I have had my 05'SE for about 3 weeks here in Idaho. Why am I having so much trouble with the closing the door. My dad always told me to not slam the door, but this is crazy. anyone one else having the same problem?
FYI.
Picked up my SE with 32 PSI in the tires. Plan to run them at 34 PSI with 5K rotations.
fyi - when I picked up my '04, tires were well overinflated, I lowered them to 32 and the ride is much better.
Open a window and try the door again. My own CR-V was so airtight that it was difficult (not mechanically so) to close the door. If I just pushed it, the door wouldn't close all the way. At 22K, it is still airtight, but I'm more used to the slight additional pressure needed to close the door on the first try.
If the door is still sticky with a window open, take it back to the dealer under warranty.
**Edit**
oops! Stevedebi beat me to it.
I agree, that sounds like an evasive answer from the dealer. I don't think there is a spec for that. Fortunately I do have a suggestion. In the back of the Owner's Manual is contact information for Honda (not the dealer). If the dealer won't fix it suggest to them that you will probably call Honda about it, because it really annoys you that your brand new car's steering wheel is turned slightly when you're driving straight.
The vehicle I owned prior to my CR-V had that problem, steering wheel slightly turned to the left when driving straight. At the first service I asked the dealer to fix it. They did. From that point on it was turned to the right about the same amount as it had been turned to the left. No. I never went back to that dealer again. And when I sold the car 6 years later the steering wheel was still turned slightly the right when driving straight.
I dropped off the car to service and Tuesday the PTTR was verified. An alignment showed all four wheels to be out of Honda spec, and an alignment performed, but still PTTR for the alignment tech. He then tried 3 combinations of tire rotations, all to no avail.
Another alignment was performed and the "fix" was to tweak the castor .3 degree. They felt it was OK now and released the car.
We still sense PTTR and will be returning this unit for another this evening. This early in the life of a vehicle, I feel something is not right and how can one tweak of an adjustment affect handling so drastically? How could it come out of the Honda factory with all four wheels out of spec? If alignment is this critical when new, what happens 50k down the road when components start to wear?
Is this model more suseptable to alignment issues? Is it more suseptable to "road crown"? None of my other cars, Hondas or domestics, have pulled or drifted.
I may have to compromise on color to get another unit as the Pewter is in short supply around this area, but I would rather have one that will track straight down the road...hopefully for the life of the vehicle.
How does the CR-V hold up to bumpy roads, other than asphalt? Anyone take them slightly off pavement and suffer alignment issues?
Would TSB 03-004 apply to an 05? I didn't mention it to the service dept, but have printed it from this forum.
Thanks for your input...and support! I'll post again after swapping this unit for another. At least this dealer is working with me and not making excuses!
Other than this issue, we are happy with the CR-V.
Can you send me the Post Number?
Rear Differential Fluid Change
I have a 2000 EX, but the write-up should be applicable to any 1997-2001 model with RT4WD.
Slugline - That would be my guess, too. That page of yours is still one of my most frequently used links.
Thanks for the link. $15 and 15 minutes, and no more squeal.
Our brand new 05 LX also seems to pull to the right. It isn't drastic but it's definately harder to make a right hand turn than a left hand one.
Definately not acceptable on a brand new car ... dealer will be hearing about it tommorow.
I had a month long break I did not drive my V.
And now when I step on a break it make sounds.
I went dealership and they said rust is on the rotor and it's not a part defect, they can't fix it under the warranty.
They also said it's ok to drive with rust on the rotor.
Is this safe to drive?
-Kevin
Anyone else with similar experience?
Here is my question. We plan to keep the car for another 3 years, should I consider buying extended warranty? I checked online and it costs a little over $1000 plus I have to pay for some inspection ~$100. If the transmission is the weak link, now it is fixed and under warranty, should I spend the money for the warranty? You know, Murray kind of got me worry.
I'm presently trying to get the dealership to fix the problem or give me a new car (all CRVs don't do this ... I test drove another one that DIDN'T after discovering the problem with mine).
They refuse ... saying it's "normal" (a condition called torque steer).
Torque steer may be a partial explanation for the drift under acceleration ... but not at other times.
The dealership did rotate the tires and do an alignment ... didn't help in the least.
My steering wheel settles slightly off center as well, and it's harder to make a left turn than a right turn.
So before you buy BEWARE ... make sure your vehicle tracks and accelerates straight. You'll have a heck of a time getting Honda to even acknowledge its a problem otherwise.
The cost to me for all this is $85.
My dealer wanted $55 for the tire rotation and brake check when I had them do the oil for $24. I said 'no thanks'. I'm going to get my tires rotated at a local tire shop for $12 on my own. I suggest for that other stuff - which CAN be a good idea to have done, you go to a local independent shop with a good reputation. I have gotten into the habit of looking for ASE Blue Shield certified shops ( http://www.aseblueseal.org/businesses/ )as an indicator of quality. But also compare against the BBB and other local business forums for reputation. My guess is you can get the tire rotation at a local tire shop for $10, the other quick checks for another $10 (at most), you can buy and add the fuel additive for $3 yourself on your next gas fill up. You can even save money I hear by going to a PepBoys type of place who will often do outrageous amounts of free or cheap inspections in hopes it will win your business if they find a problem. The dealer will even have your CR-V up on a lift during the oil change and will see if your CV boots are in bad shape while they are there - if they like to make money, they will peak at those boots and let you know if they need replacing wether you ask them to or not :-)
Hope that helps.
Elissa
I'm wondering if I can get your help/advice. I'm in the process of going to war with the dealer/Honda and I'd like to find out if I have a chance.
I'd like to know how much pull/torque steer your CRVs have?
As I said earlier, I have a brand new 2005 LX. The steering wheel settles slightly off to the right. It requires more force to make a left hand turn than a right. If you take your hands off the wheel and coast the car veers slightly right. If you hit the accelerator the veer is more pronounced. Under light acceleration, it's still a "drift". Under moderate acceleration it's as if you were intentionally changing lanes. Under hard acceleration the car literally jumps into the next lane.
How does that compare with your experiences?
Thanks in advance for the help.
This was a fairly common problem with the 1st Gen CR-Vs. Rotating or replacing the tires along with a good alignment (at a specialist, not the Honda dealer) usually corrected the problem. What's intersting is that in most cases just rotating the tires fixed the problem.
It's not torque steer since that would only happen under acceleration. It's also not a "safety feature" to keep you from drifting into oncoming traffic if you fall asleep while driving (yes, some dealers actually told CR-V owners that!).
It can be fixed.
Good luck!
ww2k
-------original message--------------------------------------
#1 of 3 2005 CR-V EX Auto Factory Alarm model? is it Checkmate? by ww2k Dec 20, 2004 (2:11 pm)
Bookmark
I wonder if some one can help me determine if a dealer-installed alarm is a Honda factory alarm. I just bought the CR-V Ex auto, orderred with Alarm and Fog lights installed (included in the purchase price). I first picked up the car without them, then the dealer told me to bring it back to the service department to install them later. So I got them installed a week later. Don't know exactly what alarm they've installed. On the service receipt, it shows Checkmate alarm, the technician left an operating menual for Checkmate model KD-100spc in the car. Is there anyone knows if this is a factory alarm? or they installed an aftermarket alarm? Also, is this Checkmate alarm any good? The reason why I suspected is because the car comes with keyless remote entry, all the lock, unlock, hatch buttons are built-in to the key nicely. But they gave me another Checkmate remote with lock and unlock buttons and told me only use them on this new remote (the only button I should use on the key is the hatch), not those on the CR-V key, said it may confuse the system??? My feeling is this is not the factory alarm, Honda should be smart enough to utilize the buttons on the key instead of another remote, shouldn't it? If this is a cheap alarm, I want to have a Honda alarm installed instead.
Any help or clarification would be greatly appreciated.
ww2k
#2 of 3 by varmint Dec 20, 2004 (2:32 pm)
Bookmark
That's pretty much standard procedure with aftermarket alarms. And what you have is aftermarket.
#3 of 3 by Mr_Shiftright HOST Dec 21, 2004 (1:10 am)
Bookmark
You may also ask this question in our ongoing CR-V Owners and Solutions Forumif you want further clarification or if varmint wishes to elaborate on what he knows.
-------original message------------------------------------------
But maybe you should ask if the Checkmate brand now makes alarms for Honda, because the Honda alarm on our CR-V was actually made by Alpine (for Honda).
I have my first annoyance with my 2004 CRV EX that I bought in July. Today, the "Side Airbag Off" light started coming on occasionally. It would come on, then go off, come on again, go off again.
Then, it got to a point where it stayed on and has been on ever since. Really annoying.
Could it be something wrong with the airbag or the sensor? Should I be taking it in to the dealer to look at?
Anybody with a similar experience?
I used your method and got two sets of numbers as described. My question is, what part does each of the LETTERs play in the radio serial number since you said that only 8 numbers makes up the serial numbers?
The dealership (Duthler Honda, Grand Rapids, MI) still refuses to acknowledge there's anything wrong.
Hats off to my dealer, Honda of Bellevue for not sidestepping the issue and doing what it took to make it right with a loyal Honda customer. The replacement unit, which he went out of the way to secure, another Pewter Pearl, drives straight and true. The wheel is centered, not the telltale slightly offcenter to the right. The difference was detectable immediately.
I have a friend picking up his new SE on Monday, I hope his is straight.
Please post what your outcome with your Honda rep is. I'm surprised your dealer won't step up to the problem.
You're welcome. Try to go on the drive with the regional manager if at all possible, or at least get time to talk to them in person. Make sure they understand that the dealership has been denying that there is any problem.
And let us know what happens.
regards,
kyfdx
