I had a Mercury Sable about 15 years ago that developed the same symptom. It was about 5 years old with about 50K miles if I recall correctly. The car would start easily, but it was slow on the uptake when blipping the throttle in nuetral.
Couldn't coax 30 miles per hour out of it on the road. Turned out to simply be the catalytic convertor was the culprit. Replaced. Problem solved. May be covered under Infinity warranty if so, but act fast.
You need to provide a little more info on your car (mileage). Also, examine the entire exhaust system for damage like a dented pipe or convertor.
Jack
I've had the car for almost six years and I'm beginning to have problems with the car at this time. When I start my car the screen on the radio disappears but the AC in my car is on. I can't seem to turn the AC off but the as the radio is able to work. Just wondering if anyone experienced this situation before? What was the diagnostics of the problem and what is the cost of the damage?
Thank you so much for your help!!!
go ahead and buy the G35. It's very easy to maintain even at home yourself. If you are in the San Francisco, Bay Area, I can service it for you for a very low cost. Look me up on yelp in San Francisco, Enthusiast Auto Care. I do all of the DIY videos also, you can watch those on http://www.infinitihelp.com
you are asking for an explanation to a very complicated issue. The facts are real:
less engine wear
less volatility
purity
prolonged use
higher amount of detergents
I can discuss this with you in detail if you want to call me or email me. First, however, please watch this discovery channel special on synthetic motor oils.
lube job
1) The obvious, has aanyone experienced this so soon?
2) I am told this is NOT covered under warranty after 12K! - I might fight that if it happens again since it happend earlier.
3) What real impact will this have on overall break life expectancy
I was told if the warping came back while under warranty, they'd replace the rotors.
As most people know, turning a warped rotor is only a temporary bandaid. The warping came back at 30K and the rotors were replaced with no questions asked.
If and when these things go south again, I'll be replacing them with a higher end aftermarket rotor. No more OEM for me once these things are done.
What could be the problem?
A clean used 2004 like you're buying is probably worth $16,000 in today's market. Being a wreck it will no doubt carry a rebuilt or salvage title, so that will cut value by 1/3, thus we are retail at about $10,500.
You are paying $4000 for it, plus let's say $2500 in parts with tax, etc. So you're in $6500 with no labor yet.
On the face of it, without seeing the car, AND even with presuming you're doing all the collision repair and paint yourself----it doesn't seem worth the trouble. If you have to hire someone to do some of the work, it definitely isn't worth it, in my opinion.
The only scenario I could see this working out for you would be a) if the car were not salvage title and b) if you did all the collision and paint yourself. THEN you'd have a much cheaper G35 than you could buy retail. But both those criteria have to be in place at the same time---no salvage, you doing all the work.
Otherwise, my two cents is FORGET IT!
Once upon a time I was in the market for a used Corvette, and a private party seller let me take his car (a 1970 large block convertible) for a full one hour spin. The owner told me he had hit a telephone pole but that the car had been repaired by a reputable collision shop. The car generally looked good and the price was attractive.
Under acceleration and deceleration the nose of the car would travel upward slightly to the right and then dive down slightly to the left. I returned, told the seller about it (he probably knew), and asked if it was ok to take the car to a place of my choosing for an opinion. He agreed.
My guy confirmed that the car was straight but that incorrect motor mounts used in the repair were causing the issue. Plus a front suspension spring was also incorrect. He gave me a quote to correct these things, and I returned to the seller. But the seller wouldn't budge on the price. I took a walk, and eventually my patience was rewarded with a 1969 Coupe, slightly more money. Still have the car 36 years later.
If the G35 is straight and running well, the price is right, and you are facing just plastic, sheet metal, and paint, this could be a good deal. Just 45,000 miles makes the idea interesting, TO ME, to get into the G35 Coupe. The car is a blast to drive and (heresy!) so civil and foregiving relative to my Corvette.
Jack
Anyway, in spite of our careful efforts, the paint job managed to show little scrapes marks as a result. We were both very surprised that such little pressure would be able to cause these marks. We hoped that maybe we were just scraping the 'paint shield'.
I finally took my car to a recommended body shop who stated a blended paint job would do the trick for about $1000.00. Being I like this car, I was considering this option. But I also decided to stop at another body shop who discouraged me from the paint job just because of the cost factor. He suggested trying a buff-out first (for about $100.00). Boy! Am I glad I tried his recommendation. They got out 95% of the scrapes. Looks almost brand new. A couple dings were slightly deeper and couldn't be repaired this way. But they are very small. Heck, any car is bound to get a few dings eventually unless you never drive it. But the difference between the string of scrapes that were, versus what I see now is really astounding.
So basically nothing to complain or question about here. I am just happy that I was finally able to get something satisfactory repaired for under $250.00 on my car.
See you there!
I recently just replaced my battery, simple stuff really. After I did this I turned the power back on and the control panel inside the car comes on, however the outside temp guage stars at 54 and works it's way down to the outside temperature.
Also the indicators don't work and the 4 ways dont work. I checked every single fuse that car has and they are all good.
Has anyone heard or had this happen to them before?
Any idea's thoughts??
HELP!!!!!
I was just wondering how much the 30k maintenance and a rear brake(s) replacement should go for? Dealer quoted just over $900...
You lumped two things together.......the 30K maintenance and the rear brake job. And you didn't state the year/model of G35. So it is difficult to say what is acceptable and what may be out of wack.
Jack..
The 30k maintenance was a little over $500.
The brakes were just about $400.
Thanks for the quick feedback....
Hope it helps!
Does anyone have any ideas?? I would appreciate the advice.
Greg
So far I have changed the brakes on this one once and the tires from Costco. Other than that there have been no major expenses, but regular oil changes. So it is safe to say that this car has been trouble free all these years.
Does anyone know if it is super expensive to pay maintainence once the car accumulates high mileage? What are the known failure mechanisms? We have talked about potentially selling this car off and buying a Nissan/Honda with lower mileage to use as a commuter vehicle.
Any suggestions/pointers on this one? If we kept the car or about 2 more years, would it be worth it? We get about 24mpg average on the freeway -not bad at all..
C'mon, you drive a nice car, it deserves good rubber!!!
It will re-pay you!!
Other than breaks and tires.. did you incur any major costs? Should I be worried about anything? I just got a 750Li Beamer and I am paranoid about potentially paying premium maintainence costs for the Infiniti (Beamers eat you up on maintainence).
Personally, we drive cars cradle to grave. Wife gets the new one and I drive the hand me downs. Figure 10-12 years total life expectancy. I just have to make sure what my wife wants next is something I would eventually enjoy. Once the car is paid off, you can pay for a lot of repairs and not be concerned a lick because it it still cheaper than the car payments. Insurance costs drop as do annual excise taxes (in MA.) Depreciation expense becomes a non issue also..
I have never had an engine failure. Oil changes and coolant......keep those up to snuff and the car will rust out before the engine wears out. Transmissions have been another expensive story despite the correct maintence schedule. Same with a/c units. I have never figured out if it was due to buying American or running a couple of teens through the pipeline at the same time I owned the cars. The G35 Coupe is my first venture into foreign. Figure that we get about 120,000 miles out of a car on average.
Like the others who have responded, I stay away from dealers for repairs, and certainly mantenance, if humanly possible except for warranty work. Have the same private mechanic for 15 years. Have been selective on rotor/pad replacement as one posted. Tires......swiched to all seasons for some winter traction, TireRack or a local tire dealer that will match the price. Currently running Bridgestone Potenza 960AS at about one third less than the oem Michelin summer tires, and I love them.
Most have you have read the rants about the G's fuel economy. It isn't great but the car is no Civic either. But the Coupe can consistently get 26-27 highway on cruise for the long haul at the speed limits plus 7. Around town 17-18. Mixed 20-21. Add in the right foot "happies" for some fun and everything plummets from there. But that for me is where the fun factor outweighs practicality.
I'm underwhelmed by the Coupe's tiny trunk, but it is not intended to be ultra practical. With the back seat folded down, no space issues. And I never ride in the back seat, didn't buy the car to be a people hauler, yet the back seat is surprisingly functional for what the car is.
So my opinion is keep it and drive it to death.
Thanks for your replies!
Sorry about not providing more info this is the first time I have ever posted.
I also changed some belts and filters and have had regular oil changes.
