The following repairs made it run much, much better
1. Service ignition
2. Valve cover gasket
3. Pull throttle and clean; new idle control valve
4. New canister purge solenoid
5. Replace several vacuum hoses
6. Pull intake/exhaust manifolds; clean intake; new gasket
7. air filter
Individually, each one had small impact, but collectively they had big impact.
It still has too much vibration at idle which is probably due to cylinder 2 testing at 120psi instead of 150. Will address in fall.
Had my mechanic look over transmission. It was 2 quarts low !
Now works great. I serviced the pan and the new transmission fluid is not red anymore. It's clear and I am paranoid about overfilling.
Thanks to everybody for their help
So I've spent some time searching the web and this forum to see if I could solve my problem without posting...but alas.. I seem to be the only one with this issue. I got my rotors rotated today and when parking my JGC tonight I heard a whistling noise. It almost seemed like high pressure air being leaked out right below my passenger doors. Any clues as to what this could be? Should I have it looked at? Or is it an easy fix?
Thanks!!
:sick:
The composition of the pads they installed and/or compatibility with your rotors may be an issue. If you do some of your own work, Autozone may carry lubricants or cleaners designed to eliminated brake squeal. It may only require removing the tires.
For convenience, one time I took my jeep to a shop near where I work. The put on a new serpentine belt that would squeal really bad sometimes. I do some of my own maintenance, but not this one. I am no fan of the dealer, but I took it to the Jeep dealer and asked "Can you put a serpentine belt on it that won't squeal?". They said yes and they did. I did not like the price, but I knew they could do it.
If you had the work done at one of these low $ brake shops that may be the problem. Some situations need high quality parts and an experienced installer, but it's hard to judge.
Thanks and I hope that this helps You some what
Roger
I'm in the market for an SUV and I've narrowed my choices down to two vehicles (02 Explorer limited vs. 01 Grand Cherokee Limited). I am extremely interested in both and they both feature the V8 engines with about 80k miles. Both have leather, power everything, etc. etc.. The Explorer has 20" rims and the Jeep has a 4" lift kit with over sized tires. Both are in immaculate condition appearance-wise. Both these vehicles are private owners, not a dealership so no warranty would be involved.
Besides the usual test drive (they both drive great), I did take them into a mechanic to inspect them. Fortunately they're both mechanically sound.
I don't feel like jumping through hoops for the bank and have to make payments so I plan on paying cash for one of these two SUV's which I've worked really hard for.
My question is; Given you're knowledge of the two make and models, which one would most likely give me the least problems (mechanically) approaching 90k to 150k miles?
I think the 02 Explorer was the newer body style as I looked at Fords in Jan 02 and they were not quite out yet (I compared with a Escape and it did not pass the "wife test"). So I bought an 01 GC and have been generally happy with it.
Other than the infamous brake problems which we got free calipers and rotors under warranty, the only other mechanical problems were minor: 3 bad seat heaters, stuff like that, all fixed under 3/36 or the extended warranty. I had a power window regulator go in 07, another notorious problem, and did it myself for $100 w/A1 autoparts vs $500 at the dealer. Oh yes, I have a loaded Laredo with the I6 and Selectrac since my mechanic said it was the best combo Jeep ever made, so I sold it to my 21 year old son last Fall and no problems in almost a year at 87k miles now. I presume you are looking at one with the 4.7 V8 and automatic 4wd quadratrac, more complicated so you may have more concerns with higher miles (can you tell if the transfer case and differentials were ever serviced?). FYI, I bought an 07 GC loaded Laredo last Fall and got it with the V8 & quadratrac since they no longer make the I6. I needed to tow a 3000lb boat and the torquey V8 does a much better job than Jeep's new V6. I would have preferred a shiftable Selectrac but you can't even get that unless you buy a Liberty, no comparison in ride etc compared to a GC. What was real interesting is I paid $1000 less 6 years later, but last Fall they had a $4000 rebate vs 1000 on the 01, and I have a lifetime powertrain warranty. I bet I could buy the equivalent 08 for a few thousand less with our $3.80 gas here in the midwest this summer.
Back to the 01, if the mechanic checks them both out it's a tough call. I am happy with my 01 or I obviously would not have sold it to my son and both another Jeep.
But I've heard the earlier quadratracs had some issues. I am sure Explorers have issues too. Good luck! Another good pro-Jeep site is WJJeeps.com
If U are referring to the fan blade attached to the water pump--take this route. Loosen the four fan hub bolts(do not remove them yet)--Remove the serpentine belt--U do this by lifting the upper idler wheel(use a long wrench on the bolt in the center for leverage_ when belt slackens lift it off the alternator pulley --then remove belt.
You may have to remove the fan shroud for the fan and viscous idler removal--now, remove the four fan hub bolts previously loosened. remove the fan, water pump pulley,viscous hub assembly as a unit(shroud may have to be lifted out at same time.) Never lay the viscous hub down--always keep it propped upright. Reinstall in reverse order.
Enjoy the busted knuckles---Good luck
Smokey Swann
Matt
Can anyone help?
It sounds like your VTSS thinks the vehicle is being stolen.
Disconnect battery and then reconnect battery with driver door open. VTSS should know that it is not being stolen. Close door and lock with keyless entry. Then unlock it using keyless entry. Vehicle Theft subsystem should now be initialized. If no keyless entry or no VTSS or this procedure does not help, it must be something else.
I have a 97. On mine the fuel pressure regulator is integrated with the pump in the tank. Your regulator may be implemented in a different way. I don't know if a faulty regulator can make it fail completely. Try to get the Haynes manual.
that is why the have the pressure cap on thr rad will rasise the boiling point to a bout 255
I have 97. Removing interior door panels was pretty easy. Separate lock from mechanism before or after removing the lock. Use judgement. My locks are held in place by a tight clip. Pop the clip and lock should come out. Replace it. Maybe the Haynes manual can help here.
I had my battery disconnected while away on vacation. When I came back VTSS false alarmed. If you don't have keyless entry then improvise. Here's what I did. Disconnect battery and reconnect it with driver door open. All other doors & trunk were closed. Close driver door, Lock with keyless entry. Then, unlock with keyless entry Mine started OK. Maybe you will be OK.
If you lost keyless entry, I believe you can get replacement at the dealer. Sorry. More $.
I believe your best chance to fix it is to fix the lock and use the keyless entry (if equiped) to initialize VTSS.
If all else fails, you may be able to disable VTSS in your Body Control Module, but it's difficult and risky.
In Jeep digital inputs are Active Low. So if a signal is labeled "Door Ajar Sense", it is true if at 0 volts(Ground) and false if 12 volts. When the door is open (true), it should measure 0 volts. I am 99% sure, but possibility of an exception always exists.
My Body Control Module has an input called "VTSS Disarm Sense". Maybe you can disconnect that pin from wiring harness and force VTSS to be disabled all the time. You might have to tie the pin to Ground. You will probably need the shop manual
BCM connectors may be difficult to pull out. Do not break retaining clips on BCM connectors by squeezing too hard (like I did once). I would say try this as a last resort.
Put the key in the ignition
Turn the key as if you are going to start the car, but not all the way to start (Stop just before)
Turn all the way back to accessory mode
Do this 2 more times
Then turn the engine over.
Also, check under the dash on the drivers side for a little button. You may have to hold it while doing the above turns to reset it.
Some Jeeps (and ironically some Fords) used this system back in the mid-1990's.
They show a diagram with a shell like casing that sits on top of the battery. The hold down bracket and its bolts hold the battery in place and secure this casing. They call the casing a "ThermoGuard".
There are no extra screws or bolts for the ThermoGuard. Once you remove the hold down bracket, it should come off. It may be wedged against the fender shield OR was forced into place when the original Chrysler battery was replaced. The width and length of the replacement battery was probably different than the original. If somebody hammered it on will a rubber mallet, you may have to break it to get it off.
It was a long time ago but your email reminded me that the first time I serviced my battery, I took mine off and threw it away.
Also, since this is a full time 4WD, can the front drive shaft or any components be removed to make it a 2WD permanently?
(I don't have any advice/info on your other question) Good luck to you.
I don't know what a good price would be but I am curious. Does that figure include labor costs for installation?
SUVs and Smart Shopper
Before you spend $ you may want to make sure your power steering gear is not leaking. It is a big $ part.
I am a die-hard DIY, but a Ford dealer mechanic I used to know advised me not to do steering repairs except to replace pwr steer pump and hoses.
I believe it was a "fan clutch". When the vehicle is moving slowly or stopped a lot, I believe the fan is suppose run at a high speed. If the clutch does engage it can't switch to the high speed.
When you are going 60 mph you get much more air going thru the radiator so a slow fan speed is adequate.
It's an educated guess because this happened to me quite some time ago.
replaced seals also [non-permissible content removed] have to remove ring and pinion to do those also gearing stamped on ring gear also pinion (these must be bought as a pare as they are matched at the factory PIA to replace do all my own work but had to have shop do these as need specal tools to disasemble and set up
good luck
Out of desperation we pulled the thermostat out. It is at the bottom of the radiator and the spring on the thermostat was in the hose rather than in the engine block.
Is that correct? Seems to me that the water flowing out of the bottom of the radiator puts the water flow against the spring and working against the opening operation of the thermostat.
By the way it does not heat up when run without the thermostat. We are going to get a new one but need to know which direction to face the spring.
Also noticed that the coolant looks a bit muddy/milky. ???
Kip
install new antifreze as this engine is all alumnim and water eats that up fast
Kip
Because of age of the vehicle I suggest you pressure test your cooling system. My understanding is that the system is pressurized to make the coolant more effective by preventing it from boiling. Sometimes you can borrow a tester from auto parts store. You may have to buy an adapter to fit radiator on your car.
You can do it with engine cold. Pump it up to your specification. I think it's normally 12-15 psi. It should be printed on your radiator cap or find it in the Haynes manual. Come back 1/2 hour later. There should be little or no drop in the pressure.
Use a rag and eye protection. When you release the tester you could get some coolant squirting
i would flush the rad and block good before installing new antifreze
when you fill with new antifreze dont for get to open blead hole on top of elbow that upper hose hooks to so get all air out of swstemi
the rad pressure on a 4.7 is 22 lbs at the rad cap
