Visitor Agreement.
So, how much longer are you keeping the LeSabre? Gonna try for 200K?
Best Regards,
Shipo
Repairs are cheap. New cars are not. Probably will replace with a used car next time that's a couple of years old.
Best Regards,
Shipo
Hmmm, not sure I agree. Why? The OBC, which is fairly consistently reporting about 4.5% above actual, and as such is the only relatively even unit of measure that I can use. Where as using the actual fuel pumped into the tank divided by the miles driven and averaged over a long period of time will show actual MPG numbers, the OBC can give you an "Apples to Apples" measurement from tank to tank. Performing a tank by tank analysis with the amount of fuel pumped at each fill-up will give invalid numbers due to the fact that each and every fill-up is susceptible to the vagaries of when any given pump shuts off. Even if one used the same pump every fill-up they are highly unlikely to stop filling at exactly the same point each time due to factors such as the angle of the nozzle in the filler neck and the GPH rate of the pump (which often varies depending upon the number of folks filling their cars at that same instant).
"I was just curious what premium fuel would do on this older vehicle. Did it seem to run any better/worse?"
According to my patented "Butt Dyno", there was zero difference in drivability. I'm now running Regular fuel and once again, I can detect no difference in how the engine runs. That having been said, today was probably a bad time sense anything as I drove to work this morning through a fairly heavy snow storm (over two inches fell while I was driving), and as such my ability to 1) drive smoothly (due to other cars and poor road conditions), and 2) accelerate at a reasonable rate were both negatively impacted. If I notice anything tonight I'll let you know.
Best Regards,
Shipo
i'm actually looking at the data for the first time, and wish it was a bit more complete (no offense, i still think its great you are doing this). Tank 6 seems like it was pretty important given that there was a slight uptick in mileage at the 3.0 oz acetone mark. Might be garbage, might not be. But, if I average all the OBC numbers up to that point, I see a 3% increase in mileage at tank 5, and a 4% increase using the calculated mileage numbers.
Of course, you know I'm not a proponent of the acetone at this point ... but I guess I'm playing devil's advocate. Someone COULD argue that you were seeing an improvement, but cut the experiment short at that time.
Then again, as you've stated, all the numbers so far were below your original benchmark. Guess we'll see if you can get back to and maintain that 22.5 pre-acetone mark.
Looking back at the notes that I posted with the results of my first 3.0 oz Acetone tank I found the following that would more than explain the "uptick in mileage":
Traffic and curiosity lead me to drive this tank like I was a little old lady, in an attempt to see if I could get back to my pre-Acetone 22.5 OBC readings. Nope. Even with using every fuel conserving trick I know (not how I normally drive mind you), I still only got the OBC display back to my best reading since my first Acetone tank. That having been said, I did get the best calculated mileage of any tank while on this test.
I remember that tank and how hard I tried to get the best mileage possible, which is something that I refuse to do on a regular basis. What was so frustrating about that tank was that had I applied the same conservation techniques to a tank of fuel from before the test, I would most likely have gotten close to 24 mpg. This is of course speculation; however, that I only got 21.2 on the OBC meant to me that the 3.0 oz. ratio wasn't doing anything for my mileage.
As for "What's next?" I'll probably go a few tanks with exclusively ExxonMobil Regular, plot the mileage from them and then try the 3.0 ratio Acetone again, this time with no more than two or three tanks of ExxonMobil Regular. My bet is that my mileage will once again drop. Should be interesting.
Best Regards,
Shipo
Tank ---- Mileage ---- Miles --- E/T ---- MPH --- Gallons --- per 10g ---- OBC --- Calc ---- Brand
Start ---- 102,808
Tank1 -- 103,102 --- 294.3 --- 6:43 --- 43.82 --- 14.883 ---- 2.0 oz ------ 21.2 --- 19.77 --- Shell
Tank2 -- 103,444 --- 341.3 --- 9:36 --- 35.55 --- 17.727 ---- 2.0 oz ------ 19.7 --- 19.25 --- Shell
Tank3 -- 103,765 --- 321.6 --- 7:45 --- 41.50 --- 16.206 ---- 2.5 oz ------ 20.8 --- 19.84 --- Shell
Tank4 -- 104,109 --- 344.6 --- ?:?? --- ??.?? --- 17.907 ---- 2.5 oz ------ ??.? --- 19.24 --- Shell
Tank5 -- 104,467 --- 357.9 --- 9:08 --- 39.19 --- 17.603 ---- 3.0 oz ------ 21.2 --- 20.33 --- Shell
As a scientist, this is very interesting, but to have any confidence in your numbers you must have only one variable. You would have to drive the vehicle in exactly the same way for each tank at the same temperature, humidity, wind velocity, tire pressure, oil age, filter age.
The proponent of acetone in this discussion seems to have disappeared but had promised high gains. I'm not sure why because there's no money to be made selling acetone as an additive like some other products might be sold.
I just hope Shipo's car is unharmed for his use and for whoever he sells it to. I understood he has it up for sale.
What will be even more interesting (and what I expect by the way) is if my mileage returns to pre-test levels now that I'm not adding the Acetone any longer.
To take this a step further, over the years I've invested considerable time into researching the early years of intermittent combustion technology and have read any number of scientific studies published by the likes of the NACA and SAE that show zero or negative efficacy of Acetone when used as a fuel additive. Unfortunately, given the age of the studies (some going back to the early 1920s meaning that there is no electronic "search" capability) laying my hands upon the exact studies and then finding the exact language has proven difficult/time consuming. The problem is that since TEL was my primary focus when reading such reports, my notes don't reflect where I came across Acetone references. Be assured, if/when I come across any supporting science, I'll be sure to post the relevant information.
Best Regards,
Shipo
Nope, not selling it just yet. I'm most likely going to flog it for another year or so in spite of the fact that I want a new one NOW. ;-)
Best Regards,
Shipo
I guess that another way of looking at this is that now that I'm back on untainted Regular gasoline, I should easily be able to get back to my pre-Acetone test baseline of 22.5 mpg (per the OBC).
So, without further ado, the numbers:
------------- Total --------- Net --------------- AVG ------------------ Acetone --- MPG --- MPG ---- Fuel
Start ---- 102,808
Tank6 -- ???,??? --- ???.? --- ?:?? --- ??.?? --- 15.593 ---- 3.0 oz ------ ??.? --- ??.?? --- Shell
Tank7 -- 105,102 --- 635.3 - 16:36 --- 38.27 --- 16.712 ---- ?.? oz ------ 20.4 --- 19.67 --- Mobil
Tank8 -- 105,468 --- 365.4 --- 9:22 --- 39.01 --- 17.842 ---- 0.0 oz ------ 21.5 --- 20.48 --- Mobil/Prem
Tank9 -- 105,825 --- 357.0 --- 9:35 --- 37.25 --- 16.839 ---- 0.0 oz ------ 22.2 --- 21.20 --- Mobil/Reg
Best Regards,
Shipo
Start ---- 102,808
Tank10 -106,073 --- 248.1 --- 6:10 --- 40.23 --- 11.531 ---- 0.0 oz ------ 22.6 --- 21.52 --- Mobil/Reg
Best Regards,
Shipo
Please, don't waste our time
Best Regards,
Shipo
ya know what i keep picturing is that I'm going to throw this tablet in my gas tank and it expands into a 2-foot sponge dinosaur.
Question: How do you get a two foot dinosaur sponge out of your gas tank? ;-)
Best Regards,
Shipo
I think it it 100 octain. Sold here at the 76 station.I have an 04ctsv. I was told it would clean off the valves and injectors. Is that true?
So short answer....could be good, could be a complete waste of money. Best way to know? Go to your local track and try some 1/4 times with and without and see if the difference can't be explained by driver skill.
I've been reading along with this thread for a while now. I thought the whole acetone test was quite interesting. Unfortunate that it proved to be only a myth, or at least for the little Shipo tested.
The only products I've ever used are the standard fuel injector cleaners and such. Nothing really promising increase mileage or anything. Well I didn't expect to see any big gains anyway. Being some what of a gear head I came up with an idea, but I have no clue whether or not it would work.
On the market are Air/fuel ratio monitors/controllers that you can buy as a performance upgrade for your car. Basically what they do is monitor the oxygen content of your exhaust and adjust the engine ECU fuel curve. As far as I know it doesn't really give any indication of fuel consumption, but if you paired it with Shipo's OBC you could have something useful. In theory, as with most claims about fuel savings and such, you could reduce your fuel curve and sacrifice some performance by leaning out the combustion mixture. This in turn could reduce your overall fuel consumption and increase your MPG.
For some of the articles I've read before on performance magazines and such, car manufacturers tend to set-up the ECU to run a little rich so it is more likely to get combustion.
Any thoughts on this?
Yes actually, quite a few. That having been said, I'm going to have to wait to get home before I can formulate them into a coherent post.
In the meantime I'll leave y'all with one parting comment:
It is my educated but never-the-less personally belief that the combustion process has been well understood from a scientific perspective since long before most/all of us were born. Said another way, I am personally highly suspicious of any and all claims to improve the fuel economy of any given car (unless said claims came from the manufacturer of the car itself). Why? Simply because the manufacturers have it in their best interest to build the most economical car possible and to that end they spend many millions of R&D dollars (billions collectively over the years) searching for better ways of burning fuel. With that in mind, the likelihood of some magic bullet for fuel economy being developed by an individual, a small company or even a group of yahoos who get together on the internet is Well, let's just say it's very remote.
Another word of caution; my Acetone Test is anecdotal at best and should NEVER be used as the basis of any study or even serious discussion on the subject. If someone wants an authoritative source to quote on the issue, I'll personally refer them to the scientific archives of the SAE or even the old NACA (precursor of NASA) for material.
Best Regards,
Shipo
If I really wanted to be the devil's advocate I'd say that the car manufacturers are in co hoots with the oil companies and the government and it's all a big conspiracy.
Please send me a free sample. I'll be happy to check it out. Email address is in my profile--just read to the end.
The links that you see are to each distributors personal websites. And yes, that is what is given out because we are trying to make a living selling them.
If you think it's a scam just don't do it. I like to help people out and it really does work so it's your choice.
FWIW, it is against the membership agreement YOU acknowledged, to peddle your wares here.
FWIW-2, most of us here are educated enough to know a scam when we see one, and this one smells scamier than most.
That link does not seem to work. I traced it as far as NY City and it comes up a dead-end. Interesting for a company that is supposed to be out of Dallas.
You say you are trying to help people. I am trying to do the same. I am skeptical of all pyramid schemes and this is a typical PYRAMID scheme. I hope you did not mortgage the home to get in.
MLM Myth
Pyramid scams
So far, the dinosaur sponge hasn't been a problem.
If the link doesn't work, here is the gist of the message:
Those wacky Japanese scientists are at it again. Tokyo-based researchers at the Tokyo University of Agriculture and Technology have announced that they've discovered a new source of gasoline - Cow dung. No Bullsh*t.
Professor Sakae Shibusawa of the Tokyo University of Agriculture and Technology is reporting that he and his associates have figured out how to... ummm... extract .42 ounces of gas from every 3.5 ounces of cow patties using heat and high pressure. As Japan produces about 551,000 tons of manure per year, this could turn out to be a less-than-trivial discovery.
Scientists hope to improve the technology to the point that the process can be made commercially viable within the next half-decade.
[Source: The Los Angeles Times]
I saw another article where waste management in San Francisco is using pet waste in a similar fashion to produce methane for power plants.
Here it is:"Poo Power
Just think what could be done if they combined this with the sewage system!
