say the alternator isn't the issue, but instead some constant current draw while the vehicle is not in use.
you could do some sleuthing by using a multi-meter available at RadioShack or HomeDepot or Lowes and by pulling fuses one at a time to try to isolate the ckt causing the drain. You could do so by either looking at the voltage across the battery (from + to -), or the current draw of the vehicle electronics from the battery (i.e. inline with one of the legs of the battery). i don't want to be too specific here because there are a few ways to approach the problem and you should know how to use a multimeter or you should know someone who does.
can you say your dealership?
some people have even been successful using a 12V bulb in-line with the battery, or even across the battery looking for a change in bulb intensity when the fuse associated with the high draw is pulled.
let's see, in the case of across the battery terminals, a bulb would glow slightly brighter when the fuse associated with the constant draw is pulled (and a multi-meter set to VOLTS reading across the battery would read a higher voltage when the draw is disconnected as its associated fuse is pulled).
if in-line with one of the legs of the battery, a multimeter set to AMPs would indicate less current flowing when the draw is removed as the associated fuse is pulled.
does any of this make sense to you? it should to your dealership. if not them, to an independant wanting to earn your service $$. this shouldn't take them 5 days. 10-30 minutes perhaps.
I don't own a Benz, but in other vehicles I've heard that some people have issues with adjustable seats and their motors drawing current when noone is adjusting them (maybe because of a bad/stuck seat adjustment switch). i'd start with that circuit, or something associated with a moonroof (interesting that they said it might be those circuits), seat warmers or door and mirror motors or the radio. in general, i think it would have to be a circuit which would be operational even if the key weren't in the ignition. follow?
does the benz have any vehicle leveling technology (electric/pneumatic shocks)?
have one person watch the bulb or meter as you pull and replace each fuse in turn. the fuse pulled resulting in the biggest step change in meter reading or bulb intensity is a possible culprit of a constant current draw.
I hope this helps. Good luck.
I don't see any reason you can't get the oil changed at the quick lube place. Again, oil changes are the same as on any other make on the market today. The advantage of having it done at the dealer is that they are aware (or should be anyway) of maintenance and service problems on your specific model and can advise you of possible upcoming service and repairs, but of course there's a price for that type of service.
As for your fuel use, if your really getting only about 140 miles out of a FULL TANK,then there must be something wrong. That model holds 16.2 gallons, and is rated for 19mpg city and 26mpg highway, so you should be doing better. I believe that model should run on 87 octane, but I'm not 100% sure.
While I had been instructed after the first time to shut it off immediately to let the computer "reset", I did not on this third time until it had down about a dozen failures over a 30 min period to the point where nothing electrical worked inside, and there were 3 warnings: ABS Failure, Check Engine, and Airbag Servicing. Then I parked it for an hour. Started it up, the warnings were still there but all the electric was back on.
The dealer said: "Brake control module was fried and the battery needed to be replaced."
I can't help but think its another symptom and the real problem has not been found. Does it make sense for a faulty brake module to only act up when your hours into a highway drive?
P.S. You need better mechanics.
i believe the sequence lowers the likelyhood of getting shocked. there may be other reasons...
you could be wearing shorts and hanging over the vehicle and making contact with the body of the vehicle with some other part of your body than a hand.
think about it, if this weren't the case, then anytime anyone took a wrench to one (either) of the battery terminals to loosen the nut and remove the connector, they would get a shock. this is not the case.
you unknowingly had some path connecting the positive and negative legs of the battery through your body for a current to flow - plain and simple as that.
otherwise, maybe you experienced a "shock" from static charges built up in your body discharging to the vehicle, much like when you get out of your vehicle and touch the body of the car... that is the only thing I can think of here.
now then, yes there is a way to find a short or drain in your electrical system.
you could use a multi-meter set to volts and measure across the battery. as you remove fuses from your fuse holder one at a time and replace them, essentially pulling the fuse from the circuit with the short (or higher than normal parasitic drain) will result in the measurement of the voltage across the battery terminals to make an uptick.
now some ckts like the ECM or other probably always have a little draw through them, but what you are looking for here is a significant step change in voltage across the battery when the faulty circuit is isolated by pulling the associated fuse to that circuit.
another way, is to pull the negative lead from the battery, and use the multimeter in AMP/Current mode with the multimeter in-line with the negative terminal of the battery and the negative cable wire. be careful not to exceed the current ratings of the multi-meter probes.
again, as you pull and replace fuses one at a time, when you pull the fuse associated with the excessive draw/short, you will see the current flow from the battery (measured in amps) take a down-tick as less current flows when the draw is less.
does this make sense to you?
if you believe you got a shock from touching only one leg of the battery without providing a path to the other leg with your body, then this sort of diagnostic exercise might be too troublesome and potentially dangerous for you to perform.
i'm not being flippant or sarcastic. an independant or someone a bit more familiar with basic electronics could help you out here.
a book on the subject or googling the subject might help as well give you the background you need to do this diagnostic work yourself. it isn't rocket science, but you need to do it in a knowlegeable and safe manner.
i hope this helps you.
[I doubt it's related, but I also have sporadic trouble with my fuel gauge (apparently) shorting out on me, going all the way to full or empty and settling there for awhile. Additionally, two of my power window switches (front passenger and rear left) only work occasionally.]
2 hours 'underhood' was probably the wrong part of the car. It's probably inside, under the dash.
By any chance is this an aftermarket radio? A Best Buy installer back in 1993 might have cut into anything installing that Sonic-Blaster XP1200 radio and amp. And the overloaded wire to the map light finally overheated here 13 years later.
Good luck. But long distance diagnostics are tough on problems like this.
Did someone stick something like a coin into the CD player?
get behind the dash if possible, perhaps remove some dash garnish if possible, if not use a makeup mirror and very bright light. look for evidence of heating / melting of insulation.
look on the web or in an auto parts store for an electrical wiring diagram for your vehicle and determine what ckt the MAP lights are attached to..
wiring harness issue, exposed wire making contact with the metal frame, problem at the fuse holder... also possibilities.
did you verify the fuse to ACC (accessories) was good? try another.
When I start the car the stereo sounds fine, but after six seconds the bass disappears. What little bass is left distorts at a very low volume. This happens when the car is started; if the key is just put into the accessory position the music starts up sounding like crap instantly, with no 6-second period of full bass.
This is the second aftermarket HU I've installed, and it worked fine in my previous car. I think the issue may be related to the amount of power reaching the HU. The fuse for the radio (in the car's panel, NOT the one in the back of the HU) was originally 7.5, but had been changed to a 10 by the previous owner to accomodate his aftermarket HU.
I'm stumped. Has anyone heard of something like this before?
A mechanic knowledgable about electronics should at least be able to narrow down the circuit, to one fuse in the fuse box that is causing the drain, very quickly. After that, it might take some time to find the actual problem.
My buddy has the same car a 2000 chevrolt cavalier Z24 and so we spent a few hours swapping parts from his car to try to get my heater to work. We changed the blower motor, the heater-A/C controls, the fan blower resistor. There is really nothing much left. I doubt its a loose wire as I pulled and pushed and banged every wire that has to do with the heater.
Anyone have any ideas...
After I threatened them with Lemon Law and called Volvo Customer Service, the mechanic was finally given permission by corporate to driving the car to and from work (50 miles each way). His quote was, " I was cruising along with the nav up listening to the radio, this XC is a really nice drive. Then, WHAM out of no where the car instantanously cut off and then came back up in a split second. It scared the beejesus out of me."
They are searching for wire diagrams, maybe now they will find the root cause or at give me a new car.
Does this sound like the motor needs to be replaced, or a relay switch of some sort?
Thanks :confuse:
1. Cruise control: After I turn the main Cruise control switch the light in the instrument panel (near the tachometer) does not come on and the cruise never works. (the light on the switch itself comes on and changing the switch, fuses did not help)
2. Rear passenger door lock listens to the central lock control switch whenever it wants to! The remotes dont work anymore and the batteries are new and so are the remotes!
Scared to take it to infiniti. Am willing to spend money on it, but how much???
Hope someone can help.
If you don't want the alarm then my suggestion would be to remove it and put everything back to original.
6V isn't enough for these circuits to operate on. It's quite possible that this aftermarket alarm is failing and loading the circuit down, or some sort of related problem.
The right way to wire in added systems on modern vehicles is to get power directly of an accessory terminal on the fuse panel or directly from the battery (fused in both of course) and not to tie in to other systems for DC power. Modern vehicles have so many sub-processors running (70+ average today I read) that it's risky to disturb any of them with unknowns.
I always suspect these aftermarket electronic add-on systems since a great many of them are built real cheap.
checked all the ground and hot wires even checked the electrical side of the ignition switch all are good.
bad ignition switch internals (have you got a lot of stuff on the keychain)?
bad smart-key
loose wires to the ignition switch
main / ignition relay
As for the rest of it, I couldn't figure out how to get the top shroud off without cutting the flange behind the key receptacle with an x-acto knife. Hope you have better luck there. Also, the white nylon two-wire switch that comes off the ignition switch you bought and goes on top of the tumbler mechanism has a tab you need to depress (on the top left) before you rotate it clockwise to get it out. This will make more sense once you get into it.
Took it for a quick test drive and everything looked ok. Good luck!
