Oil Filters, whose is best, and Why?
I think the bypass filter already has an orifice type device. Since they are in parallel, I'm not sure you need the control valve. As the filters load up there will be variations in flow but the circuit will be somewhat self-correcting.
The string shouldn't hurt anything, and it might even help keep the pleats properly spaced during the life of the filter. I doubt that though, since the string isn't glued to the paper or anything.
Most filter manufacturers don't find it necessary to use the string, but some older production lines still use them.
tom
I posed this same question about pressure reduction to one of the after market kit providers after doing so here. Their response was that since their unit only flowed 1.5 quarts/min. no appreciable pressure to the engine was lost. Unfortunately though, most of the after market stuff I've seen is kinda clunky, intended for use on heavy equipment, big rigs, and diesel generators, the filters not being easily changed like a spin-on. Permacool offers cast aluminum mount/receivers for remotely mounted spin-ons. The trick for this set up is finding a spin-on with a low flow rating and low micron rating. Because of thier intended use spin-ons tend toward maximizing flow. Claims for filtration in after market units are in the 3-5 micron range where the lowest spin-on claim found so far is around 10 although with a high flow rating/claim.
Bid
This is pure fantasy. Ideally, wouldn't the best by-pass system be almost entirely independent of the engine oiling system, using a separate electric pump - independent except prior to start up, where oil could be diverted back through out the engine. We've all heard the claims that most engine wear occurs at start up because of drain back. If it's true, and despite anti-drain back valves on better filters, wouldn't it be better to have oil circulating through out the engine at start up? Pure fantasy (or maybe better, fanaticy).
www.permacool.com
www.filtersolutionsww.com
www.kleenoilfiltrationinc.com
Will someone please clue me in about making these addresses hot links. Host?
-David
-David
www.amsoil.com
www.oilguard.com
for the best bypass filtration kits
Ryan
It looks like a trip to AutoZone tomorrow.
-David
Well, the separate electric pump is not fantasy. I have forgotten the name, but at least one company provides just such a system, for about $500, which includes all the appropriate fittings and an interlock the won't allow the engine begin cranking until a pre-set oil pressure has been achieved. As you indicate, its purpose is pressurization of the bearings before the engine turns over. This system could only help but, for me, I believe regular changes of oil and filter would be a better economic choice. A cheap way of providing some reduction in start-up wear would be to add an auxiliary starter switch. With that arrangement, you could leave the ignition off, crank the engine several revolutions to build a little oil pressure, and then turn on the ignition. This is also a bit fanatical but the idea is that main and rod bearings get some oil pressure before being subjected to the increased loading from combustion.
But from reading some of the postings here, some of you fellas are quite intelligent on this topic, so I thought I'd throw out my 2cents and see if any of you have any insight for my german import car.
Come on guys, anyone have any info for Jedd?
tom
I'd also look at Baldwin/Hastings website and see if they offer one in their on-line catalog:
http://www.hastingsfilters.com/
For some applications (especially some foreign cars), the best solution might be the OEM filter. I know for Hondas my favorite oil filter is the OEM Filtech filter made in the USA.
--- Bror Jace
Try www.hparts.com as they are having a sale on oil filters right now.
Make sure you stipulate "Filtech" filters for your Odyssey.
--- Bror Jace
Have no info on their quality/performance, though.
"Dear customer,
Our oil filters would be considered high flow and high capacity.
They
flow 12 - 16 GPM depending on size and trap / hold 90% more debris than
standard filters. This translates into a life of 6,000 miles. (We do
recommend you follow your manufacturers oil change intervals). They
have a
90% efficiency rating on an SAE multiple pass test which goes down to
10 -
20 microns. Anything less and flow rate starts being affected
adversely.
Sorry, I have no single pass data but then again, that is not a "real
world"
test. They have a 550 PSI burst strength which is more than double
that of
standard filters. This makes them suitable for all racing
applications.
The inner filter media has metal end caps to ensure no debris can get
back
into the system. They have anti-drain back valves and pressure relief
valves. On the end, there is a 1" nut for easy removal. This nut is
drilled through to allow the use of a safety wire; great for off road
racing.
Thanks for asking, Rick"
So, I think both are great products however, I honestly feel that the Pure One is comparable and I think the Mobil 1 (which I have also used) is a slightly better filter and easily available. My drain intervals go from 5000 miles to 12,000 depending on the car and type of driving and if I am going beyond 7,500 I will cahnge the filter at around 6000. Longest lasting car I have that was swithced at 1000 miles to both products now has 140,000 and engine seems fine, changes of oil and filter at 7,500. I tired 15,000 once but the results were not good, too much silicon, copper and iron for wear metals.
I think the best of the best are Mobil 1, Amsoil and Pure One
I saw Kmart has Mobile1 and Castro, both Plus and regular.
alternator, seeing a teensy, weensy oil filter never leaves me with a warm 'n fuzzy feeling. Some seem to be engineered JUST to get the job done but you can forget them for any kind of extended drain interval.
I'd look around in the aftermarket for something larger (longer/taller) ... provided you have room for it. This can be long and tedious process ... but one that can be worth it when you find a filter that has a significantly larger capacity.
--- Bror Jace
What do you think of using Nissan OEM with synthetic? I bought a bunch of them a few months ago and like to know before I return them to the dealers.
http://ntpog.server101.com/reviews/filters/filters.shtml
This is how the Mobil 1 looked after 1000 miles with conventional oil from the tester.
Nissan OEM are okay but I switched over to a larger filter when I had my Maximas and never had a problem.Manufacturers to save money and get more consistency in the filter sizes used are trying to use the same filter on multiple engines. I think this accoutns for the small canisters we find now.
Happy Holidays to All!
Many aftermarket manufacturers make high quality filters ... some better than OEM filters.
If warranty claims were common, all aftermarket suppliers would be out of business. Since the original auto manufacturer doesn't want your car to last forever, and probably isn't interested in an owner using synthetic oil and extended drain intervals, you can often do better than an OEM filter with some aftermarket units.
Often, the OEM filter is competent ... even very good ... but it does not mean we should not discuss the search for a better oil filter.
--- Bror Jace
Just wanted to let you (and everyone else with filters on the brain) know to check it and add any input to that one like you have been contributing here about OIL filters...
Search on filter and you'll find it...thanks in advance for any input...
Now back to topic folks
Everyone ready for christmas?
see ya
Rando
To All A Good Night
Ho, Ho, Ho,
Merry Christmas!
I'm not saying we shouldn't substitute filters, just that we ought to be sure that we know what we're doing.
If an improper filter results in engine damage, then the vehicle manufacturer certainly cannot be held liable. Likewise, the filter manufacturer could legitimately say that they did not design that filter for the vehicle that you used it on.
Just be careful, that's all.
tom
altinator: Read the information I gave duper. As I said make sure that the larger Pure One filter does not bottom on the threaded portion of the engine housing and that they compress the gasket material. I have used both the Mobil 1 and Pure One on my Sentra. BTW-really like the Protege. Considered it when I bought my Sentra. My wife liked the seats better on the Sentra. Now that Nissan has deleted the extremely rugged and reliable SR20DE engine and gone to a new 2.5L. I wouldn't buy it.
I assume that oil filters on the market that are manufactured by reputable companies will be at least competent and incapable of causing engine damage ... and subsequent warranty claims. Liability isn't an issue. My feeling is that the only thing that could cause actual damage would be a filter that was plugged. Only the most egregious defective filter could be in such a state and I've never seen or heard of this happening.
I asked tsjay a while back if he felt there was a brand of filter on the market today that was so poorly made that it could damage a vehicle by regular use. He said that he did not know of any.
I am guessing, but I bet that if you put an empty canister (no filter media) on an engine today and changed the oil (SJ or SL) every 3,000 miles, the motor would make it out of the warranty period and possibly past the 100,000 mile mark if driven normally.
Most of us know that for years some of the OEM filters were not the highest quality ... like the previous generation AC Delco filters, for example. So, seeking a better one from the aftermarket is a natural direction.
What I and the others are looking for in a better, aftermarket filter is either filtration for an extended period (for use with synthetic oil), greater flow (GPMs) for high-RPM driving (autocrossing or other amateur racing) or high-efficency filtration which will remove even the smallest particles from the oil for the longest possible durability. What adc100 describes Nissan as doing is what drives me and others to the aftermarket. In the name of expediency and saving space under the hood, a manufacturer moves to a dinky, one-size-fits-all filter that is less than optimum in many applications. At least with Honda, the oil filter size I'm familiar with that seems to fit all (or at least most) of their cars is of decent size. But, I'm always on the look out for a better one with greater flow, capacity and filtration ability. If I could fit a filter on my Honda Civic that caught everything down to the size of 5 microns, flowed 8-10gpms, was the size of a coffee can and cost $15-20 each, I would. I suppose I could go with a remote set-up featuring larger, multiple spin-on filters but with the extra plumbing necessary comes the possibilty for leaks and I don't believe it's worth the hassle. <:^(
Oil filter problems I've heard of, can imagine or experienced are:
1) Leaking at the gasket
2) Leaking internally ... letting dirty oil back into the motor
3) A bypass valve that opens too early and leaks internally
4) Ruptured canister
5) Low quality media which screens ineffectively.
I would expect none of these problems from a filter made by WIX, Hastings, Filtech, Purolator or most other quality aftermarket filter manufacturers. This is even ultra-rare for the cheaper filters I won't go near.
Even if you were to have a filter which you felt responsible for the destruction of an engine, good luck proving that to the manufacturer and getting a settlement. It had better be plugged solid and you better be able to show that it wasn't from something <i>you introduced to the crankcase.
--- Bror Jace
MOBIL 1 LIMITED FILTER WARRANTY
Filters manufactured for Mobil are warranted to be free from defects in material and workmanship. Any filter proven defective during the engine or equipment manufacturer's recommended service intervals will be replaced at no charge.
In the event of an engine or equipment failure directly caused by a defective Mobil filter which was properly installed and changed following the engine or equipment manufacturer's recommended service intervals, Mobil will authorize repair of the damaged engine or equipment.
Claims for engine or equipment repairs provided under this warranty must be submitted within 30 days after discovery of damage. Mobil Technical Service representatives reserve the right to examine the engine or equipment and filter to determine the amount of damage and whether it was caused by a defective Mobil filter.
This warranty gives you specific legal rights. You have other rights which vary from state to state.
Mobil filters are designed to the original equipment requirements for fit and function. Engine and equipment manufacturer's warranties remain in effect when Mobil filters are used.
To all those out there that believe that the ultimate filter should have the best of everything, including warranty policies, I thought you might find this info useful. IMHO, if you're comparing an oil filter to one that's currently rated as "the best" & can at least meet all performance specs, construction quality, durability, oil analysis results, or anything else you can possibly favorably compare & the end result is that all factors wind up being equal with the exception of one filter having a favorable written warranty while the other does not, then the one with the warranty wins "the best filter award" hands down, every time, regardless of how remote the possibility of failure is, (seems like Mobil admits this is a possibility in writing), or what difficulty may be encountered in proving it, (if it's during the new car warranty, let the vehicle & filter manufacturers fight it out). To me it's like having the option of buying one of two identical cars, especially if at the same price, & only one had a warranty, I know what my choice would be. I don't know how the "others" regard warranties on filters, maybe the thought never occurred to them & it needs to be brought to their attention, but to me it's part of being the best, so if there's anyone else out there that either thinks like me, &/or has warranty info on other filter brands, along with the technical info, it would certainly help me, & who knows, it may even enlighten a few "others" & allow them to avoid the expense of having to pay for a repair out of their pocket unnecessarily. Personally, with all other factors being equal, I can't see how having a "good" warranty could ever be "bad" & if engine damage could never be caused by a defective oil filter, then I'd like to see that in writing too------by the filter manufacturer.
I am trying a pureone right now and after about 1500 miles my oil looks just like it always does at that mileage (I also switched to Havoline from Castrol and I think the Havoline has a little better detergent action and may be cleaning up some!!)I think I am going to go with the AC filters anyhow (the Kmart version)
Gettin ready for the new year everyone?
see y'all
Rando
What do you mean about the K-mart version of AC filters? Are you talking their Castrol or Penske brand? I'm pretty sure those are made by WIX.
--- Bror Jace
Try a few different kinds and after you replace them cut them open it may surprise you.
See you in a bit.
Rando
Having said that, I suppose I'll chop up my Hastings when I pull it off my car in June. It's the first one of these I've used on my car.
I was curious to know the differences between the Penske and two grades of Castrol filters. outside, they are virtually identical. I assumed that the difference between the white and black Castrol filters was the filter media ... from the claims at better filtration on the box. The black box (premium) filter claims to trap more dirt and are about $1 more. What they don't tell you is that it is also more restrictive and is likely to plug up earlier ... activating the by-pass valve and ceasing to filter. still, I thought enough of it to put one on my twin cylinder Honda garden tractor. >;^D
And yes, I think it's silly to leave an old filter on a car after an oil change. The dirtiest oil is in the filter, you run the risk of them getting plugged with too much contaminant and if anything, they should be replaced MORE OFTEN than the oil.
--- Bror Jace
