-juice
-Dennis
We brought it to a local repair shop which said it produced the code for a bad "idle air valve" (I'm not sure what this is). The dealer has replaced the MAF sensor twice - once at 33,000 miles and again October 2002 (55K miles) under the recall. Any thoughts? What's a idle air (control?) valve and, if bad, would it explain the symptoms? Also, is it possible that a weak/dead battery could cause the computer to generate a false code and kill a fuel injector?
Man, this car is a lemon!
The stumbling could be condensation from the gas tank, something as simple as that.
First, I'd reset the ECU by disconnecting the negative battery terminal. Give it a fresh start. Wait 20 minutes, then reconnect, start her up and let her idle.
Your first tank will get poor mileage, but it'll lean out the fuel mixture and should return to normal after that.
Another thing, when starting, is to always let the fuel pump prime before you start. Turn the key to the On position, but don't start it. Listen for the "whirr" sound the fuel pump makes. Then start it. It should be smoother.
The OE battery isn't very strong, so yeah, actually, an aftermarket battery with more CCAs will help if you have rough starting. It may be an early sign that your battery is beginning to fail. I'd change it pro-actively. Yours has already lasted more than mine (I have a '98 and the battery failed 2 years ago).
Good luck and stick with us, we'll provide tips to keep it running smoothly.
-juice
-juice
-mike
Greg
sounds pretty bad.
~c
Any idea of potential problem / solution?
Thanks for the tips and suggestions. While I fully understand that lemon is a legal term, this Sube is sure leaving a sour taste in my mouth. The list of repairs - most of them major including replacing the cylinder heads and ultimately the engine short block, the clutch assembly (3x), the brakes/rotors (2x), the MAF (2x), the rear window, etc. - is quite long. However, this is my first problem "off-warranty."
I'll take your advice about resetting the ECU and probably getting a new battery. My wife drove the car to work today - fine on the highway, but stalled twice at a light - so the idle control might actually be the problem. Also, most of the problems did start after getting a tank of gas last week from somewhere new. It was premium 92, though.
Any idea or ballpark cost of replacing the said malfunctioning idle air control valve - if that is indeed the problem?
Weak spark - have you changes plugs, wires or even the ignition coil?
Fuel mix - start with the basics - a large bottle of Chevron Tektron fuel system cleaner. This will help unplug dirty injectors (poor spray pattern / atomization) and remove deposits on the neck of intake valves that can interfere with pattern & mixing.
Steve
FWIW, I'm on my original brake pads. Zero out-of-pocket costs for 59k miles, too.
Not sure about the price, but check subaruparts.com for a wholesaler.
-juice
-juice
Craig
~c
Cheers Pat.
took a long time to get the wheels and some trim/moulding
~c
Cheers Pat.
I don't think eaven Patti can help.
Yes there is a bit of a chill this morning. We like to think it builds character.
The warmest its been is -5 the past 3 days.
Subie is starting fairly well. Makes noise, timing belt? piston slap? other? Still much quieter than a VW TDI that was next to me.
--Jay
In sunny but cool Minneapolis.
Current temp -26F. Wind Chill about -50F.
-les
Colorado is getting snow this weekend-can't wait to "let her out and run around alittle"
See you at Loveland on Sunday
Jon
Steve
--jay (wonderful high temp of -7F so far today!)
Patti
What are the important mileage milestones for scheduled maintenance? What needs to be done?
I heard that it is bad to drive any new car with less than 500 miles on a long trip, that you shouldn't drive at a steady speed while new?
True or not?
For my WRX, the break-in period was the first 1,000 miles, and I tried to keep it below 4000 rpms, never cruised for long at a constant speed, and overall took it easy on the engine (no heavy load launches, etc.)
Enjoy your new ride!
Paul
In any case, congratulations on your new ride and feel free to join us in the Forester discussion where you'll learn more than you ever thought possible about your Forester.
-Frank P.
Eric
My cousin just bought an Audi A4 and his salesguy specifically said no break-in needed - those days are gone.
Do Subaru Autobahn drivers follow our prescribed routine?
Mike k
Squealing alternator - it could be just the belt needing adjustment/replacement.
Jim
I would suggest following the Subaru break-in guidelines as a minimum. I, erring on the side of caution, doubled my break-in period to 2,000 miles.
As for the alternator, I hope it's just the belt, but I recently checked the tension and it's OK. I'm going to buy a stethoscope tonight to see if I can locate the source of the noise.
Eric
Congratulations!
Patti
What color? Trans type? Options?
Join us in the Forester thread, which is usually quite active.
-juice
-Frank P.
-Ty
-Brian
Does your vehicle have onstar? I'm not sure how Subaru incorporates onstar, but some manufacturers use a special rear view mirror.
I replaced my auto-dimming/compass mirror in my WRX with a similar one that also included an outside thermometer, so I did a lot of research into these before I purchased it. By the way, I still have my original mirror if anyone is interested.
Take care,
Paul
Alon
Cheers Pat.
-mike
Jim
is just to save them a LOT of money. Good luck...but if you
keep that car the headgaskets will blow sooner or later.
qcmaninalaska
