Ford Excursion Maintenance and Repair
                    I have a 01 Ex with the 5.4 engine.  The truck only has 1300 miles on it but have a few small problems.  Main one is the cruise control.  I'll have it set at 35 (so I don't get a ticket) and sometimes it will just surge ahead.  another minor thing is the rear passenger door will pop open just a bit and the dash light will tell you the door is ajar.  Then when you stop at a light the interior lights come on.
I haven't had it back to the dealer yet, I'm waiting for the 3K oil change. Any suggestions?
In all fairness though, I'll see what happens when I take it in. Probably not till Feb. Thanx for the info. And as for the rear door, I think your right. I'm sure it's something simple.
Ned..... :-)
Have any other owners noticed this? Thanks.
Would someone please let me know what we might
be able to do.
Thanks...
I spoke with the local muffler shop regarding dual exaust system. They say that that would screw up all the sensors and the engine would'nt perform right.
Anybody got any ideas?
That one doesn't know what he's talking about...
Duals are put on vehicles EVERY day.
Anyone out there with a 6.0 PSD that can either back or refute this info?
I've owned/driven Fords going back to my dad's '57 Fairlane and '58 Edsel Corsair (wish I had them now). I'd like to stay with Ford (I have an '03 Ranger 4x4 that pulls a UHaul 6x12 trailer as well as my wife's '00 Expedition.
Thanks, Richard
Since new I have been plagued with this clunk or banging under the drivers floorboard. The dealer replaced the swaybar links, no fix. I have been under this thing many times hitting parts with sledge hammer (carefully though!) and a rubber mallet trying to figure what is that damn clunk! I even tightened the body mount under the pedals. Finally, Saturday I was determined to take another look around underneath. I saw a difference in the way the rubber mounts looked from left to right. It looked the the orange paint had been peeling off the left side due to excessive flexing. I removed the bolt, wire brushed it, lubed it with anti-sieze compound, put a large lock washer (the only large spacer I had- a flat washer or two would work fine) with a thickness of about 4mm- 5mm, I jacked up the body and inserted a foam pad to help insulate it. I then reassembled it and torqued the sh...oops the heck out of the bolt. It has been two days and it seems to be gone!!!!
I cannot tell you how HAPPY I am that it is finally gone.
I wonder if I should package these items and sell them to Ford as a repair kit?
Perhaps the body is not even? Perhaps that mount is not up to specs? Perhaps the perch was welded in the wrong position? What ever Ford did, I believe it is finally fixed.
Good luck to all those still experiencing this headache.
Saul.
At 70 MPH, what does your Tach read? Just wanted
to know with the 5 speed vs. 4 speed auto. trans.
Also, the manual states transmission fluid replacemnt at 30K. I requested the dealer drop the pan and replace the filter as well, instead what I got was the "Power Flush" using the trans cooler lines. This makes me nervous as any particles trapped in the filter either stayed there or are now circulating in the tranny if they didn't come out in the flushing process. Am I being paranoid???
Other than that, at 30k, no complaints!
Ford recommends that the rotors be turned on the vehicle, their brake lathe attaches to the caliber mounts.
I have also discussed this problem with an employee of a wholesale brake supply shop after I turned my rotors the first time. He happen to personally have an Excursion and was working with a couple other Excursion owners. They all had just replaced their rotors with an aftermarket rotor. There are high performance rotors such as the type with holes in them or the ones with slots on them. At his shop, they only carried the rotors with slots. I checked back with him recently after they have placed 10,000 or more miles on each vehicle. He reported that they were all very satisfied with the aftermarket rotors and that the Chief of a local Fire Department had just purchased some for each of his Excursion at his Department.
I also understand that Ford has made a number of improvements with their 2005 Ford Super Duty Trucks, including larger rotors and disc brakes. They have also improved the design and/or size of the frame, the leaf springs, suspension and steering to name a few.
I hope for new 2005 Excursion purchasers that the same changes were made to the Excursion!
C/ya Later Andrew
Tell your Ford Service that the Brakes are not your problem. The problem is Ford put brakes on a 7200 Lb. vehicle, that are for a 1/2 ton truck. That is just my opinion. That's a lot of weight to be stopping and starting all the time. This causes the rotors to heat up and cool down and heat up and cool down. This is a uncontrolled annealing process which causes the rotors to warp. Some times you stop and the part of the rotor that is exposed to the open air rather than in the caliper, cools faster than the enclosed part of it remaining in the caliper. Uneven cooling the rotor starts it to become out of shape. When you Cyro them it takes the stress out of the rotor in a controlled environment. My brakes have never worked this good ever. This is my 3rd Excursion. Every Excursion had break problems I have owned. I don't think your the only one. By the way Ford has been advertising better breaking and 355 Hp on the V-10 Wonder where they got 55 HP's from and why did they address the breaks on the F-series Trucks if there was not an issue?
C/ya Later Andrew
Thanks! Marilyn
can anyone tell me where the vin is on the frame on a 2001 excursion.
i own a 2001 excursion ltd with the V10 with veh. weight on reg. as 6972 lbs from ford and now with the new inspection test it would not pass due to incorrect weight.i had to get an exception and test was done with old machine.any body else with this prob?? looking to avoid problem next year. thanx
Have a 2001 Dsl Ltd 4x4. Had the 45k service done at end of March - noticed some stiffness when shifting that I hadn't seen before, but didn't think too much about it since it didn't seem to affect performance.
Went on extended road trip last week, drove from Seattle to Bozeman, MT and back. Upon return, first gear died in tranny and 2-3 shift sometimes doesn't work either. Dealer says, "checking w/ext. warranty co." to make sure whether it's covered or not.
I was very surprised by this development; but then, my last Ford was a '65 F250 2x4 long-bed automatic that I drove until it literally rusted apart (about 300k miles). With regular service, it never had any problems. None. Most reliable vehicle I've ever had, and I've owned a few (including Mercy's and Beamers and other supposedly "high-end" cars). Up 'til now, I there had been no problems with the X so I figured I was doing OK.
Recent surfing revealed a rumor that some of the earlier X's (maybe 20%) have had serious tranny problems at or before 40k. Anyone had similar experience, or is this just more baseless noise?
cheers all
~ld
Wow, how glad to see you have the same thing that I just out my Excursion in the shop for yesterday. I love my Excursion, no big problems till resently.
Same thing...service is always done well in advance and above recommendations. My rig is an 01 dsl 4x4 lmt. with 67,000 miles. About 15,00 or so I started to notice a higher rpm when driving have a fultter or hesitation. Took it to the shop and they replaced a sensor on the engine which help the futter....Now my tranny needs to be replaced beacuse it is slipping at 2-3 gear point. What's funny I am in Seattle as well maybe it's just our area.
What are you doing to fix yours? I am getting a rebult installed at the tune of about $3,000....
On a side note...what knd or fuel milage are you getting with yours? I get right at 14.7 gpm
Very interesting - thanks for your response.
I am now very very glad I did something I usually don't do, namely, bought the extended warranty when I bought the car. In short: dealer (Harris Ford in Lynnwood - can I say that?) is replacing entire unit with a new 4R100-B transmission unit. Warranty covers everything except the trans fluid inline filter that Harris says they have to install; after hearing about how flushing the line may not get out all the bits of metal from the exploding clutch plates, I'm cool with that - you should make sure your mechanic does the same thing.
In short, out of pocket: $500 deductible plus maybe $200 for the filter, other ancillary parts and excess labor. Considering the ext. warranty cost me about $1500 at purchase time, it has definitely paid for itself with this one.
The flutter you mention - I had that @ appx 1400-1500 rpm also, but it sort-of went away on its own, so didn't think more about it.
Just before my transmission exploded, I was getting about 18 mpg freeway and 14-15 mpg combined mileage.
And I am highly annoyed with how expensive diesel is in this state!! Prices in Montana for #2 are about $2.45/gal and here they're almost $3/gal. Any conditions that cause diesel to be more expensive than premium gas are either very fishy or just plain wrong, IMHO.
Good luck with your X, hope the repair goes well.
cheers
~sam
i have a 2001 excursion
the backup sensor goes to off each time i put it in revers.
and i can not get it to work when i push the bottom.
any help on this?
morten(norway)
thanks for any help
I just turned 60,000 miles on my 2000 Ex. Limited, V10, 4wd. The back brakes finally needed replacing. In search of something better, I found NAPA carries a Cermic composite material pad. It should provide better braking, less heat and MUCH less (little to no) dust. They were not cheap at $69 a set, but are complete with hardware which is a plus. I figured I would replace the front pads, even though they still looked great. The front pads had been replaced several times along with rotors (warped) at 12k, 24k and 33k miles- but have been fine since. When replacing the front pads I was SHOCKED to find the passenger side caliper slide pins was RUSTED and frozen. I am not sure, but I would suspect when the dealer serviced the brakes, they neglected to grease the pins. It is all together today and stops great. Probably a combination of better pads and fully working front brakes! I still have a noise underneath (I was hoping the frozen caliper was the culprit) so further investigation is needed. When I apply the brakes, I still get a small *clunk* noise. I think it may be the rear driveshaft slip-joint. It seems to have play in it. It does not have a zerk fitting for lubrication, so dropping the whole shaft is my only option. Not good or fun.
On a better note, I did install Sirius satellite radio! I hardly use the CD player anymore as there is always something great to listen to. I bought the Streamer GT model and can take it from car to car to home, where ever.
I am also looking into getting a clear bug deflector. I had a smoke colored one, but I didn't like it on the white truck.
Other than this brief update, everything else is doing well.
I found the *clunk* culprit. Ok, the inspection station found the problem. As I mentioned, the truck is a 2000 with only 60,300 miles. As it turns out it needs FOUR ball joints!! :sick: YIKES. At first, my heart stopped realizing that replacing four ball joints just might be a $800 job. Sure, I do all my own work, but replacing these is a major :mad: PITA. Luckily, I did buy the ESP with this and they are covered!! YEAH. Now, I made an appointment at the dealer to get those done, the right rear door lock actuator replaced and the rear driveshaft checked. The moral is, buy the extended warranty folks if you plan on keeping the truck.
I was leary when I did, however I knew this would be last Excursion I would buy. Even if you sell or trade your vehicle in, you may be eligible to get a pro-rated refund. I did receive a refund when we traded in our Explorer.
Next update......??????
$4000 later, apparently we have a broken front axle assembly on the left side???? Bearings went bad, tore the housing, and broke a "pumpkin"???
All I know is this is exstreamly out of sorts to happen. He drove the truck 150miles back to the shop. The dealer ship thought this is weird, and 2 mechanic friends, think is weird.
Has anyone heard of this?? Should this happen?
Do you rock climb your vehicle? This sounds weird also. That is a Dana 60 front axle and is very strong. Something catistrofic must have happen. If you haven't been abusing or maintaining it. Personaly I would question the problem. My Excursion did a crazy thing with only 8500 miles (Eddie Bauer, V-10, 4X4) My AC completely leeked out of the system. The dealership checked out for leekes, with no indication of any bad connections or holes in the lines. So they refilled the system and it seems to work just fine as before??????? As for the brake rotors the Cryogentics Company that I deal with are not very timely with delivering a processed set of rotors. So with that said. My Company will not be offering them for replacemment. My reputation is on the line. I don't want to be unrealible because of them. Don't get me wrong their Cryo Process is very good. But the service takes forever.
Here is a web site to check out http://www.frozenrotors.com. This is not the place that did mine. But it looked pretty good to me if you want Cryo Rotors. Sounds as if I better buy the extended warentee for the 04 Excursion (Full coverage) One thing after another. But it could be worse if it was a GM product Ha Ha good stuff right?
C/Ya Later Andrew
To answer your question, no we do not rock climb. This Large vehicle is mainly used for hauling our 2 teenage boys w/ friends & 2 German Shepards to hour Vacation property about 150 miles away. We do pull a 22ft deck boat and or 2 Sea Doos, up a very bumpy hill. But that is about it. This vehicle is perfect for the job. We slowly 4x4 up the bumpy hill pulling the boat, less then 1/8 of mile (or less then 1/4) not sure, but what ever. This 4x4 is a family boat pulling car. That is about it.
The Ford is still in the shop, waiting parts. Hubby is going to take all the broken parts to show. We think we should contact Ford about this. Any suggestions??
driving me crazy!!!
Two days ago and for no apparent reason, the tail lights blows the fuse in the box under the hood. brake lights, turn signals, flashers still work.
No damaged wiring, no trailers hooked up, nothing.
does anyone have any suggestions other that 8 hours at a dealer?
I bought my 2000 Excursion (6.8L Limited) used in 2003, and have driven about 40K trouble free miles...but in the past six months the following problems have come up one after the other:
1) door ajar light/bell sounds randomly during heavy rain...all doors closed tight...re-closing any/all doors repeatedly usually gets this to subside
2) backup sensor remains 'off' at all times, dealer says computer indicates left/center sensor is bad
3) all door lock actuators except driver's door have failed - I'm running laps around this thing to let my kids in the other side!
4) auto-locking 4WD has failed - immediately after a 5 hour drive in 4WD during a snowstorm - smelled a bit of that old 'burning clutch' smell - only way into 4WD now is manually locking the hubs and turning switch to 4x4 (I'm guessing vacuum failure?)
5) and finally, just this week...when turning the steering wheel in either direction (stopped/idling) there is a loud non-metalic-rubber 'brrrrr' sound - only while actually turning the wheel - almost sounds like something metal pressing/turning against something made of rubber. If you turn the steering wheel slowly the
'brrrrr' is lower in pitch, turn faster and it's higher in pitch...I do know this is not the usual powersteering pump noise, which is still present and still sounds quite normal...it's something in the steering linkage I'm guessing...
So - any ideas for the above? I'm pretty handy so can follow suggestions well -I'm afraid these problems are looking like a couple thousand $ in dealer shop time and bits-n-pieces...
Thanks in advance!
TENapster
Anyone know what's up?
My door ajar light and all the lights in the truck will not go off. Does anybody have a solution to this problem.
I own a 6.0psd 4x2 2003 Excursion with 36k on it. I took it in for leaking oil on driveway. Well come to find out according to the dealer, due to the lift kit the transmission cooolent lines are stretched out, and mixing with radiator coolant and contaminated the transmission fluid. According to the dealer there is no way to flush it out. Only option is rebuilt or new transmission. Has anyone else had such problems? Dont know weather to trust the Dealer.
