even if you went with an aftermarket rim, the most they could do is deny warranty coverage to something like a wheel bearing, etc., if they could prove that the aftermarket rim caused the part to fail.
They may be experiencing oversteer because of excessive speed. Sometimes increased straight ahead traction may cause people to be overconfident in the abilities of the vehicle they are driving.
regards,
kyfdx
If you're light on the throttle on snow, and keep your speeds in snow covered corners reasonable, so that you aren't drifting around them, I don't think there's anything to be afraid of.
If you are the type that likes to "stomp and steer" in snow, and count on the AWD to save you, you might want to look at a vehicle that is full time AWD, as they would react more predictably in these cases.
As kyfdx says, this sytem is primarily to get traction up a slippery hill, or to start out, not to influence handling when the car is already travelling 20-30 mph. Sure, you can get it to engage then, and sure it helps. But, I still drive slowly in snow.
kyfdx
What are some recommended tire alternatives to the stock issue tires?
Brand, sizes, tire model, etc.
I'll let you know on snow, but they look like they would be an improvement there too, looking at the tread blocks. The last tires were decent in the snow, but not exceptional, so I'm not expecting these to be any worse.
I only have about 1k miles on them, but so far, I'd definitely recommend them, as would most of the reviewers on Tire Rack's site.
The cheapest gas on our trip was in Missouri about 30 miles west of St. Louis 87 no ethanol @ $1.64.
Sounds like yours are in good shape, regardless
My guess is that the octane is way, way down the list of factors that affect pump price.
Numero uno is TAXES, then MARKETING, then "formulation" (where the additives and/or seasonal blend is either widely available & cheap or is short supply), then perceived 'commodity cost' (i.e. the raw Crude Price does get reflected at the pump, but mostly with a leading rise and a lagging fall...) and THEN the actual octane rating. And NO, I do not beleive that 93 octane cost anywhere NEAR 20 cents a gallon more than 87 octane...
http://www.taxadmin.org/fta/rate/motor_fl.html
Two months ago the price for 87 octange here in Indianapolis was as low as $1.35/gallon. By the end of July prices had jumped to $1.65 at some stations, while the lowest was still $1.40. Two weeks ago the cheapest price I could find was $1.60. This morning I saw $1.45 again.
Octane 87 -- $2.15, Octane 89 -- 2.25.
I haven't seen ANYTHING lower than $2 for more than a month here in SoCal. Now how's that?
I wonder how Gray's bill to allow illegals to legally get drivers licenses will affect your insurance.
I run mine at about 33PSI. My CR-V rides a bit harsher, but I haven't noticed any handling problems.
It is interesting, but UNDERINFLATION contributed the tire failures on the Ford Explorers a couple of years ago. They were being set to 24 PSI, but then the Explorer is a larger and heavier vehicle.
underinflation is the big problem with most cars.
If your engine light comes on, surely you can show the dealer the light? If you bring your car in for warranty service before the warranty expires, and the dealer cannot fix it but acknowledges the problem, I think you have a good legal case that the dealer must ensure it is fixed, even if the problem continues past the official warranty period.
15 trips to the dealer in 3 months is something like once every three days. If this problem as consistent as you report (happens every time the A/C is used), then I would recommend finding another place to service the vehicle.
The rear differential uses a special fluid Honda calls dual pump fluid. It is not automatic transmission fluid and can not be replaced by automatic transmission fluid.
Since my '99 EX is a 5 speed I don't know anything about the automatic transmission, but I'm sure someone else will answer your question.
I took a look at the Max-Gear web page. I don't think it will work with the CR-V, since the rear differential isn't a simple differential like most vehicles with rear drive or 4WD. The RT4WD rear differential is a complex hydraulic mechanism.
In very simplistic terms, within the rear differential there's one hydraulic pump attached to the front axle and one hydraulic pump attached to the rear axle (hence, Honda's "dual pump" terminology). As long as both axles are turning at the same speed the hydraulic pressure is the same from each pump. Once the axles turn at different speeds, indicating slipping of at least one wheel, the difference in pressure output of the pumps causes a clutch system within the rear differential to engage, transfering power the rear wheels. So the fluid in the rear differential isn't gear oil like you find in a normal differential, but is something closer to hydraulic fluid. The Honda website notes that the "Real Time™ 4-Wheel Drive is a hydraulically actuated system..."
http://www.edmunds.com/townhall/chat/townhallchat.html
6-7pm PT/9-10pm ET. Drop by for live chat with other members. Hope you can join us!
kirstie_h
MODERATOR /ADMINISTRATOR
Share your vehicle reviews
I can direct you to an article on the subject, but I cannot link it here. The site requires registration (free and no spam), but it's well worth it.
I have a problem with my 2000 CRV. If anyone of you have similiar problem or can provide some clues for me and my "beloved dealer", appreciate your help.
The problem is whenever I drive the car over 40 miles/hour and release the gas pedal, there is a weird noice coming from somewhere. The noice sounds like wind blowing through forest. The noice will die down when the speed is below 40 miles/hour and no gas; and put the gear on idel will not make the sound disappear, However, if you apply gas (accelerate the car), the noice will be gone.
The noice comes out (I swear) after my dealer did 30k maintenance on my car. When I first heard the noice and sent the car in, they are so sure it is the decelerator problem: someone did not put enough oil into it. But later, they told me they could not find out the cause, and claim all CRVs have similar noice.
My question is have you guys heard any strange noice when over 40 miles/hour and apply no gas? Do you know whether this is a general defect or just
my luck?
do you have bad gas mileage or any other symptoms?
