These are the dimensions of the imagination. It is an area that we call.....The Twilight Zone.
Thanks for your cooperation!
I brought it to the dealer. He said it was normal. He informed me that CRV's are just noisier than the 2003 Accord (my other car) and less well noise insulated.
Is the dealer correct that this represents a normal sound? Do I have any problem at all with the vehicle that I should be concerned with (e.g., Could my tail pipe be loose or the exhaust be loose from the manifold?)? The dealer said that the fact that the sound goes away immediately when the clutch is depressed means the noise is due to the engine working against the forward movement of the car and the noise is not of concern, nor repairable.
By the way, when I asked the dealer's repair rep about this during a test drive, he said that if there was a problem with the exhaust, muffler, etc. that these problems tend to occur at around 1750 RPM's, not at 3000+ RPM.
Any advice? Anyone? Should I bring it to another dealer? Has anyone heard of this before? Others in the forum threads have commented about vibrations but none that I see limited to the specific RPM range as outlined above.
This is poorrichard. I just finished arbitration with Honda to repurchase my 2005 Honda CRV! The Honda Service folks performed the TSB and supposedly found a bad tire. after 5 times at attempting to repair by Adamantly stating that : "It is a normal characteristic for the Honda CRV to pull to the right", I had a final repair attempt by Honda Division Parts and Service manager who stated the crv was performing as designed. None of the repair attemts cleared the PTTR. Only two of the attempts did they do anything other than to utter "it is a normal characteristic..."
I went to BBB and requested a technical expert and he agreed that the CRV had some sort of alignment problem like; pulling to the right at all times when accelerating.
The Honda rep at the hearing admitted that the CRv has one drive axel shorter than the other.
The Arbitrator drove it and agreed the PTTR was there.
Any car manfactured like that WILL pull to the right and arbitrator agreed.
Any front wheel drive car with uneven length drive shafts will pull during hard acceleration. It's called torque steer.
Pulling during easy acceleration, or while driving at a constant speed is not normal and is not caused by uneven drive shaft lengths.
My 1999 CR-V does not pull during normal acceleration, and does not pull while driving along at a constant speed. It does pull if I really "floor it."
I'm sorry Honda wasn't able to fix the PTTR problem with your CR-V. But please be aware that it is not a design flaw, and is not something that every CR-V has a problem with, despite your comments about uneven drive shaft lengths.
JM2C
I can't understand why there is still
no real fix for this problem ???
(I'm not talking about tires, tsb or subframe "solutions")
Phil.
Some pull, most don't.
The tire balancing, TSB for the suspension, and the subframe adjustment are the fixes. If they have all been done on your CR-V and it's still PTTR have you talked to Honda directly? (not your dealer).
I had a mechanic check out the heat shield....it was hanging on by a bolt thread and rattling. Took the entire shield and clamp off.......beautiful....no rattles, sounds great. I put in better gas (CHEVRON with TECHRON) and the engine is purring.....
The belts and timing belt were ok....
Thanks so much for your help and IDEAS.
Just remember that your CR-V only needs 86 octane fuel. Any higher octane is a waste of money. Higher octane will not give you better fuel mileage, nor will it give your CR-V more power.
JM2C
If he is in 5th at 3750 RPM he is going about 80 mph. I think the wind noise will be greater than the engine noise.
Referring to OP, I don't know what noise you have, but I hear nice growl as I open up the trottle. All the way to the RED line, shift... Unfortunatley if I red line in 3rd, I am already going way above legal speed limit in most states (80 mph).
Try revving the engine in neutral at stop and see if the noise persists. By the way, you will find the "clutch burner stop". The engine just cuts off at 4500 or 5000 RPM when you are stoppped.
As to VSC, as promised, I would test it out in the snow. I was doing doughnuts and the car does not seem to have YAW sensors. The inputs are read from the wheel sensors. If I turn the wheels fast to send it into a drift, the brake would start locking up individual wheels. That would only happen when the wheel were slipping, but not when the car was sliding sideways with the wheels turning.
With the VSC disabled, I was able to do perfect RWD doughnuts. As I remember, my 2001 CR-V was more FWD prone, than the 2005 with the redesigned AWD system.
When I make a hard turn/full turn left or right, it is making a very funny noise. Sort of like it stutter(sp?) and the engine is about to die n when I am out off the turn, its fine. Sound like something is grinding.
It is not CV join or CV booth. I have check. I have no idea what it is and it is sad with Honda name, something like this can go wrong already?
Anyway, I am going to the dealership this weekend for them to take a look. If you have this problem, please let me know.
Just to eliminate the possibility that this is not engine related, read up at the link below and confirm it is not the problem you're experiencing.
varmint, "Honda CR-V Owners: FAQ" #3, 22 Nov 2003 12:10 pm
2. Open the drivers window and stick your head out the window
3. Drive slowly in a tight left hand turn
Is the sound from underneath or from the engine?
If it's from underneath then your rear differential fluid needs to be changed. Use only Honda Dual Pump Fluid.
The noise is coming from the front of the car.
I tried to open the door and drive in circle, but I just cant pin point it.
Then follow Varmint's link and read the information there.
I had replace the transmission fluid and it was easy.
1. For the rear one, where would it be at the rear of the CRV?
2. I notice in the repair book there are 2 bolts and you fill the fluid side-way? How would I insert the fluid?
You need two quarts of Dual Pump Fluid because it takes 1.1 quarts to fill the rear differential. The rear differential is located in the middle of the vehicle, between the rear wheels and is the size of a football.
The upper bolt is the fill hole, the lower bolt is the drain hole. Make sure to loosen the fill bolt first to make sure you can get it off before removing the drain bolt. Both have crush washers you should replace, and can get from your Honda dealer.
After draining the old fluid replace the drain bolt with a new crush washer. Then add fluid until the fluid is level with the bottom of the fill hole. If you put too much in let it drain, then wipe up the overflow. Some people use a funnel and hose, but you might have better luck with a small pump you can get at most auto parts stores. The pump fits into the bottle of fluid and has a hose that goes in to the fill hole. Because of the location of the fill hole on the side of the rear differential you can't just pour the fluid in.
Both the drain and fill bolts should be torqued to 35 lb-ft (47 N-m, 4.8 kg-m).
Hope this helps.
I'll take my 03 CRV to the dealship this Sat for find out about the funny noise when I do a hard turn. I'll let you all know what happen.
Funny last Sat I went there to make an appointment and the guy was shock to find there is no history of my car at 67K miles. I said I been doing things myself on my car. Now its time to pay the dues.
Where's my problem, bad compressors or a short somewhere in the CRV? Everything else works fine and each outlet has it's own dedicated 10 amp fuse.
Make sure you buy one with a current reading range exceeding 10A.
Set the multimeter on the 20 or 50A or what have you, and use the multimeter in-line with the ckt, i.e. hot (center pin of the outlet) out to multimeter lead, and from the other multimeter lead to the center pin of the compressor plug, then from the outter connection on the plug (i believe that's ground), to the outter connection on the socket.
Start the compressor. How much current is it drawing? You'll probably find, it draws an instantaneous current when first switched on, higher than what is needed after it is running steady state.
I presume the rating of the motor (on the box, instructions, and compressor motor) are less than 10A, but the instantaneous current (i think the term is "inrush" current) is actually much higher...
It's probable the fuses are "fast blow" type, which means, they can't handle an over-current for much time at all.
DO NOT place a higher amp rating fuse, or a slow-blow fuse in the circuit! The fuse is protecting your vehicle's wiring!
Hope it helps.
There has a little bit of rear axle's design than 2006 CR-V EX AUTO. 2006 CR-V EX looks more value.
From brochure, We just see the different between 2006 LX 4WD and 2006 EX AUTO are 4 Alloy wheels, Moonroof, Audio Control, Outside temp. indicator, Rear Privacy glass, Colored Mirror... .
Please have someone tell me your suggestion. Thanks!
Yes, VTEC solenoids fail, usually from improper oil, or extended oil intervals, but sometimes they fail on their own.
The tell tale sign of VTEC solenoid failure is resistance to rev past 2500 RPM/5000 RPM on some models, and lack of power. This is known as the vehicle going into the "limp mode." Limp mode is the VTEC-E mode where the car is running on 12 valves to save fuel.
The dealer should have read the code and would have seen the VTEC solenoid failure. If, it is the solenoid, and you have the extended warranty, you should have no problem getting it fixed. If your extended warranty is HondaCare, you are good. If it is something else, you have to read the documentation to see what is covered.
He said something about the air bubble in the pedal or something.
Did he also recommend "halogen headlight fluid"? lol
Anyone else have this problem? What's my next move?
New vehicle with less than 500 miles? Take it back to the dealer and make them fix it.
JM2C
This is why you have a warranty! Jsut take it in.
Take it to the dealer!
I LOVE MY CAR!!! This is my 5th Honda, so I know it will be ok, but what a noise.
