Visitor Agreement.
How do you that use a laptop for nav set it up and place it. does it talk to you and where do you place it. I've got a company laptop (dell 15in screen) so if my wife wants in indash cd changer i can't get my nav, so i need options. Would this then be the better way to go with nav (if you already have a windows laptop) or get it from factory.
tow kit--what about after market units, i have a utility trailer less than 1000 lbs max.(i use to transport my dog, and snowblower, stuff from lowe's) If this is like the ody, why not an after market tow hitch, now i just need to know if and where it can be installed...$700 is steep. My last tow hitch i had installed was around $225 (granted no trans cooler or radiator cooler but it works for a small trailer.
The sand colored pilot on its site, which color is that, and will it be delayed till august?
They feel the competition is the trailblazer, explorer, Highlander. 2.5 inches taller than the HL, slightly smaller than the explorer but more interior room.
For me the only competition is the Highlander (quality issues and resale value) butthe HL doen'st have NAV or a 3rd seat and is smaller also the mag says HL is more $$$.
Does the HL have NAV for '03 this fall
This will be one hot tamale for sales, and put big pressure on MDX HL and others. Does the MDX with NAV get the in dash cd changer? WHen comparing $$$ a pilot ex leather with nav will be about 5-7k less than the MDX but the mdx can get memory seats and wood grain interior.
towing: For a trailer of 1000lbs I'd personally just get an aftermarket hitch, but check the owner's manual. If it states you need to have the "tow-package" for any trailerweight, putting a hitch on from aftermarket *could* (but depending on your dealer/situation) void part of your warrranty. Some companies only require the package if you tow above Xlbs.
Competition: The Kia Sorento is gonna be a contendor in this market very soon as well. Not sure of Nav, but volume-wise it will be close and it's gonna have a full frame, 3.5l engine and about 250hp. Also if you don't need 7 pass seating the Axiom is very close as well.
-mike
Thing is I have a 2000# camper. You add 5 people plus stuff for the trip and you have another 1200# or so. Your now at or very near 3500# but not near 4500#.
--jay
On the boat v. camper, if the camper has a profile like a boat (like a popup) then I'd probably not worry about hitting the 4000# or 4500# mark. Axles on trailers are generally rated at no more than 3500lbs each, so to get over 3500lbs on a pop-up would require a dual axle trailer, haven't seen many of them around, which leads me to believe that most if not all pop-ups are less than 3500lbs.
-mike
What/where is this first mag article you refer to???
Also second paisan's recommendation of "delorme Street Atlas" (I have both SA, and MS S&T). The SA allows trips to be uploaded to my gps receiver, which I use standalone. The device has allowed me to say "I never have to ask for directions"......I just don't know where I'm going.
I have connected a laptop on long trips, and in my Ody it fits nicely on the shelf between the front seats with the monitor reclining on the dash like a huge flat screen.
Don't know about Travroute software, but isn't it pricey, like $500? SA and MS S&T are both sub $30.
I'd imagine one reason for a softer ride could be the tire size and maybe the type. Perhaps Honda has tuned the suspension slightly.
I agree that this vehicle will put a lot of pressure on the Highlander. A lot of folks will cross-shop it. The Highlander has some nice attributes (e.g. VSC), but so far you can't get it with nav. The Pilot has "5+3" seating, as someone here so eloquently put it, which is better than "5+0" seating. Not to mention more cargo room.
(Yes, the MDX Touring or the MDX Touring with Nav both come with the 6-disk, in-dash, magazine-less CD changer. It's a terrific feature.)
Below is a link to an article on the iihs.org site regarding side impact crashes (which kill 10,000 people a year), and the benefit of head air bags.
http://www.hwysafety.org/news%5Freleases/2000/pr121400.htm
Agree the tongue weight does play an issue with the rear axle and how much its rated for.
However cargo capacity does play into the towing. A vehical has a GCWR (gross combined weight rating) this is basically:
vehical + trailer = GCVW.
so if the GVWR is 8000# the vehical empty is 4500# and the trailer is 2000# I can add 1500# of people and cargo. If the trailer is 3000# I now have only 500# of cargo and people.
Honestly I never new much about this stuff until a week or so ago when I bought my camper. I learned alot from multiple web sites and message boards about towing campers.
--jay
Also I would check for trailer ratings of your vehicle outside the US. Amazingly most if not all vehicles have a higher tow rating outside the US because the ones sold here want to make sure that they don't get sued. For instance my trooper is rated at 5000lbs here for towing, in the UK, Japan, and Australia, it has 7500lb towing with the same setup. (engine, suspension, etc). Thank the lawyers for the lower tow capacities
-mike
http://adcontroller.unicast.com/upload/hnda/pilo/hnda_pilot1_a_300_Primedia_-rend_html_ad_doc.html
The reason is simply that if you're sitting up higher, the risk to your head is significantly lower. Even if you're in a sedan, and you get hit on the side by another sedan, the head injury is not usually significant.
While NHTSA does NOT test head injury in its side impact tests, EuroNCAP does (www.euroncap.com). If you check their site, you'll find that generally, a car getting hit by another car in the side doesn't cause significant head injury. This is true for vehicles with and without head protection. Even when the head hit the door sill, there was not a very high potential for injury.
It thus follows that if one is riding higher in an SUV and gets hit by a sedan, injury potential is distributed even lower than if one was in a sedan. That's why many SUV's easily score 5-stars in the NHTSA side impact tests. If the SUV gets hit by another SUV or a minivan, the injury forces are distributed higher, but probably not to the head.
In fact, that IIHS article you mentioned has to resort to "the pole test" to test the head protection airbag. E.g. an SUV losing control and sliding sideways into a telephone pole. IIHS had to resort to this type of test since an SUV-into-SUV test wouldn't have produced the type of head injury they want to point out.
I don't question that the pole scenario can happen, but I have to wonder how frequent this scenario is, relative to full-frontal, offset-frontal, rear-enders, and vehicle-into-the-side impacts.
Side curtains also don't help children much. If you look closely, they have a "sweet spot" and very little cushioning toward the edges. A child's head wouldn't hit that spot in many cases.
Thus I think side curtains are somewhat overrated. Though again, I'd rather have them than not have them. And I would, personally, not buy another lower-riding sedan without them. In the case of a sedan, the concept of a tall SUV or minivan plowing into the side does invite large head injury. NHTSA's side impact tests do NOT illustrate a higher vehicle hitting you; their barrier is roughly the size of a smaller sedan.
I was #6 on a list of 17 people waiting(as of 3 weeks ago), I called today and changed from Silver exl to the first to wait for Sagebrush. As soon as the commercials hit the airwaves, I think the whole Oddy waiting game will become a reality (4-6mo wait) for the Pilot. $500 can be knocked off a MDX now, wonder about the barganing of the Oddy in a few months (not that it matters to me).
Any idea of if the Leather is Heated? What about the Oddy and CRV for comparison?
As for their holding back info, just think about this - there is a new Accord coming out this fall. No info - afaik, not even a spy photo has been shown of their bread and butter product. They like to keep us guessing.
That's not the same as a higher riding vehicle. However, if the truck hits an SUV lower (than it does the sedan), the driver's head would still whiplash into (and through?) the window. This would likely cause serious injury that could be avoided with a head type airbag.
The bottom line is that I agree with you. I'd rather have it, and would pay for it as an option.
I would add, If ford can price it into an explorer, so can Honda. And worse yet, it's not even offered on the MDX.
IMHO, I would replace "would" with "could." In theory, you're correct. But as I indicated in my previous message, crash testing has shown that this doesn't happen quite as badly as one might think.
Body/head recoil in a side impact simply isn't the same as it is in a forward impact. Videos of side impact crash tests demonstrate this. Rarely does the occupants' head come through the window. It'd be even rarer for the head to go through the window, and then bend down enough to hit the hood of a pickup impacting on the lower portion of the vehicle. Perhaps if one is an idiot and doesn't buckle up, it might happen.
At worse (and this is not very frequent), in side impact tests, the dummy's head tends to simply bounce off the door sill or the pillar. Unfortunately most side curtains don't cushion those areas. In the tests, most of the time there is no head injury, hence my original point. EuroNCAP tests confirm this.
That's one reason side airbags are not as large or as forceful as front airbags, there just isn't much recoil. Also why NHTSA doesn't currently instrument head injury in their side impact test.
Again, I'd rather have them than not, and Acura should put them in the MDX. Toyota doesn't yet have them in the Highlander, though. I just think that side curtains in SUV's are overrated and won't produce as many safety benefits as one might think.
Also, when Honda/Acura eventually introduces head protection, it'll be interesting to see if it's in the form of side curtains for the front and rear, or just multi-chambered side airbags for the front occupants only (e.g. 2003 Subaru Forester, some of the GM SUV's). We'll see.
I think that would depend on the speed at which the truck strikes the SUV on its side. If it's so severe that the whiplash could cause the driver's head to hit the window, I wouldn't worry about head curtains. The driver's spinal cord would've probably already snapped at this point.
I wouldn't characterize folks that don't buckle up as idiots. Certainly, they are foolish. People don't buckle up for lots of reasons including being very busy people, thoughtlessness and ignorance (not in the pejorative sense - meaning only that they don't fully understand the consequences.) Most of these people have normal intelligence.
tidester
SUVs
-mike
thanks,
mike
After market hitches may take a while since this is a new vehicle.
Thanks for the info on using your laptop for gps, my wife says she would rather save 5-7k, get NAV without the in dash cd changer. but will the cd player be a single player with a changer added on or just a changer (installed away fromthe dash) she changes cd's a lot.
Just got back from China saturday, adopted a little girl, that's why we need a new vehichle, have to sell the turbo bug 2dr, sell the ml320 (we need an update) it's got 65k miles, and will probably sell to a famliy member.
If you all would like to see pictures of our little girl Chloe (8 months) here is the link
http://www.ofoto.com/I.jsp?m=86573740403&n=1445491042
We are trying to get her on a schedule, but after a 14 hour flight in economy class it's tough they are 12 hours different. But my wife has been working real hard on exercises, and keeping to a regimine. she is getting stronger every day (she's at a 6 month development level 5-10 percentile for US babies, but she will catch up.
Hey, everybody else is quoting it....
Ive watched a number of side impact videos and, AFAIK, the window always shattered before the dummys head came near it. There are several where you can watch the dummys head pass through the opening, but the glass is already gone. Since the vehicle is pushed away from the impact, theres not reason t suspect that the occupants head would hit the shards either.
These pics are for the CR-V, but you can see in both cases that, even when the glass doesnt shatter, it can be pulled away from the occupant.
CR-V without SAB
CR-V w/ SAB
In short, I don't think that hitting the window is a big deal. Whiplash is a greater possibility, but I don't know that an airbag would prevent that.
Wonderful people, there were 6 couples in our group in Nanchang, every time we stopped hordes of people would crowd around us to touch and look at the baby, they love children over there, we would plug up streets, walkways, grocery stores, people are just amazed that we have a chinese baby. children would run up to us to try out there english. it's amazing. great experience.:)
I'll get back on subject on the pilot--excuse the tangent.
Yes, I think we've seen some similar videos. If the window shatters, a side curtain doesn't have much to brace itself to keep the head from sticking out the window (in the event that it does happen). If anything, the head protection seems to be much more effective when something is actually smashing through the window, and the airbag acts as a cushion to keep your head from impacting against it and sustaining severe trauma.
That's why IIHS had to resort to smashing an SUV sideways with a pole ;-) They couldn't have generated the same type of head trauma with the pickup they used against the sedan, and it was their objective to dramatize (sensationalize?) the benefits of head protection.
Again, I'd like to see Honda/Acura introduce head protection into their sedans and SUV's. Certainly it's of value in the sedans, and is of some, albeit limited, value in the SUV's.
tidester:
Perhaps "idiot" is too aggressive a word and not politically correct, in which case I apologize. But, given the fact that there is such information given out about the benefits of seat belts, I'm not too sure I can think of very good words for those who don't buckle up.
It's everyone's freedom of choice to do what they want in life. But given that most fatalities result from not being buckled up, all they're doing is driving up the insurance rates for the rest of us!
I just can't buy into excuses like some people are "very busy" to buckle up.
This may sound harsh, but it's my opinion.
nofeer:
Congratulations, you're doing a great thing!
And now, back to the Pilot ...
-mike
Steve
tidester
SUVs
Nope. Right on. "Too busy," "I just forgot," "I didn't know the consequences of not wearing a seat," bla bla bla. I say if a driver can close the door, turn on the radio, and adjust the mirrors, he or she can remember to buckle up, too.
No seatbelts - foolish? Absolutely! It's the "won't happen to me" syndrome and the data is on their side. Inconsiderate? Totally! Not only will it drive up my insurance rates, it will certainly cause surviving loved ones agonizing grief IF it happens.
tidester
SUVs
hmm, that's a bit morbid. Nevermind :-)
Steve
His comment, "I usually rely on the airbag." (!!!)
Back to the Pilot, I noticed its headrests are of a different design than the MDX? Are they similar to another Honda vehicle (e.g. the Odyssey or hopefully the new CR-V)?
Reason I'm asking is that while the MDX has thus far scored stellar crash test scores, the IIHS assessment of the headrests is not particularly good. Assessment for preventing whiplash, that is. The MDX's were rated only "marginal." This is disturbing given that Honda/Acura generally hasn't done well in the headrest assessments -- until perhaps now. The new CR-V now carries a top rating and the new RSX also gets it (though with a footnote).
Hopefully Honda is correcting this deficiency in its newer vehicles and the Pilot will benefit from it. Heck, if they work well and can be swapped, I'd consider trying to get the Pilot headrests for the MDX (or new MDX ones if they get updated). The current MDX headrests are not particularly comfortable and I can see how they don't do a very good job of preventing whiplash.
http://www.iihs.org/vehicle_ratings/head_restraints/head_honda.htm
The second row headrests are too small, IMHO. They seem to have been designed with the sole intention of increasing reaward visibility. They can be raised quite a bit (to an acceptable height), but they are still small. And how many times to people in the rear seats actually adjust them for a proper fit?
The third row headrests are the same design/size as the second row. However, the seatback is too low as demonstrated in this pic. (note the headrest could still be raised another notch, but it still wouldn't be high enough)
Motor trend--on newstands yet or for subscribers?
-mike
Thanks for the incredible perspective on what's really important in life.
Chloe is adorable.
