The Texas Lemon Law is normally not as effective as the Texas Deceptive Trade Practices Act. I don't know whether you have a viable claim, but under DTPA, you can file suit within two years after you knew or should have known of the facts that gave rise to your claim. There are some claims in Texas that have four-yr limitations, such as breach of warranty and breach of contract. Last, I believe that sometimes statutes of limitations can be "tolled" if you can show they strung you along for the purpose of getting you to miss your filing deadline. You might consider sending a demand letter (to Nissan, the dealer, etc) outlining your claim and telling them you're considering filing suit under DTPA (under which you can collect up to triple damages for knowing violations) and see what happens. Of course, it would be better to have a lawyer do this for you but that can get very expensive very quickly.
I asked couple questions under "Nissan Murano" thread and did not get any response. Thinking that maybe I asked in a wrong thread I would like to repeat the questions:
__________
Hello happy Murano owners (most of us),
A while ago (#2417) I asked if anyone installed an aftermarket towing hitch and harness, and I did not see any response. I recently purchased a towing hitch for my ’04 Murano from eBay ($119 including shipping) and installed myself. It is made by Quality-S in Arizona. It is a decent hitch with round tube, although not nicely hidden under rear bumper as the genuine Nissan hitch, but savings are noticeable when comparing with Nissan hitch.
Now I want to install a wiring harness that is available only from Nissan dealer, and the price for the harness is $100 – ridiculous price for set of wires and connector. I would like to purchase a standard harness from local AutoZone and do the wiring myself, but I cannot find the connector on Murano that is used for connecting the factory towing harness.
Does anyone know where the connector for connecting genuine Murano harness is located? I can only find harness in rear of vehicle in the spare tire compartment, and it does not have any connector for the towing harness. But it should be somewhere as there is a towing harness available from Nissan.
Also, I have very annoying rattle from the passenger door. It is not loud, but it is annoying when I drive in quite environment. I disassembled the door materials and test drove the car – the rattle is still there. It appears that the rattling noise comes from window area, and I did not want to go that far and disassemble the window. Do you think it is something that can be repaired under warranty. Does anyone have rattling noise from passenger door that does not go away even when you press all materials on the door while driving?
Your input would be much appreciated.
Ray
There's a definite sensation difference between the CVT and a traditional transmission. The engine is supposed to wind up like that (so they tell me!). I don't think the powertrain is designed to be driven aggressively. It's actually really a sweet, smooth ride when driven easy, and the CVT has a lot to do with how smooth it is. But sometimes I just want to punch it, and it just feels wierd.
There's so much to like about this car. The handling is excellent. I'm slowly changing my driving habits to match the car's characteristics, but maybe with gas at 2.75 a gallon, it may be a blessing in disguise.
Have fun!
Mike G.
Just wondering if anyone received the recall notice from Nissan?
http://www.nissanhelp.com/Bulletins/Murano/2003/4.htm
and specifically if you scroll down, you can find this:
http://www.nissanhelp.com/Ownership/Bulletins/Nissan/2003/NTB03-033.htm
Check out:
http://www.nissanusa.com/form/0,,action-NRecallPublicLanding_sctid-51054,00.html
Expect your notice in the mail if your Murano qualifies for the recall.
I would contact
National Consumer Affairs Office, Nissan North America, Inc. at P.O. Box 191, Gardena, California 90248-0191.The toll free number is (800) 647-7261.
Maybe they can convince the dealer to refund your $220.
I also had the fuel filler door latch problem a few months ago. The dealer replaced the latch at no cost. The replacement latch failed to open a week later. Both failures-to-open happened as I was attempting to gas up to go on long trips. The dealer squeezed me in both times to get the tank open so I could make the trip. After the second problem, I had the dealer remove the latch device and I now rely on the magnetic catch on the door to keep it closed-forget the electric latch. I support the need for a manual release for the filler latch.
I experienced the same problem with my 2003 intermittantly and twice while driving from CA to AZ or Vegas across the desert. Not very fun at all.
I go into the habit of stopping with at least a 1/4 of a tank on trips
in the case I had the problem I could hopefully make it to a dealer.
The relay (cylinoid) should fix the problem (at least for a while mine has not broken again but it's been only about a month).
Some tips for you: There is a way to open the side (like an emergany release) but you have to remove the inside back panel to reach it. At 40 degrees I would have been happily dismantaling the car!
The best thing I had done was to just have it disconnected. Some dealers refuse but most will. (Of course if your handy you can do it yourself). The door will close and function properly with or without the relay. The only thing you lose is extra protection from tampering....then again if they really want to tamper they would just slide under the car and cut the hose....
If your not out of warrenty it should have been covered. For first year cars I always buy the extended warrenty!
Besides the gas door problem:
1) I have a rattle in the front dash under the speaker cover (3 times the dealer has tried to fix it)
2) My CD player failed and had to be replaced
3) Last month I had the entire rear end replaced because the electromagnetic clutch went out and the pinion bearing was gone. For this the Dealer accused me of driving the car in AWD at all times. Funny thing is I had never had the car in AWD since the first week I drove it. (I have never been in need of it) -- Good thing here was I had decided to buy the extended warrenty just before the warrenty was up because I didn't trust the first year transmission.
Now I have two other problems that the dealer refuses to believe because they can't get any engine codes, even when they experience it (to bad mechanics don't know how to work on cars without codes anymore). These were happening before the last repair and it had been in seveal times for both problems.
1) When driving down a highway or freeway in my case (say 65-85) when I hit an incline the you can feel the car jerking, my husband says it feels like the transmission slipping, if you simply maintain speed. A couple of times I have become nervious that the car may quit. The incline does not have to be large or particularly long. Any ideas?
2) Often when I get in my car the car will not start properly. Though it seems to start right up -- it immediately dies. Once I had to have it towed in to the dealer and 4 hours later when they finally got to it -- it just started right up. Once I was in the car with the Service Manager and it took 3 times to start the car. Again, no codes, no fix. has anyone experienced this one?
I got lost there for a minute and thought you were talking about the IRS....
The 4WD & AWD systems explained discussion may be of interest.
I just got my Nissan Murano SL 2005 after few days I started hearing ticking sound at speed 100Km/hr and it gets worse if both passenger and driver windows are rolled down. I plan to take it to dealer, but was curious if there is any known fix to this. I saw door trim/panels/windown rails but any other reason that may cause this.
Thx..
Plan on taking it to another dealer and see what they say about the other problems. If it wouldn't be such a hassle I'd go to Las Vegas...very knowledgable service deprtment. (the one on Sahara) . We really love the car, but if the problems keep up I'll have to get something more reliable. This is my second Nissan with problems. Had a 2000 Quest with signifcant elecrical problems and the electric windows kept breaking (very bad design). Bummer because I loved my '96 Quest.
I have this problem with my 2005 Murano, I kept blaming the wife for changing the settings, until it happened to me. It is only a minor annoyance and a complete waste of time, to take to the dealer, unless, I can make it happen for them. I had a Honda that the doors would randomly start locking, it would click,click,click,click... for hours at a time. There was a TSB for the problem, but, it was out of warranty before the problem started. Honda wanted $250 for the module, so we never replaced it. Just a minor annoyance. We traded in the Honda for the Murano. The wife loves the Murano.
also, has anyone had luck with turning off the auto door lock feature, when using the key fob to open the gas cap door, when out side the car. the doors lock on their own thanks.
Turns out my '03 needed a new EFI Throttle Chamber which also acts a throttle positioning sensor. This was causing my problems with starting the car (when warm), jerking or hesitation on long uphill grades at a steady speed between 70 - and 80 mph (not tested yet), and sluggishness in the performance (got some pep back in my step). :shades:
Still frustrated at the number of times I had to take it back and forth to the dealer, especially after having to have it towed in for not starting once before.
Other issues that bother me, but apparently the dealership can not duplicate are a constant rattle from the under carriage (right side), a squeak from the left rear under carriage when exiting the vehicle.
The owners manual recommends NOT using them. Just wondered if it might help my fuel economy ?
My dad is a mechanic, and is recommending CPR Injection System cleaner.
Comments ?
I also have an '03 and I had the same problem. It's the transmission.I had to replace it only 8 mos. into my ownership.
I'm having other issues with my car right now. Took my car in for the alternator recall and to fix my gas door (door won't open due to bad fuse.) Now my car is skipping if I slow down from 75mph to 60mph and the car shakes occassionally as if it wants to die. The "check engine soon" light came on and off this past weekend so I've got to take it in the the dealer.
I share the same sentiment as the other driver. This is my first and last Nissan I'll ever purchase.
Other than you, I have not come across any postings of similar problems. Have you had anyone look at it yet?
