One question aside from a slippery start, when else would one use the LOCK function?
1. Take it to another dealer for a second opinion. Experience tells me the variance in quality of work and know-how is staggering.
2. A faulty battery may have been the problem all along. The dealer may have just guessed about the alternator. I have had new ones go out on me in the first 6 months.
Question (to the forum) how can a battery be damaged by an alternator?
Anyway, I was super excited yesterday because I just found out via an ultrasound that I was having a baby girl - was on the phone with my sister, didn't look behind me well enough and backed right into another vehicle.
So sad. My fault. No one was injured, so life goes on.
Anyway, I am taking my Murano in to get fixed, and was wondering if anyone had any insight into what a replacement bumper might cost? I realize labor costs are involved as well, but I just want to know the cost of the bumper in case the body shop tries to tell me the part itself costs twice as much.
Also, is the part going to come painted, or will they have to paint it? I assume they will be painting it, and if so, what's the likelihood that they will be able to match our shiny Merlot paint job?
In the end, that's my biggest concern. The dent can be fixed, but a mismatched paint job is not something I am going to want to put up with.
Bumps aren't cheap - over $1,000 US easy I bet, although someone else will have to chime in if they know the price of just a bumper.
This link will give you some idea. (hwysafety.org). Here's another test as reported by MSNBC.
I have had my 05 Murano for a little over a year now. I suffer from numb hands from a steering wheel vibration. My Murano has been in the shop 51 times for warranty repairs. It is now fishtailing all over the road after a wheel alingment.I am going to trade it in and get a used 04 Quest. Good luck with your new Murano. I think you may need it after your problems with your Quest, it's just a matter of time before your Murano exibits the same symptoms that your Quest did.
They also say they should be able to match the paint "no problem". This is a big time auto body shop near me that gets ALOT of business, so I believe they will do a good job, but I am not holding my breath on the paint as I hear it can be extremely difficult to match the paint on any car.
I have heard that bumpers on some cars can be tricky to match though.
A battery can be damaged by an over/under charging alternator due to a faulty voltage regulator that's integrated with the alternator. Either over- or under-charging causes sulfation build-up in the cells that prevents them from fully charging.
http://www.woodmizer.com/en/articles/support/chargingsystem.aspx
Most of the time, therefore, the alternator is the culprit. And while the odds and time difference are too great (my Maxima with the defective alternator was an '86) and the statistics too limited, it would seem that Nissans are prone to this problem.
Given that the Murano has a drive-by-wire system (electronic throttle) that is electrics-dependent, it's no surprise the gas pedal shuts down when there's no current. With the old "drive-by-cable" system, one could still nurse a sputtering engine without shutting down completely.
Alternator recall done 3 weeks ago.....all seemed good. 3 Nights ago, a dreadful (difficult to explain) grinding noise started to come from the engine compartment when u would put your foot on the accelerator and it would rev between 1000 and 1500.
I took it to dealer to listen to and fix. At the same time they were switching out the head unit of the bose stereo system which had rather handily just come in after being on order for a few weeks - occasionally when playing CDs the left speakers would just cut out.
So, the grinding noise was from the alternator recall when the technician hadn't put some bolt back correctly, it had sheared and snapped off, making the grinding. That was replaced, and the noise has gone.
Now, (and I think they're just lucky I'm the kind of person that shrugs off and laughs about these kind of things), I picked the car up this afternoon from the dealer, and was in a hurry to get to a dinner appointment in philly. So it wasn't until I was half way across the bridge, when i tried putting a CD in the in-dash autochanger, that i realised where there had previously been an open slot in which one could cunningly feed CD's and listen to them (all be it only out of the right speakers), errr, the hole was gone. Interesting, I thought. i pressed the load button, nothing whirred, clicked, showed on the screen or anything. The hole on the face of the stereo is still there (that wasnt replaced), but it is just solid plastic behind it.
a. they ordered the wrong unit.
b. its slightly mis-aligned (but the tape deck is aligned, and it doesnt even whirr when you press the CD load button, it's like it doesnt know it has a CD changer)
c. they put it in upside down, inside out, back to front, dropped it on the floor, I don't know what!
I just find it comical that they could do this work (replace the CD PLAYER) and not test it (REALISE THERE IS NO LONGER A HOLE AND YOU CAN NO LONGER PUT CD's IN THE CD PLAYER!!!)
PS Rental car this time was a brand new grand cherokee. And this is why i still laugh about the murano problems.....the cherokee sucks! I almost had an accident in it - the location of the ignition, and the size of the key is such that if you are 6'6" like myself, and you have people sat behind you, you have to have your seat fairly far forwards, and if you happen to move your knee to the right slightly, you catch the large key in the stupidly located ignition, and turn off the engine. Which was a tad dangerous when doing 60 up a highway. Luckily traffic wasnt too bad and I could just coast to the shoulder and restart. The door handles are cheap and nasty, the parking brake looks just, well, out of place, the engine sounded gruff, it ate gas, and the seats werent comfortable. HORRIBLE CAR!!
KEYWORDS: NISSAN MURANO WINDOWS DOWN OVERNIGHT
Is there a website to start collecting these or sending info to Nissan ?
Our windows went all the way down...
In the news, Reliability of Some Asian Brands Questioned by Consumer Reports (Inside Line)
Back to my accelerator issue: the dealer said it was due to a leaking transmission hose. They ordered the new part and fixed it. At least you hope it's been fixed, because I commute 80 miles a day to work and back.
Well, this morning, the vehicle stopped again.....same symptoms, but fortunately for Nissan, this time they did'nt have to pay for a 40 mile towing bill plus car rental.
If you've ever watched a Professional Golf Championship, there might be a commercial showing a few golfers "doing their expert job"......and the commentator will say......"these guys are good"!!! I truly wish I could say the same for Nissan's mechanics.
A. Go to a different dealer. I would rather drive the extra mileage to get a second opinion and, if lucky, a more competent dealer. Dealer quality varies wildly. OR
B. Go back to the repairing dealer and inform them in writing (registered mail) that is fix #2 and that they are on the lemon law clock. After the third unsuccessful fix (depending on your state) contact a lemon law attorney. At the same time create an online case with the NHTSA Office of Investigation. The case will include all the car's info as well as the dealer's info. Phone NCA and open a case, quoting the NHTSA case number. Inform the dealer of the NCA case number as well as the NHTSA case number. You will be surprised how a dealer reacts to a well-organized customer who shows them that they are going to take action.
NISSAN WILL PAY TO HAVE THE VEHICLE TOWED......TO THE NEAREST DEALER ( this is too f%$%Y%^YU% funny....the nearest dealer IS THE IDIOT DEALER THAT I WANT TO AVOID).
Anyway, after I informed "my" dealer that I just had a conversation with NISSAN1.....they agreed to pay for a rental vehicle. In fact, while waiting for the dealer to decide what to do.....I went online and got some info on a throttle sensor malfunction.....printed it out....then gave it to the BOZO....who picked up my vehicle.....DUH!!!
After 3 hours.....they call me....said they have ordered the part (THROTTLE POSITION ACTUATOR). NISSAN is becoming too much of a hassle. The Murano is my 7th NISSAN product in the 40 years of my driving life, and most likely will be the last. Last November, I traded a 2003 350Z, because of a "tire-feathering" issue with the front suspension.
Yes, I have traded emails with a Lemon Law attorney on the Z. Now, possibly the Murano will be next. The weird thing is.....the Murano rides great....has a lot of power, but cannot depend on it enough to drive to work.
Nissan plant rolls on (Jackson Clarion Ledger)
had my briefcase in the back seat, CDs in the front armrest, etc etc.
At first I thought the car was broken into, or someone was playing a bad trick on me. This is NOT good. Although I am happy with the vehicle, there is another bad thing the Murano does: it locks you out of the car with the keys in it.
"Thinking about selling"
