Mazda MPV
1259260261263265
  • mityfleamityflea Posts: 1
    I DO know that the same like vehicle (Toyota or Honda) with 120K miles on it would not have these conditions. I should have spent the extra $5K at the time and went that route! Good luck! TCC
    Really? Are you sure about that? I've had a 2001 Honda Odyssey needing a new transmission twice already. Turns out that Honda installed defective transmissions on the Odyssey from 1999-2004. The Acura CL, TL, MDX and Honda Accord suffered similar problems. The Third Generation Odyssey hasn't reported major transmission issues in case you're wondering. I've heard a rumor that it shares it's transmission with the Ridgeline. As for the Second Generation Sienna, it's had quite a few problems too. From electrical problems, to door spot welds constantly breaking. So if you think buying a Toyota or Honda is anymore troube free, think again. I personally would trade my $4500 transmission troubles for all of your minor problems any day.
  • tcc21tcc21 Posts: 69
    Well, maybe there are a few bad apples out there with the Honda emblem on them....but I know of a person who owns a 2003 and they love it and my sister has a 2004 Sienna and it is very solid after 160K miles on it. Maybe I should have only mentioned Toyotas are better in the long run. I know the Blue Book on both Hondas and Toyotas are stronger in the long run than Mazdas! My 2003 MPV with 122K on it in excellent shape is around 7K dollars. The similar Sienna is worth more! Sorry if I mispoke for those of you having troubles with your Hondas. I know there are more bad apples with Mazda on them out there....I could go on about the Mazda 6's from 2003 -2006 - people I know that had those vehicles were not real happy.
  • sm00vesm00ve Posts: 1
    I only have one pet peeve with her. I can't find a manual for the van. NO one seems to carry one, internet or otherwise. The van is 5 years old, so surely someone should've taken one of these apart by now and wrote some notes or something. Haynes & Chiltons are starting to dissapoint me greatly...
  • linda424linda424 Posts: 1
    I just took our 2002 mpv into the dealer to get checked out because we had a loud noise near the catalytic converter...it was the flex exhaust pipe.The dealer put it on the "scope" to check for any other problems...he said there was none. 3 days later the van was running horrible..bouncing and erratic rpms...we had the exhaust hose replaced...much quieter but now engine light is on and it seems to have some sort of misfire....when the rpms get really low the breaks seem to harden and its hard to stop unless you go to the floor with the pedal. Shouldn't the dealer have noticed the brakes....they did have the tires off when we went to pick it up...not sure why, if there is a brake problem. Is it still safe to drive with the engine light flashing on and off until I can get back to the dealer? Van was fine until we got to the dealer...
  • aa0526aa0526 Posts: 29
    We bought ours NEW in July 2002.
    We have the 3.0 v6.
    Here is a list of things that have been repaired the last 7 years.
    1. IAC valve - replaced part of TSB recall 2005
    2. IAC valve - replaced again in 12/2008 after CEL came on.
    3. Mass Air Flow sensor - cleaned in 5/2008 after CEL came on
    4. Mass Air Flow sensor - replaced in 10/2008 after CEL came on
    Other than that - there's been no problems.
    BTW - the hardest part is diagnosing these things ---- some mechanics just make guesses ... others are more knowledgeable than others. I used an independent mechanic for items 2 -4. I had to 'help' them understand the problem by giving a detailed history and telling them what I have heard from this board. True enough ---- I was right!
    He initially wanted to replace either the O2 sensors or the coils.
    Right now - my MPV is in the shop ---- the fan is not working causing the engine to overheat. But after 124K miles --- and a cross country trip thru 100+ degree weather and wintry blizzards - it is difficult to complain.
    I do change my oil every 6-8K and use synthetic or semi-synthetic.
    What were the engine codes for the CEL?
    My past engine codes have been PO171 and PO173.
    I've had a few more ... but previous experience has been the following:
    1. IAC or EGR valve
    2. Mass Air Flow sensor
    The EGR valve leak produces very rough idling - if not jerky driving.
    The Mass Air Flow Sensor problem (usually either very dirty or worn out) - results in poor acceleration and low HP especially from 3rd gear to 4th and 5th and poor mileage.
    Most mechanics will blame the O2 sensor or any of the coils. They can charge a lot for the labor for these ... so be aware. Read the codes... read the codes ... and research them carefully ... some mechanics are just as naive about these codes as any layperson --- yes, even the newbie mechanics at the dealerships!
    BTW .. just got back from the mechanic ...
    My two fans are not working ... something due to the wiring.
    If the two fans are connected directly - they run perfectly fine.
    The fuses are OK.
    I will bring the van to an electrical shop.
    I had them check the brakes ... after 124K, the brakes are still at 50% !!!
  • rgb2rgb2 Posts: 31
    I bought 04 ES in Jan 05. Loved it last month. Took it in for last oil change and inspection before warranty expired in Dec 08. The "full circle" inspection said everything OK. Then in May I noticed oil stains on the driveway. It's due for an oil change anyway, so I take it to the dealer - and get the "leaking oil pan" and $500 quote to replace it. Since the car has 46K miles only and been regularly maintained at the dealer, I complain. The dealer says will get back to me, and a couple a days later call and says that Mazda will cover 50% of labor and new gasket, but not new oil pan. Take to another shop to double check - they say the front crank seal is also leaking. Go back to dealer, after some haggling he agrees there are 2 leaks. So after a lot of wasted time, energy, and $250 I got a couple of new gaskets and a shaken belief in Mazda reliability and dealer expertise. Still love the MPV but having second thoughts about keeping it for 10 years as I originally planned.
  • jipsterjipster Louisville, KentuckyPosts: 5,505
    Mazda replaced a ignition coil that was under mileage warranty, but a few months over the 48 month warranty, without a hassle. The oil pan problems seems as if it is becoming more prominent lately. We've got a little over 5 years on our MPV... hoping to get 10.
    I had my oil pan gasket replaced for 360 at a local garage I trust. The problem is that the gasket is a METAL one that get's warped and causes the leaking. You can't tighten it since it is warped. Poor design to start with -dah! You'd think that engineers would learn?? Anyway, my new gasket is a different material that conforms to the pan and will not warp under heat. I had a bad leak too and had a mess on my garage floor and the undercarriage area. Good luck! These MPV's are nice when they are working but have many little bugs waiting to bite!
    I have 124K miles on my 2003 - I am the original owner and have gone thru all the fixes thru the years. I do change oil every 3K miles too.
  • lg2207lg2207 Posts: 28
    I would've taken the offer for 50% from Mazda since your out of warranty (IMO)-- to save the headaches of running around- anyway our '02 with 57,000 which is serviced regularly by an independent shop recently had to have the plan replaced- as one member indicated the pan and the gaskets wore out. We needed the new kit which had updated gaskets recommended for this vehicle. It cost us $435 in between the $360 the other member mentioned and the $500 quoted by the dealer. I hear you on Mazda reliability- we have an '07 6S Wagon that has had numerous problems (way more than anything we've had over the past 7 years on the MPV)
    Take Care
  • mcadrechamcadrecha Posts: 46
    Tonight, after returning home and parking the car in the garage, when I turned off my engine, I could not remove the key from the steering column. I can't get the key to rotate all the way back to the off position (it stays on the accessory position). Has anyone ever had this happen before??
    Michael
    Oops, forgot to say I have a 2002 Mazda MPV.
    I have a 2003 MPV with 126K miles on it. Sometimes mine will get stuck for a moment but I jiggle it or shake the steering wheel and it comes around and out. It could be a worn tumbler or worn key too. How many miles on it?
    Other issue for me - I keep having the CHECK ENGINE LIGHT come on and have had it cleared about 10 times - no kidding. The message comes up that my 2nd Bank has a Catalytic problem?? Replace converter? Ugh! Runs fine and no change on mileage for gas. I'm just leaving it for now. They said it would just keep running fine but I would not pass emissions testing if we did that again. Anyone ever have THAT issue with these lovely beasts?!?
    :mad:
  • jdelgjdelg Posts: 1
    I have a 2004 mpv, and I have replaced 4 ignition coils, and the mass air sensor. Everytime it seems to have happened while raining, or just after raining. From what i've seen this is common to the mpv. will this just keep happening? or is the flaw in the original coil, and trouble is cleared with replacing the part. I really can't afford a new van right now, but I'm worried because my wife uses it to drive my young children around. I'm just not trusting it anymore, as it has broken down from this trouble. Anyone relate to this? Any advice? Has anyone ever found a way to waterproof these coil/plugs?
  • I have read that the rear coils generally go out 1st because of the heat, when mine go out I'll replace all 6 at the same time.
    I haven't read much about the MAS and I'm not sure it's related.
    I have a 2003 and it's common. I just let it dry out and it seems find until the next major rain or I wash the engine off. I had it checked a couple times. They said one of the front coils could be replaced - about $200 labor and parts...but I put it off. It runs fine 90% of the time. It's happen since it was new. Drove in a terrible downpour and it started sputtering on the ride home. I just lived with it for a couple days and it dried out. I think it's a combination of the compartment design and what they are. My more major issue is my catalytic converter and it's related sensors. I've had my check engine light come on numerous times due to a 'left front bank #2 issue with a mix/lean cold something. I have it cleared and it pops on about once a month. I will not replace the catalytic converter until the car quits. My mileage contines to be the same - good and it runs smoothly. We'll see. Lot's of crazy things with these MPV's.
    The front coils (#4,5,6) are easy to remove, shouldn't take 10 minutes. You could do it yourself for the price of a $69 coil bought online. The $200 price you speak of probably includes the dealerships diagnostic fee of $99.
    First coil of mine went out in a torrential downpour, the second... not sure... may not have been raining.
  • You can also purchase the coil packs on ebay for $120-185 shipped depending on the manufacturer and both have received good reviews on the MPV forum, they also have a great article on how to do-it-yourself.
    I HAD the same exact symptoms on my 2002 Mazda MPV back at 112K miles.
    I brought it to two different mechanics.
    The problem with OBDII codes is --- they don't really describe the root cause. They describe the problem / general area... which is a good starting point.
    But it is up to the mechanic to further do investigations.
    Anyway - the first mechanic replaced all the plugs, did a change oil etc ... and cleared the codes. The codes did disappear ... only to reappear after 9K miles.
    The second mechanic CLEANED the MAF sensor --- the codes disappeared.
    After 5K, the codes came back - I CLEANED the MAF sensor on my own (with instructions from the mechanic), the codes disappeared. He did tell me that if it appeared one more time, it was time to REPLACE the MAF sensor ... which I did 6 months later.
    The CEL came back again ... but it was for the leak in the PCV valve.
    The CEL come back ON/OFF when I drove at high altitude during a snow storm. It has disappeared and has never come back on again.
  • I experienced a similar problem a few years ago with my 2000 MPV. In my case it was an interlock that interfaces with the ignition switch. In my case the switch would go to the off-lock position if i disconnected the battery. I also note that there is a small cap on the plastic steering column cover above the ignition switch. Te cap should pop out and this should provide access to release the interlock manually and then you should be able to turn off the key. I believe the repair cost was ~$150 at the dealer. Although they originally tried to sell me an ignition switch, they eventually did the honorable thing and just replaced the interlock.
  • buzzkbuzzk Posts: 15
    we had the same problem w/our 2004 MPV; code reader [98 bucks from chain discount store - well worth it!] said it was #1 cylinder [most exposed to rain]; I pulled it, as it can be easily reached, & in my judgement the design was blisteringly stupid; it had a VENT hole, for cryin' out loud!! that is SILLY! - lets rain vapors get in there & short out the spark. I've worked on other, similar systems o&o over the years & they ALWAYS sealed the spark plug well against moisture; I cleaned it & plugged it w/silcone,which stopped the problem. then I got a complete set of new coils off e-bay [cheap] which seal around the raised lip at the top of the plug well in the normal, rational, manner & have not had the problem return. [we love the car but have other problems at this time - will ask abt them in a different blog]. Get new coils which are configured to cover, & seal, the raised lip at the top of each spark plug well. they're a pain to install due have to remove intake manifold, but,w/patience, easily done. it's worth it.
    Cheers, BK
    I've blogged on here in the past too about this issue. Everytime I drive my 2003 in a heavy rain or it sits out in a heavy rain, it has the stumble problem as your's had.
    I too went to a local garage and the replacement would be around $200 plus or minus a few with labor. It is the one in front that has the issue on mine. Sounds like you dug right in and got them all fixed with a better method too. It is just nuts that they had this design on all these MPV's! Common sense was not in their vocabulary among some other things on this vehicle!
    Like trying to change the rear license plate lights, or the headlight on the drivers side or other marker lights in front. Why can you not override the auto dimmer of the inside lights to keep them on?? They turn off after 3 minutes and then you have to shut all the doors and open again to start the time cycle over again - bizarre!
    And a kicker one - up thru 2003 - no auto door lock/unlock button on the passenger door! I've had power locks for 25 years and have always had a button on the passenger door as well as the drivers door in my Chrylser, Chevy, Dodge cars! Ugh!
    I bought a brand new 2001 MPV at your dealer Dufferin Mazda. At the same time, the dealer also sold me at $600 a life time rust protection program. During annual check of last year, the dealer found rust on my car and then point me to the provider of the coating product. Eventually, I got a written letter from the provider after their own check, saying no their product had been applied onto my car.
    The rust protection company was the provider, and they didn't provide the rust protection? They owe you a refund on whatever their take was from the dealership. Sue them in small claims if they do not reimburse you. Permaplate is the party you should go after. Might try calling the BBB as well.
  • I have been deceived by a Mazda dealer for years. I complained the case to Mazda Canada but no response. Second time I started with info request about a book so I built a connection with it, then I asked for help to deal with the dealer. But it quickly turned me off. See the communication between it and me.
    Did any one have similar experience and an idea how to have the dealer to compensate my loss?
    The following is the communication between (in a reverse order); and all email addresses and phone numbers are removed according to the policies here.
    Subject: RE: General Inquiries [INTR:076385]
    Date: Thu, 29 Oct 2009 06:28:00 -0700
    Hello Mr. Jiang,
    Upon reviewing your correspondence, it is regrettable to be informed of your negative experiences with Manpreet Moti. We appreciate any feedback our customers have about Mazda dealerships and we do review each concern carefully with the dealership's Management, however, matters between yourself and the dealership must be resolved with the dealership. We can review your feedback internally, but to have a matter addressed, you will need to address it with the dealership. Further, if your concerns are regarding a dealership which no longer exists, then we are unable to review further, as there is no one to review with, nor can there be any improvements made since the dealership is no longer in existance.
    Should you have any feedback with regards to your current dealings with Yorkdale Dufferin Mazda, we would be pleased to have you share this with us. Our reviews are internal with the dealership and as such, your matters will still need to be addressed directly with the dealership, but we appreciate your feedback.
    Mazda Canada Inc.
    Subject : RE: General Inquiries [INTR:076385]
    Date : Thu, 29 Oct 2009 04:08:23 GMT
    Dear Mr. Mazda,
    I can understand your dealerships are not your subsidiary companies. But are there any regulations to regulate their behaviors especially when come to your consumers?
    I doubt the change of ownership of Dufferin Mazda dealership is just a game to evade its responsibility.
    Why does it continuously check my car every year without notice of this change?
    They promised they would contact the PermaPlate (provider of antirust coating material) and let PermaPlate send a person to my garage to fix the rust when they found the rust. Later, manager Manpreet Moti always said she would contact their person inside PermaPlate to resolve my case. Every time when I finally reached her, she always said 'busy busy' and promised would call me back very soon, even once said within 15 mins, but she never did even once. She asked me all documents and personal info every time but never gave me any words in written.. Moreover she used to suddenly hang up the line claiming I was recording the talk.
    She never responded to my messages and emails. She never picked up my call before my several attempt and hours' waiting on line.
    Do you accept this kind of dealers as your terminal sensors to your customers? Do you acknowledge these fraud and rascal behaviors? Will you still just await there and see how this evolves on?
    Wish you do somethings to protect your image.
    James Jiang
    Date: Tue, 27 Oct 2009 11:19:29 -0700
    Hello Mr. Jiang,
    Unfortunately, we are unable to provide information regarding Dufferin Mazda due to privacy regulations and we are unable to forward your concerns to Dufferin Mazda, as we no longer have any ties with them. Further, please note that Mazda dealerships are independently owned and operated.
    Mazda Canada Inc.
    ---- Original Message ----
    Date : Tue, 27 Oct 2009 17:53:30 GMT
    Thank you, Sir.
    Please provide me some info about your dealer Dufferin Mazda, like owner name, phone number or email, so I can contact him or her. Or forward my message to him or her, let him or her contact me.
    We like this car. We brought life time rust program and life time oil change and maintenance program for the car as well. Please help to solve the case so we could still consider Mazda next choice and recommend to friends.
    James
    Date: Tue, 27 Oct 2009 06:53:49 -0700
    Hello Mr. Jiang,
    It is regrettable to be informed of your situation with the rust protection. Unfortunately, Mazda Canada does not offer any form of additional rust protection or coverage and would not have any information on this. You would have to review with the rust protection company and the Management at Yorkdale Dufferin Mazda. We recommend your direct contact with the General Manager, Mr. Subhojit Das (people call him Das) at XXX-XXX-XXXX, as he would be in the best position to determine if Yorkdale Dufferin Mazda is able to assist you. We can confirm that Yorkdale Dufferin Mazda is under different ownership and Management than Dufferin Mazda and as such, records belonging to Dufferin Mazda are likely unavailable to Yorkdale Dufferin Mazda.
    Mazda Canada Inc.
    Date : Fri, 23 Oct 2009 20:26:28 GMT
    Thank you, sir.
    I will contact them for the book.
    Here is another issue. To simplify it is:
    I brought a brand new 2001 MPV at your dealer Dufferin Mazda. At the same time, the dealer also sold me at $600 a life time rust protection program. During annual check of last year, the dealer found rust on my car and then point me to the provider of the coating product. Eventually, I got a written letter from the provider after their own check, saying no their product had been applied onto my car.
    Now the dealer says that the owner changed and cannot find any records about the application of the product, and refuses to issue any paper as required by the provider, neither do anything to fix the rust.
    Right now, the dealer has a new name Yorkdale Dufferin Mazda. The others are same.
    Can you tell me what should I do and what can you do?
    James Jiang
    Date: Fri, 23 Oct 2009 12:05:35 -0700
    Hello Mr. Jiang,
    To locate your nearest Mazda dealership, please visit: http://mazda.ca/eng/dealers/dealerlocator.asp. Based on the provided postal code, your nearest dealership is Scarboro Mazda. Speak to the Parts Department.
    Mazda Canada Inc.
    Date : Fri, 23 Oct 2009 18:56:43 GMT
    Hello Sir,
    I have attempted several places but nothing found. I am living at M2J (postal code). Can you tell me where (Address and phone number) I can purchase it for my 2001 MPV LX ?
    James Jiang
    we got a full factory shop manual from Mazda when we bought the car. Unlike manuals for our Toyota or our Subaru, the price was reasonable [I think it was abt $100.00 + or - & it's one large book]. VERY detailed, tho occasionally the trouble-shooting sections are not very realistic... but, IMHO [do most of my own work] WELL worth having...
    BTW so far the shift problem was fixed adequately by a software flash done for free by the dealer [after we found out abt it from a private owner - Mazda NEVER notified us!!!!] & the throttle position sensor cut out the engine but didn't give a code on either of my code readers [check engine light stayed OFF] had to use old fashioned reasoning & experimenting to get the hint it was the problem. The truely idiotic spark coil seals, that allow water in the plug well & short out the spark, were replaced by reasonable priced coils I got from ebay that have a [heaven forbid!] normal, rational, effective seal that prevents water entry.. the factory system is so utterly idiotic it beggars the mind.. they actually designed in a VENT!! which, of course allows water & particularly atomized water or steam from hot engine in rainstorm to enter & trash the spark [see my other posts] I'd advise NEVER use OEM coils unless they've improved the design. In any case, good luck!
    Cheers, BK
    A few yrs back I saw quite a lot of issues w/rust in almost of the major automobile brands; at least a major portion of it was caused by DEALERS selling aftermarket so-called corrosion prevention systems [ofetn quite a few hundred dollars - cost the dealer very little, like the upholstery "stain prevention" systems & "pinstriping"] not endorsed -or even desired- by the manufacturers; As I rercall, at one point Honda corp was quite unhappy w/problems caused by this; besidess being often truely un-needed, they also often gunked up the drain chanels all companies put in to prevent water accumulation, CAUSING [dirty?, salty w/road salt?] water retention &, in turn, causing the corrosion they were sold to prevent. Certainly other manufacturers also had this issue. On top of that if such were sold a lot in a given town, it would "prove" rust is a problem in that climate w/many brands of cars, giving a "reason" to sell even more harmful "rust protection." something to think about next some slick talking dealer's salesman tries to sell you a car. - Check w/the manufacturer before buying such garbage.
    Our 2004 MPV appears to have litle if any rust - the chanel in the bottom of the sliding door opening has a rather silly plastic drain plug w/a tiny flap that is easily stopped up to the point of uselessness - easy to remove, once you find it, [front of the chanel] to stop water accumulating & sloshing there... & we have NO aftermarket so-called "corrosion prevention" system..
    Cheers, BK
  • My 2002 MPV has served me well but the miles are high and I'm beginning to look for a replacement. If there were such a thing as a new MPV, I'd buy one in a heartbeat. Since there isn't: What the closest thing to an MPV now? I have tried a Kia Rondo, Toyota Highlander; looked at Mazda5. Nothing comes close yet -- especially in hitting the "sweet spot" for size, utility and flat-floor capability with 2nd row seats removed.
    Suggestions?
    Well, you may try finding a lightly used 20006 MPV.
  • Yeah a 2006 MPV is like a newer and improved MPV and I always see nice 2006 MPV's with 30-40k miles for $7-10k.
