyed that I even had TSB numbers.
Anyway, I asked if they could order the $5.00 part before I brough the truck in. They totally refused. Saying that they have to look at the truck before the can order it. I told them I would be right down. But that didn;t work for them either - too busy they said. So as of now I have an appopintment in 2 weeks for them to look at the truck then order the part, then schedule another appointment to have the gasket installed.
I spoke to the sales manager, I even offered to buy it from gmpartsdirect and bring it to them.
Overall I am very pleased with the truck - the ride - the looks - the power. Just hope it lasts.
