Visitor Agreement.
Here is the question for some who missed on it:
Why can't them limiteds come with that factory hitch? Why some of them dealers refusin to add
that hitch now?
cwirth, you get that repair manual on them tindras
yet? Heard you was lookin for one. Don't tell me
you did the haul and broke it now?
These here trucks rule for sure! Thanks go out to Dave40 and that TruckForce now!
Check em out now:
http://community.webtv.net/dp2000/TRUCKFORCEACTION
If anybody joins this here one, let me know now, I want to check out your truck there. These here
trucks are where's it at now!
Why would a Chevy lover as yourself (and Z71) continue to be here on this Tundra topic? Why do you keep asking about a hitch for the Limited? You don't have one or plan on buying one so why ask?
So what if the factory in Indiana does not put a hitch on the Limited. MY LIMITED came with a hitch, receiver and wire harness. I don't care if it was factory or not (Reese hitch). Have you ever put a tool box on a Chevy? If so, it was not factory! Have you ever had to replace the tires on a Chevy? If so, they are not FACTORY PARTS EITHER!!
Who gives a rat's [non-permissible content removed]; obviously you are the only one. So, does this make you the "rat" or the "[non-permissible content removed]"?
personal ones on #1129 now mhill5, as not to
chop this one here up. I wll answer all your
ramblins on that topic only. You can find the #1129 now can you not? Time will tell on this.
As to the hitch, many others have asked the same
question. I was not the first on this now. You say "So what if the factory in Indiana does not put a hitch on the Limited", this is not
an answer? If you have the answer, pipe on up
with it now. Was not askin about toolbox or
tires and such, just tryin to get to the bottom of this hitch mystery on them limited ones.
There is no mystery here on the hitch. The only mystery is in your mind. No one else here really cares about whether the hitch comes from the factory or not. If people want one they will get an aftermarket hitch. So why don't you do everyone here a favor and drop this subject. You can pick it up on topic #1129 and talk it to death. We all are getting really tired of you repeating yourself over and over regarding this hitch on the limited.
I think that you realize that the Tundra is such a good truck that you have to find something to pick on. Why don't you grow up!
I'm also looking for a roll bar and push bar.
No, your reasons are not obvious. Hang on, I'm reading your mind...No, nothing there, sorry.
Edmunds is running a discussion board here, not a day care. Can't we have a little fun? Lighten up.
P.S. Keep up the open forum Edmunds, it's been a hoot. It's even got me taking a 2nd look at the Tundra despite some amazing "tells" warning me away.
IS that topic 121??? message 121 under a specific topic??? I had no luck trying all these options. Unfortunately I deleted the message before checking to email of the sender though I do remember it was someone on AOL. Please respond again with more detail.
email about them limited ones? Good luck on that 121 one now!
If you wonder why then check these ones here out: http://community.webtv.net/dp2000/TRUCKFORCEACTION
When some of them limited ones goin join that TruckForce? Sure would like to see that soon.
Good luck on this one now!
You said you were going to do the compare on those drive shaft diameters.
How is the compare ?
Good luck on this one now.
too. Guess thats why them Chevys rate so much
higher on the haul now. Would not haul the heavy load with that driveshaft for long. Good luck
right back at ya!
The only problem I have is a rough shift from 1st to second under light acceleration. I have seen this comment elsewhere, but no solutions or remarks. HELP!
If your transmission is smooth or not I would welcome comments. If you learned of a fix I would really welcome that.
I drove the 3 other trucks at the dealer and all had the same problem. The rough tranny doesn't measure up to the general excellence of this truck!
Thanks in advance!
I just don't see many trucks, of any brand, stranded on the side of the road with a broken drive line, exluding pre 1980 vehicles.
that drive shaft as the generic reference for that driveline in general. In doin the visual compare, that Chevrolet has the more beefy lookin
drive line to it. This is not to say it is stronger, more just a visual compare between the 2 of em.
As for the rough shift from 1st to 2nd, it is a little abrupt, but not untolerable! Fact is, the crisper the shift, the less wear to the transmission clutch packs.
And Rube, driveshaft diameter is different, basically because the Chevy's driveshaft is aluminum. And good luck with your engine; the new Chevy Z-71's around here, are having a little problem with their crankshafts. They are breaking!
So if you want a Class IV hitch on a Tundra 4x4 Access Cab Limited all you have to do is what I did when I took delivery on my Tundra yesterday. Make sure parts has the hitch in stock. Hand your check for the Tundra to the dealer to complete your purchase. Then drive the truck 25 feet to service. Go get a cup of coffee or some lunch. Come back, pay the service department for the hitch and installation and drive away.
By the way, the Tundra, like all the other Toyota trucks requires NO ADDITIONAL EQUIPMENT to tow. The Tundra comes with the auto trans cooler, HD radiator, battery etc. already installed. All you need to do is connect the wiring and bolt the hitch on. If you buy the Limited 4x4 Access Cab like I did you're then ready to tow 7000 lbs.(7100 lbs. for the other 4x4 V8 Tundras, 7200 for the 4x2s.)
Toyota's hitches are supplied by Valley, Draw-Tite and Reese, just as other automakers subcontract some parts. You just don't usually see the brand name on the hitch.
I haven't noticed any harsh shifts. To me the snappier the shift the better. I'll bet a good shift kit in the V8 Tundra would let it chirp the tires on the 1-2 and 2-3 shifts! But then again the Tundras are going for finesse.
By the way, I love the truck, especially after owning 13-15 Chevys (who's counting - depends on if you count the ones that didn't run.) So does my friend with a Z71 4x4. He's going to look into buying one after riding in mine.
Has anyone put on nerf bars or tube sidesteps? What brand? Were they welded or bolted on?
Any info on hard tonneaus and caps from Snugtop, Leer or Skillcraft, especially with prices would be appreciated!
V8.)
3 hitches from that factory not the 4? Don't think that wieght on them limited one has much of anything to do with that lack of factory hitch, after all, them Chevrolets wieght alot more than them limited ones and they get the factory hitch.
There is some other reason that them limited ones restricted on that haul now.
Don't know about most, but if I wanted the low emissions I would have brought me one of them battery cars, not a truck.
If you think about what EPA does, it doesn't make sense they micro-manage what towing options a manufacturer can install. If anyone does, it is DOT, or NTHSA. 8600 GVWR=light truck.
This would be of great service to all us Tundra owners since we could get the "truth" straight from the horse's mouth.
You might even pick up some brownie-points in the process for showing initiative.
1) Why don't the factory offer that hitch on them
limited ones to begin with?
2) Why does the factory limit that hitch to the
class of 3 on them sr5 ones?
Good luck with this one now!
on the Tundra very mysterious. I think only you do. Hope you can find out for us the answers to the questions you ask so often.
Maybe that repair manual you ordered on them limited ones have the answer now? Can you explain them hitch mysteries cwrith? Good luck on that one now!
beloved tindras that be havein the trannie troubles, per many tells by them tindra owners now! What say to them tindra trannie troubles now eusac? Many tears will be shed on that trannie before the fix be comin. Good luck on this one now!
