Oil Filters, whose is best, and Why?
tom
see ya
Rando
FRAM PH8A 12 vertical rows of 0.18" holes, alternating 3 then 4 with a total of 42 holes punched in FLAT steel tube. Since there are 34 vertical filter pleats and 12 sets of vertical holes, there are approximately 3 pleats for every row of holes. It appears there are always pleats that do not have an easy oil path to a collection hole. It would have been nicer if these holes were staggered rather than perfectly vertical.
Super Tech ST-8A Approximately (I haven't destroyed this yet) 14 holes in 15 rows that alternate, about 210 holes of 0.1" punched in a slightly corrugated, about every 0.2" around the diameter, steel tube.
WIX 51602 This is another side seam like the FRAM and a pain to open. Designed for a diesel, it has no bypass or check valve (they are internal to engine), but probably typical of filter element construction (3.90"x 0.67"x 48 pleats = 251 square inches). Three sets of spiral rows with 47 holes each for a total of 141 holes of 0.17 " punched in a steel tube which has 3 DEEP spiral channels stamped into it. One filter pleat came loose during inspection as a result of insufficient glue coverage.
The WIX tube is clearly a neat design for collecting oil the from the filter pleats. Super Tech uses a larger number of holes, though smaller, and corrugated channels to collect the oil. The FRAM filter was used way beyond its recommended service, but I believe the small number of holes and the pleats forced up against the flat steel contributed filter media puncture failure. In some places two pleats were being forced through the same hole. There could be flow problems with all these blocked holes. As I said before, I am interested in examining used filters to determine which constructions contribute to a better filter. The collection will grow.
My thoughts on FRAM. It might be easy to say that some engineer is stupid or that not putting in extra holes and stamped metal channels is a way to save cost. In fact, I believe that this design is a very deliberate attempt to limit flow rates when the oil is thick. This prevents the filter medium from being crushed by a high differential pressure due to the significantly lower surface area of this filter. In contrast to minimopar, I believe that the bypass valve is a decent design, possibly because it is expected to be used.
I've always insisted that Wal-Mart substitute a SuperTech filter for a Fram, could it be that despite the shoddy construction and lack of filtering media that Fram is really the second best filter?
I work on old marine flathead engines and most of them don't even have oil filters. So, I'm not as concerned as most about a filter going into partial bypass. I am concerned about the failure of the check valve in the FRAM PH8A (I just bought this car used)since most wear happens at starting. The material used is inappropriate. Supposidly a cone shape that seats on the cone shaped metal endplate, the material had flattened out. The edges would no longer touch the metal or cover the holes. It is made thicker and stiffer to support and center the filter. For that reason I would never buy a FRAM.
The thing I have noticed about the FRAM filter media is that it seems fuzzier and less stiff than other filters. I will be getting a low milage FRAM from a friend shortly. One filter doesn't make a valid study.
Interestingly the original MiniMopar filter comparison was almost as negative towards Champion Labs as he was Fram. Complained that Champion Labs filters had rust (I remember that about five years ago but haven't seen it lately) and thinner filtering material (have seen quite a few Champion Labs filters disassembled at AutoZone and didn't notice that either). Interestingly enough the author of the study heard from the Champion Labs attorneys, not the Fram attorneys.
What I was really interested in on that box was the comparison showing that Champion Labs filters greatly beat the other competitors but BARELY EDGED OUT THE FRAM. Maybe the basic Fram filtering material is pretty good (fuzzy?) but the construction of the filter still stinks. Anyway, I for one, having seen the insides of Frams still wouldn't buy one even if they do have a good filtering medium.
As far as the FRAM filters, they are the only ones that make my truck rattle up in the valve train area until thoroughly warmed up,,,,no other filter has ever done that. I don't use them anymore. Champion may have increased their quality in the last few years maybe, I don't know. But I know there is only one filter right now that I WON'T use.
see y'all
Rando
I told them it was a question on edmunds - maybe they have made a change they are not wanting to "advertise".
so what filter do I switch to?
not Fram
not supertech - (a wal mart spec item)
what?
AC?
Maybe just use Toyota factory one
Pep boys sells Purolator, and proline, also made by Purolator.
Those Supertech filters are in transition it seems, some models are advertising synthetic blend media and the box is different and the filter is painted black on those newer models.
Motorcraft is also made by Purolator, I am using them on my Nissan truck now..Nissan has started standardizing down to a smaller generic size that fits several model vehicles and the Motorcraft version is still the larger size.
Good luck
Confusing isn't it?
Rando
The Castrol "plus" uses thicker/Synthetic blend paper, looks like it corresponds to the Napa Gold and Silver versions..If you like Wix filters, go fer it....If Kmart cheapens up they may go to a different brand but for now they are probably pretty good for the $$$, Years ago all the generics were Frams, but now they are actually pretty good filters...both the Kmart Wix's and the Walmart Champions (AC's and Supertechs)_..
see ya
Rando
Yes, I believe the difference between the two is the filter media ... and about $1.50.
Don't forget to check out this filter review, especially if you drive a Honda or some other import:
http://ntpog.server101.com/reviews/filters/filters.shtml
--- Bror Jace
Are you saying that the black and white are the same? or the white and Penske are the same?
The White Castrol and the Penske have the same description on the box at least, and the black says that it has more dirt capacity..
The black Castrol that I cut open looks similar to the Napa Gold in that article, I can't say about the others yet.
I can say that the first black Castrol had a LOT of spring tension on the cartridge,, caused some deformation on the cartridge, compression caused some curves in the cartridge pleats, otherwise looked like a pretty good filter, thicker paper than the others I have seen so far.
See ya
Rando
Into little oil passages or hydraulic lifter parts?/
Filter is suppossed to filter, no add contaminants!!!!
any sites like that for Toyotas?
I need to e-mail that NTPOG dude and let him know. It has been on my "to Do" list for too long. <:^(
I do not own a Toyota so I am not aware of Toyota-related URLs but I am sure they are out there. There are a couple of studies specifically for Hondas that I know of, that being the most extensive. I might mail that guy a Hastings just so it can be included.
As for the Wix/NAPA/Castrol/Penske filters: I believe the white and black Castrol are identical except for the media used. These seem to be the same or very similar to the NAPA Silverline, but this varies with the part number. And, the white Castrol filter is probably very close to, if not identical to the yellow Penske filters. All of these are available at most K-marts.
As has been stated before, this varies a bit with the filter number in question as some you would think should be better or worse will turn out to be absolutely identical. Most Hondas take NAPA #1334 and this filter is significantly smaller in the NAPA Silverline (same size as Castrol and probably Penske) than their Gold. I have a Honda lawn tractor and there is only room for the smaller spin-on filter so I bought a Castrol Max-Plus (the black one) and I'll leave it on for a year or so.
Plus, filter manufacturers will cross-source certain filters, especially the more obscure ones. Fewer of these are needed to fill the demand so it is cheaper to merely buy a completely-made filter from someone else and paint/mark it to look like yours rather than completely re-tool for a low-production run.
I saw this a lot with brake sets but the different part numbers will fewer for oil filters. For example 80-90% of all Hondas made in the last 10 to 12 years actually use the exact same filter. The same is NOT true of disc brake pads where the same number of models are covered by several different sizes.
--- <b>Bror Jace
I have taken apart a used Fram PH series and I don't care how it filters. The back flow check valves are made out of a plastic that flattens out and no longer works. Its made of a stiff plastic to center the filter element (and vise versa). Some other Frams use a better silicone check valve. I think Fram has some issues as a company when they sell some things that work and some that don't. I feel bad for an old hometown of mine company.
i need a while to think about this one.
97xpresso Probably doesn't matter a lot. I want the best I can get because I change oil with syn once/year. Also-like I said-I'm concerned with the thickness of the filter wall. But then again I'm paranoid.
Here is their rather evasive (IMO) answer:
Dear customer,
The dealership may not void a warranty or force you to use specific products per Federal laws. The Moss-Magnuson Warranty Act of the Fair Trade Commission states that if a part is not covered under warranty, the consumer may use any brand they choose to. No info on wall thickness but they do have 550 PSI hydrostatic burst, and helps reduce the risk of rock and stone damage.
Thank you,
Adrian Orozco
Thecnical Support
The only way you are required to use a manufacturers filter, is if they give them away for no cost.
However, if the aftermarket filter is the cause of the failure, then your claim in not with the carmaker, but with the filter maker.
TB
nor the penske site or I missed them.
says Fram Castrol and Penske are the same
When the oil filter is mounted upside down, Jeep extends a tube up the center so a large air pocket does not get trapped inside. The coarse mounting threads would allow oil to seep by and drain the filter. Internally the filter check valve flapper extends to this center tube to seal it. This one, surprise, was deformed and didn't seal. If I ever find a filter with a check valve that works, I'll add an external O ring to the tube for a better seal. Amazing what you learn by taking used filters apart. I need to find some other activities!
purolater
wix - dana
AC?
who to add to this list?
sound s like napa, castrol and penske do not make their own filters but are just marketing brands.
How do you get to a list of who the basic manufacturers are, and then buy from them?.
All manufacturing plants are owned by Baldwin.
So, never really know who is making what???????
any disadvantages to that brand?
zr2rando: On Feb 14, you posted, "The Napa stores sell the Napa gold and silver, and the Kmart stores sell Castrol,all of which are made by Wix, a good brand." How sure are you?
Tyson
