I was only trying to give the briefest of demonstrations on how much better disc brakes "feel", but it's way more complex than that, comparing discs to drums.
There are pros and cons and different vehicles respond to different systems.
One area I definitely don't agree with you though is wet weather performance---I think discs are far superior. Also drum systems are more complex than disc brakes.
One reason that semis use drum brakes is that drums last a lot longer than discs might on such a heavy vehicle.
But that is rapidly changing. Truckers are very conservative about change but Peterbilt is now offering all-wheel air disc brakes and you will see most trucks using this technology in the next ten years I think. Europe is already switching over to air discs on heavy trucks.
Having said all that, I think front disc/rear drum on most light passenger cars is plenty good enough.
I remember the days (1950's up) of front V-8 engines with rear wheel drive train. (more even balance front to rear) In those days, one pretty much changed both front and rear drum brakes. Even then, the rears still wore a lot easier.
If you fast forward to today, most and a majority % of the cars have front wheel drive front engine. For example, my VW Jetta has a 60/40 static weight bias. During most operations it can shift to as high as 90/10 with 80/20 being pretty normal. So for example, how they overcome this engineering problem is to make the rear rotors and pads app half as potent and use apportioning valves, etc to supply more initial force to the rear disc brakes. This type of set up is also pretty similar on my Z06 Corvette, which is probably one of the shortest stopping production machine on the market.
Just when I thought I have seen disc/drum combination pass into history, I had need of a commute car and got a 2004 Honda Civic, which has the disc/drum combination. It will be interesting to live with this old/new combination.
The art of spooning. (holding the adjuster away while loosening the star adjuster) thru a slit the size of a couple quarters edgewise, takes a certian finesse.
I wonder if most folks even realize that they must hit the brakes firmly while reversing to adjust the drum brakes? Insdead, the drums get less and less effective forcing the front brakes to wear out faster.
http://www.eastwoodco.com/shopping/product/detailmain.jsp?itemTyp- e=PRODUCT&RS=1&itemID=2438&keyword=49012
Professional brake service shops (mostly gone now) or even those guys that used to drive vans from shop to shop (also mostly gone now) always had arc grinders to match the shoes to the drums for a perfect fit, and unless a problem occurred later (or no self adjusters) the brakes didn't need any adjustment over their life.
Don't use 'em!
I used to wrap a 3-prone stone hone in 600 wet/dry paper and hone slowly with WD-40. Got a nice mirror finish with very little metal taken off.
Once when I was especially broke, I blew a rear grease seal on my 1951 Ford Woody. The rear shoes were soaked with oil so I dipped them in kerosene and lit them on fire!
It actually worked!
Actually, they saved a lot of time and trouble.
HMMMMM...may have to change my mind about rear drum brakes after all
http://www.erborrico.com/206raba.wmv
Question 1. Can I spray the brake cleaner over the entire caliper assembly while it still mounted?
Question 2. Will doing the above remove the antisqueal compound that is clearly visible on the back of the pads/guides on my new vehicle, or damage any of the seals?
If so, is there any method of cleaning/preping without removing the assembly and pads?
Question 3. Can the same paint be used to paint the exterior of the rotor hub and edge (obviously not the rotor surface where pad contacts).
Thanks Steve for pointing me to the appropriate thread.
2)Not likely (but take care with the pressure-point surfaces of the pads that are LUBRICATED. Re-lube with proper brake-grease afterwords)
Removing the pads is VERY trivial to do. Even removing the rotor may even be easy. (I can have the rotors off my truck within 5 minuts per side and the pads off in another 27 seconds)
Do not touch rotor with fingers. (use rubber gloves) Also scrub rotors thoroughly with degreaser before re-installing. Protect the rotors as if they were in a hospital envronment.(wrap with a towel)
If you must leave the rotors in place. (with calipers pulled and pads removed) Cover the rotors with a cloth to protect from any contaminants while you are wire-brushing the caliper-housings and painting. Still... you should degrease the rotor before putting back into service.
QUESTION: What material are your calipers of? (aluminium, castiron, Steel...??)
3) NO! (The rotors normal operating temp will burn off any coating. Even chrome/nickle plating would not survive on the rotor itself. Also, you risk contaminating the braking-surface. Even touching the rotor with your FINGERS can affect braking performance.)
One more question. I believe all bolts have torque specs. Should I borrow a torque wrench for when I reinstall the calipers, or a good hand tightening should be OK?
Cheers.
BTW: Incase you do not know some of the cautions;
*)DO NOT let the caliper hang by the rubber hose. (either wedge it somwhere where it will not fall out or use an old metal coathanger to secure it to a suspension part)
*)DO NOT PUSH ON THE BRAKE PEDAL while the caliper is removed. There is danger of pushing the pistons clear out of the calipers.
*) If you push the piston all the way in, (C-clamp or waterpump pliers) it will be MUCH easier to remove/install the caliper.
MOST IMPORTANT: Verify brake operation BEFORE driving.
I picked up some brake quiet, and found two products. Not sure which to use. One is AGS sil-glyde brake lubricant. It says it stops pad squeal and lubricates caliper slides and contact points. The other is Permatex Disc Brake Quiet. The grease thats currently on my pads is copper in colour (new Subaru Wagon). Which is better, or should I try to get the original product from the dealer?
Now, as I understand it, the screw type calipers are only used on rear wheels, and are of this configuration to accommodate the need for an emergency or parking brake. Is this correct?
Actually, on-car machining equipment is preferred since it virtually guarantees no runout in the rotor after machining.
Ended up using copper antiseize for the guides and on the calipers where they contact back of pads. Pads have shims attached (which I did not disturb) so no need for anti-squeal. This is what car had from factory, so did not want to mess with other products (ie.warranty). Funny thing is that in speaking with some shops, they are also using antiseize to lubricate guides.
If you try to pull the drum BEFORE removing all slack from the automatic adjuster, the "ridge" on the drum will catch on the brake shoes.
