Oil Filters, whose is best, and Why?
Maybe filters are relatively cheaper now than 20 yeras ago, promoting the "why not" mentality.
As much as I hate to admit it: Filters probably don't really mean a lot with regards to wear. I mean, if you can drive a vehicle 200K and change oil and filter every 15K and have almost no engine wear or change oil and filter every 25k and and after 50K (consumer driving-no machine or lap driving) and have negligible wear, what does that say?? Of course this was using a high quality syn oil.
Caution: Don't try this with your conventional engine oil!!
what does that mean? still being made with cardboard or not?
As an aside to those who might care, (:oÞ ---I looked at a Pep Boys for ACDelco and Motorcraft filters today for my Nissan 3.3 liter V6. They apparently do not carry those numbers any longer. I think this may have been noted by another poster quite some time ago. Call mine a confirmation.
And, I woudl not trust a Fram to be a horse of any different color. they may just be using the belief that more expensive is better (true in most cases) but I would not trust Fram to be actually making a better product
Also companies like Purolator and Mobil 1 started publishing their very high efficiencies. As far as I know Fram still does not publish their efficiencies. So the "leader" in filter sales is obviously not a leader in technology.
and a metal end cap is much stronger than a cardboard end cap.
I would still like to know, from a scientific perspective, just what the ramifications of the cardboard end cap actually are-- opinions including my own aside!
http://www.minimopar.net/oilfilter-fram1.txt
Of course there is no way to verify the allegations. It is scary stuff if true.
http://www.minimopar.net/oilfilterstudy.html
Then click on the link under the Fram section
The slitters that cut the big rolls of paper into the widths used in the filters are not perfect, and the paper can have a "wavy" edge, which can cause scalloped edges on the pleat packs. This can cause a poor seal when the depth of the sealant is not sufficient to compensate. It's all a matter of degree. A few thousandths of an inch wave will not be a problem, because even the bead of glue on the paper end caps will cover this. If the wave is more severe, the plastisol would compensate where the glue bead wouldn't.
tom
Has anyone ever used a SYSTEM 1 filter? This is a permanent filter that uses a stainless steel mesh screen that you take apart and clean then use again. I have seen them on race cars but have never talked to anyone that uses them.
I do wish that the oil filters were bigger. Those suckers are SO small ...
I think they exist
like for 4 Cyl camrys the 14477 interchanging for the shorter 14476?
Question: My Toyota 22RE engine calls for a Purolator PL10241. Based on the Purolator book I selected one significantly bigger which has an extra disc in the outlet. Its purpose is to cut down outlet flow if the bypass opens (I believe). I guess I'm looking for additional information on this device. The filter is also used on the Later Model 2L DOHC engine- if Focus.
Apparently it works O.K. because I have used two already in the vehicle. (I'm a risk taker)
Also it has all the information on all the old Chrysler products. I have an old 87 Le Baron for my Hobby car and there is some good info. for maintaining this old vehicle.
see y'all
Gotta watch some Olympics!
Rando
Good Morning
Rando
http://www.acdelcotechconnect.com/html/tpi_fil.htm
Oct 21, 2001 (05:53 am)
"The Pure One has micro glass, and it actually has a lot of it compared to other high-efficiency filters. That's why they get 96% efficiency on the J806 test. We make the media for the Pure One, so I know what goes into that paper."
tom
I am surprised that there were no more square inches of paper in the Pure One than there was in the other filters. The media is more restrictive than for most filters, and they usually add pleats to compensate for that.
If you are going 3K on oil changes, then I wouldn't worry about the Pure One clogging and by-passing, even if it did have the same number of square inches of paper.
Please keep in mind how over-designed automotive oil filters are! They hold more dirt than they would ever realistically see in the real world. But the companies compete based on test stand data, so they keep trying to out-perform each other.
tom
tom
http://www.danwieboldford.com/oil.shtml
I thought I remember seeing something on another forum about them being made for racing ... and not to be used for a long time. You might want to e-mail them and tell them how long you intend to use their filter, just to be sure.
If you get an interesting answer (pro or con) please post it here. >;^)
wdfdct23, I just started using Hastings since the Filtech OEM Hondas are becoming VERY scarce. I'll be pulling mine (LF-402) off in another month and hacking the bugger open. I'll also be having the oil tested ... but that won't be until May or June.
--- Bror Jace
Thanks again,
Al
Also, That Pure-one did not have any string wrapped around the cartridge, maybe they don't do that any more? It did have metal endcaps though, and slightly less sq in of filter material..
Thanks again
see y'all
Good morning,
Rando
Remember, guys, even when filters are from the same company, they come from different production lines. The big name filter manufacturers have several production lines within one plant, and sometimes they even have entirely different plants. Some of the lines may have been modernized while others may be older and have not yet been upgraded.
Older doesn't necessarily mean lower quality, either. The modernization of the lines is usually for higher output and/or fewer people on the line for lower production costs. Older can even mean better quality, since more of the steps are performed by people rather than by machine.
tom
If the paper is a little thicker, and the pleat packs, therefore, a little longer, humans can compensate for the slightly larger circumference of the cartridge when it is placed into the end caps. A machine would be set for some optimal pleat pack length and would handle some variation, but would not be as adept at handling the extreme ends of the variation as would human hands.
Also, remember that the pleat count varies in most assembly operations. Every so many revolutions of the scoring roll in the pleating equipment, an ink spot is sprayed on the paper. When the stream of pleated paper gets to the cut off station, the person at that work station manually cuts the paper at the ink spot. They can be off a pleat or two on either side of the ink spot. Now, some plants have automatic cutting of the paper into pleat packs, and this gives a more uniform pleat count per filter.
I just feel better with people performing most of the steps, since I know so well the variation that the paper has.
tom
that the Purolator Pure One was a top
oil filter. Since then I have been
using it. No problems whatsoever. I
have been pouring in Mobil 1 since
'86. No problems. My Camry has no
sludge inside (had to repl eng cyl
head gskt @ 148K mi due to coolant
seep) and has had no mechanical wear
problems - tapping, knocking, leaks
smoking, etc, etc, etc. My '83
Mercedes Turbodiesel never had a
problem in 257K mi until I wrecked
it. I used the M-B Genuine oil
filter. Both these cars had a 5K mi
oil change interval. My wife's Sienna
has 83K mi on it and it gets Pure One
and Mobil 1 at 7.5K mi intervals. No
problemo. I got the last of the 0-30
Mobil 1 at Wal-Mart and will soon go
to the 0-40 that we use in Mercedeses
at work. My newest is a 1.8 Turbo
Passat. She receives 5w-30 Mobil 1 &
Pure One every 5K mi. Too soon to
tell about any problems (13K mi/5
mos). I have used in the past Wix
Gold, Hastings and even AC Delco. No
problems. CHECK & change the oil &
fltr regularly. Use the recommended
API service designated oil (hard not
to) & the proper viscosity and you
will not have to worry. While your
aren't worrying, you will have time
to check the tire pressures so your
tires won't wear out prematurely.
Tires cost BUCKS! Also, don't do a
bunch of stop/go driving. The engine
needs to get warm and be driven a
while before shutting off. Don't warm
your car up in the morning before
taking off, it not only pollutes but
the oil gets contaminated more
quickly.
Happy motoring!
Can you see any difference after it is dirty/used?
I have been looking at my used filters after reading all these oil/filter posts out of curiosity..
later gator
Rando
