Oil Filters, whose is best, and Why?
1363739414249
  • americanflagamericanflag Member Posts: 400
    expect to see a difference in the oil analysis between the two filters?
  • bigorange30bigorange30 Member Posts: 1,091
    Let me see if I understand this now. You seem to have been doing very diligent research here fro the past couple of months or so. You have decide that using synthetic oil is a good thing. You have decided that those of us here and on bob's website that use Mobil1 and other synthetics and have done oil analysis that we have posted good results on 7 - 10, 12 or 15K mile change intervals are letting our oil stay in there too long and therefore you will change yours every 4K. HUH? You justify this extra cost because you want to treat your engine with extra special care. Then you have decided to use a K&N air filter because many have said that it will give you more power, gas mileage or better filtration.
    Then you have decided to use a cheapo paper oil filter because some have said that they don't do anything anyway? How in the world does that make sense when you look at your overall approach. You ignore hundred of oil analyses and do overkill on changes and them skimp on the filter because someone says they are of no use?
    Maybe I'm crazy but this seems like contradictory thinking.
    I'm asking. When you say paper filter, I assume you are referring to the Ford Motorcraft? I am really asking the question. You think the Ford Motorcraft is that inferior to the Mobil 1?
    See, bigorange, I read on Bob's site that the expensive filters that filter more may actually not do as good a job at preventing engine wear as a cheaper filter that flows more oil. So I don't mind spending more for a Mobil 1 if it indeed will improve the performance of my oil filter. I would be interested in seeing the site you referenced above or any other sites that have good info on filters, esp Mobil 1 vs Ford Motorcraft. I have read some of Bob's site, that was when I started thinking the Mobil 1 may actually be better. I am still learning :)
    see a difference in performance between synthetic and dino! It is like back to square one. I am sticking with the Mobil 1 oil though, that is for sure.
    but I will tell you that the Mobil1 and the Purolator were the best. The Fram's were crap. I don't remember off the top of my head what he said about Motorcraft but I don't remeber anything else being close to the top 2.
    that the Ford Motorcrafts were highly regarded. But if the Mobil 1 filter is more effective I would definitely use it (maybe it would help counteract the K&N?).
    should be obvious like which filter works better... you know there are those who say the filter doesnt matter.
    Your driving yourself crazy. Just make a decision and go with it.
  • mralanmralan Member Posts: 174
    I'll soon be getting my first oil change on my new vehicle. I called PepBoys and learned they offer Mobile 1 Synthetic oil changes, but not the Mobile 1 filter.
    My choices are PROLINE, Purolator, or Fram. I know the consensus is to avoid Fram ... so which should I choose between Proline and Purolator?
    As far as the debate between added protection Mobile 1 (and other synthetics) may offer ... all I have to add is this. I spoke with a rebuild mechanic who told me synthetic oil engines are considerably "cleaner" than DINO engines.
  • adc100adc100 Member Posts: 1,521
    Proline is the same as the regular grade of purolator. Pepbuys doesn't sell Mobil 1 filters. You could take the M1 filter there and have them put one in.
    I personally would avoid PepBoys for oil changes(or any car maintenance)-but thats just me.
  • texasjeeptexasjeep Member Posts: 270
    americanflag is not only driving himself crazy, he is driving me crazy too. ;)
    Bigorange,
    I don't think there is evidence that filters don't do anything. I am just undecided on how much filters actually NEED to filter out and if changing oil only would be sufficient.
    It would be easier to run the same filter on a new car with changing the oil only, but of course I am not willing to do that.
    I am thinking about doing that with my 198,000 truck, but if the engine goes after 30,000 or so, it wouldn't tell me anything because it could of happen with routinely changing the oil filter. Now if I could put anther 60,000 on that would have some meaning. I guess I could do a oil analysis and see if it is getting significantly worse over time. Maybe I will even break down and go into a wal-mart and get a supertech filter to do this. :)
  • airwolf1000airwolf1000 Member Posts: 225
    Don't forget there are flow issues to as far as oil filters go...Not all filters are the same and yes they do make a difference. I would not rack my brain over it though, there are alot more things in life to worry about. If you use your time and energy to work smarter and harder instead of focusing too much on this issue you would be able to afford the better things in life (maybe a better car and more often) Think of how long you plan on owning your vehicle and go from there. Dino Oil with regular changes including filter will easily allow the vehicle to go past 100,000 miles.How does the engine being cleaner impact performance? Is it significant will you be able to notice?
    More important is Viscosity as this has a direct effect on engine wear. Also the Level of Phospates in the Oil as this helps to maintain seals and reduce wear.....
    Airwolf1000
    My goal say for a engine with 198k would be to have the innards as clean as possible and the tolerances as close to manufacturers specifications when the motor was built. To that end the single best thing I did was to go with Mobil One synthetic oil. The problem with this is one of scale and the truth is how many folks actually have this as a goal? I would hazard a guess and say not many.
    It has been proven beyond a shadow of a doubt that synthetic oil can go as high as 1m miles in a diesel rig no less!! Of course they are equipt with double filtration systems and preoilers., and manufactured to a higher standard and durability.
    From a marketing perspective, the gas engines really don't need to go much pass 250k . So even if they were manufactured to last 500k who would buy them? Who would keep them? More importantly who would pay the extra manufacturing costs?
    I would but I am a statistical anomoly! :)
    So if one wants to go past 100k one only needs to install a preoiler and bypass filter. (two filter configuration) Cost aftermarket: 300-500 dollars. The cost justification would be to forstall an engine rebuild (app 1.5-5k) for as long as possible.
    Given the fact that most folks trade or buy newer when the vehicle is max 8.5 years and with a yearly mileage of 12-15k per year the ranges is between 102-128k, folks are looking to replace. I would say the manufacturers and the customers are dialed into one another.
    Yes flow is an issue. If the flow is high, that is not good because it probably means it is not filtering as much as one that has a lower flow if they have the same surface area. Now, if 2 filters both stop the same particle size and one has a higher surface area, it will have more flow. More flow is NOT always good.
    whipping boy for the oil filters forum? Here you guys are who live on this forum talking about oil, and you are giving me a hard time for doing the same thing. Seems ironic.
    My point, which was ignored BTW, is that there is a lack of hard evidence on this stuff and that it can be argued forever. Rukings intelligent post about his success with Mobil 1 is very persuasive, but then there is the Blackstone people talking about how they see no advantage to synthetic and that the only thing they have found to make a difference is pre-oilers. Anyone know a good link on pre-oilers and double filtration systems?
    #1944
    Actually Amsoil folks do sell bypass filtration systems.
    http://www.amsoil.com/
    "Preoilers" can be perused in the Summit Racing catalog.
    I still can't get over the above mentioned posts.
    Talk about revenge of the nerds. When the guys with the pocket protectors and the masking tape on their black glass frames start giving you a hard time, somethings wrong. At least I get dates!
    Ruking, your experience with Mobil 1 is about as good a selling point as I can find. Did you use the Mobil 1 filter also?
    #1946
    "Ruking, your experience with Mobil 1 is about as good a selling point as I can find. Did you use the Mobil 1 filter also? "
    Let me give you the short answer first. No! If you want to hear the explanation, let me know.
    those guys, but I would be very interested in hearing about why you didn't use the Mobil 1 filter.
    but your just making this thing more complicated than it is. You are talking about how hard it is to determine which is best. Its not that hard but what's worse is that it doesn't matter enough to warrant the fretting you are doing about it. I am all for learning more about these things but I have made a choice already. I may change what I use but not soon or without seeing alot of reasonable DATA that says I should. I not going to switch just because of what someone says though.
    Ruking: I am also interested in hearing what filter you use and why.
    Let me first start by saying that I currently use OEM for the Toyota Landcruiser (case of 10 for 3 bucks ea) (Reason: one size fits all)
    OEM AC Delco (PF-44 $2. ea)for the Corvette Z06.
    However, the 1987 Toyota Landcruiser that I sold with app 250k I used FRAM PH8A filters !! :(:)
    Why? I could get it anywhere 2 for 5 bucks. Since the synthetic oil stayed clean longer, you dont have to change the filter as much. While even I would be tempted to say it will decrease the longevity of the engine, it ran strong and CLEAN up until I sold it. Toyota also went to a new oil filter P/N oem. It was WAY smaller and I was skeptical at first. I also along the way got a 91,94,96, and 97 which happen to use the same oil filter. So it was almost like one size fits all!
    On the Corvette the interesting thing is that AC Delco had a premium filter called the UPF44. (8 dollars each, this rivals the Mobil One filter) They for whatever reason notified the high performance community they were discontinuing the line. Of course, a campaigned ensued from various vette owners to keep the UPF-44 filter and AC Delco for whatever reasons decided to keep this filter.
    In the process of research and also following this thread, I was noticing at Wally Mart that their Super Tech oil filter line was getting its graphics on the box face lifted. On one side of the box are the specifications that looked oddly like the AC Delco UPF44 specifications @8 dollars each. So I pulled it out and lo and behold the Super Tech LOOKS IDENTICAL to the UPF44 sans the graphics !!! So I made it a point to check the specs again for the UPF and it matches EXACTLY with the Super Tech specifications. In fact on closer look in the foot notes it mentions that CHAMPION LABS did the specifications. So the AC Delco UPF @ 8 dollars each morphed into the Super Tech @ 1.97 ea.Both made by Champion Labs. So in closing when I use up my AC Delco PF-44 I will switch to the Super Tech brand!!!
    Here is the technical kicker. Fully 60 % of all engine wear happens in the first starts, i.e., parts not sufficiently coated with oil. So with out getting PREOILERS it matters not whether you use synthetic or conventional. Next 40% of all oil wear is due to particles under I believe 20 microns (which filter's do filter) so 40%of engine wear x 40% of wear due to smaller particles is 16% so as you can see it is a very small % and in fact this tracks somewhat with the recommendation for preoilers.
    a significant improvement if one spent the extra $ and used the Mobil 1?
    And to some of you I am not fretting; can you say hobby?
    #1951
    Yes in theory!! However the oil lab has no real way to measure the effects of whether or not filtering down further really does prevent further wear between (2k 3k 5k 7.5k intervals)!!!( I am also assuming synthetic oil like a Mobil One) Without doing extremely longer oil change intervals!!!! So now we are talking upwards of 25k intervals. Shoot most folks think I am crazy for doing 12-15k intervals. So if I would have done 25k intervals I would have done a total of 10 oil change intervals on the 87 TLC !! 12-15 and 25k oil changes are just not acceptable to the majority of folks that change oil, not to mention the folks on this thread.
    I have started at 7k and will do oil analysis and work my way up.
    I probably should list what I understand as "the ideal" under current available technology. First of all, bypass oil filters, the primary oil filter does the heavy duty flow chores and the finer bypass filter that filters 10% of the oil to flow back technically "clean oil" back to the main system. Second, Preoilers (this should largely decrease the 60% of all engine wear at startup) third, good quality synthetic oil. Barring amy manufacturing weakness, the goal will be to run the engine 300-500k. This is probably overkill for the majority of folks for many obvious reasons.
    the Ford Motorcraft? Also, regarding Pre-Oilers, aren't they esoteric? Have you ever used one?
    http://www.frankhunt.com/FRANK/corvette/articles/oilfilterstudy/o- ilfilterstudy.html
    It's still down but you can bookmark it and keep checking back to see if it comes up.
    believe i figured out that a bypass is a second filter that is attached to your car aftermarket. I am not disputing you but it seems a radical step. Wouldn't a Mobil 1 filter be a sort of middle ground between a paper filter and and adding a second bypass filter?
    #1957
    For sure it is the middle step. Especially given what has to be balanced.
    have a bypass filter built in.
  • lobsenzalobsenza Member Posts: 619
    I actually own a preluber and used it on 2 vehicles. I definitely think it reduces engine wear. It has 2 drawbacks. It is a pain to install (and it is difficult to fit under many hoods) and it requires running the oil through extra hoses. Every extra hose is an inreased risk of a failure of a hose (it did use specially reenforced hoses). In addition, I keep my vehicles 100k-125k and I doubt I will have a failure during that time without the preluber. So, the preluber sits in the attic unused....
  • oilcan2oilcan2 Member Posts: 120
    we seem to have 2 definitions of "by-pass" filters
    1.the built in mechanism in all stock oil filters
    which allows oil to flo if the filter gets clogged
    beyond being able to filter.from what I understand
    this is spring loaded and may vary slightly between brands and applications.
    2.A aftermarket seperate filter system,it takes
    oil pressure for the intake and returns the oil
    via the oil pan or valve cover,the filter can filter much finer particles than the stock oil
    filter because if it does get clogged you still
    have your stock filter in place.
    Americanflag - My post was just razzing you. I was not flamming you. It was meant in good clean fun. That is why I had the winky smile at the end ;) . By the way, this is my first week hanging out on the oil boards and I don't know much about engines and oil really.
    From what I hear, I am too scared to switch to synthetic on my 198,000 mile truck because there is a good chance leaks will show up. I am thinking about switching to synthetic on my 23,000 mile Jeep. It does not get a lot of miles put on it and when I do drive it, it is usually off-road. I would want to go at least 7,000 on oil changes and that would push me out to a at least a year for a change. Not sure I want to go that long of a time period for changes with the conditions it sees. For now I do plan to keep the Jeep forever though. Maybe even the truck too.
    If I wanted to run my truck with the same filter and do oil analysis every other oil change, I could tell by the analysis if the oil is getting worse and the filter is not doing its job?
    Oil filter test results!
    http://www.mr2.com/TEXT/oil_filter_test.html
    Anatomy of Oil Filters
    http://websorcerer.com/GeekOut/index.html
    More Than You Ever Wanted to Know About Motor Oil
    http://www.vtr.org/maintain/oil-overview.html
    Engine Oil Filter Study- Looks to be the same as the one Bigorange listed but different location
    http://minimopar.net/oilfilterstudy.html
    Engine Oil Filter Study- Also the same but slightly different
    http://www.scuderiaciriani.com/rx7/oil_filter_study/
    although I THINK they are a different from Frank Hunt's study. Frank geave a pretty clear indicator that Mobil1 and Purolator Pure One were superior to all of the others that he tested. This seems to be held up by some of these other studies but some offer other alternatives. My approach would be to use one that multiple evaluators have suggested. I look forward to reviewing these studies in detail too.
    #1963
    I read the first link you posted. Based on what I read, it seems that the Toyota OEM is considered unsatisfactory. Given that test I will switch to a Super Tech product (AKA Champion Lab product) for the TLC. Not only is the Champion Lab product BETTER it is also cheaper!! What about that isn't there to like? Thanks for the timely post, which to me amounts to a heads up!
    This test also brings up that the look of the filters can be deceiving. So I would not personally judge based on looks alone. The OEM Toyota filter LOOKS GREAT and expensive. The implication that this is a GREAT filter It has a heavy case, silicon seal and with silicon lubricant on the seal from the factory!! The opening is also shrink wrapped.
  • fwatsonfwatson Member Posts: 639
    I won't guarantee these all work anymore, but if you really want to read about filter tests this should be a good starting point. I bookmarked it quite awhile back so some links might have died.
    http://kozmik.guelph.on.ca/gtdproject/fluids/oil_filters.htm
    Maybe you meant to say different-but filters don't have a bypass filter built in. Just a bypass valve.
    That's what I was talking about. Thanks for the correction.
    (I am talking about the second filter that can be attached to your oil system aftermarket), I notice that these are discussed on Amsoil's site.
    I can see where one of these filters may have a use if you are following the Amsoil oil change at 80,000 miles or 7 years whichever comes first approach, because that extra filter is one of the only ways to clean the oil during that long interval. But if you are a Johnny regular oil change at every 3000 miles type, I can't see where this extra filter would be that important. Seems like again instead of filtering the oil you are changing it regularly. An oil change has to work better than the best filter IMO. I'm not an expert I am just speculating here.
  • noobie1noobie1 Member Posts: 326
    I've been reading the last few dozen posts with great interest because I recently installed the Amsoil dual set-up on my truck ('02 Silverado 8.1L). One important point I believe may have been overlooked while hashing out the pros and cons of extended engine life is this: given that steps are taken when the engine is new or newly broken in, and reasonable care is given to keeping it tuned, let's say that the life of the engine CAN be extended to 300-500K. Even if I personally don't see the odometer turn that figure for one reason or another there's the assumed benefit of retaining that "freshness" of a new engine much longer than is ordinarily possible. Some may not relate to this at all or even know what I'm talking about. But then some of us develop an acute sensibility about what's going on in there. And, knowing that it's good is worth the effort alone.
    For those interested, there's one thing about by-pass filters that completely surprised me and you won't hear their marketers talk about. Noise. You've got to be very careful where and how it's mounted because the sound generated by the oil pump telescopes through the oil lines to the filter mount and radiates from there outward. Unless you don't care or your oil pump is especially quiet, then dampening MAY be part of the project.
    One more thing in answer to #1969. I had never heard of by-pass filtration before I visited the Blackstone site. These are people who's business it is to analyze oil daily. Without endorsing any manufacturer or commercial enterprise their praise of the concept was ringing. After looking into it further I decided to experiment.
    Life is risk. Make it fun.
    -David
  • edwardn1edwardn1 Member Posts: 103
    ...I would still buy them. Availability in any Wally World, consistently high ratings, very good check valve system to prevent dry starts in base down applications, plus you get a semi-synthetic media, usually only found in a high cost filter. If we buy them, they will stock them.
    Iv'e heard about that noise or jitter when using
    the dual remotes ,Iv'e used the seperate amsoil
    bypass on various cars and never had that problem.
    The biggest problem Iv'e encountered is finding a
    tap to get oil pressure,and finding a place to
    mount the filter.
  • vidtechvidtech Member Posts: 212
    i was wondering if you had cut open one of the new stechs.the one i cut open was the st8 and i have to agree that the media is top notch.the anti drain valve is typical of other brands.what i do not like is the bypass valve.i would not use that filter in cold climates or long change intervals.the way i see it if the filter should become restricted in order for the oil to bypass the filter,the element would have to partially colapse.there is no spring loaded valve in there.i do not know how the old style was constructed but i feel that is why the filter sells for a buck ninety seven.you get what you pay for.
    Someone posted a while back that in some ways the oil filter does not make a whole lot of difference. I have to agree with that point somewhat. If you look at the post/link where the OEM TOYOYA filter actually FAILED where the Fram filter was satisfactory, is a case in point. Toyota is not only known for "good quality" and long durable life, but in fact makes very close tolerance engines. The fact that they recommend AND use less than satisfactory OEM oil filters seems to indicate that even using conventional oil and less than satisfactory oil filter works like a champ! So in that sense this is good news! So if you use synthetic and a very good to satisfactory oil filter you have the extra margin of protection, and for me extending the oil and filter change intervals to 15k.
    Whether or not there's a difference in the level of sound amplified by one set-up or the other is not something I can comment on, although I don't doubt your experience. However, if all your experience is with passenger vehicles, one possible point to consider is that there may be more design attention given to sound elimination there than on trucks. Also, with my installation, I probably couldn't have picked a worse location: on a support member of the driver's side floorboard, directly under my feet. I can actually feel the sound in my feet at certain RPMs. If I hadn't given special attention to vibration dampening (no metal to metal contact) it would no doubt be much worse. I'm currently building a mount for relocation, this time behind the driver's seat on the frame. If it's still noisy, I'm making provision for a sound box on the new mount plus foam insulation on the lines which should prove satisfactory. All this may seem to be a royal pain to some, like "Why bother". Actually, it's quite an enjoyable challenge, like a hobby.
    Your problem with tapping into pressure with the single mount, as you probably know, is not a problem with the dual mount; An adapter taking the place of the full flow, simply routes the oil to and from the engine. Another advantage of the dual mount is no loss of pressure, at least not that I can tell. Unlike the single mount, the oil from the by-pass never leaves the pressurized system.
    If your ever faced with that problem again you might look to Perma-Cool. They and others make what is called a sandwich adapter that fits between the engine and the full flow with outlet and inlet holes.
          http://www.jegs.com enter part #771-189
    -David
    on doing this. Please let us know how it works. You are trying a technology that is new to most of us, you are a pioneer! Heck, if something like this did work, I would not expect the car companies to let us know, look at 5W-20 grade oil. Obviously engine life is not a priority for them.
    Are you running Amsoil? How often are you changing your oil? Also, Blackstone said pre-oilers also really helpful, have you looked at them at all? How many miles does your truck have on it, was voiding the warranty a concern? Are you doing oil analysis? I would be interested in hearing of the results.
    I am starting to sound like a geniune oil nerd here! Oh well, at least I had friends in High School ;).
    tell ;)
    No, I'm not running Amsoil: M1 synthetic 10W-30 and M1-301 full flow filter.
    I haven't changed the oil yet. It was just installed Jan 1. Only 1000 mi. so far. At 4000 mi. I'll send Blackstone a sample and take their advice on when to change. The mileage read 22,000 when installation was done, well broken in. Blackstone did two analyses to that point with everything looking good.
    I'm very high on the concept of pre-oiling, but have yet to find much helpful information yet, mostly from lack of opportunity. Any help here by way of knowledge and/or sources would be greatly appreciated. Someone mentioned Summit. Thanks for that.
    I asked the service writer at my dealership about warranty concerns. His reply, "Why would something that keeps the oil cleaner longer be a warranty problem?" How logical. But that doesn't mean that the manufacturer would take the same stance if a pricey fix were in order. So far with GM I haven't found the warranty to be of much use anyway.
    oilcan2; I'm using the Amsoil BE-90 by-pass filter($26.50). If you know of or ever run across a cheaper alternative it would be very helpful to hear about. I called the tech people at Hastings who I'm pretty sure make the BE-90 but their data base couldn't find by deminsional data. If I find same I'll let you know as well.
    -David
    BTW- I don't really agree that this is all that pioneering. Many others have tried it as evidenced by oilcan2.
    -David
