Let the engine idle, listen through a length of 5/16" hose, CAREFULLY, around the intake to head, throttle-body to intake, around fittings etc. Lots of plastic hoses/lines break inside rubber boots etc.
Any suggestions from others that have fixed this? I was considering buying a new leather wrap from Wheelskins. I suppose the old leather wrap should be cut-off the wheel before adding a new wrap? Any suggestions welcome - I have no experience with wheel wraps.
It runs great, except a few things. I mainly drive it back and forth to school, a modest 10 miles a day, 20 tops.I noticed that the inline 6 is semi weak for it. It drives nice, but i do a decent amount of highway driving at times, and it handles it fine, i just wish it had a little more get up and go. When i press the gas hard it accelerates semi slow, down shifts, and they gets up to speed. Any thoughts on how to improve my engine performance. I have previously thought about a cold air intake, some new plugs and switching to synthetics.. Any thoughts?
I also noticed that when i try to put it into 4wheel low, it doesn't like it too much and starts to tremble a little bit.
Unless your plugs haven't been changed in the last 30K miles, new (and I'm assuming by 'new' you might mean 'performance') plugs won't produce a noticeable change in engine performance beyond a few % improvement in fuel economy.
In my opinion, unless you're making a lot of accompanying modifications, a cold air intake alone is a waste of money for this engine. 5-10 hp simply isn't enough to produce a significant change in power.
Using a synthetic blend would drop your engine temperature slightly and let you go for longer between oil changes, but I also think this is a waste of money.
As for the 4WD L, please provide some more details. Did the previous owner service the transfer case? You might also think to check the TC linkage with the transmission - it can come loose even with normal driving.
Good luck
some parts houses have a cheep engine stescope that has expanabul rods to listen to the engine while it is running (could be bad piston rod etc ) you should be able to pin it down closer before you pull engine.
the remote button is broke
is there any other way to open the tailgate without remote?link title
I'd check if the thermostat is stuck open (a safety mechanism to avoid overheating). If it is, replace it. Make sure an get a 210 degree thermostat (Cooler is NOT better on the Jeeps... causes an error code, no heat, etc).
If you replace the thermostat, make sure you get the correct one with the little bleeder valve in it. It looks like a little rivet that can allow air bubbles to escape and not build up in the engine.
My 4.0 heats up to 210 within 5-10 minutes depending on outside temp.
I'm lost when it comes to this question.
Any help would be greatly appreciated..
Maddy
I know this may be a deeper issue (I've read some other sites talking about air intake, etc...), but if I can just adjust the idle up some and see if that could do as a work around for the time being, that'd be great. I'm just not sure how to do it/where to look. I remember my dad doing this for a car that had the same issue, but that was many moons ago. If this Jeep can just last me 1 more year until it's paid off, I'll be happy.
Can anyone gives some me some pointers on where to look and what to do to turn the idle up? :confuse:
Brian
went ahead and replaced all 4 shocks and man, what a pleasant improvement on all-around ride and handling (esp. on turns - not nearly as much lean). well worth $40/mopar shock.
now my question is when i drive normal it is fine but as soon as i try to pass it starts chugging like i'm going on and off with the throttle. Also does it in park idling and throw the throttle to it full and it does it just like before what could this be? fuel press. reg.?
fuel injectors, electrical, cat conv? Got any ideas. Please help its our only vehicle
The chuggin freaked me out and I'm so happy it's gone.
