Chrysler 300M: Problems & Solutions
                    Aare there any recalls or tsb's for 2000 300M's?
I have some creeking in the right rear "C" pillar and some squeeking & creeking on the entire right side doore front & rear. Anyone have any info?
http://www.nhtsa.dot.gov/cars/problems/tsb/servicemmy1.cfm
Hope this helps!
KarenS
Owner's Clubs
I'm having to address Wind Noise TSB 23-07-00 and loose weatherstripping on the door jams 23-20-00. I already had to point out the Front strut Caps Issue to my service Manager. You should have seen his slack-jawed expression. "How'd you find that out?" was his question. What a moron.
I'm trying to work this one out. I'm at 40,000 miles and out of warranty.
It has been a year and a half since I have been back to Edmunds. Thanks to all the information I got from Edmunds I went out and bought a 2000 M in September,1999. The car has over 18,000 miles on it and not one problem. The window motors keep working and no rattles or bad tires. Is Ruskie still around? I will have to get used to the NEW LOOK on this forum!
Also I know of 2 other 1999 300M's with lots of paint chips on the hood.
I have done my own TOUCH UP to the specks and have since added a hood bra... Lo and behold there are new chips UNDER the bra on the hood. Is there a TSB or some sort of recall on the hoods for substandard paint application?
Sincerely
Gary
If anyone has any news about these items, I would certainly appreciate hearing about it.
Thanks! ps, still don't have the car back,, its been 10 days.
Some of these things were starting to worry us so the car is going to be at the 5* all day for it's fourth visit on Monday. We have many more problems/issues than just the above three, but we'll have to see what the dealer can do about these first.
When i put on the R W D for the back window ,i can't receive any radio stations or their is alot of static ?????
Wondering??????
Has anyone experienced the "engine stopping while driving problem"?
I have experienced both problems w/my 300M. I like the car, but I cannot accept "mysterious" problems. Any data, hints, or solutions would be greatly appreciated. The NHTSA website listed several customer complaints and 1 LHS TSB.
When the car is first started there is a loud clattering noise that quickly goes away. The dealer says that this is normal for this car. Anyone experience this?
The 300M is a great vehicle. We are concerned that the stabilizer bar replacement is not a "usual" wear item. We have never had to replace stabilizer bars on other vehicles that we have owned.
at the above post I'm beginning to wonder if I really want a 300M. How reliable is this car ?
It's a great looking vehicle and I do not want a 4-dr sedan like everyone else has. Would
anyone recommend buying a used 2000 model with low mileage ? If so, what should I look
for ?
Thanks for your assistance...
check any msg board for any vehicle and youll see just as many 'glitches' with each car. youd be amazed. check out bmw's its a hoot
KarenS
Owner's Clubs
1. Stay well back from big trucks you'd be surprised how much stuff the toss up off their tires even in nice weather.
2. Invest in a nose mask for the front end. That's what finally cut down on the chipping for me. But you have to have it on religiously and clean under it frequently to keep from putting fine scratches in the finish.
Ted
The dealer picked it up and the problem turned out to be that the harness connector between the engine and computer wasn't snapped together tight. It wasn't obvious visually, they squeezed the two halfs together and heard the snap of the latches engaging. I haven't had any problems since.
Ted
To Bamabell: Yes, the vertical dash crack is on the left side of the passenger side air bag
The biggest improvement came when I replaced the underwhelming Good Year LS's at 10000 miles. Went to Conti CH95's. Not perfect, but much better than the LS's.
I have found that wheel balance is ABSOLUTELY CRITICAL on this car. Even my new tires required a 1/2 ounce balance after just 5000 miles. As long as I stay on top of this.. all is well.
Another issue for me has been brakes. I have the non-PHP version, and the stock pads just did not give me a very confident feeling. In addition, I started to notice brake induced vibration when braking from higher speeds. I have been experiencing with pads and rotor replacement, but am still not quite happy with the braking situation at 23000 miles. Will keep at it and post again if a breakthrough occurs.
In spite of this, I truly love this car. It does so many things so well and looks so good doing them.
I started having problems with this car 10 months after I bought it. I'm now just past 2 year mark and still takingit in for warranty repairs. I wish I never bought it.
It should help.
I, too, have experienced creaking noise that was suspension related. I had to take the car in eight times, over a period of six months to finally correct the problem. What was replaced were: rear strut striker caps, dampers, bushings and supports (twice). To this date, the problem has not reoccured (thankfully), as I had threatened to invoke the lemon law to get Chrysler to buy back my car.
Referring back to the #1 posting, I also have noticed a C pillar noise. I think this has to do with build quality. When the car is experiencing cornering forces, it stresses the car frame to where the noise is heard..like when you walk on steps in an old house.
Other than that, the car rocks. The 360w Infinity sound system, AC, heated seats, room and low financing deal on a less than dealer invoice price. For the $, its a great car. I would buy another one, provided I get the color I really want, with maybe a DVD navigation system
AFTER 3 YRS (BOUGHT 1999 300M)THE EXPERIENCE HAS BEEN HORRIBLE - PWR WINDOW MOTOR BROKE, 2 MAJOR TRANSMISSION FAILURES, FUEL GAUGE SENSOR FAILURE, BRAKES NEED CONSTANT WORK (ROTOR SHIMMY / PAD REPLACEMENT)ETC AND CHRYSLER KNOWS ABOUT MANY OF THESE PROBLEMS AND YET THEY WON'T STAND UP AND DO A RECALL SO I AM STUCK WITH IT BEING OUTSIDE THE WARRANTY - NEVER AGAIN CHRYSLER - NEVER AGAIN GOODBYE 300M HELLO G35
Since my vehicle is still under warranty, and it has been great otherwise, I would very much like to fix this annoying problem as soon as possible. Thanks for your help!
