Even I have done 85~90(maybe) and the feeling is :
"Where the hell has the engine gone? Did I drop it?"
It's so damned smooth at high RPM(3500~4000).
Note:
some car makers tend to balance the engines at lower speeds which gives you the effect of having smoothest engine at city driving conditions..but you know what happens when you hit the highway...shake..shake and rattle....
Does anybody have any info. on when the 5door hatch is coming out? My wife likes the looks of it so we may end up being a 2 Protege family! I'm glad to see Mazda making this move. Hatchbacks are great in my opinion and a Protege with a hatch is the best of both worlds. Peace.
I am about to get a 2001 ES, but I was wondering if anyone can think of a good reason why the Corollas have daytime running lights since atleast the 1999 model, but the Proteges still don't have it.
I would really appreciate any comments on this.
Thanks in advance.
Daytime running lights are required in Canada, so Toyota is probably making it common to save on multiple build specs. Of course, it just turns off those of us who don't care for daytime running lights.
It will be all Mazda engineering.
Mark.
Leo
Of course, snow tires are the best. My Mom's old 323 used to be a horror in the winter. Then she put 4 snow tires on and now it plows through the snow better than an SUV.
Leo
Higher in dealer snob factor, higher in price, more than likely higher in cost repairs.. there's a webpage somewhere that lists the estimated costs over the span of several years.. when I find it, I'll post it.
Leo
The jerk is from not letting the car shift completely into reverse before you apply the throttle. Zoom Zoom does not apply in reverse, so stay the patient course.
I've been too busy to be reading edmunds, but I want to give you an update on my 2000 Protege' ES. I have had it for 15 months and have 18K on it. Had to have the differential replaced, but of course it was under warranty. Car's been fine since then -- I love it! I am a little timid to be a ZOOMer but I do like taking the ramps at speed
My only concern is possibly declining fuel economy. I'm down to about 26 mpg now; when the car was new I was getting 28-29, and around 31 for _purely_ highway driving. Does anyone have any ideas about why it's declined?
Zoom, Zoom, Zoom...
I noticed the same thing ... I bought my 2000 ES 5-speed last May, and all spring, summer and fall I was getting about 29-31 mpg in mixed highway and city driving. Then, once November or so rolled around, I noticed a decline to about 25-27 mpg. I complained here, and someone else told me that in a number of states (especially in the Northeast, but also here in Virginia) they use reformulated gasoline in the wintertime to cut down on emissions. When springtime rolls around, the gas formulation should go back to normal and our gas mileage with it.
I hope I'm conveying this correctly -- if I'm full of it, someone please jump in and correct or explain it better!
I have noticed that my Protege doesn't zoom quite as much with this different gas, btw, so I think there's some truth to all of this. I think some of the gasoline dealers are using one formula and others a different one, too, because I get VERY bad gas mileage with Amoco gas, but good mileage (like 3-5 mpg better) using Citgo. Weird, huh?
Do keep in mind, especially if you live in northern climes, that you may tend to use your defroster a lot more in the winter -- which uses your a/c compressor, which makes your engine work harder and cuts down your gas mileage!
Meade
With the reformulated gas, I notice that the mileage is lower with it too, but not too much. My Protege still averages about 26 mpg no matter the temperature. Lowest I ever got was idling in 100-degree traffic this past summer, and that was 20 mpg. Hell, that's what my Bonneville AVERAGES on one tank of gas with mostly highway driving!
highway from our last trip was about 29MPG, and coming back about 28. but we had 4 people and loaded trunk. plus I didn't use the cruise, too much fun punching it up to 100MPH!!!
Doctorann...There are several things that can degrade your gas mileage...it might be one or a combination of things.
Change your air filter if you haven't already done so. A dirty air filter can cost you up to 3 mpg.
Check your tire pressure.
Put some injector cleaner through your tank (add cleaner to an almost empty tank and fill your gas tank).
Lastly, like Meade (and others) said, different brands of gas can affect your mileage too.
Pete
And the air filter does have a lot to do with the fuel economy. Mine did improve about 3 or so mpg when I put a new one in. Did it myself, and it only cost $16 for the filter.
Stick with a 6cyl. and you can't go wrong. The trany deal on those is for the CD4E on the 4cyl. For a real fun ride, try to find a 6cyl with a manual trans. I shocked quite a few faces with that car.
http://www.thecarconnection.com/index.asp?article=3282&sid=180&n=157
Also earlier question about poor winter fuel consumption. I think it's true about winter reformulated gasoline. Second point is concern for using defroster and subsequently ac compressor is that although when in the defrost mode the ac will come on, it will only come on if the ambient temperature is above a certain point. My guess is somewhere around 50 degrees. The compressor will not come on if outside air temp. is below the cycling temperature of the ac system. Essentially air in the ac system can only get so cold.
In the winter time, the owner's manual also says when defrosting windows, put the setting on "fresh air" and not "recirculate" because it helps defogging quicker. I never turn on the AC button when defrosting though, and it seems to go fine.
Also, my 1999 DX has almost 37K on it. The engine still heats up very quickly according to the temperature gauge, but it takes what seems like forever for heat to actually come out of the vents. It blows cold for a good period of time, then finally turns warm. Also, I noticed this past summer that my AC took a long time to cool the car down on hot days. Not so when new. I am going to take the car to the dealer before it goes out of its 50K warranty have them do a complete check. I have 2 other nagging recurrences with the car too, so I will hopefully get those straight when taking it in.
Owner's Club---------I think we have to email the host.. But with the amount of posts we've done, I don't see why not.. the Owner's Club room says we need 2 members as the "spokesperson" for the club..
I say Meade and Pete.. sorry Vocus but you're waffling on the Bonneville!!!
Just wondering.
The same can be noticed when comparing 626 to camry and accord. What gives?
I got the job in Chicago (just got my offer letter faxed to me!) and I'm leaving to drive there on the 24th or 25th of this month. I haven't heard back from Suchismit so I don't know if he is still around there. I'll have to buy the new splash guard before I make that drive so I don't allow any water up into the engine compartment.
I'll be pretty busy until then so I don't know how much I'll be able to post.
Pete
Pat
Sedans and Women's Auto Center Message Boards
