Ford Excursion Maintenance and Repair
1567810
  • ljgjr1ljgjr1 Member Posts: 1
    I have a 2003 with the 6.0. Sometimes it is hard to start here lately. It will sputter & die out while trying to start it. It is turning over fine & the batteries should be good. Sometimes when you turn it over it will start but sounds like it sputters & slowly ramps up to normal idle speed. I've changed both fuel filters.
  • lovemyxlovemyx Member Posts: 3
    I love my 01 7.3 Diesel XLT! She's got 117,000 miles on her. I get 13.9 mpg mostly around town. Yesterday, I heard a new sound. Dealer said she needs a new hydro boost unit. Anyone else replaced theirs? What other fixes should I be preparing for? Seems like it's always $1000 when something goes wrong :-(, but I have never loved a vehicle like this one. Six kids and a dog. Gotta have it :-) Just like to know what's coming. Thanks! :blush:
  • green_monstergreen_monster Member Posts: 2
    I love my 01 as well. It is a Limited with the 7.3 and I now have 125k miles on it. My first and only major repair was I had to rebuild the transmission. Apparently Ford changed the way the gears sync by "using stubs not slots" as they did previously. Ford only did it for a few years and then went back to the old way. The cost was $1800 to rebuild. The fix was basically building it back "the old way". 1000 to replace the boast seems awful expensive. I would call some local shops and get some pricing. The job only takes an hour to do. I know my front end is getting loose and will need new ball joints in the near future. Except for wear and tear, the tranny was all it needed.
  • walt501walt501 Member Posts: 18
    edited October 2010
    First off, I have a 2003 7.3L 4x4 with 135K miles on it that I purchased at 16k miles. Here is what I have experience in terms of repairs -
    Alternator - commonly replaced item. I replaced mine with a new Ford alternator at 80k miles.
    Water Pump - commonly replaced item. Mine was replaced at 68k miles. Coolant additives needed to protect the block from coolant cavitation in diesel engines can drop out of suspension causing wear on the water pump bearings. I have since upgraded to a better coolant - Chevron Delo HD Diesel Extended Life Coolant approved by International for all of their diesel engines 1999 and up. So far, so good.
    Transmission - mine is stock and working fine in part because I have followed Ford's recommended flush and fill every 50k miles. Everyone needs to follow Ford's spec here to keep their transmission alive and well.
    Ball joints - commonly replaced item. These trucks, are HEAVY and all that weight travels directly down and through the ball joints. So it is no surprise they wear rapidly. Mine were replaced with Motorcraft (not Ford branded) ball joints that unlike the stock Ford ball joints have a GREASE ZERK and they are greased every oil change, which for me is every 5000 miles for me.
    Brakes and Rotors - unnecessarily replaced item. As I have preached here over and over, auto shop airguns KILL ROTORS. Lug nuts need to be torqued to a specific value to impart even stress around the rotor. The ONLY way to do that is with a torque wrench and torquing the lugs in a "star" pattern. The other issue with brakes is the slide pins that the caliper rides on. These pins will become corroded over time, causing your caliper to hang up and destroy your pads and rotors. I recommend having your slide pins removed and lubed at least every other year - more often if you live in the snow/salt belt. My front rotors lasted 75K miles and my rears lasted 110k miles - because I carry a long handled torque wrench (from Sears) in the truck at all times and NEVER let an air gun do the final torque on the lugs.
    Sway bar end links - commonly replaced item - If you're hearing a clunking sound in your front end and have good ball joints, it's likely your sway bar end links. Again, you're dealing with a lot of weight with these trucks so these items do wear. Also, a lot of Excursions didn't come with a rear sway bar - if you don't have one I highly recommend you install one. Hellwig is a commonly installed brand.
    Shocks - commonly replace item - Again, a heavy truck means the shocks have a lot of work to do. If you have your original shocks and over 20k miles, I assure you they are shot! After trying another brand (that bet the "ranch" and lost at 30k miles) the only replacement shock that it suitable for these trucks are Bilsteins! Mine have 50k miles on them now and are as good as new. Also, if your truck is 4x4 you should also have a 5th shock - your steering stabilizer. Replace it as well with Bilstein.
    For 7.3 diesel owners, you need to clean and or replace your Exhaust Back Pressure tube and sensor. This tube can fill with soot blocking of the reading at the sensor giving the powertrain control module an incorrect reading. I have read from people in the know about this engine that this is the number one cause of reduced mileage in the 7.3L diesel engine.
    Other than routine maintenance items like tires, oil and air filters, that's all I can come up with for the moment but I'm sure I've overlooked a few items so here's a chance for others to chime in with their experience.
  • ford73ford73 Member Posts: 5
    I have a 2003 Excursion with the 7.3L diesel. The problem is that it does not start all the time. It turns over but just will not start. I some times have to wait a hour + before it will start. It just started doing this about three weeks ago. The truck has about 168,000 miles on it. I do not want to bring it to a dealer if I do not have to, I just do not trust them..Any help would be great.. Thanks
  • bionutbionut Member Posts: 9
    Assuming you have already changed the fuel filter, I would think it's either glow plugs or fuel pump. Fuel pump is an easy do-it-yourself, but it costs around $200. Glow plugs are not so easy, but are about the same price or a little more for a complete set. I would recommend looking in yellow pages for a performance diesel shop. They are usually more qualified than the "stealership", and they are almost always cheaper. They can test the glow plugs and the fuel pressure.
    Just curious: what kinds of electrical problems have you had? I think I need a VSM, but not sure. Good luck. Let us know how it comes out.
    Just changed the fuel filter and have not had any electrical problems. I was told it way be the glow plug regulator on top of the passenger side valve cover or even the valve cover gaskets... I way try a performance shop.... Thanks p.s. I like that ''stealership'' comment..
    Let's avoid disparaging remarks directed at any group of people. I'm sure customers would not appreciate similar derogation.
    SUVs and Smart Shopper
  • shadetree_mechshadetree_mech Member Posts: 10
    I worked on a friends 7.3 that wouldn’t start, have someone try to start you rid while you have a meter on the battery terminals. What we found that the truck would crank and sometime would start but not always. We found that with ignition on it would show ~12v which is good, glow plug cycle was about ~11.8v, good also, but when cranking it would drop to 10.0v~10.5v. at this time I pulled my 7.3 next to it and did the same measurements, and in all cases it never dropped below 11.5v. So I attached the jumper cables to his rig & mine and it cranked right up. Bottom line after checking the battery terminals it was found they had a lot of corrosion between terminal cable and battery terminal. I used a $1.50 battery cleaning tool clean and tighten up all of the connections and presto!!! I'm thinking the engines computer didn't have enough power to do its job when starting and sequence the injectors to add fuel.
    Another check....another problem I have run into if your rig isn’t starting, is glow plug relay is on the fritz, if your injectors are working but you glows are you'll see the following condition. If then cranking and not starting you have a lot of white smoke coming out of your exhaust, that white smoke is actually atomized diesel fuel, this means the engine isn't warm enough to combust the fuel, hence most likely glow pug relay it on the fritz, sometimes to get you going you can tap on the glow plug relay with the butt of a screwdriver, and it be a short term fix but ultimately you need to replace it. Hope this helps.
    Thank you, I will try them both. The truck has new batteries but I never did clean the oil off of the terimals before I installed them..Thanks again
    I read my own post, sorry for the bad english.... anyways, reply back on what you untimately find, I'd like to keep up on what problems folks encounter with these engines. So far they seem to be pretty bullet proof and run forever with very few hiccups.
  • tontetrucktontetruck Member Posts: 1
    Our 2005 Excursion on a 40-45 degree morning stars with a sputter then after 5 seconds of sputtering idles normal. We can't drive it for about 10 minutes because the truck will chug along and won't go over 20 mph till she warms up. Any help out there on this?
    From what I have heard that's normal for a 6.0. from the sound of it I'd say symptomatic of not all of the glow plugs functioning, check them it a meter 1 by 1.. Should either be close to 1 ohm or less which is good, or if they are reading infinity they are bad. I gather once it has warmed up and is running it starts fine?
  • tbudowtbudow Member Posts: 6
    I have 2000 Ford Excursion V10 w/ 170K mi. It has always run great. However, recently and coincident with having my tires balanced at WMart, it developed a rattly/pulsating noise in the rear end. The noise is not there when in Park, only when in Drive, and most prominent (for obvious reasons, I guess) when stopped or at a slow rate of speed. The local Ford Dealership thinks it is the catalytic converter. Any ideas?
    Thanks ever so much for your thoughts.
  • steve2000xsteve2000x Member Posts: 2
    Maybe a heat shield near the converter.
    Thanks for the response. I will give it a try.
    Regards
  • excursionfanexcursionfan Member Posts: 2
    We had the same problem. Only heard the noise when going slow. Turns out we needed a new back end. It's going to cost us $3300 to fix it--much more then the front end I had fixed 2 years ago. But as I type they are fixing it. I did a little research and my engine is a dynamo--can get 300K out of it. So at 238K now we can still get at least 3 years out of the truck. But we thought long and hard about it. Still, I love that truck--it can tow my trailer, take my family of 6 on vacation and I've picked up 16 kids after a football game. Best vehicle we have ever owned. The inside is trashed after 11 years ( 2000 V8 5.4) but I don't care. And when my kids learned to drive--if they can drive this thing--they can drive anything.
    Aaaaahhh. What does that mean-- a new backend?
    Do you know why they say you can attain 300K+ miles? I love my truck too and was considering trading it since it is not a diesel and has 170K mi. You know, it is just the fear factor--but if some professional actually says there is that hope, it would make me feel better about putting more money into it. I love the fact that body style will never change on the Excursion so that you feel your car is now tired and old. Know what I mean?
    New back end----barrings seals etc. It's not cheap. $3300 But we talked to mechanics and people who work for Ford who we know personally as friends. They told us that the engine was a beast. That if we cared for it we could get 300K out of it. In fact, told us they have seen people with 350K before the engine went. With that in mind, we didn't want to buy another big vehicle and monthly car payments being about $600--it was just cheaper to repair. We have NEVER had an engine or trans repair ( knock on wood). We have had to repair the front and back end, window motors, gas leak and even the excellorater cable ( that was a scary thing when it frayed and needed to be repaired). We pull a trailer and have a family of 6 so the big car is great. Just made sense to us that even if we only got 6 months out of it ( and we hope to get 2 more years) we were still ahead of the game. Plus we were told yesterday that it was only worth $2500 in trade in--and that's after it was fixed. We might be able to get $4000 if selling by ourselves but if I get at least a year out of it why do that? It still drives like a dream and when I'm pulling a trailer you can't even tell. I only have a 3000 pound trailer but it's nice to drive the speed limit while pulling it instead of dragging along at 55 in the slow lane.
  • daddy818daddy818 Member Posts: 18
    My wife's 2000 Exc. 6.8 L, V-10 Triton(gas), 4 wd. While driving(slow or fast) the front wheel on the drivers side emits a clicking noise(sounds like when you would put a playing card on your bikes front fork with a clothespin so it would make a clicking noise when you rode your bike, only its not as sharp a sound). I removed the wheel, the caliper, the caliper mounting bracket and the rotor and then spun it by hand and I can still hear the noise, it sounds like its coming from inside the hub. The noise just started happening yesterday. Anyone have any ideas on what to check & how to check it. I'm hoping I can do the repair myself due to lack of funds at the present time. Thanks in advance for any help or advice. :confuse:
  • idgolfjunkieidgolfjunkie Member Posts: 15
    The noise is most like the bearing hub assembly, I had one fail on my 2000 ex a few years ago, and replaced both at the same time (figured if one was failed the other couldn't be far behind). These are not cheap parts, the local ford dealer quoted me 465.00 each (4 years ago), I ended up buying aftermarket units off of ebay for about 250.00 each, that was about 80,000 miles ago and haven't had a problem.
    I am the proud owner of a 2000 excursion with the 7.3, I purchased it new on 2-1-00 and have driven it daily since and now have over 230,000 miles and still going strong. In the eleven years I've replaced the alternator once, I rebuilt the whole front end, including the two bearing hub assemblies, and about a year and a half ago I had the glow plugs replaced because it was starting a little slow, and that's it for major stuff in 230,000+ miles. I love this rig, and have no plans to sell it anytime soon. Since Ford discontinued the excursion, those of us lucky enough to have one should feel good in knowing that the diesel equipped ex's are bring 4 to 6 grand over KBB.
    Hope this helps.
    Were you able to do this hub replacement yourself? Do I need to have anything pressed on? Or any "specialty" tools? And if you did do it yourself about how much time is involved? (i.e.- hours,days) Thanks idgolfjunkie!
    Wow! Thanks so much! So much information, you're awesome :-) I'm going to take her in and have them check the sway bar, because I have taken her in and had the ball joints done and they couldn't figure out what the clunking sound was coming from. I'll bet you are right on! They heard and felt it, greased everything and said it wasn't a problem, so I have been listening to this now for around 8 months. I haven't done any major damage to it? Have I?! Sorry it took so long to reply :-( Homeschooling six kids and transporting them to all their social events takes up most of my time. Checking posts falls a tad low on the totem pole of life :-) How much might the sway bar cost? If you have time, I really appreciate your wisdom! Keep on enjoying the highway :-) Who wouldn't?, in what I affectionately call, "My land yacht!"
    I didn't do the install myself, I was having the entire front end rebuilt at the time, ball joints, sway bar, hub bearing assemblies, and replaced all four rotors (fords units suck), I purchased the parts and had my mechanic install them. My brother in law owns an auto repair shop so I don't do much wrenching anymore.
    edited April 2011
    Thanks for the kind words! You haven't done any damage to your sway bar - it's the "end links" that bolt to the sway bar and then to the vehicle frame that go bad. In most cases, you only need to replace the end links to fix the problem, but I would also have the dealer check the two bushings that actually hold the sway bar to the vehicle and make sure they're good while they're doing the end links. Cost for the end links is about $35 each. You'll need two, one for each end of the sway bar. If you plan on doing the work yourself, you can find them online for $20-$25 each.
    I should also mention that you can upgrade the bushings in your end links (it's actually the bushings that wear out) with polyurethane bushings from energysuspensions.com. Also if your vehicle is 4x4 check the track bar bushings wear.
    Another less common area of hidden front end noise on Excursions that usually rears its head on higher mileage vehicles is the two front body mounts. These are rubber bushings that go between the vehicle and the frame to isolate road noise. These can be a bear to replace, but if anyone here should find they have that problem I can get you a procedure to replace them, as dealers will often advise against replacement because of the cost.
    Awesome! Thanks again! Unfortunately, I can't do any of this myself. However we have an excellent relationship with Fred Beans Ford of Boyertown. We've bought the Excursion, an F-150, (2) F-250's, an Escape, and a Mustang in less than 10 years there, so they treat us like family and give us all the discounts I ask for ;-) I'll print this out and give it to them, and they will take care of it. The service manager was glad for the advice you gave me and keen to get right on it. Hope you won't mind me pickin your brain on occasion as the need arises :-)
  • camper200camper200 Member Posts: 1
    I need a dependable 4WD for family vacations and towing a tent trailer. Which diesel motor is superior; 6.0L or 7.3L? Also what is the consensus for the best overall package for the Excursion (think engine, transmission, interior features, and reliability). Thanks for your input.
  • thebeast15thebeast15 Member Posts: 2
    I have an 01 X and when I put it into reverse and give it gas, there is a clunking sound. Can somebody tell me what this would be? It is completely stock and has 90,000+ miles.
    When it comes to horsepower, I would not suggest the 7.3 unless you would get a chip. Other than that the 7.3 is very reliable and I have had no problems out of the 10 years I have had it.
  • roosmamaroosmama Member Posts: 28
    I don"t know if this is it or not for sure but.... with our truck we had a clunk noise a while ago. I would put it in reverse, give it some gas and actually got a clunk with a bit of a jerk. Took it to a mechanic because had no idea what to think. Anyways, we ended up having to get the rear end rebuilt and repacked. Hope this is not the case with you. Milage on the truck was about the same when we had it done, but we do drive this unit like we stole it!!
  • moltenartmoltenart Member Posts: 1
    Wallz,
    I don't know if you'll get this, but thanks a lot. This solved my door ajar and interior light problem. Amazing what a little liquid wrench will do;)
  • swallisswallis Member Posts: 1
    edited August 2011
    I completely agree, in our excursion v10 the brakes are ****, we had a collision because all traffic suddenly came to a stop and our truck couldn't stop. We are going to have a little dispute with ford about this. We have never had this problem before on any large vehicle. It's ******** on ford and looks like we are not getting another excursion, looks like either a suburban or new Durango
    So your Excursion brakes are bad? Really? I assume you've followed Ford's procedures for maintain your brakes that include, but are not limited to the following -
    >Torque wrench used to maintain proper lug nut torque, not Bubba at the garage using the air gun to jam them on, thereby distorting the rotor and leading to pulsating, diminished braking force and shortened pad and rotor life?
    >Slide pins cleaned and lubed annually to ensure even braking force and prevent calipers from hanging up on the slide pins leading to reduced braking effectiveness?
    >Proper components used that meet Ford's specifications whenever brake work is performed?
    My original Ford brakes - pads and rotors - lasted to 110,000 miles and provided excellent braking effectiveness. Of course, I knew how to maintain them. Make sure you have all your receipts showing you maintained your brakes to Ford's exacting specifications when you have your "little dispute".
  • BenzeneBenzene Member Posts: 3
    I have had the same chattering problems as everyone else. The most recent time I worked on the brakes I replaced the rotors, calipers, and pads. While doing the job I also replaced the caliper pins -- could not help but notice that the two pins in each caliper are NOT identical. Does it make a difference which pin goes in which hole? I assume that it does or else they would be identical. After a few thousand miles the chattering is back. Hard to believe there's not a "permanent" fix for this.
  • agoodwinagoodwin Member Posts: 16
    Haven't posted in a few years. The damn brakes on the EX are undersize for the weight of the vehicle. (My Opinion) Anyway I have owned 3 Excursions and all of them have had some sort of braking problems. I cryogenic treated my rotors and that prevented them from warping. I currently have 40k on them now. With no problems. I have seen posts from others that bought rotors with slots and dimples in them off e-bay I believe. They have had good results with them. The old posts are back in the archives for reference. I would like to know of a good brake pad that is aggressive and will stop the beast better.
    C/ya Andrew
    I've posted about excursion brakes before, I have an 00, ex with the powerstroke and its an awesome rig, I will have owned and driven it for almost 12 years now and am nearing 250,000 miles.
    I will tell you this, don't buy ford parts, they suck and are way overpriced, I've had aftermarket rotors and pads on mine for the last 95,000 miles and still haven't replaced the pads, best part is that I bought all four rotors with pads for 300.00, less than ford wants for just the fronts.
    If your ex is cavetating only during braking, then its the brakes, if its pretty much all the time, check the bearing hub assembly (what the rotors mount to on the front), I had one fail and figuring if one was going bad, the other was probably close, so I did both, also replaced the upper and lower ball joints at the same time and have had no issues since.
    I won't buy any parts from ford since the local service writer quoted me 1700.00 for all four rotors and two bearing hub assemblies, and then got mad when I asked him how ford could sell excursions for $50,000 when they obviously had $75,000 worth of bearings in the things. I haven't let a ford dealer near my ex in the last 8 years, and won't.
    Good luck, hope you get your problem solved and always remember, ford was smart enough to cease production of the best SUV ever built, and we are lucky enough to own one.
  • dwallace84dwallace84 Member Posts: 2
    I'm looking at buying a used excursion 2000 limited with 158k and the 6.8 V10. My wife and I have 4 kids and do a lot of vacationing and currently have to take 2 cars on trips our either the baby gets to go stay at grandmas house. I'm going to test drive it today so any advice on things to look our listen for would be very much much appreciated. :D
  • nukefordnukeford Member Posts: 4
    The trans went out in my Excursion at 152k--smell the trans fluid. If it smells burnt the trans could be going. Also check the tires for sporadic feathering of the tread. I's about time for alot of those front end parts to be going out. Make sure all the door locks work at each door including the rear.
    Turn the radio on for a while. Some of the CD players overheat and malfunction or the radio will start searching for stations all by itself once it warms up. CHECK THE OIL PAN. See if it is dripping-push on it to see if it is soft. Excursion oil pans are rusting through and it is a couple thousand to fix because of the labor involved.
    GOOD LUCK
  • pfteryl1pfteryl1 Member Posts: 12
    Regardless of all the supposed miracle cures for the front brakes, be prepared to replace pads & rotors every 10k miles or less. The engineering is inherently defective. Too small plus woefully in sufficient air cooling of the assembly. For every story of normal brake wear, there are 100 failures. The EX brakes heat up without even being applied because of lack of cooling, particularly on long, high speed trips. Perhaps worse with 4WD
    edited May 2012
    My original brakes on my Ex lasted 110,000. Miracle? Nope. It's called a TORQUE WRENCH and Ford says the lug nuts MUST BE TORQUED TO 165 foot pounds! Failure to do so will apply uneven stress to the rotor and create hot spots, formerly mislabeled as rotor warping. After being replaced at 110k miles, my current rotors and pads now have another 50,000 miles on them without issue. I recommend you purchase a long handled torque wrench from Sears and carry it in your vehicle at all times and use it! Leaving your lug torque to Guido with the air gun and the overly aggressive trigger finger is a recipe for early brake failure. Also, the calipers use the common slide pin design. These pins must be kept lubricated with high temperature grease. In the rust belt that can mean lubricating the pins every year. Follow these two recommendations and you too can have Miracle Brakes like me!
  • kyfdxkyfdx Moderator Posts: 264,118
    165?!!
    My car specs 88 ft/lbs.. (not an Excursion..)
  • davesv10davesv10 Member Posts: 1
    hey guys anybody have some advice to getting a stuck oil filter out iam haveing a problem removeing it its frozen
    It's kinda messy, but I usually drive a big screwdriver through it to use for a handle. You can drain a lot of the oil out first by drilling a small hole in the bottom.
  • twtcadtwtcad Member Posts: 13
    I'm assuming you have the v10 per your name, so I can not say specifically. But I have the 7.3l, w/ a huge filter and I punch a hole in the bottom w/ a punch or screwdriver and hammer to drain the filter. Then you can either drive a screw driver thru it as was mentioned above or I use a huge pair of channel locks, they work great. Also not to be a smart [non-permissible content removed], but make sure you are using the righty-tighty/lefty-loosy rule.....you should be turning counter clock wise. And remember once you are ready to put the new one on to fill the filter at least 3/4 full and smear new oil on that gasket, that will help a lot in keeping it from getting stuck in the future. Good luck
    One other thought for a "Stuck oil filter", I'll do the punch the hole as last resort cause once you put a hole in the filter, you will compromise the intergrity of the filter and sometimes you end up tearing the metal right off the base, then you are really up the creek!
    One other thought for a "Stuck oil filter", I'll do the punch the hole as last resort cause once you put a hole in the filter, you will compromise the integrity of the filter and sometimes you end up tearing the metal right off the base, then you are really up the creek!
    I recommend getting an oil filter wrench (~$10), the ones that match the bottom of the cans are light duty, but there are also some that lasso the oil filter and tighten up and give you leverage to break it loose. Once you get the filter off check the metal contact surface that the rubber gasket on the filter hits, make sure this is smooth, pre-lube (with clean oil or grease) the rubber gasket before you reinstall the new one. Also I only tighten the filter as much can I can with the grip of my less dominate hand usually about 3/4 of a turn past snug "for me it's my left hand" since I'm right handed.
    Good luck!
    edited August 2012
    less dominate hand
    That's a neat trick. I changed the oil in my minivan this afternoon and after oiling the filter gasket I hand tightened it pretty snug with my (dominant) right hand and then backed it off an eighth of a turn or so. Will try it your way next time.
  • donc7donc7 Member Posts: 1
    Starter grinding on my fly wheel. I had the fly wheel changed and new starter put on. A year later its doing the same thing. Any help will do!
    Thanks Don
  • suvluva34suvluva34 Member Posts: 2
    I HAVE A 2000 FORD EXCURSION AND EVERY TIME I TURN IT SQUEAKS VERY VERY LOUD AND IT'S VERY ANNOYING....WHATS CAUSING THAT? :confuse:
    The flywheel should not fail that quickly unless it was defective. My '02 7.3 has 205k miles, on its third starter and still the original flywheel. Even if you are not mechanically inclined, I would suggest you check the starter to make sure the bolts are tight. Especially with the diesel vibration, the bolts can work loose and when the starter tips, the gear doesn't engage fully with the flywheel. I recommend cleaning the bolts and holes and using blue loc-tite on them.
    Regarding your squeak, I would check the usual suspects such as ball joints and tie rod ends. Also, sway bar end links and sway bar mounting rubber mounting points are a know source of squeaking on these vehicles. If you've never had them replaced, that would be my best guess as to what is causing your squeak. Finally, the front body to frame mounting bolts and rubber isolators can eventually wear. If the squeak feels like it coming from right under your feet on the drivers or passenger side, it could be the body mounting points will need attention.
