Since that part is expensive you may want to try using a air intake spray cleaner first to see if it helps.
Disconnect the hose that comes from the air cleaner to the intake at the intake (engine) end, There is a plate in there ...look inside you will see it...spray in there with the cleaner.
I did this once on a Toyota and it was a big help.
I have never heard of laser plugs....did you mean irradium ?
Just courious...how many miles on your Aerio ?
Kaaihue
Thanx....
If the drive is five miles and/or 15+ minutes in length, my generator charges the battery enough to maintain normal starting.
Second....is the alternator output per specs.
Hope this helps.
A lot of auto supply stores will check the alternator output for free or you can buy a cheap tester for around $6.00
-d
I looked up the situations that could come with black ATF sloshing within my system, and things simply don't look that good even if I choose a professional flush. Fortunately, I am a zealous saver and can take the potential hit (it will be painful, regardless).
The next time I get an offer for a fluid change at 30k or 60k, I won't hesitate taking it.
I have ran MANY cars up to 100 K before changing trans fluid....never had a problem.
As far as them not wanting to touch it...that is just plain STUPID...I don't care who changes the fluid if it is truly "black"....the result will be the same.
I bet you have burnt the transmission up...overheated the bands....thus "black" fluid.
BTW: I now have an 06 with 392K on it...tranny fluid has only been chnaged twice...it is not black now...nor was it ever.
Hope this helps for anyone who has an isue wth Rear Tire premature wear.
If you have comprehensive insurance your best bet will be to hit a deer and total the car.
One more note. I have not been able to drive my `03 SX since 1/6/09 when the engine died.(92k miles and still under warranty). I took it to the dealer, they agreed by the sound that the engine was bad and told me they needed ~$300 to pull the pan and head to take pictures for Suzuki for authorization of the engine replacement. I knew then that I was going to get screwed. They told me the engine was bad and that I ran it out of oil, which of course is not true. After the dealer threatend to start charging storage I towed the car home and got a better look at it with a few car friends. Neithe the dealer or Suzuki would say more than the motor was bad. We found that the skirt on the #3 piston was broken and a stationary cam chain guide was broken. I don't see even if the car was run low on oil how it could cause either problem. Suzuki still asserts that it is my problem.
Suzuki will act in bad faith every time. Get rid of your problem car as soon as you can it will only get worse. :lemon: :lemon: :lemon:
It seems likely that your electric fan is not coming on for one reason or another. It could be something as simple as a fuse or relay, or it could be that the fan itself is out.
just wondering if anyone has had to replace anything related to their exhaust. i apparently need a "muffler and center pipe assembly" since there are rust issues. according to suzuki they have to order this part from california and parts alone cost about $575. a muffler place nearby has the muffler for $200ish but they are missing the center pipe. the auto shop that would fix it would charge under $100 labor so the bulk of the cost to fix this is parts. any ideas where i can find the parts? and/or has anyone one else had this problem?
Three weeks ago, I had a BIG zinger. The engine quit on my sister in law as she was driving home. She called and told me there was a loud "bang" and she couldn't get it started. Since she was about 2 hours away, I suggested she have it towed to the local dealer.
The Gainesville, Florida Suzuki dealership is no more and we were told to take it to a Chevy dealership. They had the car for about three days and the report they gave us was bad, real bad. The head was warped and the crankcase was full of coolant. A rod broke in two putting a rather impressive hole in the side of the block. The coolant was not low as I had just checked all the fluids before I let her use the car earlier that day.
Three weeks later we have a brand new engine and a new 100,000 mile power train warranty, and, get this....no money out of pocket.
First of all thank You very much for every one who are giving suggestions and those who are sharing their thoughts.
I Bought second hand suziki aerio 2003 model 3 months back. it worked fine till now and we went for a long drive 2 months ago too but did not have a problem. But suddenly yesterday when I was on highway suddenly car started to jump and all of sudden after some distance it stopped. It was not moving at all. I stopped the engine and again started it but the car did not move forward. And when I start the engine and leave it in parking it shuts down by itself. I took to the mechanic he saw it and told nothing except take to the dealer.
I am not understanding what to do. Please can anyone suggest some suggestions....
Thanks in Advance.
Northlander
WTF!
Is this vehicle on par with the Ford Edsel???
I was joined to suzuki at the hip until this piece of crap came on the market. Never again.
I got an '05 swift at the same time (which is made by Daewoo), and it has 93,000 kms. I just got the second set of tires this past summer and still on the original brakes and rotors. A better vehicle by far.
I had a problem with my check engine light. I asked one of the guys at work, and was sent to their "favorite" mechanic: I had the code checked; it indicated I needed a new catalytic converter ( smog equipment). In my case, the location of the code indicated the expensive $1000 (or was it two thousand?) one. He recommended I had tried pouring in a container (quart? It the size of a lighter fluid bottle-the ones people use on their BBQ) of denatured alcohol in the gas tank to see if that would clear it( when you do the fill up); no luck. The mechanic also tried to just reset the code, and told me if the code/light came back in, then I would probably have to do it. The light came back in.
I was panicked at the $$$$ outlay in my future...THEN, it was suggested, I start inexpensively, and tried to JUST REPLACE THE SENSOR, which was like $79. The local mechanic who did the work even told me, upon pickup ,that the original sensor tested good. The codes cleared and never came back, and that was a year and a half ago! Oh, and you know if you fail to tighten the gas cap well enough, the check engine light comes on, don't you? It will clear in a couple of start-ups after you tighten it. Good Luck. Ronnie
I know that the 65 is 10% larger, but it's also cheaper and has a higher milage guaruntee. Not to concerned with the difference in speed ratings 'cause I don't race it or drive over 75mph.
http://www.miata.net/garage/tirecalc.html
I own a 2005 Aerio Sx, with 69,xxx miles, which seems to enjoy stalling while in reverse (when shifted from park) and has a rough idle. Oddly enough, the issue seems to be alleviated when the AC is on. Any ideas as to what is going wrong?
Mine idles rough when I am low on oil or in need of an oil change, which is usually the same. Meaning, when I am in need of an oil change, I am also low on oil for some reason. This has been going on since I was in the 60,000 mile range or before even. I have a 2003 Suzuki SX. Ronnie
Anyone know of ECU updates or failed Knock Sensors...? Any other experiences with a noise when cold over 2500 RPM? Change the Spark Plug to colder or Hotter plugs? This is my daily driver and I do or have the mantenance done and check the book for each mileage as described. I disagree with changing Anti freeze every 30,000 but I do it;).
Al
I thought I had my belt and tensioner components replaced at one point. I was wrong.
good lucks.
This was years ago now, but (I'm a 2003 with 177,777+ miles now)
The car wasn't going anywhere when I pressed on the gas because the car was popping out of gear.
I own an '04 Aerio SX wagon with 70,000-ish miles on it. I recently took it into my mechanic for some general maintenance including flushing the brake fluid, but was told that this model doesn't require brake fluid replacement. Is this accurate? I was also told (by a different mechanic) that fuel filter replacement is not an every-30,000-miles maintenance requirement for the Aerio; more like every 150,000+ miles and, when the time comes, it's pretty expensive to replace. Is this also true?
