When two new batteries died within a couple of days and the dealership couldn't (rather wouldn't deal with it because I didn't buy a replacement battery from them - Atlantic Toyota :mad: Amityville Long Island)under warranty, I traced it down to a damaged electric seat adjuster that got jammed in the "on" position. The seat adjusters in Toyota's work with the key out /off. As I suspected there was a electrical draw. [Quick lesson - by disconnecting the negative battery cable from the negative battery terminal, then hooking up a 12 volt bulb from the negative battery cable to the negative battery terminal with all switches and all electric turned off including the dome light, if there is a bright light, then there is a constant draw from the battery (which there was). If there is only a very dim light, it is normal.] I removed fuses one at a time checking the light bulb each time to see if it dimmed. When I took out the final fuse (isn't always the last one) the bulb went very dim which is good, almost no draw. That fuse was for the power seats. In checking the seats my son noticed that the power seat button was out of place and jammed in the "on" position! Apparently someone either jammed something between the door and seat or something caused it to break, but there is was - the adjuster switch was "on" drawing down the battery, even when the key is out!
I have a '99 Ford Expedition which is acting up. Everytime it rains, all of the electronic things in the car starts turning on by itself without the key being in the ignition. The heater would turn on, radio would turn on, engine lights would turn on but the car would not start if I was to try and turn it on. I know there is a short somewhere but where? Can anyone help?
ps: do they have to replace the actual part or can the code just be reset to fix the problem? Dealership says it is $180 to replace part and would take 1 1/2 hours, but I was under the impression from the mechanic that it was simpler than this to fix. any advice to help me not get ripped off would be appreciated.
But if there is an actual 'problem', the light will reset when the vehicle computer reads the error condition again when it is driven.
What does the 'mechanic' quote you to replace the part?
How sure is he that this is what is setting the light?
Has he used a code reader, gotten the error code, and 'looked it up' (or an expensive code reader may give him info on what the error code means)?
i'd make sure the coolant level was at the top of the radiator when the car was cold and that you had the proper mixture of coolant to water.
a battery and alternator isn't going to impact heater efficiency as far as i know... maybe you were adding detail to what you've replaced recently.
my thinking is maybe your water pump is sticking, or your belt driving the water pump is loose such that the pulley isn't spinning properly, meaning the blades inside the pump aren't pushing much fluid, and only when you give it gas is the fluid circulating properly because the pulley is spinning faster.
it's also possible the replacement thermostat is hosed.
maybe there's a coolant temperature sensor that gates coolant to the heat exchanger. don't know.
good luck.
anyone else with this kind of problem? ideas?
abranger
Anyone have any ideas?
Thanks very much for your thoughts.
With what you've done thus far, I guess that would be what I'd look for next.
It's also possible for moisture to move via capillary action between a wire and it's insulation.
Good luck!
Can the EC computer be the cause of a short downstream of the fuse? Can the circuits relating to fuel pump circuit traverse the firewall into the passenger compartment? Is there any wiring of the fuel pump circuits that can relate normally to "stop circuits" (like brake lights)? Can turning the steering wheel, maybe in combination with left turn signal, be a factor? Is the engine being at operating temperature a factor?
I am at the end of my ideas and will probably need to take it to someone with more expoerience and ingenuity to figure it out.
i'm stumped.
I had someone tell me today that they had this exact same problem with their GM truck and it turned out to be a wiring harness under the dashboard overheating and making contact with ground intermittently. A new $60 harness evidently fixed that. My schematic shows 12V hot going directly from the EC to the fuse but I am not sure the exact routing and is the reason why I was asking about wiring inside the passenger side of the firewall. I am going to poke around some more this weekend under the dash to see what I can see. Thanks for your continued interest. I'll let you know if I find it.
Any suggestions?
Bluetoo
That's 5 months ago!! I have no idea what's being discussed!!
A power seat may not have a fuse, it may have a circuit breaker. This is larger than a fuse, but these usually are in the same power box as the fuses. Or, it could be in a power box under the hood.
Thanx
or use an ampmeter that can handle a few amps.
when you pull the fuse associated with the circuit that has an atypically high current draw, the current flow should decrease dramatically.
hopefully this will help you localize the problem.
When driving,the dash instruments quit functioning.
Odometer goes blank spedo & tack stays at the speed I was driving.
Cruise control quits working. It may be off for a few minutes or hours. I suspect it may be heat related as it happens in the winter when the heater/defroster is on but never in the summer with airconditioning on. If I turn the heat to cold air things start working again in 10 20 minutes.
My friend suspects the problem lies in my Electronic Control Module, but he admits he doesn't know GMs all that well. I have the following questions:
- Does anyone else think this is the likely culprit?
- Would a repair shop be able to use their Snap-On Diagnostics to better pinpoint the problem?
- Is there any sort of traceable relay that might be fouled between the computer and the transmission?
- How likely is it that the problem resides in the transmission (I had it flushed a little more than a year ago)?
I appreciate any thoughts on what's ailing my car. Thanks.
