Sounds like your car was heavily modified (OK, hacked) by the previous owner(s). Wouldn't make me comfortable, either.
I've toyed with the idea of getting a 2002 or 2003 Aurora cheap once my '98's paid for, but don't know for sure. Sat in a new GTO Saturday and liked it a lot, but I'd heard of the Monaro/surfed the Holden web site before Lutz even saw the car and got the idea to bring it over here. I wouldn't buy one at least until the next model year (wait for the inevitable second-year changes, though the GTO's only got a 3-year run in its present form - maybe it's time to buy low in year 3 before the American-made Sigma-Lite/VE one comes out).
--Robert
Pin 87a of the series/parallel relay is ckt 409 light blue connecting to the non-ground side of secondary cooling fan motor and to pin 30 of the high speed relay.
Each of the three relays has a pin 30. For the low speed relay, pin 30 is connected to the 60-amp fuse by red ckt 642. For the series/parallel relay, pin 30 is connected to one side of the primary cooling fan motor by white ckt 504. For the high speed relay, pin 30 is connected to pin 87a of the series/parallel relay and to the non-ground side of the secondary fan motor by light blue ckt 409.
There is a diode wired across the terminals of the primary fan motor. I do not know if this is the diode referenced in the SB.
I analyzed the wiring diagram and here is how it all works: 1) with neither ckt from the PCM activated, neither fan receives power; terminal A of the secondary fan motor is grounded directly to ground point G103, and terminal A of the primary fan motor is connecteded indirectly to terminal B of the secondary fan motor. Terminal B of the primary fan motor is open.
2) with PCM pin 32 (cooling fan 1 (low speed control)) activated, the low speed relay connects power from the 60-amp fuse to terminal B of the primary fan motor. Terminal A of the primary fan motor is connected to Terminal B of the secondary fan motor through the series/parallel relay. This puts the two fan motors in series so that both operate at 1/2 voltage (assuming the windings are the same).
3) with PCM pin 33 (cooling fan 2 (high speed control)) activated in addition to pin 32, Terminal A of the primary fan motor is grounded through the series/parallel relay, and terminal B of the secondary fan motor is connected to the 60-amp fuse through the high speed relay. Now both motors are connected in parallel and receive full voltage.
4) with PCM pin 33 activated without pin 32 activated, the primary fan motor receives no power and the secondary fan motor receives full power.
I believe scenarios 1, 2, and 3 are valid. I do not know about scenario 4.
This is one of those cases where a picture is worth 1000 words. I can mail you a copy of the diagram if you give me a mailing address.
So the 60 amp feeds 2 relays in Hi-speed parallel or 1 in Low-speed series. That still doesn't explain the deficiency of 10 guage wire on a 60 amp circuit. If I can lay my hands on an ampmeter I'll full that fuse and actuate the fans by turning the A/C on to determine the draw. Maybe it will be low enough that a lower amp (safer) fuse can be used. Sure would be a mess to burn up the wire harness from the fuse all the way to the firewall relay and beyond.
#1088--TPS reset
#1121--Idle relearn
You're right about the 60-amp fuse feeding a 10 gauge circuit. I'm thinking that maybe the high fuse rating is to handle high start-up current for the fan motors; the 10-gauge wire is not a factor then since it does not have time to heat up. But, there is no protection for a longer-term situation where current may exceed 30 amps but not reach 60.
I think you are right about the diode having been added to the 1997 service manual, since the SB was for '95 production. The component locator states that the diode is in "body harness, between splices S141 and S143 near secondary cooling fan motor." Seems strange that it is near secondary fan instead of near primary fan; there is a diagram that supports that statement.
I found a 7-page diagnostic for the cooling fans in another section of my service manual. It verifies my analysis of operation. It includes parameters for operation.
Low speed operation occurs when:
1) coolant temp exceeds 229F
2) trans fluid temp exceeds 302F
3) a/c operation is requested
High speed operation occurs when:
1) coolant temp reaches 234F
2) trans fluid temp exceeds 304F
3) certain DTCs are set
I'm surprised that the temperature points for low-speed and high-speed operation are so close together.
I omitted something from my last message. When I replaced FPR, I did not need to do anything to initiate a relearn. Either it wasn't needed or it was done automatically without any intervention by me.
Dang just got back from a test run. She's not. About 66 at 2k and it cuts out just shy of 110.
Yea the top-speed sprint is a very easy determinate. Mine (an Autobahn)was pulling very, very nicely to 125 till I had to back-off for traffic.
The fuel pressure regulator is a diaphragm-operated relief valve with fuel pump pressure on one side, and regulator spring pressure and intake manifold vacuum on the other side. The regulator's function is to maintain a constant pressure differential across the injectors at all times. The pressure regulator compensates for engine load by increasing fuel pressure as engine vacuum drops. The pressure regulator is mounted on the fuel rail.
The cartridge regulator is serviced as a separate component. When servicing the fuel pressure regulator, insure that the back-up O-ring, large O-ring, filter screen, and small O-ring are properly placed on the pressure regulator.
With the ignition On, and engine Off (zero vacuum), system fuel pressure at the pressure test connection should be 333-376 kPa (48-55 psi). If the pressure regulator supplies fuel pressure which is too low or too high, a driveability condition will result. Refer to Fuel System Pressure Test for information on diagnosing fuel pressure conditions.
easier ways to find out....
I did enjoy checking the anti-lock with the salesman riding shotgun though. Inspires me with a slogan for breaking the seat-belt law, "Break The Law, Break Your Face"
The flame popped out the PCV fitting on the front valve cover. No fuel leaks (other than the FPR).
How do you know yours isn't flooding? If the FPR leaks, the leakage goes straight to the intake manifold through that little black hose.
Anyway I woould at least check and if necessary clean the throttle plate and bore.
I certainly agree with blk97aurora. The fuel has no where to go after it leaks except into the intake tract ans then into the combustion chambers, hence the backfires.
I want to see if anyone here know the bulb size that's behind the Trunk & Fuel release switch and Interior Lights & Twilight Sentinel switch also?
Any help on this is greatly appreciated.
I'm working once again on another project, I'll keep you all updated.
Peace.
Http://www.cardomain.com/id/javidogg
I tried many avenues for replacements. Olds dealer and ACDelco supplier both said they are not available separately and suggested buying new switch assemblies to get the lamps. Huh?
I ended up buying used switch assemblies off eBay to scavange the lamps (and to have spare switches). Also pulled a couple of them (clear not blue) from an extra HVAC control from my '86 Toro.
I really think they should be available from sub-miniature lamp suppliers (like Chicago) but I gave up trying to find the right item. If you're interested, I can dig up my research from a year or so ago.
Les
I am trying to program a second keyless remote for my 2001 3.5 litre.
First of all can anybody help me with the procedure so I can do it myself. I read a few posts on the subject, but none seem to be for a 2001.
Another dumb question is where is the DLC on the 2001 and what does it look like.
Looking forward to a reply
Thanks in advance
The Nacc
2001 Oldsmobile Aurora
Data Link Connector (DLC): Double row 16 terminal connector, lower left side of instrument panel
Document ID# 642973
Keyless Entry System Description and Operation
The keyless entry system is a supplementary vehicle entry device. Radio frequencies or discharged batteries may disable the system.
Keyless entry allows you to operate the following components:
The door locks
The rear compartment lid release
The illuminated entry lamps
The panic alarm (instant alarm)
The keyless entry system has the following main components:
The transmitters
The remote control door lock receiver (RCDLR)
When you press a button on a transmitter, the transmitter sends a signal to the remote control door lock receiver. The RCDLR interprets the signal and activates the requested function via a class 2 message over the serial data line.
Unlock Driver Door Only
Momentarily press the UNLOCK button in order to perform the following functions:
Unlock the driver door only.
Illuminate the interior lamps for approximately 25 seconds or until the ignition is turned ON.
Flash the exterior lights (if selected ON in personalization).
Disarm the content theft deterrent (CTD) system.
Recall the memory seat and the memory mirror positions for that driver.
Unlock All Doors (Second Operation)
Momentarily press the UNLOCK button a second time (within 2 seconds of the first press) in order to perform the following functions:
Unlock the remaining doors.
Illuminate the interior lamps for approximately 15 seconds or until the ignition is turned ON.
Chirp the horn (if selected ON in personalization).
Recall the last radio station for that driver.
Lock All Doors
Press the LOCK button in order to perform the following functions:
Lock all of the doors.
Immediately turn off the interior lamps.
Arm the content theft deterrent (CTD) system.
Rear Compartment Lid Release
If the vehicle transaxle is in PARK or NEUTRAL and the ignition is in the OFF position, a single press of the rear compartment release button will open the rear compartment lid. The interior lamps will not illuminate.
Alarm
A single press of the panic button performs the following functions:
Illuminates the interior lamps.
Pulses the horn.
Flashes the head lamps for 30 seconds or until the following conditions occur:
The panic button is pressed again.
The ignition switch is turned to the RUN position with a valid key.
The vehicle is unlocked with the key.
Keyless Entry Personalization
The exterior lamps and horn chirp may be personalized for two separate drivers as part of the remote activation verification feature. For mode descriptions and programming instructions, refer to Driver Personalization in Personalization.
Rolling Code
The keyless entry system uses rolling code technology. Rolling code technology prevents anyone from recording the message sent from the transmitter and using the message in order to gain entry to the vehicle. The term "rolling code" refers to the way that the keyless entry system sends and receives the signals. The transmitter sends the signal in a different order each time. The transmitter and the remote control door lock receiver (RCDLR) are synchronized to the appropriate order. If a programmed transmitter sends a signal that is not in the order that the RCDLR expects, then the transmitter is out of synchronization. This occurs after 256 presses of any transmitter button when it is out of range of the vehicle.
Automatic Synchronization
The keyless entry transmitters do not require a manual synchronization procedure. If needed, the transmitters automatically resynchronize when any button on the transmitter is pressed within range of the vehicle. The transmitter will operate normally after the automatic synchronization.
Javi,
Les
____________________________________________________
Hey Les,
Thanks for the heads up, well after some surfing on the web, I ran into a guy that makes his own LED retro fiting into a socket style bulb like the one we use on our Aurora's.
So I'm currently working with him on this.
We'll see how it turns out.
Also that's kind of wack, how GM and AC Delco and the Olds Dealer recommend it buying a new part to replace them tiny bulbs.
I just wanted to know the bulb size for that part for now.
We'll see.
Peace.
The package designation for these bulbs is "T-1 neo wedge."
Can the programming be done without going to a dealer?
If so, how does one go about doing the programming by himself?
Thanks in Advance
The Nacc
