Oil Filters, whose is best, and Why?
That would be a good shoot out!
re: oil flow - seems like the oil pump would determine flow, not the filter.
PS vw bugs are still sold in Mexico - I went to Cancun recently, lots of newer VW bugs - a simple car - wish they were still sold here tho they had drawbacks.
So Fram filters are the best to get?
Bascially the fram filter could allow you to go longer on oil changes but it doesn't filter well and you could have some problems?
Does everyone bash Fram only because of the studies done on the filters?
How many people have had real experiences with failures that could be related to fram filters?
This is one reason why I am leaning towards filters not being all that important.
ruking1
Why did you have to use those change intervals for the VW?
It is easy to bash FRAM because it is made cheaply. Two things lead me to agree with Armtdm 1. my app 250k miles using 15k intervals with Mobil One 5w-30 oil and FRAM filters. 2. Some one recently posted a study that showed OEM Toyota filters UNsatisfactory compared to a satisfactory FRAM filter. (I use OEM Toyota filters and will no longer buy them) {but the real acid test is in the below paragraph}
Back then in 1971-1980 the conventional oil didnt even know what the SL rating was! So the problem was sludge sludge sludge. Oils today are WAY superior to the oils in the above time frame. Also I ran the VW to app 225 miles before I sold it. READ: 225,000 miles WITHOUT an oil filter!!! AND air cooled to boot!!
Keep in mind that this VW ran the dreaded leaded fuel and both the engine and the oil ran far dirtier than todays products!!! It would be interesting with a valve and ring job for the VW to see what the change intervals could be for Mobil One 5w-30 SL version!!
The religious things that you had to do in a 70VW bug: 1. change oil religiously. 2. Next critical thing was adjust the valves. 3. The oil filtered air intake could store a lot of crud, so cleaning and reoiling the intake system was another semi religious thing to do.
The clutch on the 4 speed lasted about 125k? Tires lasted about 45-50k, Shocks about the same. Ditto on the front end stabilizer. And you also had to be careful not to gas ones' self to death (what is it with German cars and leaking exhaust gases) due to the heating system. Tune ups were pretty regular and about every so often you had to run a carb tune up routine. Brakes, I don't remember. And I had to buy a new exhaust extractor about every one and half years. With gas at 29 cents? I used to get 30-34 mpg. This was all during college and 5 years of armed services duty, so a lot of trips skiing and multiple trips across country. Imagine going cross country for 32 dollars in gas?
This is also why I am going with 3,000 mile oil change intervals even though I am using Mobil 1. I am thinking the best oil filter is an oil change.
Best - 1) Mobil 1, 2) Bosch Premium, 3) Supertechs, 4) STPs and some others that I didn't write down.
By the way, the number for the Champion Labs Hotline is 1-800-882-0890 in case you have similar questions.
I am a Mobil 1 fan. But the argument is that their best filter, the Mobil 1, while having a higher level of screening for particles, also inhibits oil flow more than a cheaper filter which screens less effectively. Thus, the results in oil analysis can actually be better with the "cheaper" filter.
Another example is the K&N oil filter. It is also I believe made by Champion Labs and a "high end" oil filter, but it is designed with the opposite approach of the Mobil 1. It screens less, flows more. So there is a question of "which is best".
If I knew the Mobil 1 was the best, believe me, I would use it. Right now, I am leaning towards the Motorcraft (less restrictive) based on what I have read on Bob's board.
Also, 3000 interval oil changes.
I would only be interested in a by-pass filter if I were looking at extended drains.
http://www.shoclub.com/
Our local K-mart is closing, but Target is opening soon. Do they have a store brand built by Champion or Wix?
I guess it's time for me to start hoarding the ST2808s
Our Wal-Marts also seem to be allocating more shelf space to the Fram oil filters and less to the SuperTechs.
-Kent
Sorry to say I couldn't find any ST2808 for my Accord or ST2827 for my sons Altima.
The search goes on.
To me you shouldn't FEAR the "lower flow" rates of the Mobil One filter. Perhaps knowing the parameters/specifications of the OEM engine flow rate and combining it with "whatever flow rate filter" you have will meet your application. You will probably find that the flow rate of what ever filter is right in the statistical middle.
I agree that the Wally Mart Super Tech filters @ 1.97 presents great value and is a high quality product made by Champion Labs (it even says so on the carton-the graphics i.e. footnote). As a matter of fact, the Super Tech filters meet the specifications of the AC Delco Upf-44, which is a neck and neck competitor with the Mobil One filter sold at 9. and 12-13 dollars respectively.
You certainly won't go wrong with the OEM Motorcraft. (I am not current on the cost or who they subcontract the oil filters to)
As you know K&N heavily promotes its performance benefits as with its high flow air filters. So a high flow rate in the oil filter is probably in keeping with its marketing. While K&N and Mobil are both excellent filters and well made, at 11. and 15 bucks respectively (for one of my applications AC DELCO PF44 @2. per), I personally question whether it gives 5.6 x to 7.6 x better filtering than the equivilant WalMart Super Tech @ 1.97.(all three are made by Champion Labs)
I would guess that to do a reasonably scientific test is way out of the scope of what most folks would logically want to do.
I am surprised that someone who is willing to waste money changing a sythetic oil at 3000 miles is not willing to spend a few extra dollars for superior filtration.
Also, most agree the air filter is more important than the oil filter. I just don't see an argument for the Mobil 1 except their generalized advertising claims. Have you had good results with it?
Modern automotive engines are designed so that not all of the oil flow is pushed through the filter just prior to reaching the vital lubrication areas. It is a matter of collateral circulation, much like the blood circulation in your body. The auto engineers design engines so that as much oil as is reasonable can get pushed off into the filtration circuit, but in the event of a blockage or narrowing of flow there, the remaining circulation is quite adequate to keep the engine lubricated. Cleaning the oil is a dilution principle event. Filtered oil is continually being pushed back into the general field of oil that is keeping the engine lubed.
If we paid 3-5 times more for all of our auto maintenance items, all of our groceries, etc. it adds up. Why spend 10+ bucks for an oil filter when there is precious little evidence to indicate that it's worth the money - i.e. it increases the longevity of your engine, or even IS LIKELY TO INCREASE the longevity of your engine, or inreases fuel economy, or ...
"M1-301
Like the Champion, this filter is made by Champion Industries. However, it uses a unique end plate and a thicker can that make it the strongest filter available for wide-distribution retail sale. It also does not use the fragile paper media of the Champion filter. I’m happy to say that this filter is NOT a fake. It is definitely a unique design.
It uses a synthetic fiber element that can filter out very small particles and is much stronger than the fragile, Champion paper media. It is rated just under the Purolator Pure One as far as filtering capability, but is still very much above conventional paper filters. It also has a very strong construction to withstand high-pressure spikes during start-up. Given the choice between the Purolator Pure One and the Mobil 1 filters, I would choose the Mobil 1 because of the restriction concerns of the Pure One and that pesky assembly string. However, as with all Mobil 1 products, expect to pay 2 - 3 times as much for this filter."
I don't know how you can get a more glowing review than that by someone that has no vested interest in saying so.
The guy who did this study is Russ Knize who has no tie to mobil1. He actually seems to like Chryslers and may have some tie to them but he claims the following on his FAQ page:
"Who are you and what are your qualifications?
Quite frankly, I am just a concerned automotive enthusiast that is tired of being toyed with by these manufacturers. In reality, I am an Electrical Engineer with no qualifications in the area of filtration analysis. However, I have eyes and some common sense, which has proven to be enough to accomplish what I set out to do."
However, the aforementioned quote says nothing about the Mobil 1 filter being 'worth the money.' Unless I missed something, it does not even say 'this filter is much better than most of the other filters we tested.' Therefore, the question of 'is it worth the extra money' remains unanswered, IMO.
Sure, he says the filtering capability is 'very much above' that of typical paper element filters. But that's a pretty general statement and I don't conclude, based on that statement, that the Mobil 1 is therefore superior in filtration to all paper element filters. Plus there's the notion that filtration is not the only concern. And the theory, hammered on here by the respected armtdm, that ALL oil filters really aren't doing that much anyway.
I don't think I'm alone in thinking that the body of evidence available to even web-savvy consumers regarding filter comparisons and tests is pretty thin.
If someone wants to believe that the Mobil 1 filter is the best widely available filter available, that's fine. It may be correct. But I don't think anyone can honestly say that with much certainty at all. The claim that it's worth the extra money is an even bigger stretch.
tells me that that he thinks that the mobil1 is better than any paper filter he has tested. It doesn't seem to be a gross extrapolation to say that it would be better than any paper filter.
His review opinion of the mobil1 is better than any other review he did. He didn't state that the extra cost was worth it but he certainly didn't say it wasn't worth it either.
Is there any evidence anywhere that any filter restricts flow to levels that are unhealthy for any engine?
