Ralph-
Just catching up here, so sorry for the delay.
As someone who drove as a livery driver on the weekends for 10 years in Brooklyn, I can say it is definitely educational, as well as fun. The reason I stopped is because it was not profitable anymore; drive for 12-13 hours, spend $20 on gas, and come home with $40-45. I like to drive, but I've found after stopping that I like sleeping later even better:-) I still have the license though, you never know.
Mark
I used to have a NYS chauffeur's driver license in college. I worked a couple summers for an old hotel - Minnewaska Mountain House outside of New Paltz, NY. I'd drive old (= old) wealthy (= stinking rich) widows from the Upper West & East Sides "up to the country" for their summer vacations.
The car was an old, gigantic black caddie limo that was 2 car lengths long. It was fun fighting (and pushing aside) the NYC taxis as I transversed from one side of Manhattan to the other. The widows would [non-permissible content removed] and complain, fall asleep on the way up and then tip me $40. (1980 $). It was fun and good summer job money...
I like to drive. I wouldn't mind doing airport limo driving when I retire - but I would never pick up passengers from the street. Dangerous way to live...
[Sorry this isn't a problem or a solution.]
Ralph
That being said, a brand name oil that meets the API specifications will do an adequate job. I log every tankful of fuel I put in my vehicles and find no MPG difference between Mobil 1 5W30 and Quaker State 5W30. In theory, the synthetics should extend the oil change interval, bu no automobile manufacturer will acknowlegde this, so if a warranty claim comes up, you need records of the oil changes at the manufacturer recommended intervals.
I love my Subaru, but feel the Quaker State will do the job for 25% on the cost of Mobil 1.On the other hand, if you want nothing but the best, go with a 100% synthetic. (don't bother with the "Synthetic blends", they offer almost no advantage.
Jim
-juice
Ralph- I didn't do street pickups, it was only radio dispatched. I'm not that nuts (I think).
Mark
-mike
Mark
-mike
-juice
Last weekend I had a minor little accident in the car...smacked into a dead deer in the middle of the road. The idiots that hit it never pulled it off the road...and drove about a mile down the road until their '00 Jetta stopped. Totaled their car! Only damage to my car is a broken plastic shield under the engine. The dealer (Calkins Subaru in Lewistown, PA) checked it out and suggested that I have the alignment checked because they could tell that it smacked the rear control arms pretty hard. Insurance is going to count it as a comprehensive claim...so at least I only have to pay $100.
Learned something today though...be careful loading up the trunk! I went to get some rock salt for the church...but 400 lbs in the trunk. The car was weighed down...but didn't seem too bad. However...when I started driving...the steering was SCARY! Very light...felt like I could loose control at any time. Needless to say...I unloaded it ASAP!
With 400 lbs, I'm surprised the load floor didn't cave in! That's probably the weakest part.
Craig
Well, I still cannot see how there would be pressure from one side causing fluid to come out the other since they're both vented cavities. If I had the diagram you mention more might come to me - feel free to scan it and send it to me offline.
Do they feel there's fluid mixing going on? Or is it just that some gear oil is getting forced out (which I can't agree with unless other fluid is being forced in - thus my question about the relative levels of each)?
IdahoDoug
Interestingly, the next Legacy is supposed to be a lot lighter. I bet it has fewer brake issues.
They can't fix the wind leak? Ask them to change the seals.
ebony5: probably a faulty sender. I think it's under the rear seat.
Depending on the value of the car, I might just rely on the odometer, zero it out after each fill up. It's more accurate anyway. Mine reads "E" even with 4 gallons left over some times.
-juice
Anyway, I smelled something burned right after the braking and it lingered for a while. Is this normal? Or is it something that needs to be looked into?
Thank you everyone for your help.
-mike
Just kidding, it's normal. I saw Motorweek test a Pathfinder Armada and that heavy beast took so much energy to stop that the brakes were visibly smoking.
-juice
Patti
Craig
Will be more gentle with the brake next time.
Ended up being the wear indicator on the rear brake pad assembly. Installed new rear pads / turned rotors (BTW Patti, off the car, since their on-car lathe has been broken for quite some time - "needs $3K repair and we think the off-car lathe is better."
For comparison purposes....with oil change/lube came to $280. - No. NYC suburban dealer - Curry Subaru.
Also, as someone reported earlier, jambed rear sunroof cover DOES require headliner removal! ARRGG! Crappy design... I'm going to try from the top if it ever stops raining around here...
Ralph
Greg
Call us about not getting the coupons. We can check into why. It is a dealer program, so I'm not sure why they didn't check into it for you. Probably someone unfamiliar with how it works.
Anyway, call 1-800-SUBARU3 and we can check into it for you. I'm glad it was just the wear indicators on the pads.
Patti
-juice
They are an excellent service department - and sales department. Please leave me out - although they are going to know it's me because I spoke to two mechanics about it Wed. night. If you could wait a couple weeks - or act like it is a routine check - that would be good. I'd hate to sour my relationship with them - especially because I'm thinking about getting another H6 (2005) Outback - to replace my Accord. Having a good working relationship with this dealership is key to my next purchase. They are also open Wed. nights and 1 mile from my house - can't beat it... Thanks.
Greg,
I did a bozo no-no yesterday by mentioning the salesman's name in my post...oops. Here it is minus the name...
Very happy. With the purchase and service.
Last night I asked why I never get coupons from them. They stated that they come directly from Subaru? I've never gotten any - I get "Drive", though. And I'm signed up at Subaru.com, although I hardly use it. Anyway they gave me 10% off my bill (they did it last time I had a high bill at my 30K service).
Straight-shooters.......so far.... :-)
Oh, also referred someone to my salesman from 3 years ago - NYFD member - last week. He purchased a WRX (mid-life crisis) and told me they are going to give me a $50. gift certificate. Haven't gotten it yet (could have used it!).
Ralph
No worry though. I'll wait.
Have a great weekend!
Patti
Second would be a bad thermostat - either installed wrong or just N/G.
I don't know if the 2.5 has a special bleed proecedure for purging air after the system's been worked on.
Anyone else have a clue?
Larry
DaveM
Patti
DaveM
Karl
-mike
-juice
Thanks for holding off a couple weeks. They obviously don't want to spend the $. I had the front rotors turned on our LLBean at 10K in the Fall of 2001 and it was broken back then...
BTW, the senior Subaru mechanic there [Darin] is really, really good - takes the time to explain things and does the job right (and is recognized - he has several Subaru plaques/awards). He is the main reason I'm holding off replacing our Accord right now - waiting until we can properly assess the 2005 Outback H6 sedan (features, etc.) this spring.
Ralph
I'd be a bit suspicious if that type of thing has been used in your vehicle, because it sometimes is a last ditch effort for people trying to avoid an expensive head or intake manifold gasket job (it really just delays the inevitable in that case). I've also heard used car dealers sometimes use the stuff to temporarily hide coolant leaks that would be expensive to fix.
I'm also wondering if it's possible for the sealant to settle in the wrong places and restrict coolant flow enough to cause problems. I have seen residue from it on thermostats and other cooling system components, but there doesn't usually seem to be a large quantity in any single location.
Patti
Craig
It's a great idea to offer something that one simply pours into the cooling system to quickly fix leaks in tough places, and possibly avoid costly engine repairs. Unfortunately, I've seen the store bought sealants fail to live up to their claims enough times that I just don't have much confidence in them.
-mike
If you recall, the service people at my dealer were very nice and very helpful, but it seems that they may have missed my problem?
My Miata's valves clatter like crazy when it's cold, but it goes away gradually as it warms up. Oil might help, but it hasn't caused any problems for me in about 3 years owning it (it's a '93).
-juice
Granted, first three times done under warranty at no cost to me but time. Dealer replaced rear rotors because he stated they were defective, but why not the fronts?
Now at 47,000 front rotors showing signs of warpage (shudder, wheel wobble on stopping, just like all the times b4).
And the wind whistles... they just keep coming back like a bad habit. Dealer says it's inherent in framelss window design, yet my '98 OB never had the problem.
Of course, called SOA, got terse woman who, after I explained my concerns, asked "well, what do you want us to do?" How about give me a set of brakes that last longer then 10,000 miles? She said "we'll et back to you". Yeah right, 2 months later and nary a word.
Needless to say, "lemon law" is brought up in conversations with friends, but not sure I want to persue that route. I suppose it's an option, but I'd rather just get this situation squared away without lawyers. I'm thinking of having the brakes checked by an independent who will let me in his shop and show me the problem, then go from there.
Any suggestions would be helpful.
I guess the only thing I will say is that the dealer could be part of the problem. If they fix your rotors and then the problem comes back, it could be that they are overtorqueing your lugs. That's a sure way to warp the rotors on any car. I know my dealer must use a wallop to torque my lugs, because I can barely get them off. Whenever possible, I always re-torque the wheels myself after any service (they usually pull a wheel or two off for state inspections). The dealer should know better, but I think it's a combination of lazy techs and service managers that just don't know any better.
In the case of both of my cars, the brakes were fine after the initial resurfacing, and we've got over 50,000 miles on the 00 car and over 30,000 on the 02 car.
Craig
