-juice
~c
So yes shifting ok.
-juice
Cheers Pat.
what you're experiencing sounds like: (in my humble order of likeliness so far)
a) bad synchronizer(s)
b) bent or improperly installed shift fork, causing gear(s) to not be fully mated
c) gear wear --usually misalignment, manufacturing or assembly defect, or abuse
Good call bringing it into the shop promptly. If they say nothing is wrong, grin and bear it, log a call with 800-subaru, and then wait until it gets louder. Then bring it back and call in the heavy hitters. aka Patti.
~Colin
But the stock shift lever has rubberized insulation to dampen the vibes. Not sure if the XT's does or not.
-juice
I mentioned a possible faulty bearing when I dropped it off, only because there is one, and ONLY one, other report of such an incident over on Nabisco.
Colin: Instead of 'chatter', could it also emit a high-pitched squeak/squeal/chirp/almost a whistling noise? There with the clutch out, not with the pedal down, and I can almost modulate it with very slight pedal movement. Mine's been there for awhile, but hasn't affected function at all.
Cheers!
Paul
Friend of mine with a new STi claims that the high-flow, high-performance foam air cleaners (K&N, for example), are bad for Subies as they tend to mess up the airflow sensor by allowing too much air into the engine, screwing up mixtures, performance, emissions, etc.
Truth, or bullbleep? I'm needing a new air filter, and contemplating a K&N or equivalent.
Whaddya all think?
Cheers!
Paul
K&N Air Filters, bolt-on power?
Glad the dealer found the problem. I think you're the first person I know of who has had a tranny problem with the new "reinforced" 5MT.
Ken
~c
-Brian
Cheers Pat.
-mike
Thanks and I'm sorry you had the scare!
Patti
What he is referring to actually is that often the kids who run these filters over-oil them, this results in excess oil flowing over the MAF and destroying it. So it's essentially a myth, but with some background in reality.
-mike
That's even better news. Perhaps SOA wanted to take a look since it's one of the few data points they have for the new 5MT.
Ken
This post describes your rights if you have a newer model Forester or Impreza and have wind noise caused by your window gusset.
I got a document in the mail yesterday about this issue. The document was released by Subaru in April 2004 and refers to MY2002-2004 Foresters and Imprezas. (the doc cost $5 from subaru technical site but s&h was $15!!!)
Anyway the net net of it is if you hear wind noise and think it's coming from the window gusset (triangular shaped plastic part on the window near the side view mirror), subaru will check the following.
1) cars with newer window gussets installed (outback, legacy, baja) are not part of this - only impreza and forester models have the older style window gussets that would be considered for replacement by newer gusset.
2) dealer will confirm wind noise over 40MPH by test drive. if pressing on glass eliminates the noise then go to next step
3) dealer measures space between window glass and gusset on both inside and outside of window (with window up). if space is less than 2mm you're fine.
4) dealer measures space between each side of gusset with window down. if space is less than 5mm you're fine.
5) finally, if space between gusset sides is > 5mm, space between glass and gusset is > 2mm and wind noise is eliminated by pressing on glass, then dealer will install new style window gusset (instructions most likely in another 2-page document that costs $15 to drop in the mail) and adjust the angle of the gusset so the space between glass and gusset is same on inside and outside of window.
Thanks for the input, guys.
Cheers!
Paul
There's no bolt but now there's a star-looking thing that indents into the plug. I've seen them before but can't remember the name. Hopefully, I can find it at a hardware store.
-Dennis
Cheers Pat.
Thanks Pat.
-Dennis
Cheers Pat.
Thanks people,
fitzy2
legacy sedan 4*204269
legacy wagon 4*301951
outback 4*614779
baja 4*100963
If your LL Bean does not have one of the VIN ranges above then you likely have the older gusset and can go in and get them replaced for the newer part:
new part number left: 61158AE01B
new part number right: 61158AE00B
BTW - I made a mistake in my posting in test #3. It should read: "if space is less than 0.2 mm (not 2mm) with the window up and the door closed, then you're fine."
elissa
Now, at 27k, the light has come on again. I plan to call the dealer ASAP to schedule an appointment, but am wondering what happens if the dealer is unable to resolve this issue. More to the point, what happens after the 36k all inclusive warranty expires and an AIR BAG problem continues to appear? If the problem was noted prior to the warranty expired, I would "assume" Subaru is on the hook to provide a resolution.
In addition, I signed up with mysubaru.com, but noted that they do not have the recall work being done for my VIN number (the parking rod issue). I was assured when I purchased the car that this work had been completed at the dealership. How can I tell if this work has been done or not?
All in all, I have been happy with the Subaru, and the first problem with the Air Bag light did not concern me too much. Now, however, I am worried that I will have a persistent problem that will be difficult to resolve. How many times should I have the dealer attempt to correct this problem, and then who should I escalate to (beyond the service manager at the dealership)?
Thanks for all of your time!
How about the new 2005 2.5s?
Piston slap is not that common, actually. We now have 5 Subies in the family and not one has had that problem.
The 2005 engine is basically an evolution of the EJ255, so it probably has a lot in common with the existing engines.
-juice
-juice
Otherwise, after the waranty expired, the car has been solid! (WRX).
If so, the area where my HVAC filter is installed has a cap (though it looks more like an L shaped lid) that secures with two bolts. Maybe one bolt fell off?
-juice
The Forester's 2.5l is bored out significantly, the cylinder walls are a lot thinner. Plus, any large 4 cylinder will have more shakes to deal with, there's just more reciprocating mass.
What's impressive is that your '93 is still in good tune, so it's kept that advantage.
-juice
When filling the gas tank, whether running on fumes, half full, or mostly full, ALL gas pumps shut themselves off every 1/4 gallon. Pumping very slowly helps sometimes, but it still shuts off. Took it to the dealer who called the tech-line and they recommended replacing the vent valve and the filler valve. $600 later, the problem still exists NO IMPROVEMENT! Heeellllpp!
Val
If it just started, you may have condensation in your tank - try dumping a can of Dry-Gas in there - see if that helps.
I will try the Dry-Gas.
And Juice, the 92 is not mine but belongs to my brother-in-law who came for a visit with his family. It has always been dealer serviced and very well maintained. Mine was a 93 junked last year.
Basically, I am waiting for the Legacy GT to become more prevalent at dealerships before bringing in my car for the notice. :-)
Keep us posted.
-mike
