Lincoln LS
1267268270272273299
  • akirbyakirby Member Posts: 8,062
    It's right there on page 24 of the 2000 manual. However, it's wrong. It does not say to press reset first. The instructions for resetting the oil change warning right below it are correct. You are forgiven. :-)
  • haironghairong Member Posts: 153
    Yesterday we had a mild rainy day in SE MI, and my 03 LS's auto AC went crazy! After starting the car, rain had stopped 2-3 hours before, within 5 mins, the outside temp. dropped from normal to -5F, then came back and stayed at 2F! You can imagine the amount of hot air the AC started to blow to me. I had to turn the whole AC (not just Auto) off, and left the windows open in an on/off drizzle. For the next 10 min. the reading stayed around 2F, then it started to climb up slowly. In the next 15 min. it reached 52F and stayed until I got home. That was about 20F below the real outside temp. This morning, everything is back to normal, like nothing had happened.
    My guess is water/moisture must have gotten into something to cause the problem. Then as "it" dries out, it returned to normal. Have you guys had/heard this happening to other LS, a common LS problem? And of course, the next question, should I bring the car to the dealer now, when everthing is normal, or wait for another "rainy" day?
    BTW, this is the 1st time of such problem. It did have other AC related problems before, but not this kind (IP/vent rattle, fan motor noise, bad control unit, etc, all fixed however).
    Nope - that's a new one. Water and electricity don't mix. If it happens again carefully document everything that works or doesn't work. That will help troubleshooting.
    1) Your hypothesis could be exactly right. This happens often after a car wash.
    2) OR, your A/C display could have been throwing a code for some malfunction. May wanna have the dealer check it out.
  • gunnersmategunnersmate Member Posts: 243
    Could be water collecting on the AC compressor and the clutch coil is right there. This sounds like the compressor is shuting off and with water collecting on the clutch coil it could cause the coil to short.
    Thanks guys, for all your helpful input. I don't know about gunners' comment. The AC was working fine before and after that rainy day. I think the compressor was shut off because the outside temperature reading was only "2"F, as in frozen winter morning :) Seems like the AC and control unit were doing what they were supposed to do.
    nvbanker, did you mean you've seen/heard this happen after a car wash? Do you know which part could be the problem, sensor, wire, connector? Like I said, for me it's the first time, I need some pointers here.
    I guess the one positive thing from this is, now I know the answer to this LS trivia, "Does LS have a negative sign '-' on its thermo display?" After all, we haven't seen minus temperature here for several years, let alone driving in it.
  • ezaircon4jcezaircon4jc Member Posts: 793
    Is your wiper "heat" coming on? If not (it's supposed to come on below 40º), I would suspect the control unit.
    Does the external temp sensor control the AC? In the recent episodes I went through it was a result of the compressor not engaging becasue the clutch coil was shorting.
    "nvbanker, did you mean you've seen/heard this happen after a car wash? Do you know which part could be the problem, sensor, wire, connector? Like I said, for me it's the first time, I need some pointers here."
    This happens every time I get the car washed - the water gets on the sensor behind the grille, and cools it way down (which around here can be 50 degrees, but is never going to take it into the cold regions). It slowly compensates back up and for the period of time it thinks the ambient temp is much lower, I get reduced cooling, but not no cooling in this range. The unit considers the outside temp and compensates somewhat. I don't know if that's what happened to you or not, but that's what has happened to me in all of my Ford cars with auto climate.
  • jerrym3jerrym3 Member Posts: 202
    Well, the deal is just too good to pass up.
    MSRP $40,950/pay $30,770 (A-Z plan plus additional $1,000 Ford A-Z plan coupon plus $6,000 Ford cashback.
    Light Tundra Metallic V8 Sport.
    Any words of wisdom?
    Juat have to get the little woman to test drive it to see if she can accept the different ride between her 89 Lincoln Towncar and the 04 LS.
    Should make a nice companion to my 2003 TBird, 94 Tbird, 58 TBird, and 64 Galaxy 500XL convertible.
  • rayainswrayainsw Member Posts: 3,192
    "Light Tundra Metallic V8 Sport.
    Any words of wisdom?"
    Enjoy it!
    - Ray
    '03 LS V8 Sport Autumn Red
    2022 X3 M40i
    hurry before someone else gets it!
    "Should make a nice companion to my 2003 TBird, 94 Tbird, 58 TBird, and 64 Galaxy 500XL convertible."
    Wow, nice stable!!! I had, and restored a 65 Galaxie 500XL myself a few years back!
    The LS will be a totally different ride than the Titanic (89 Town Car) your wife is used to, however, it's so much more fun to drive, she'll likely be fine with it. And it will be the best car you've ever owned.
    Glad to hear that your LS Grin has been reinstalled. I hope it stays that way. Thanks for following up on my request these folks I have been dealing with are total loosers in regards to customer service. I went two weeks without as much as a word about my car. Further, all of my previous communications were a result of my being proactive. I don't expect daily calls but one a week come on is that too much to ask.
    Thanks again for the contact information. I intend to call them today to pass it along.
    Took it for a ride last night. Getting the A-Z plan PIN today and doing the deal tonight.
    Yeah, nothing rides like a Towncar, but neither my wife nor I can take to the recent TC styling. Besides, the only good color for a TC is black, and, around North Jersey, you'd look like an airport limo service driver.
    Even with 145,000 miles, you do not hear or feel suspension travel when our 89 TC hits a sewer plate or pothole. That will take some getting used to. But, I have noticed when taking limo service to the airport, the new TCs handle better (than my 89), but they seem to transmit the bumps more.
    So, the LS it is.
    Thought about the 2004 Marauder that was on the dealer's lot. She didn't like it ("why would I want to ride around in a car that looks like something from Homeland Security"). Does make sense. And,I figure a new LS 8 sould be quicker than a stock MM, handle better, have enough interior room (empty nesters) and trunk space for the two of us.
    If I can get the highway MPG from the LS that I got recently with my TBird (27.5), I'll be totally satisfied. (The 89 TC takes regular, but it's a very thirsty car.)
    Any winter driving suggestions (tires, etc), I'd love to here them. Also, does the 03 TBird and 04 LS share a common wheel offset? I'd like to mount snows on my TBird wheels and use them on the LS for the winter. Then, I'd buy a set of 04 TBird premium wheels and Vogue Tyres. (The white/gold stripe Vogues on the black TBird look great. I've seen pictures on the TBird Thunderbird Nest chatbox.)
    Most LS owners think the fact that it doesn't ride like a towncar is a huge plus. The LS sport will ride harsher than the non sport, but if you want the V8 you don't have a choice. You can switch to the 16" wheels to soften the ride a bit. The tbird and ls wheels are the same.
    "If I can get the highway MPG from the LS that I got recently with my TBird (27.5), I'll be totally satisfied. "
    In just over 10,000 miles (approx. 30 fills) on my ’03 LS V8 Sport, I never averaged over 25.0 mpg for a full tank.
    If I fill the tank in the AM before driving to work, the display (proven quite accurate) will typically show something like 26 – 27 or even 28 (if A/C is off) as I pull off the highway after 18 to 20 miles at 65 to 75 mph. But then it starts a slow decline as I drive on surface streets, commute home in the thick of Metro-Hotlanta PM traffic, drive short hops such as to lunch, and drive weekends when I have more opportunity to ‘exercise’ that lovely V8. If I do some extended driving outside my normal commute, I have seen some averages between 23 – 24 mpg over a full tank. And I rarely drive over 2,650 rpm.
    Just one data point. And I certainly don’t think that this is bad at all, given the other vehicle attributes. . .
    - Ray
    Wondering what highway mpg the LS would achieve with the 6-speed trans. in current Jags.
    2022 X3 M40i
  • dclsdcls Member Posts: 32
    Well, you made a great choice. Every time my wife drives our V6 LS she always comments on how much fun it. Hmm..I better check the tires. I've driven the new TC's while the LS was in for maintenance - missed the LS! More responsive, quieter and handling doesn't compare. Have fun!!
  • leadfoot4leadfoot4 Member Posts: 593
    I've had good luck for the last 3 "snow belt" winters with Dunlop Graspic snow tires.
    design and production philosphy in respects to the Mustang and future autos.
    http://internationalreporter.net/scripts/techDetails.asp?id=104
    At 22.5 miles, the "check transmission" message went on. Going into the dealer tomoorow morning.
    What's that saying, you never get a second chance to make a good first impression?
    "At 22.5 miles, the "check transmission" message went on. Going into the dealer tomorrow morning."
    Happened to me once - the afternoon I picked up my '03. Went away on a re-start (<ctrl> <alt> <delete>) and has not happened again in 10,000 miles. . .
    Good luck!
    - Ray
    Never even brought it to the attention of Service . . .
    2022 X3 M40i
  • sdasda Member Posts: 7,677
    Did you ever decide on tires for your LS? You mentioned that you would be in the tire market fairly soon, so I am curious. Haven't seen you post lately, hope all is well.
  • cwzcwz Member Posts: 72
    I have Porterfield brakes with ~30K miles and they still look okay. Any experience on how many miles one should average with the Porterfields? Also had the coolant reservior crack, anybody have this happen as well?
    no tires yet - sidelined by some outpatient surgery. Still would appreciate suggestions for a V6, quiet-riding tire. Thanks,
  • lamarlamar Member Posts: 9
    The Kumho ECSTA KH11 gets some good ratings and cost just over $100 each at TireRack. They may not be good for snow and ice. Since I live in Georgia that is not a problem for me anyhow. They are what I will replace my Michelins with on my 2002 LS Sport V8.
    Yeah I have them and have used the 712's. I think the 711's are agreat tire and just recommended them recently to someone else on here. Heck could be same guy sorry for the repeat if so.
    I have gotten pleanty of mileage out of them and the noise level is pleasant and the grip is great. I live in florida so the warm roads likely lend hand to thier sure footedness but I love them and intend to buy another set after i retire, pardon the pun, these. The 712's are dynomite in the curves but tread wear is horrible.
    I spoke with the Tech today and they have been advised by the engineers from the mother ship that when replacing the fuel pumps that they should also replace the rear electronic module which is subordinatte to the PCM.
    They have had the car now for about a month and a half since the replacement of the REM 2 weeks ago have not been able to duplicate the probelm.
    On one of the test drives they cracked my windshield so i had my insurance company replace it there at the shop.
    Plus I am having them replace the solenoid pack and the valve body in my 5r55n. This will be the 3rd time but the first time I have had to pay for it.
    According to the Parts folsk and the tech responsible for my car this is a systemic problem with the LS of the 99 and 00 years. The SA said they do about 3 a week. Who ever designed this transmission deserves to be keel hauled.
    The bright side is that they said if the first relacement would have included the valve body I would have never required a second or third repair. So if any of you are experiencing problems with shifting in to reverse and harsh/ late shifts and are considering going in to the dealer for work take some time to interview them.
    Consider becoming a AAA member and find out if your dealer is AAA approved repair site becasue if the workmanship lacks or the repair they stated would fix your car didn't AAA will arbitrate for you and the dealer has to accept AAA's decision but you don't. I won't go into why I now know this but I feel obligated to share this with you all.
    despite the foul weather I have endured i will certainly be happy to be seated in the drivers seat of my LS again.
    have a pleasant evening.
    90K plus on my 2000 LS and the trans is just fine. After talking to my dealer, they don't do very many tranny repairs. The issue you describe
    "So if any of you are experiencing problems with shifting in to reverse and harsh/ late shifts"
    is corrected by a TSB. The number is 01-14-05 (for cars built before 10/17/2000, there is also one for later builds) and it is a pcm re-calibration. Sounds to me like your dealer looks at you like a cash cow (ABSOLUTELY NO offense intended towards you!!!!) See if they even bothered with the TSB. They also appear to be nothing more than parts changers, never looking for the root problem. I'd find a new service department!
    I appreicate your bring that to my attention but that TSB was performed in 2001 or 2002 when I first started having problems. In fact the problem was not remediated then and shortly after that they replaced the first solenoid pack.
    The harsh shifting and late shifting is just one problem. The other issue is when putting the car into reverse. It takes up to 10seconds most of the time and then kicks really hard like someone hit you from the rear.
    This is the second dealer to diagnose this problem and they did it without prior knowledge of my previous repairs. Unless the PCM can loose the reflash which I possible but highly unprobable I know that this transmission has issues correction SUBSCRIPTIONS.
    Unfortuneately now the depth of thier search is limited to the breadth of my bank account because these repairs are paid for by me.
    I have no doubt that many of the dealer's service shops do not know what they are doing. I can't afford to go to yet another dealer shop for service. I am loosing money and time plus the folks that are now taking care of my car have little or no history with the vehicle.
    If I had that kind of money I would have purchaed a Bentley or Rolls. :)
    Hey question: If these are being replaced under warranty doesn't that work have to be approved by someone other than the service department. I am sure they told me before the first 2 repairs thAt they had to get approval for this sort of stuff due to the cost.
    I just fitted KH11s to my wife's car. They are strictly summer tires; they have no all-season capability. That's no problem for me as I have Michelin Arctic Alpines mounted on steel rims for winter driving. The Kumhos have a quiet and compliant ride, but they still handle quite well-Tire Rack testing indicates that the KH11 is superior to many so-called "high performance" all-season tires.
  • dlaughlin1dlaughlin1 Member Posts: 3
    does anyone know where a decent manual can be bought on the 2001 LS model? I am told my computer flagged the "range senson" on the tranny. Would like to know where it is located, how hard to change and what it can cause. Had coild replace (3) and it took care of all the missing and erratic acceleration but this was flagged. I was thinking the coil problems might have caused it to set.
    You can get the real ones from Helm. They have cheap ones on CD on Ebay but they don't have all the details.
    Just because the computer reported a sensor it doesn't mean the sensor is bad. You really need to test the sensor to determine if it's bad or if what it is sensing is bad.
    Hope you have a nice floor jack, jack stands and thorough tool kit, that includes the trs alignment tool, becasue that is a hard part to reach my friend.
    I have no idea where a man on the street can find these factory tools.
    honestly, I would take it in and let them deal with it.
  • pnewbypnewby Member Posts: 277
    I'm taking the LS in for the 6th time because the Air Bag warning light flashes then remains on. Anybody heard of this before?
    Yes, and IIRC, it's a code for some failure. What I don't understand is why the dealer hasn't diagnosed and repaired the problem already.
  • gkarggkarg Member Posts: 230
    I'm pretty sure that the LS tranny that you have is the same tranny (or close to it) that the ever-popular Ford Explorer uses. (Probably the Mountaineer & Aviator and others do as well.)
    This would lead me to conclude that the service people at any urban dealership should be more than familiar with that tranny (since there are so many Explorers on the road.) It sounds like your dealer is referring to the 5r55n tranny in general.
    The only time I get a delayed downshift in my '00 V6 LS is when I use the SST and it is only the 3 to 2 downshift - never the upper gears and never on an upshift in either mode. I had the tranny fluid changed at 30K and need to do again w/ 64K on the clock.
    They're basically the same but not identical. 5R55N was used in the 00-02 LS. 5R55S for the 03-05s. The truck versions have different letter designations as well. The car versions are assembled in Sharonville OH even though the sub assemblies come from France. The truck trannies are actually assembled in Bordeaux.
  • sniemietzsniemietz Member Posts: 40
    Okay I give up. I put on a set of Porterfields about 1K miles ago and they squeak like a freight train. They usually squeak during light braking. I like the way they feel especially when doing heavy braking. I don't seem to notice any fading at all but I don't know if I can tolerate the squeaking. Most pads that I've installed before on other vehicles usually have shims pads but the Porterfelds didn't come with anything..nada..no clips to put on the ears...nothing. I took them off and applied a little of the disc brake grease and it seemed to help a little but they still squeak. Has anyone encountered this problem before and please..what is the magic solution. I'm just about ready to go back to semi-metallic or even try some of the ceramic pads. Help.
    more than likely it is build up. I hate to say it but you have 2 choices first live with the sound 2 take them off and use a light abbrasive sand paper and sand them down a bit.
    I had the same problem and after sanding them twice I havent heard a peep since then. rest assured you bought the best pads out there.
    I have put about 200 miles on it since its most anticipated return and it spins like a top and stops on a dime. No shutdowns and the tranny shifts smoothly. I slips into reverse and you would hardly notice it.
    There fix for the shutdown was to replace both fuel pumps and the engineers followed that up with recommending that the rear electronic control module be replaced.
    The solenoid pack and valve body have been replaced and I can certainly tell a big difference from the previous repairs which only the solenoid pack was replaced. Only mileage will tell but I feel very confident about the work and testing that has taken place.
    The fine folks at Courtesy LM in Tampa, Fl didn't even charge me labor for the tranny work and I supplied the parts.
    They told me that I needed to replaced the #4 coil becasue it was diagnosed as misfiring so I plan to begin the replacement process of CoPs now. If any of you have done this on the V6 sport I would like you opinion on one thing.
    Should I do all 6 or wait for them to fail and handle them a they come.
    I figure #4 is on the drivers side and I do not have to take down the intake system yet, underscore yet.
    Thanks for the tip. I am very happy with the performance of the brakes it's just the squeaking. How can they get a build up so fast? I'll give it a try this weekend. Since this will be my third time looking at them it should be a breeze.
    No problem. I think they are glazing over and it may be from long braking which is basically creating a lot of heat and over a long period of time that could be glazing the pads. Not an engineer but I did stay at the holiday inn express last night.
    I suppose the same thing might happen with repetitive late breaking as well. With the 50/50 loading of the car I couldn't even say if this would be a front dominant issue.
    I know that when I did my brakes I only sanded the fronts but I used the porterfields on all four.
    Did you only do the fronts? If you did the back brakes did you make your own pistion wind back tool or did you buy one?
    I've found that overly gentle usage of the brakes can cause a more aggressive pad to squeak. A day at the track usually cures the problem-at least for a while. You might try making a series of hard-just short of ABS intervention-stops, say from 70 mph-20 mph. Allow a mile or so of driving between stops to allow the brakes to cool. Give it a try; it sure can't hurt...
    I was going to suggest the same thing. A few hard stops every so often will reduce or eliminate the squealing. At least it does on mine. I have about 20K on my front Porterfields.
    have either of you guys had to scrub the rear pads? Correct if i am mistaken but most cars are more front loaded and as a result front brakes make about 60% of the braking power. With the LS since weight is 50/50 is the braking load more distrubted or are their laws of physics at play and just cant be circumvented regardless of how the automobiles weight is distrubted?
    Noah - it's not the static weight distribution. When you start to brake you shift most of the weight of the car to the front regardless of whether it's a 51/49 LS or a 60/40 civic. So the front brakes will always wear faster than the rear. My fronts were shot after about 30K but my rears lasted well past 50K.
    I guess it goes back to Newtons first law of motion. Middle school science returns; then what is the benefit of a 51/49 or 50/50 weight ditsi.
    This is a front/back balance and thinkning back to cub scouts it was better to front load the car in the soap box derby. Obviously there is a big difference between gravity races and automobiles but I am curious as to why they are so proud of the platforms weight disti.
  • cdnpinheadcdnpinhead Member Posts: 5,630
    Has more to do with traction on corners, not braking.
    With ~equal weight distribution, all four tires will begin to lose traction at about the same time. Put a different way, all four maintain traction up to a higher speed, which yields better cornering performance than with a FWD car in which the rear would tend to slide.
    Thanks for info. It makes sense to me... too much weight at one end cause a it to break traction sooner. I was thinking more linear; probably becasue I drive the "I" way too much.
