Regardless of any other issues, the coolant fans should go on by themselves. By passing this system with a switch suggests to me that the mechanic doesn't know how to fix the coolant fan problem.
If the jury-rigged switch cures the overheat, then he has to go back and fix the original system.
The traction control theory sounds a bit wiggy to me. My advice to people, and to myself for that matter, is always take the simplest answer first, and deal with that.
So if the engine shuts off, someone has to first get control of the overheating, and then be ready with a fuel pressure gauge and a spark tester as soon as the engine cuts out.
Although you can put a short piece of jumper wire in the relay & power distribution panel to force the fans on high full time, this is a bad idea except for test purposes. Forcing the fans to run full time fast will likely stress them and maybe kill the motors. More expense to fix the original problem.
Have a check to make sure you have the added diodes to the fan circuits. If they were not originally installed, depends on year, there was an added jumper harness near the fans to add them. Without them, there is known TSB relating to ABS system because the spikes can kill any electronic component and TSB specifically to the ABS system.
With the traction control problem, it could be causing the system to initiate, even mildly causing the brakes to drag and thus working the engine harder it will overheat.
The temps you mention are within the normal scope of the system so even with the fans forced to run on high full time you will find yourself stranded on a hot summer day.
Fix all problems related to codes for check engine light. (It might even be the computer.)
It sounds like you are dealing with a shade tree mechanic or two. Was the big repair bill related to this issue? I'd definitely be talking to that guy, maybe about getting some money back.
Your problem may not be an easy one and thus might need someone who has really good equipment that can read the computers. Although a few might have some really good expensive equipment, only the dealer has equipment that can go the full yardage. That is reprogram the computer if necessary. If a non-dealer shop finds you have a bad computer, buys one for the vehicle, they will have to take it to the dealer to get it programmed!
Any GM dealer can do that, but as to who is most knowledgeable relating to this machines powertrain computer system, it is likely Cadillac. This vehicle shared a lot of the same, the Aurora 4.0L engine is a Cadillac. It is the down-stroked twin of the 4.6L
The low oil pressure sounds significant.
These vehicles run with a very low oil pressure when warmed up.
And to make sure we are on the same page, maybe you can create in your signature which vehicle specifically. The year and the engine if you don't have the common 4.0L, so that we don't have to keep digging back to find what you have. A simple one line of text with that info, created and then copy, paste into each post. Thanks.
Assuming 4.0 since it is most common, get an accurate oil pressure guage, tee it into the port of the sending unit and monitor. See if it actually drops to the signal point of shutting down. If not, then you have wiring or computer problem.
If it does drop, check to see if you have oil cooler & or the adjustable valve for diverting flow to the cooler. I think that valve can be worked with externally, that is other than adjust. And someone may have altered the adjustment.
Other than that, I suspect you have serious problems that likely require tear down.
Failing oil pump, engine wear that won't allow sustaining even the low required pressure, an internal leak such as a failed headgasket that is allowing oil to be dumped back to the crankcase before reaching the head, etc.
Make sure you have the proper viscosity oil, 10W30, at all times. Someone may have put in the wrong stuff such as 5W30 or 0W30 and that might be your only problem. You might even have a defective oil filter where the bypass valve is stuck open.
If you are at the teardown point, it is time to make some serious decisions. How is the vehicle over all?
Consider a new engine and possibly tranny. One thing I can tell you, I regret moving out of my 96. A damned hard vehicle to find something comparable to. New ones can be gotten with most of the same features plus a few extras such as navigation and bluetooth, but to replace the ride and handling seems to be a priceless affair. If mine had been very good other than tranny and engine, I would have kept. I'm now considering looking for a clean one, classic style, and putting in engine or tranny or both if necessary. Fuel is pricey, but cheap compared to fuel and payment of anything that will come close to this vehicle.
That should be OK oil. But there is a small possibility that it was packaged wrong if it turns out to be an oil pressure issue. I had a 79 Pontiac Bonneville that although high mileage was in very good condition. I decided to start using Mobil 1 in it and only change every 12K which worked out to once a year for my wife. I forget the exact weight of oil it was supposed to get, 10W30 I think. But the locals only had a different weight in stock, maybe 10W40. I used that for a couple of years and then one store got the proper weight and I got a case, 6 quarts. I did my change but noticed there really was a big difference as it poured from the bottle. By time I reached 6K I had to add the sixth bottle. I had picked up a couple more by the time I was at 12K and then bought another case. Wait a minute, this stuff looks much more like the previous weight I was using. I called Mobil wondering what was going on since the only conclusion I could come up with was that I got regular oil in a Mobil 1 bottle. And after pressing the guy, he admitted that they were bottled on the same line. The car continued to use oil after that.
Note: Penzoil used to have the reputation for cleanest engines. Typically their oils had always had a reddish hue until a few years ago. The last I used it, it seemed to have a bluish hue, like the additive package they also make. And Quaker state for the dirtiest. Older experienced mechanics could tell you in a second if you were using either of these. Other oils were in between. The Quaker bragged about no leaks and with good reason. There would be so much crud buildup it would be near impossible to leak. Tore one open myself and it looked like the dinosaur lived and died in it.
What I said toward troubleshooting, earlier message, still goes.
I've searched parts wherehouses, local boneyards, after markets (autozone/checker/napa), and no other options.
Before I give the dealer my son's dental money, does anyone have any other thoughts?
Thanks Everyone! Have a super Monday!
Russ
LOOKS LIKE THIS
http://www.makcotransmissionparts.com/D84410H.html
So must be part of the detent plate that locks you into each gear, as you can see.
It seems most of the guages were fed directly from computer but with all those items not working it seems likely you have power not being fed to where it needs to go.
You might want to subscribe to ALLDATA DIY (www.alldatadiy.com) for around $29 bucks and this will show you step by step for this, and many other procedures for your car.
My question is this....... Could a failing relay cause the fuse to keep blowing? And could I just swap relays with another one to test it? or are they all different? Any suggestions would be appreciated.
When was the last time O2 sensors were changed, you might get a code.
The FPR can leak internally which will put fuel present at the vacuum line. Check for parts that have been replaced with non-GM such as plugs. Also a weak or bad coil can show up this way.
How did you solve the problem? My mechanic found replacement parts at Cadillac to the tune of $1000. Does that seem right?
In addition, did you have any further problems with your car? If I put this much money into my car I'd want it to last a good while longer.
I'd suggest you use a private, trusted, experienced mechanic to verify Cadillac's first opinion of the problem and the solution and get a quote from him. If you don't have a trusted, private, experienced mechanic.....get a recommendation from a friend or family member. BTW....I have an "electrical" guru apart from my nuts and bolts guy, and he handles the Aurora gremlins at half the cost. Both of my mechanics deliver the first time every time with NO BRING BACKs.
Not one dealer mechanic touched my Aurora after the extended warranty expired in 2005. Yup, aside from routine maintenace (brakes, etc.) there were a couple of expensive visits to the shop after that, but to me the car was worth it.
When I had my idler arm tensioner replaced, my mechanic had to use an engine hoist to get at it all.....I saw the car with the engine partially raised on an engine hoist and was horrified, anticipating the labor costs. The engine mounts were replaced at that time (precautionary). Since labor was already pretty much a sunk cost to raise the engine to get at the tensioner, I had him replace the A/C compressor, still working fine but for the price of the part, the mileage/age of the car, and my intention to keep it, it seemed like the cheaper thing to do to save money down the road.
The mounts, A/C compressor and the associated labor, including all of the engine raising labor.... these came to about $1,400 of the total bill.....and the compressor alone was a $680 part.
At that time (besides the idler pully tensioner replacement, I also had a new thermostat, water pump, and hoses done as well....as the water pump was starting to seep coolant. Radiator had been replaced a year earlier, a leak at the neck.
Most recent issue 11/09: fuel pump quit at 114,000 miles, and the neck on the gas tank was completely corroded away, couldn't bolt the new fuel pump back up. Had to drop the entire rear suspension and exhaust to get the old tank out and to put the new one in. Total charges were about $1,450 for that one.
Transmission, exhaust, and suspension on the car still original and untouched!!!
This is the most enjoyable vehicle I have owned in 43 years of driving, but it has been more problematic than any of the others I have owned. The aggravations have been worth it to me. Daily driver. No regrets. But that's me and my experience.
Only you can decide how and when you want to spend, and functionally what the Aurora is worth to you.
Question: What is the minimum, acceptable oil pressure reading when the 4.0L engine is warmed up to normal operating temperature and the RPM is at, or about, 800-1000 which I encounter when stopped at a red light?
When cold, oil pressure is 60+; digital oil pressure reading can dip to 8-10 when stopped & idling. Oil pressure rapidly rises upon acceleration.
Thanks for any words of wisdom you may have.
The Texas Shadow 12-04-2010
I think it is not uncommon to see the oil pressure drop under 10 psi at idle of 700-800rpm with the engine fully warmed up for a while and the oil hot. I think one guy noted the manual said it should not drop below 5 psi at idle.
Never checked mine at idle but it tops 60psi when cold and runs at about 34 psi at 2,000rpm when the engine has run at operating temperature (195-200 degrees) for about 5 minutes.
In-car gauges can be inaccurrate to begin with. And the Aurora oil sending unit can go bad, but it is cheap to fix.
