Dodge Ram: Problems & Solutions
hope that helps
Has anybody ever experienced this before? Did my head gasket blow? Or is it my transmission? I'd like to have some idea of what's wrong before I take it in.
Thank You
Joe
Thanks for the help.
Steve
kcram - Pickups Host
i have just a need to do this.
It's been the best truck I've ever had and I not ready to spend 40thou to replace it.
Hope one of use gets this figured out.
mechanic" and knows a lot about engines. The problem is that because it's a van, and the connecting rods are on the bottom, does the whole front end need to come off (bumper, etc) or can the engine be lifted straight out of the van? Can anybody give me some advice on this? We're trying to figure out if it's worth the effort and money to fix, or sell "as is"? My friend says that if he does it, the parts should only be about $2000 or less. I've been searching the internet but can't really find much about how to repair/replace the connecting rods and rebuild the engine and how hard and time consuming it is. Any help, advice, would be a welcome relief!
01 Ram 1500 Quad, 5.9 SMPI V-8, 4 Sp, Auto, 46 RE. My truck has 10353 miles, all logged by me. All service and maintenance has been done as reccomended, correct fluids used.
The problem: When reaching 40-45 mph, when going into 4th gear, makes terrible vibration noise, stops if I let off gas, or push on through to higher speed but oh the noise kills me, knowing it must be "painful" for the truck! If over drive is OFF, no problem, no noise. Turn O/D on at cruising speeds of 60 and up, no problem. EXCEPT gas mileage- ouch!
Engine light came on,"P1740 TCC" code refers to "either the TCC solenoid or overdrive solenoid doesn't seem to be making much sense" (neither that does that explination!). Here is what I have gathered: Could be overlay harness, dealer says "$109. for part alone, may fix, if not, would likely have had to replace harness anyway" True/Not True? Additional thoughts: could be Thrust Bearing, or Overdrive Unit. Or TCC solenoid Power Control or Overdrive solenoid.
I don't really understand these things, but I'm trying. I have been told that it can be a common experience that customers are often told they need a new trans, when they only need parts, which is what they GET, but are CHARGED for more. Does anyone know of this problem, (not the cheating people, the transmission) and if so, how has it been solved? What should I LISTEN for a mechanic to say or NOT say? What could I be looking at cost wise (ballpark) for any one of the five items I mentioned above? How much labor is involved?
I have an appointment to meet with mechanic on Tuesday 5/30, and I'd like to go as well armed/educated and prepared as possible, so Thanx in advance for any advice, suggestions or shared experiences!
Ask the mechanic what it needs to go X amount of miles. Always asume in your questions that it does not need a rebuild. Offhand, I don't think you do.
Dan
I was advised to tap the brake while still accelling to see if that would stop the noise/vibration,(this was to determine if it could be the torque converter, I guess) but, wouldn't you know it, I can't get the truck to do it today! It doesn't do it all the time, and only between 40-45(50) mph, and when the O/D is "Off" it doesn't do it at all.
But I REALLY need to get it fixed. What kind of Transmission "credentials" should I look for in a mechanic? What should I "watch-out" for? I really can't afford to spend money in the wrong direction, but I DO want to do the right thing. Any advice is appreciated!Thanx in advance for your insights!
Has anyone else had this happen to them??
I have exactly the same problem. It started last year.
I have a -98 4x4 2500 sport, witch is lifted, and has 33 in tires.
I went to my local dealer, and they changed one pressure sensor and a pressure regulator, because the codes indicated that they where the problem. No luck. After hours of searching, they contacted an expert on transmissions, and he told that there is a signal- cable that is between the gearbox "brain" and the engine "brain". This cable runs in a bundle with other cables. It was said that the other cables gave interference to this signal- cable, and needed to be re-routed, away from the bundle. My local dealer did so, and it solved the problem, for a while......
Now the problem is back.... So it looks like it did not solve the problem completely.
Is there any others with the same problem? have you been able to solve it? i would be happy to hear from others, that might have a solution for this, or have any ideas what the problem could be.
PS. I am a Norwegian, so if you find any wrong spelling, i'm sorry for it...
BUT, I have noticed the fuel numbers. My '05 2500 CTD 4X4 gets very respectable unloaded mileage(about 19 mpg), but I have yet to crack 13 in this truck. Is it because the diesel is still relatively new. Or is the weight of the MegaCab just that much more to make the economy this bad. I know I shouldn't argue about economy in a 7000 pound truck, but I would like to know if there is anything that is different about this model v. others.
BTW: This engine seems to be much smoother than the '05. There is not even a slight hint of vibration in the steering wheel as in the '05 while idling or taking off from a stop.
Good Luck, hope this helps
I have a 95 dodge ram 1500 4x4 5.2 litre. i am trying to replace the front shocks on it and i am stumped. how do you get the shock out? do the coil springs need to come out? i noticed where the top shock bolt is there is 3 bolts and i am not sure if that's the shock tower or the bolts holding the spring in. any help would be appreciated.
The Cummins is a very tight engine when new, which means the fuel economy will not be best when new, but I've owned 12 CTD's in the past 15 years, and this is the first time I've experienced this. I also thought it could be the new lo-sulfur diesel that's dragging my economy, but who knows.
BTW, I changed from the OEM to Edelbrock IAS last year on my 01 Ram 1500 and have been pleased with the upgrade.
But the problem is still here.
It is stalling under power in forward gear and it is worst when turning left. This truck could run all day in reverse without any problems. When we replaced the upshift solnoid two weeks ago ran great for a week and now is starting all this stuff all over again.
I am thinking it is electrical problem (Shorting) going to the tranny is there a wiring harness somewhere hidden. This truck has been nothing but problem since it was bought new in 96 only has 145,000 miles
