As for the locking stuff, I have an S so I don't know.
Myself and a few others are experencing the pulling effect. Mine happens to be to the left. While on the highway if I let go of the wheel, I'm switching lanes weither I want to or not. The slope of the road just determines how fast I'm commin over. On a perfectly "flat" road my car will drift over slowly.
Haven't had any other problems. It's definitely fun to drive. Hope there are no further issues.
As for headlights, it may be due to the projector headlight design, similar to HID lights, it has a sharp cutoff area. Most headlights can be adjusted though, check repair manuals or online search for headlight adjusting levels. If you do it yourself and do it wrong, you might be pulled over.
And finally alignment, it seems to me a few of your cars have a slight alignment problem, on a flat (no crown) road, you should go straight, if it's slightly tilted to the right, driving in the right lane of a crowned road may be enough for it to pull to the right, same with driving in the left lane with a slightly tilted to the left. Mis-alignment is not a simple yes or no, there are degrees of it, some are more misaligned than others, but the dealer should be able to fix it for free since it's such a new car.
I love my loaded MT 6s and haven't had ANY of the problems folks have listed on all 12 pages of this discussion. However, I do have some problems or issues that I was wondering if anyone else has come across.
First, I have the Bose upgrade...at certain pitches of bass, both of my front door panels (and the rear for all I know) vibrate. One song may have a real heavy bass (dance or hip-hop kind of stuff) and nothing happens, it plays it perfectly. But if I play something like Radiohead that has some more unusual and higher range of bass, the door panels vibrate; I know it's the panels because I can slightly subdue the vibrations by pressing on a few spots on the panels. The driver's side door had a broken panel pin when I got it and this problem arose after they fixed it. I plan on taking it into the dealer when I find time, but was just wondering if anyone else noticed this problem.
Second, my passenger's window has become stuck twice and after messing with the other window switches in an effort to reset it somehow, it works. I assume this is probably a loose connection, but wondered if anyone else has come across this issue as well.
Next, my seat seems to be a little loose. It was fine until recently when I noticed that if I shift my weight to one side or the other the seat seems to pop over like it's not fully engaged or possible broken. It can probably be fixed, but as I said before, I'm curious.
Finally, has anyone achieved better than 20 mph in the city? This is a fun car, so I do tend to have a heavy foot, but I barely push over 300 miles a tank if the driving includes anything but highway. It was a blast driving it from Atlanta up here to Rapid City SD, much smoother and comfortable than my '99 BMW 323...plenty of bhp to really blast down the highways.
I absolutely love this car, but little annoyances need to go away. With just over 7,000 I don't expect to have any issues.
p.s. I still think the 6s is the best deal out there for sports sedans and that the Accords and Camry are so darn innocuous and lack any character. Once mazda works these little issues out and adds a few more options it could compete very well in teh next bracket up.
The other day I had to mute the stereo as I was driving over a fairly bumpy road, and I noticed the door was vibrating slightly then as well. All I can figure is that maybe something is loose in there or it needs some extra sort of insulation. It's annoying during certain songs, but I don't know how soon I'll be able to get it to a dealership to have it looked at. I figure as a worst-case scenario, I'll have them look at it when I have my first oil change.
If you get the issue resolved or find out anything else, please let me know as well.
As for drifting my 6 stays straight on flat roads but has a strong drift when I'm on sloping roads either left or right. I've found that to be a problem with almost every car I drove but it does seem more pronounced with the 6. I figure that it must be the tires as the Michelins grip the road well so it brings out the slope even more. I just learned to live with it. My father's Maxima with 17's does it to the same degree as the 6 so I imagine it's common with the lower profile tires.
- When to get the first change - with the initial wear, I understand an early-ish change is a good idea. Perhaps 2K miles? Or earlier?
- How and when to make the switch to synthetic tranny and engine oil. Stick with dino for a couple of changes, do a couple of blend changes or just dump in equivalent synth in both (engine and tranny) right away? I don't live in a bad weather area - so I think Mobil or Castrol Syntech products (instead of RedLine or something more exotic) would do the trick.
Any opinions? References? Experiences?
Has anyone have problems with the manual 6.
I've gt the Bose, and have the same problem; certain tracks on certain CDs cause vibration in the door. This happens with bass settings of 1 - 3 (I never set it higher). On some tracks I have to turn bass to negative 1 or 2! Treble stays at 5.
Loupie
Is the 6s known to have a fairly abrupt transmission, or are these signs of an automatic that needs adustment or service?? High speed runs seem to smooth out the shifting characteristics somewhat....in general, I find that the throttle response upon shift to be not as smooth as I had expected.
My 6s shifts smoother now at 4,000 miles than it did at 500.
I know there is a new flash out for the ECM. I'm not sure if it applies to the TCM or not.
I have seen 5 or 6 posts on the other MZ6 site for this shifting . I have never read anything about the "whine" sound.
Also remember the 6s has a "fly by wire" throttle. It takes a little while to get used to. The response is not the same as a mechanical link. Mazda is aware that people have been complaining about the throttle response on the 6s. Hopefully they will offer a solution. The new ECM flash may help. I'm not sure what it contains at this point.
Mark.
I put two coats of Nu-Finish on my 6s the first day. While I still have dust, it only takes me 5 min to wipe it off with a paper towel every couple of days.
Now, if your someone who can't take 5 min every other day, then there is no real solution to the dust issue other than new pads.
Mark.
I'm running 20w during the first few thousand to facilitate break-in, and insurance if something breaks. Any assembly problems would show up by 6,000 miles. The 6s engine runs hot IMO. There is no way I'm running anything less than a 30w. 20w is CAFE. It will turn your 200,00 mile engine into a 100,000 mile engine, IMO.
Do a google search for bobtheoilguy. You will never look at oil the same way again.
Anyone who's already made the switch to synth (either before or after using a couple of 5W20 oil changes)? What about tranny fluid? MaltB?
The Motorcraft FL-820S is also a very good filter if go with 3-4,000 mile drains with dino.
Mark.
Just was wondering if anyone else had this problem. On my passenger side door the courtesy light cover keeps falling off. I assume it happens when I hit a bump in the road. I put it back on because it looks like it just sits in the slots but it keeps falling out. Also the plastic piece that is situated on the trunk top keeps falling out as well. Any one know what that is for. Car drives great just don't like the fact that parts are coming apart already.
T
Sorry to hear y'all have the same vibrations, I assumed there would be some other folks with the same problem. I only have my bass up to 2, but still get the same response...I would have thought they would have engineered the system to handle all ranges. When I first got the car there wasn't any vibration in the passenger door, but after they replaced a missing screw it started. On the driver's door, they replaced a broken clamp in the door and that was supposed to fix it. I'm going to take it in next week and will let you know if they fix it. It's not a huge deal, but annoying nonetheless.
Love the hell out of the car, but want everything to be perfect. I haven't had any of these other problems I read about.
Has anyone heard anything about MazdaSpeed upgrades yet?
GaDawg21
I have the same problem and end up cleaning my wheels at least 3-4 times a week. My front right wheel is showing some loss of coating on that wheel and has a gritty/porous quality to it now. I'm going to get this taken care of via warranty...there's NO WAY this should be happening this early, particularly when the other three are fine. I was about to start waxing my wheels because McGuire's wheel cleaner isn't enough.
This wasnt an issue on previous cars
See pages
6-15
and 6-48
in your manual
BTW, I would bet that Car and Driver, Road and Track, et al tested a pre-upgrade Mazda 6. After having the ECM upgrade, the car was MUCH faster, and revved even more freely---it is probably an even better performer than was suspected!!
I hope this is not a stupid question. What is the ECM flash and where do I find out about it?
T
"flash" = reprogram by reloading the non-volatile RAM in the ECM
I'd be interested in seeing if anyone else has noticed improvements after the flash and the build date of your car.
"On some 2003 Mazda6 vehicles, the Check Engine Light may illuminate under certain conditions and a diagnostic trouble code may be stored due to improper programming of the Powertrain Control Module."
The reflash greatly improved low-range power in the car (mine was reflashed before the recall announcement). My gas mileage has also improved to 28 MPG 60%highway/40% city.
The other recall notice I received was for the Brake Reservoir.
Loupie
