I'm sure a car audio shop could disarm your alarm quite easily but I don't have the wiring schematic, so I'm in the dark on that, no pun intended.
Could this be the alternator?
Joyce
Take it to an autoparts chain (pep boys, autozone, etc), they will do an alternator and battery load test, and can tell you whether your alternator is putting out the right voltage and amperage correctly, and whether your battery is holding it's charge and supporting the load. This is usually a free service they do.
If you get a set of schematics, you'd be able to troubleshoot the circuitry. I looked at helminc.com who have an online subsription service for like 10bucks for 2 days access, but they don't have your make vehicle.
If you can locate a set of schematics, I'll try to help diagnose your problem.
I will be forever grate full
Mike
e mail address digger_dog67@yahoo.com
Pull the connector off the power window motor.
Put a voltmeter across the leads inside the connector you removed.
Push the window button for 'up'. You should get 12 volts. Push the button for 'down'. You should get a 'reversed' 12 volts.
If you get these voltages, the wiring is ok, and the motor is failed. If you don't get these voltages, you have a wiring or fuse problem somewhere.
If i connected the wire to a 12 volt battery could i get the windowa to go up????
I don't mind them not working so much as them being stuck in the down position??
Yes, if you pull each door panel, you should be able to jump power directly to the window motor. If the window tries to roll down, just reverse the leads and it should roll up.
The 'up' and 'down' is accomplished by reversing the voltage thru the motor.
I jumped the windows to get them up. That is a relief. so I know the window motors are o.k. I checked every fuse at least 3 times. In a Park AVENUE there are four fuse boxes. Large one under the hood and a smaller one next to it That hold the large fuses. There is a set of fuses under the back seat, they all are fine. and there is a set of fuses under the dash on the passenger side and they are all fine.. lifted up the fuse boxes and checked to see if there are any loose wires going to the fuses and they are all fine. Still can't figure out why the windows and radio quit all at once. The rear windows don't work along with the master switch in the front.. as well as the radio. Dosen't seem like the radio has anything to do with the windows. Would a bad master window switch at the drivers door have any thing to do with the indivual window switches not working. I guess what I am trying to say is would a bad master window switch cause the indivual window switches to quit working.
IT IS GOOD TO KNOW THAT THE MASTER DOES HAVE SOMETHING TO DO WITH ALL THE OTHER WINDOWS. i'LL LOOK OVER THE MASTER AND SEE WHAT i CAN DO. iT LOOKS LIKE IT WAS WORKED ON BEFORE, SO IT IS A GOOD STARTING POINT.
I am looking to see how or if there is a way to program how my vehicle locks/unlocks the doors when it is placed in drive or park, how the lights flash when I hit the lock button on my fob remote and also how the horn sounds when the lock or unlock button is hit.
My vehicle is a 2004 Chevy Astro Cargo Van with a keyless entry system. I have figured out how to program new remotes, but I also wonder if there is a way to manage the other settings. I know that on my Impala I just use the radio to set all these settings, but my Astro has the old style (90's style) AM FM head unit. I'm almost postive there is a way to personalize these settings, but I'm not sure how to do it beyond programng the key fobs to work with the vehicle. Anyone out there know how to do this? If you have a late 90's early early 00's GM vehicle with the old Delco head unit with Keyless entry (especially GM trucks), I am sure they are programed in the same way. The instructions I found for the fob remotes were actually for an '01 Silverado
My left turn signal just started showing a fast flash indicating a burned out bulb, which I replaced...The bulb lights up but does not blink when I try the left hand turn signal...Tried reversing the right hand bulb with the left hand side...the right hand side continues to work while the left although is lit doe's not blink...
Hopefully some-one can be of some assistance with what might be the issue and solution...thanks in advance...
Simon
You have a 9 year old vehicle, which since batteries typically last about 4-5 years would be at the end of it's useful life....assuming you have had one replacement at the 4 year mark. It leaves me slightly suspect, since your battery is hard to get to, whether you have a lot of corrosion built up on your battery terminals causing high resistance to your power buss. What I would suggest since it is the simplest to do, is to get in to your battery and check those terminals for both corrosion and tightness. You should also check the connections on your negative cables where it connects to the frame, and the positive cable where it connects to the starter and main fuse buss.
Only after I checked all of that (the easiest to do), would I move on to this stuff. You're going to need either a competent shop who knows electrical problems and has access to your specific electrical schematics (like the dealership)...or if you are good yourself with electrical troubleshooting but a set of schematics. I would focus in the area of the main buss fuse back to the fuse box, the ignition switch relays. You may also have a computer prolem that has surfaced. This area is going to get expensive to diagnose, which is why my recommendation to focus first on the electrical basics.
I don't know where you can get electrical schematics online. For my chrysler products I've typically bought the manuals from the address in the back of the owners manual...but they are pricey. Don't know if you can find them online, HELMINC doesn't carry chryslers.
You might be better off taking it to a Chrysler dealer for repair.
If your mechanic has truly gotten a good battery in this car, cleaned the battery cables and checked for them being eaten up with corrision, I think you have an electrical problem that he has no idea how to diagnois.
That's because the alternator isn't charging. Jumping the battery let it charge up, then when you drove it, it used up that charge. That is a clear symptom of what happens when the charging system is not working. Any 1st year apprentice would pick that up.
I have just heard back from the mechanic and he said the battery is fine and now he thinks that it could be something to do with the ignition switch relays also.
He THINKS???
There shouldn't be any thinking in this diagnosis. It is clear that the charging system isn't working. He should start with determining what the alternator is actually putting out at the alternator and then to the battery. If the alternator is putting out charge voltage (around 13.5V) at the alternator and it isn't getting that at the battery, then there is a wiring problem.
I'm going to agree with Mr. Shiftright and bolivar. It is clear your "mechanic" doesn't have a full grasp of how the starting and charging system on your vehicle works, which is a shame, cause it is pretty basic.
By the way, did your "mechanic" happen to hook up a scanner to your vehicle to see what the PCM (computer) was reading your charging system at? I didn't think so.
The reason for that question is, your PCM regulates the alternator. No signal from the PCM, no charging.
My best guess is either the fusible link at the battery is blown/broken, Fuse T in the Power Distribution center is blown or the Field wire to the alternator is broken.
If all 3 of those are intact and have battery voltage to them, then the signal from the PCM is the problem.
Any auto parts chain will check both your alternator and battery under load, a free test. (autozone, pepboys, etc).
- You could have a bad battery
- You could have a bad alternator
- You could have loose and/or corroded cable connections
- You could have left something on (or something is defective which didn't turn itself off), which drained down your battery to nothing
- Some combination of the above.
The lights draw substantially more current than the other items. I suspect you have a VERY bad battery, or a couple diodes in your alternator are out and it's not able to produce enough current to charge up your battery or drive the lights.
You should have the battery charged, otherwise you might overstress your alternator and then you'll have TWO problems.
I killed my battery by leaving my lights on overnight. When I attempted to jump my car from my girlfriend's car battery I accidently switched the cables and connected them in reverse. I successfully started the car (by connecting the cables correctly). When I removed the cables from the battery the car stalled immediately. I was told by several people to replace my alternator. I replaced my alternator. After replacing the alternator and jumping the car again the car does not stall after removing the cables but idles very low. The problem now is that when I press the break pedal to put it into gear the car stalls.
I did not change anything except the negative battery terminal. I replaced it because it was rusted and broke off during the alternator changing process. The grounding block and negative cable are both connected to the new main terminal connection of the negative battery terminal. I made sure to connect the electrical wires securely to the new alternator also.
I should also add that I took my battery to both Advanced Auto and Autozone to be tested. Advanced Auto's machine did not say bad but said "replace battery" indicating to me that the battery is bad. Autozone's said "good battery". I was ready to replace the battery until I saw that. I would prefer to save money if it is not the battery.
Once again I appreciate any advice given.
With the motor running and alternator correctly charging the battery, you should see something like 13 to 15 volts.
Back to your problem. If you incorrectly connected the jumper cables, you might have done all kind of things in addition to harming the alternator.
You might have also melted a fusible link somewhere close to the battery. Or burned up who knows what computer - more than one if your car has more than one.
