I had this on my 2003. It went away before 1000 miles.
I'm gonna try your Lazy-Boy idea sometime.
It turned out the reason it stopped working a day after it was fixed is that some wire was not plugged in all the way. It cost me about $90 to get it looked at and fixed at the dealer in Reno, CA. Fair enough, it wasn't their fault. However, Sussex Honda who did the work to begin with (and apparently did not plug everthing back in) has still not reimbursed me the money for this repair.
Crappy customer service at Honda USA, slimy service depts, and an AC unit that is built to last 50K miles (and opnly costs a grand or two to fix). I can't wait to buy another one of these cars! Not.
Be sure to replace it on time or before. If it breaks on the CR-V engine you'll need a major engine repair because it is an interference engine - the pistons and the valves occupy the same space at different times - timing maintained by this belt. It is breaks it can dent the pistons (or break them), bend the connecting rods, and bend the valves...
It did mine at 80K b/c we have done quite a bit of towing with our '99 which is at 125K miles right now.
You could go to an independent shop and ask for a 2nd opinion and replace the sensor only. We have purchased whole used 30K engines from wrecks for $750 or so. Buy the whole engine and sell parts. Convoluted way but you'd be money ahead in the long run.
I love my Hondas and Volkswagens BUT the dealer systems for both leave ALOT to be desired. Both brands have dealers that have tried to rip me off with NO SUCCESS. I have caught dealers in lies, incorrect advice, incomplete information, bad repairs. Consequently I do not use dealers but choose to do my own repairs.
Your two greatest resorces are the Helms Inc repair manual (study and learn some auto mechanics even if you do not plan to do the repairs yourself) and forums like this one...
Good luck all!
Chris
Cookeville, TN
Shaking during stops are generally caused by warped rotors. Does your brake pedal pulsate? It's the brakes. My CR-V develops a rumble sound when I get the brakes hot as coming to a stop from 75 mph or when easing off a mountain pulling our utility trailer.
Switch mechanics and try again. MAKE SURE they use either Honda genuine parts or GOOD quality brake rotors. The cheap Chinese replacement parts have failed me within 3 months and with slow small town driving and many customers when I sold auto parts to pay for college. We even found a brand new Chinese rotor that was thinner(under spec) than a 260K mile rotor from a Mitsubishi truck... Obviously the customer did not buy that rotor!
Take care all!
Chris
Cookeville, TN
Chris
Cookeville, TN
Some rotors will tolerate turning. Some will not - warping again within 10K miles again. In that case just replace them with Honda or good quality domestically produced rotors (i.e. not Chinese copies).
After a turn or two the rotors will be machined to their minimum thickness and you'll be required to replace the rotors. Give the "turning" - a chance b/c they can be a real moneysaver and is a normal repair.
Suggestion: after a hard hot stop (interstate offramp or emergency stop on the highway) slip the tranny into neutral (or use the clutch pedal like me!) and take your foot off of the brake pedal so you don't leave the hot brake pads tight agains tthe rotors. This habit has worked for me to keep the rotors from warping on any car. Of course you may need to adjust your style for the occasion - for example you want the brake lights to stay on until the car behind you gets stopped...
Chris
Cookeville, TN
Hate sleeping in a glass box with no privacy...
That said we've used this function a few times. Can sleep in the back too if the seats are laid flat (hauling cargo style) if you are less than 5'7" tall (I am not...).
I like the tents that we've seen that extend the cargo area a bit in length. See Pontiac Aztec, VW Westfalia, etc.
Anyone had on of those rooftop tents?
Chris
Cookeville, TN
Thanks for all the input.
Sounds like you should have gotten the Element, which has such a kit available...
What could this be?
2002 CRV 40K miles
Zax
Don't be guessing on something like this! Get it checked before you ruin your rotors!
Never had ANY problems with my 2000 CRV, now at almost 45,ooo miles and I love it.
Until I noticed a rattle or bad idle noise recently. The rattle occurs at about 5-10 mile per hour, and then stops with more gas. No gas, no rattle. More gas no rattle. I THINK that it's a tuning/adjustment problem. Just had a HONDA service done at 42,000 miles. They said I only need to flush the cooling system at 50K (yes I know...I am METICULOUS about getting oil changes, and suggested maintenance etc).
I think it's a gas throttle problem. Or clogging on the air intake....Any suggestions? I am ready to take the wd40 and spray it into the air intake (Of course with the air filter taken off, and the engine running in park).
Is this just a BAD gas, or "it needs a tuning" rattle, or could it be more? :confuse: Any suggestions or experience with this?
I never looked at it in terms of the rpms....(by the way, I have a Ph D in engineering, but my playing with cars and fixing them has been over 30 years ago in college!!!!).
I can check the rpms tonight. It's a rattling sound at very low speed, and there has been some vibration in park/idling or in drive, with a stop at a red light.
Is it possible that it's the injection system's getting clogged? or Dirt on the air intake/carperator? or something like that? Should I even TRY the wd40 spray in the air intake trick....or is that going to make things worse?
I don't want to drive on Thanksgiving 250 miles and have a REALLY bad thing happen...
I may just be "nervous" since I worry about any new/strange noises....it's the mechanical/nuclear engineering training....worst case scenario thinking. :surprise:
Just a question....is this just a "get a tuneup" issue, or am I going to see the engine fall out (only kidding) ...as in the timing belt,
I had the spark plugs replaced at 44000 (or at least the Honda dealer said he did it....) at a new Honda dealership vs. the one I bought it from....
Now, does anybody have replacement tire recommendations? I'm considering Goodrich Radial Long Trail, Michelin Symmetry, and Michelin HydroEdge. I like the superior ratings of the HydroEdge but it's more of luxury car tire than a small SUV tire. Opinions?
Try running the engine with the driver's door open (in Park with the parking brake on, right? Lets be safe!). Increase the idle until you can hear the rattle. Is it coming from the engine compartment or underneath the car?
No, I'm thinking it's a loose heat shield on the catalytic converter. The 1st Gen CR-Vs seem to have a problem with the front mounting points of the top heat shield rusting out, which causes the heat shield to rattle at certain RPMs. A metal hose clamp around the catalytic converter over the front mounting points of the heat shield will stop the rattling.
About $3 for the clamp and a few minutes of work is much cheaper than the cost of new catalytic converter, and probably a better solution than just removing the heat shield (as I know some people have done).
It's probably nothing major but for us to try and guess at it's cause is impossible over the internet.
I would have a shop look at it.
One was a set of Bridgestone Duelers. These are the lousy ones everybody complains about. They are "fair" in terms of road handling, "not-so-hot" in terms of noise, and "downright awful" in terms of longevity.
The others were BFGs (I forget the model). They were really no better for road handling and noise, but they lasted a good 60-80K miles. I swapped mine at 55K miles and they still had a decent tread on them.
1. Loose heat shield (1 point for Bob).
2. Loose tensioner. The first gen CR-V had a TSB at one point because the timing belt tensioner was set improperly at the factory. No reason why it wouldn't work it's way loose over time. This would cause a rattle which sounded like a loose heat shield, but only at certain RPMs.
3. This is the bad one... tight valves. I've never heard this myself, so it's hard for me to diagnose. I'm wondering if she is hearing a little valve tick at low rpms. At higher speeds, the sound of the road and other noises might mask it.
The more I'm seeing here, the less I think it is either 2 or 3.
I remember, the old air cooled VW's were critical on this. We were supposted to check the valve adjustments every 3000 miles. A tight valve will burn. It was a good thing on an old VW to hear a bit of ticking.
Ok, where is the heat shield relative to the air filter, radiator etc on the 2000 CRV.....?
What's a TSB? Which tensioner andwhere?
Will I be able to open up the hood of the car, with the engine running a recognize what's rattling?
I know it sounds dumb, but I don't know all the names of stuff, but I know what the major components do (after all I do have a Mechanical engineering degree.....) but the newer cars are not as EASY to play with as a VW bug, and a Ford Galaxy I took apart in high school....just for kicks...
I am worried it's a fan blade, or something like the engine mounts.....driving 250 miles on Thursday........
:confuse:
BFG Touring T/A's.
It's the heat sheild on the catalytic converter, which is part of the exhaust system and is underneath the CR-V. The catalytic converter is the first exhaust component after the exhaust manifold. On the 1st Gen CR-V it's in the middle of the CR-V, aproximately below where the dash is inside.
When you climb underneath (with the engine off and cold and the parking brake on!) take a large screwdriver with you. Locate the exhaust and follow it forward to just behind the engine compartment. Grab the screwdriver by the blade and bang on the catalytic converter with the screwdriver handle. Hit it pretty hard, and hit both the bottom and top. If either (or both!) rattle you've found your problem.
TSB = Technical Service Bulletin, something that the manufacturer publishes as a special notice about a service issue.
The Timing Belt Tensioner adjustment requires removing the engine head cover. Probably something better left to a mechanic. The timing belt needs to be changed at or before 7 years/105,000 miles.
I owned a '67 VW camper for more than a few years and did all the maintenance on it myself, including rebuilding the engine. When you changed the oil you also checked the valves.
Funny, because they were never tight. Still, I did check them
Don't worry, I won't play with the timing belt tensioner.....the last time I took an engine apart it took 3 days to put it back together.....1974, Ford Galaxy....the transmission took 4 days....I learned NOT to play with car parts after that fun....pre-school for going to engineering school, according to my dad..what was he thinking????
And I do know enough to have the parking break on, and the engine cooled down before I play with the exhaust/converter train.....
Not everyone does, so it's better to include the safety issues, too.
They are noisy, but I have lots of tread left at 38K miles on my 2003 EX. I keep them between 32 and 36 PSI.
It's been doing this for quite some time so I'm used to it and don't feel it's a major problem.
Called dealership down the road. Nice guy had to take a car for a test drive so he stopped by for me. Said it was most likely the battery. Sat in car. Called hubby. Suddenly CD player is making whirring, clicking sound even though keys not in car. It stops. Then I notice anti-theft is blinking and it wasn't before.
So I walked around the mall for another hour. Came out and car started. But gas gauge read empty (wasn't), anti-theft light still blinking, and clock is blinking at me. Won't let me reset clock or turn on radio. But I managed to drive home okay. Gas gauge slowly crept up.
I checked the fuses and don't see any problems. Anyone got any ideas? Do I have a ghost or what?
thanks!
